[petsc-users] Setting PETSc Sundials Options Using PETSC_OPTIONS
Thu Jul 25 11:29:25 CDT 2013
Then as Matt refered to  - TSSetFromOptions() isn't getting called.
Satish
On Thu, 25 Jul 2013, Lesleis Nagy wrote:
> Hi Satish, Matthew,
> I'm just about to compile a version of PETSc with debugging symbols included, so that I can use gdb. Satish, I've passed the option that you suggest and the output is as follows:
> #PETSc Option Table entries:
> -options_left
> -options_table
> -ts_sundials_gramschmidt_type modified
> -ts_sundials_monitor_steps
> -ts_sundials_type bdf
> -ts_view
> #End of PETSc Option Table entries
> There are 7 unused database options. They are:
> Option left: name:-ts_sundials_gramschmidt_type value: modified
> Option left: name:-ts_sundials_monitor_steps no value
> Option left: name:-ts_sundials_type value: bdf
> Option left: name:-ts_view no value
> It appears as though PETSc ignores the 'ts_view' option.
> Les
> On 25 Jul 2013, at 17:15, Satish Balay wrote:
> > On Thu, 25 Jul 2013, Matthew Knepley wrote:
> >> On Thu, Jul 25, 2013 at 9:53 AM, Lesleis Nagy <l.nagy at ed.ac.uk> wrote:
> >>> Hello,
> >>> I currently use PETSc (version: 3.3-p7) and petsc4py along with the
> >>> Sundials interface to perform time stepping for some FEM code that I have
> >>> written (for completeness I make use of FEniCS). I would like to pass
> >>> options to PETSc from the command line using the PETSC_OPTIONS environment
> >>> variable. I set it with the following values:
> >>>        $ export PETSC_OPTIONS="-ts_sundials_type bdf
> >>> -ts_sundials_gramschmidt_type modified -ts_sundials_monitor_steps
> >>> -options_table -options_left"
> >>> I then run the code using:
> >>>        $ mpiexec -n 2 python script.py
> >>> Everything appears to work and my code terminates. However at the end of
> >>> the run, '-options_table' / '-options_left' reports that
> >>> -options_left
> >>> -options_table
> >>> There are 3 unused database options. They are:
> >>> Could someone explain to me why PETSc is reading the Sundials options that
> >>> I've supplied but is not using them?
> >> 1) Your solver might have an options prefix
> >> 2) You might forget to call TSSetFromOptions()
> >> The easiest thing to do is run with -start_in_debugger and set a breakpoint
> >> in TSSetFromOptions()
> > Also use -ts_view to check if sundials is actually getting set/used..
> > Satish
> >>   Matt
> >>> Kind regards
> >>> Les
> >>> The University of Edinburgh is a charitable body, registered in
> >>> Scotland, with registration number SC005336.
