[petsc-users] Slepc installation
Sat Mar 30 11:25:19 CDT 2013
On Sat, Mar 30, 2013 at 11:24 AM, Sonya Blade <sonyablade2010 at hotmail.com>wrote:
> If the below means the successful installation and test then
> I'd like to thank you all for trying to help the novices in a benevolent
> way especially for Jed Brown and Satish Balay.
> make test
> Running test examples to verify correct installation
> Using SLEPC_DIR=/cygdrive/D/TEST_FOLDER_dell/slepc,
> PETSC_DIR=/cygdrive/c/Users/...../Downloads/petsc-3.3-p6 and
> PETSC_ARCH=arch-mswin-c-debug
> C/C++ example src/eps/examples/tests/test10 run successfully with 1 MPI
> process
> C/C++ example src/eps/examples/tests/test10 run successfully with 2 MPI
> process
> Fortran example src/eps/examples/tests/test7f run successfully with 1 MPI
> process
> Completed test examples
> Please confirm?
Yes, looks good.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130330/7359e831/attachment.html>
