[petsc-users] make all freezes
Mon Sep 16 08:33:58 CDT 2013
On Mon, Sep 16, 2013 at 1:18 AM, Analabha Roy <hariseldon99 at gmail.com>wrote:
> Hi,
>  I just got a new laptop and installed linux mint KDE. Details below:
> samsung NP300E5X-U01IN:
> Kernel 3.8.0-26-generic #38-Ubuntu SMP
> Four Intel Unknown 800MHz processors, 16760.20 total bogomips, 3733M RAM
> System library 2.17.0
> I tried to compile petsc-3.4.2 with the following configuration
> ./configure --with-scalar-type=complex --with-c2html=0 --with-debugging=no
> --with-fortran-kernels=1 --with-hdf5=yes --with-hdf5-dir=/usr
> --enable-parallel
> The configure log is posted here<https://dl.dropboxusercontent.com/u/2769707/configure.log>(dropbox)
> The configure script seems to run okay, but running "make
> PETSC_DIR=/usr/local/src/petsc-3.4.2 PETSC_ARCH=arch-linux2-c-opt all" or
> "make all" causes the compile to hang with no output.
This sounds like a CMake problem on your machine. Please try running
  make all-legacy
although it seems like your Builder run succeeded.
Downgrading to a previous version of petsc does not seem to help. The
> problem persists. Using default options "./configure
> --with-scalar-type=complex" doesn;t seem to change anything either.
> Running ./config/builder.py works, but then "make test" hangs similarly,
> as does running make on any example or any of my petsc sources.
This is different. It is likely that your MPI is not setup correctly to
launch on this machine. Can you
run any MPI job?
      Matt
> Thanks in advance,
> *Analabha Roy*
> C.S.I.R <http://www.csir.res.in>  Senior Research Associate<http://csirhrdg.res.in/poolsra.htm>
> Saha Institute of Nuclear Physics <http://www.saha.ac.in>
> Section 1, Block AF
> Bidhannagar, Calcutta 700064
> India
> *Emails*: daneel at physics.utexas.edu, hariseldon99 at gmail.com
> *Webpage*: http://www.ph.utexas.edu/~daneel/
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130916/af7e1b7d/attachment.html>
