[petsc-users] PCGAMG
Mohamad M. Nasr-Azadani mmnasr at gmail.com
Wed Mar 27 18:08:57 CDT 2013
Thanks Jed,
How did you create these matrices?
    ierr = DMCreateMatrix(DA2d,  MATMPIAIJ, &LHS_mat); CHKERRQ(ierr);
(The DA2d is a DMDA in two dimensions, with 1 point stencil width, 1 dof,
STAR_STENCIL).
It is a 5-point based discretization of the laplace equation on uniform
grid).
Always send the FULL error message, including the stack trace.
[0]PCSetData_AGG bs=1 MM=11000
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: No support for this operation for this object type!
[0]PETSC ERROR: Not implemented for A=mpiaij and P=seqaij!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Release Version 3.3.0, Patch 6, Mon Feb 11 12:26:34
CST 2013
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: ./ex1 on a arch-linu named yoda.mee.ucsb.edu by mmnasr Wed
Mar 27 13:12:28 2013
[0]PETSC ERROR: Libraries linked from
/home/mmnasr/Softwares/petsc-3.3-p6/arch-linux2-c-debug/lib
[0]PETSC ERROR: Configure run at Tue Mar 26 14:35:30 2013
[0]PETSC ERROR: Configure options --with-cc=gcc --with-fc=gfortran
--download-f-blas-lapack --download-mpich --download-hypre --download-mumps
--download-blacs --download-scalapack --download-ptscotch --with-debuging=0
[0]PETSC ERROR:
[0]PETSC ERROR: MatPtAPSymbolic_MPIAIJ() line 81 in
src/mat/impls/aij/mpi/mpiptap.c
[0]PETSC ERROR: MatPtAPSymbolic() line 8362 in src/mat/interface/matrix.c
[0]PETSC ERROR: MatPtAP_Basic() line 12 in src/mat/utils/ptap.c
[0]PETSC ERROR: MatPtAP() line 8256 in src/mat/interface/matrix.c
[0]PETSC ERROR: createLevel() line 152 in src/ksp/pc/impls/gamg/gamg.c
[0]PETSC ERROR: PCSetUp_GAMG() line 722 in src/ksp/pc/impls/gamg/gamg.c
[0]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[0]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: KSPSolve() line 402 in src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: main() line 158 in ex1.c
application called MPI_Abort(MPI_COMM_WORLD, 56) - process 0
[cli_0]: aborting job:
Can you set up an example that can reproduce?
See attached.
Mohamad
On Wed, Mar 27, 2013 at 3:54 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> How did you create these matrices? Always send the FULL error message,
> including the stack trace. Can you set up an example that can reproduce?
> On Wed, Mar 27, 2013 at 3:18 PM, Mohamad M. Nasr-Azadani <mmnasr at gmail.com
> > wrote:
>> Hi,
>> I am trying to use PCGAMG.
>> The matrix I have is based on a 2-D DMDA, Laplace equation.
>> This is the part of the code I have to setup the solver:
>>  KSP solver;
>> PC pc;
>> ierr = KSPCreate(PETSC_COMM_WORLD, &solver);
>> ierr = KSPGetPC(solver, &pc);CHKERRQ(ierr);
>> ierr = PCSetType(pc, PCGAMG);CHKERRQ(ierr);
>> ierr = KSPSetFromOptions(solver); CHKERRQ(ierr);
>> ierr = KSPSetOperators(solver, LHS_mat, LHS_mat, SAME_NONZERO_PATTERN);
>> CHKERRQ(ierr);
>> When I run the code in parallel, it is fine.
>> But when I run it in serial, this is the error I get:
>> [0]PETSC ERROR:
>> CST 2013
>> [0]PETSC ERROR:
>> Any thoughts?
>> Mohamad
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130327/7ac32f40/attachment-0001.html>
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130327/7ac32f40/attachment-0001.c>
Type: text/x-chdr
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130327/7ac32f40/attachment-0001.h>
