[petsc-users] Setting PETSc Sundials Options Using PETSC_OPTIONS
Thu Jul 25 18:18:45 CDT 2013
Call TSView yourself if you don't use TSSolve.
On Jul 25, 2013 12:06 PM, "Lesleis Nagy" <l.nagy at ed.ac.uk> wrote:
> Ah, I don't make a call to TSSolve(). I have a loop and then make calls to
> TSStep until my exit criteria is met.
> On 25 Jul 2013, at 18:02, Satish Balay wrote:
> > Hm - ts_view should be checked in TSSolve() - so somehow thats not
> hapenning?
> > Satish
> > On Thu, 25 Jul 2013, Lesleis Nagy wrote:
> >> Hi Satish, Matthew,
> >> Thank you very much for your help. Everything seems to work with the
> exception that PETSc now doesn't pick up the 'ts_view' option!
> >> For completeness, when using PETSc / petsc4py / FEniCS I simply called
> 'ts.setFromOptions()' on my on my petsc4py time stepper object (called
> 'ts').
> >> Is the appearance of 'ts_view' in the unused database options list
> something I should be concerned about? When I call the 'view()' method on
> my time stepper object it seems to output information that I would expect
> to see.
> >> Many thanks
> >> Les
> >> On 25 Jul 2013, at 17:29, Satish Balay wrote:
> >>> Then as Matt refered to  - TSSetFromOptions() isn't getting called.
> >>> Satish
> >>>> Hi Satish, Matthew,
> >>>> I'm just about to compile a version of PETSc with debugging symbols
> included, so that I can use gdb. Satish, I've passed the option that you
> suggest and the output is as follows:
> >>>> #PETSc Option Table entries:
> >>>> -options_left
> >>>> -options_table
> >>>> -ts_sundials_gramschmidt_type modified
> >>>> -ts_sundials_monitor_steps
> >>>> -ts_sundials_type bdf
> >>>> -ts_view
> >>>> #End of PETSc Option Table entries
> >>>> There are 7 unused database options. They are:
> >>>> Option left: name:-ts_sundials_gramschmidt_type value: modified
> >>>> Option left: name:-ts_sundials_monitor_steps no value
> >>>> Option left: name:-ts_sundials_type value: bdf
> >>>> Option left: name:-ts_view no value
> >>>> It appears as though PETSc ignores the 'ts_view' option.
> >>>> Les
> >>>> On 25 Jul 2013, at 17:15, Satish Balay wrote:
> >>>>> On Thu, 25 Jul 2013, Matthew Knepley wrote:
> >>>>>> On Thu, Jul 25, 2013 at 9:53 AM, Lesleis Nagy <l.nagy at ed.ac.uk>
> wrote:
> >>>>>>> Hello,
> >>>>>>> I currently use PETSc (version: 3.3-p7) and petsc4py along with the
> >>>>>>> Sundials interface to perform time stepping for some FEM code that
> I have
> >>>>>>> written (for completeness I make use of FEniCS). I would like to
> pass
> >>>>>>> options to PETSc from the command line using the PETSC_OPTIONS
> environment
> >>>>>>> variable. I set it with the following values:
> >>>>>>>      $ export PETSC_OPTIONS="-ts_sundials_type bdf
> >>>>>>> -ts_sundials_gramschmidt_type modified -ts_sundials_monitor_steps
> >>>>>>> -options_table -options_left"
> >>>>>>> I then run the code using:
> >>>>>>>      $ mpiexec -n 2 python script.py
> >>>>>>> Everything appears to work and my code terminates. However at the
> end of
> >>>>>>> the run, '-options_table' / '-options_left' reports that
> >>>>>>> -options_left
> >>>>>>> -options_table
> >>>>>>> There are 3 unused database options. They are:
> >>>>>>> Could someone explain to me why PETSc is reading the Sundials
> options that
> >>>>>>> I've supplied but is not using them?
> >>>>>> 1) Your solver might have an options prefix
> >>>>>> 2) You might forget to call TSSetFromOptions()
> >>>>>> The easiest thing to do is run with -start_in_debugger and set a
> breakpoint
> >>>>>> in TSSetFromOptions()
> >>>>> Also use -ts_view to check if sundials is actually getting set/used..
> >>>>> Satish
> >>>>>> Matt
> >>>>>>> Kind regards
> >>>>>>> Les
> >>>>>>> The University of Edinburgh is a charitable body, registered in
> >>>>>>> Scotland, with registration number SC005336.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130725/892e921d/attachment-0001.html>
