[petsc-users] Solving Poisson equation with multigrid
Thu Jun 6 14:30:52 CDT 2013
On Thu, 6 Jun 2013, Michele Rosso wrote:
> Hi Satish,
> I tried what you suggested:
> #!/usr/bin/python
> if __name__ == '__main__':
>   import sys
>   import os
>   sys.path.insert(0, os.path.abspath('config'))
>   import configure
>   configure_options = [
>     'PETSC_DIR=/u/sciteam/mrosso/LIBS/petsc-3.4.0',
>     '--with-cc=cc',
>     '--with-clib-autodetect=0',
>     '--with-cxx=CC',
>     '--with-cxxlib-autodetect=0',
>     '--with-fc=ftn',
>     '--with-fortranlib-autodetect=0',
>     '--with-x=0',
>     '--with-debgging=0',
>     '--COPTFLAGS=-O3',
>     '--FOPTFLAGS=-O3',
>     'FFLAGS=-F -em',
>     'LIBS=-L/opt/cray/cce/8.1.7/CC/x86-64/lib/x86-64/ -lcray-c++ -rts
                                    you have an extra space here  ^  It should be -lcray-c++-rt
Satish
> -lcraystdc++ -lsupc++ -lgcc_eh',
>     'PETSC_ARCH=arch-test-cray',
>   configure.petsc_configure(configure_options)
> but now I receive another error:
> "C compiler you provided with -with-cc=cc does not work"
> I attached the log file. Thanks for your help.
> Michele
> On 06/05/2013 02:15 PM, Satish Balay wrote:
> > Sorry my configure cmd file was from an older test case for c++.
> > Do you need c++ build of PETSc? If not - suggest removing
> > --with-clanguage=C++ option.
> > [Majority of use cases should not need --with-clanguage=C++ - even if
> > user code is using PETSc from C++]
> > If c++ is needed - you can try adding: CXXCPPFLAGS='-h gnu'
> > Satish
> > On Wed, 5 Jun 2013, Michele Rosso wrote:
> > > Thank you Satish for your help.
> > > I followed you instructions, but I am getting some errors during the
> > > compilation.
> > > I attached the python script I used to configure PETSc, and the logs for
> > > both
> > > configure and make.
> > > Michele
> > > On 05/31/2013 05:08 PM, Satish Balay wrote:
> > > > The following is my configure command to build PETSc on a cray with
> > > > cray compilers:
> > > > $ cat reconfigure-arch-test-cray.py
> > > > #!/usr/bin/python
> > > >     import sys
> > > >     import os
> > > >     import configure
> > > >       '--with-cc=cc',
> > > >       '--with-clanguage=C++',
> > > >       '--with-cxx=CC',
> > > >       '--with-fc=ftn',
> > > >       '--with-x=0',
> > > >       'FFLAGS=-F -em',
> > > >       'LIBS=-L/opt/cray/cce/8.1.4/CC/x86-64/lib/x86-64/ -lcray-c++-rts
> > > > And you might have to look for the recommended optimization flags - and
> > > > use
> > > > with:
> > > > --with-debgging=0 COPTFLAGS= FOPTFLAGS= CXXOPTFLAGS= etc.
> > > > And on BlueWaters - you would have to remove the following lines from
> > > > PETSC_ARCH/include/petscconf.h [before runing 'make all' to build the
> > > > libraries]
> > > > #ifndef PETSC_HAVE_GETPWUID
> > > > #define PETSC_HAVE_GETPWUID 1
> > > > #endif
> > > > Satish
> > > > On Fri, 31 May 2013, Michele Rosso wrote:
> > > > > Thanks, but I'd rather use Cray since only a small part of my code
> > > > > relies
> > > > > on
> > > > > PETSc and, as suggested by the BW staff,
> > > > > Cray-compiled code performs generally better on Cray system.
> > > > > Michele
> > > > > On 05/31/2013 02:57 PM, Jed Brown wrote:
> > > > > > Michele Rosso <mrosso at uci.edu> writes:
> > > > > > > Hi,
> > > > > > > I confirm that
> > > > > > >             -pc_type gamg  -pc_mg_cycle_type v
> > > > > > > -pc_gamg_agg_nsmooths 1
> > > > > > > produces the correct shift in PETSc 3.4.
> > > > > > > So my problem is solved.   I will upgrade to 3.4 in my productive
> > > > > > > machine installation.
> > > > > > > It is a Cray machine (Blue Waters). Assuming I want to use the
> > > > > > > Cray
> > > > > > > compiler, which options should I use for ./configure
> > > > > > > for the installation.
> > > > > > Or the Intel compiler or GCC.  PETSc should run at similar speed
> > > > > > with
> > > > > > any.  IIRC, Cray recommends the Intel compiler on their machines
> > > > > > with
> > > > > > Intel CPUs.  There are examples in config/examples/.
