[petsc-users] make all freezes
Analabha Roy hariseldon99 at gmail.com
Mon Sep 16 03:18:09 CDT 2013
 I just got a new laptop and installed linux mint KDE. Details below:
samsung NP300E5X-U01IN:
Kernel 3.8.0-26-generic #38-Ubuntu SMP
Four Intel Unknown 800MHz processors, 16760.20 total bogomips, 3733M RAM
System library 2.17.0
I tried to compile petsc-3.4.2 with the following configuration
./configure --with-scalar-type=complex --with-c2html=0 --with-debugging=no
--with-fortran-kernels=1 --with-hdf5=yes --with-hdf5-dir=/usr
--enable-parallel
The configure log is posted
here<https://dl.dropboxusercontent.com/u/2769707/configure.log>(dropbox)
The configure script seems to run okay, but running "make
PETSC_DIR=/usr/local/src/petsc-3.4.2 PETSC_ARCH=arch-linux2-c-opt all" or
"make all" causes the compile to hang with no output.
Downgrading to a previous version of petsc does not seem to help. The
problem persists. Using default options "./configure
--with-scalar-type=complex" doesn;t seem to change anything either.
Running ./config/builder.py works, but then "make test" hangs similarly, as
does running make on any example or any of my petsc sources.
Thanks in advance,
*Analabha Roy*
C.S.I.R <http://www.csir.res.in>  Senior Research
Associate<http://csirhrdg.res.in/poolsra.htm>
Saha Institute of Nuclear Physics <http://www.saha.ac.in>
Section 1, Block AF
Bidhannagar, Calcutta 700064
India
*Emails*: daneel at physics.utexas.edu, hariseldon99 at gmail.com
*Webpage*: http://www.ph.utexas.edu/~daneel/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130916/39b3e570/attachment.html>
