[petsc-users] Setting PETSc Sundials Options Using PETSC_OPTIONS
Lesleis Nagy l.nagy at ed.ac.uk
Thu Jul 25 12:05:36 CDT 2013
Ah, I don't make a call to TSSolve(). I have a loop and then make calls to TSStep until my exit criteria is met.
On 25 Jul 2013, at 18:02, Satish Balay wrote:
> Hm - ts_view should be checked in TSSolve() - so somehow thats not hapenning?
> Satish
> On Thu, 25 Jul 2013, Lesleis Nagy wrote:
>> Hi Satish, Matthew,
>> Thank you very much for your help. Everything seems to work with the exception that PETSc now doesn't pick up the 'ts_view' option!
>> For completeness, when using PETSc / petsc4py / FEniCS I simply called 'ts.setFromOptions()' on my on my petsc4py time stepper object (called 'ts').
>> Is the appearance of 'ts_view' in the unused database options list something I should be concerned about? When I call the 'view()' method on my time stepper object it seems to output information that I would expect to see.
>> Many thanks
>> Les
>> On 25 Jul 2013, at 17:29, Satish Balay wrote:
>>> Then as Matt refered to  - TSSetFromOptions() isn't getting called.
>>> Satish
>>>> Hi Satish, Matthew,
>>>> I'm just about to compile a version of PETSc with debugging symbols included, so that I can use gdb. Satish, I've passed the option that you suggest and the output is as follows:
>>>> #PETSc Option Table entries:
>>>> -options_left
>>>> -options_table
>>>> -ts_sundials_gramschmidt_type modified
>>>> -ts_sundials_monitor_steps
>>>> -ts_sundials_type bdf
>>>> -ts_view
>>>> #End of PETSc Option Table entries
>>>> There are 7 unused database options. They are:
>>>> Option left: name:-ts_sundials_gramschmidt_type value: modified
>>>> Option left: name:-ts_sundials_monitor_steps no value
>>>> Option left: name:-ts_sundials_type value: bdf
>>>> Option left: name:-ts_view no value
>>>> It appears as though PETSc ignores the 'ts_view' option.
>>>> Les
>>>> On 25 Jul 2013, at 17:15, Satish Balay wrote:
>>>>> On Thu, 25 Jul 2013, Matthew Knepley wrote:
>>>>>> On Thu, Jul 25, 2013 at 9:53 AM, Lesleis Nagy <l.nagy at ed.ac.uk> wrote:
>>>>>>> Hello,
>>>>>>> I currently use PETSc (version: 3.3-p7) and petsc4py along with the
>>>>>>> Sundials interface to perform time stepping for some FEM code that I have
>>>>>>> written (for completeness I make use of FEniCS). I would like to pass
>>>>>>> options to PETSc from the command line using the PETSC_OPTIONS environment
>>>>>>> variable. I set it with the following values:
>>>>>>>      $ export PETSC_OPTIONS="-ts_sundials_type bdf
>>>>>>> -ts_sundials_gramschmidt_type modified -ts_sundials_monitor_steps
>>>>>>> -options_table -options_left"
>>>>>>> I then run the code using:
>>>>>>>      $ mpiexec -n 2 python script.py
>>>>>>> Everything appears to work and my code terminates. However at the end of
>>>>>>> the run, '-options_table' / '-options_left' reports that
>>>>>>> -options_left
>>>>>>> -options_table
>>>>>>> There are 3 unused database options. They are:
>>>>>>> Could someone explain to me why PETSc is reading the Sundials options that
>>>>>>> I've supplied but is not using them?
>>>>>> 1) Your solver might have an options prefix
>>>>>> 2) You might forget to call TSSetFromOptions()
>>>>>> The easiest thing to do is run with -start_in_debugger and set a breakpoint
>>>>>> in TSSetFromOptions()
>>>>> Also use -ts_view to check if sundials is actually getting set/used..
>>>>> Satish
>>>>>> Matt
>>>>>>> Kind regards
>>>>>>> Les
>>>>>>> The University of Edinburgh is a charitable body, registered in
>>>>>>> Scotland, with registration number SC005336.
