[petsc-users] PCGAMG
Wed Mar 27 17:54:35 CDT 2013
How did you create these matrices? Always send the FULL error message,
including the stack trace. Can you set up an example that can reproduce?
On Wed, Mar 27, 2013 at 3:18 PM, Mohamad M. Nasr-Azadani
<mmnasr at gmail.com>wrote:
> Hi,
> I am trying to use PCGAMG.
> The matrix I have is based on a 2-D DMDA, Laplace equation.
> This is the part of the code I have to setup the solver:
> KSP solver;
> PC pc;
> ierr = KSPCreate(PETSC_COMM_WORLD, &solver);
> ierr = KSPGetPC(solver, &pc);CHKERRQ(ierr);
> ierr = PCSetType(pc, PCGAMG);CHKERRQ(ierr);
> ierr = KSPSetFromOptions(solver); CHKERRQ(ierr);
> ierr = KSPSetOperators(solver, LHS_mat, LHS_mat, SAME_NONZERO_PATTERN);
> CHKERRQ(ierr);
> When I run the code in parallel, it is fine.
> But when I run it in serial, this is the error I get:
> [0]PCSetData_AGG bs=1 MM=11000
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: No support for this operation for this object type!
> [0]PETSC ERROR: Not implemented for A=mpiaij and P=seqaij!
> [0]PETSC ERROR:
> [0]PETSC ERROR: Petsc Release Version 3.3.0, Patch 6, Mon Feb 11 12:26:34
> CST 2013
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR:
> Any thoughts?
> Mohamad
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130327/e0129783/attachment.html>
