[petsc-users] Slepc installation
Sonya Blade sonyablade2010 at hotmail.com
Sat Mar 30 11:24:30 CDT 2013
Dear All,
If the below means the successful installation and test then
I'd like to thank you all for trying to help the novices in a benevolent
way especially for Jed Brown and Satish Balay.
make test
Running test examples to verify correct installation
Using SLEPC_DIR=/cygdrive/D/TEST_FOLDER_dell/slepc, PETSC_DIR=/cygdrive/c/Users/...../Downloads/petsc-3.3-p6 and PETSC_ARCH=arch-mswin-c-debug
C/C++ example src/eps/examples/tests/test10 run successfully with 1 MPI process
C/C++ example src/eps/examples/tests/test10 run successfully with 2 MPI process
Fortran example src/eps/examples/tests/test7f run successfully with 1 MPI process
Completed test examples
Please confirm?
