[petsc-users] Setting PETSc Sundials Options Using PETSC_OPTIONS
Lesleis Nagy l.nagy at ed.ac.uk
Thu Jul 25 11:27:37 CDT 2013
Hi Satish, Matthew,
I'm just about to compile a version of PETSc with debugging symbols included, so that I can use gdb. Satish, I've passed the option that you suggest and the output is as follows:
#PETSc Option Table entries:
-options_left
-options_table
-ts_sundials_gramschmidt_type modified
-ts_sundials_monitor_steps
-ts_sundials_type bdf
-ts_view
#End of PETSc Option Table entries
There are 7 unused database options. They are:
Option left: name:-ts_sundials_gramschmidt_type value: modified
Option left: name:-ts_sundials_monitor_steps no value
Option left: name:-ts_sundials_type value: bdf
Option left: name:-ts_view no value
It appears as though PETSc ignores the 'ts_view' option.
Les
On 25 Jul 2013, at 17:15, Satish Balay wrote:
> On Thu, 25 Jul 2013, Matthew Knepley wrote:
>> On Thu, Jul 25, 2013 at 9:53 AM, Lesleis Nagy <l.nagy at ed.ac.uk> wrote:
>>> Hello,
>>> I currently use PETSc (version: 3.3-p7) and petsc4py along with the
>>> Sundials interface to perform time stepping for some FEM code that I have
>>> written (for completeness I make use of FEniCS). I would like to pass
>>> options to PETSc from the command line using the PETSC_OPTIONS environment
>>> variable. I set it with the following values:
>>>        $ export PETSC_OPTIONS="-ts_sundials_type bdf
>>> -ts_sundials_gramschmidt_type modified -ts_sundials_monitor_steps
>>> -options_table -options_left"
>>> I then run the code using:
>>>        $ mpiexec -n 2 python script.py
>>> Everything appears to work and my code terminates. However at the end of
>>> the run, '-options_table' / '-options_left' reports that
>>> -options_left
>>> -options_table
>>> There are 3 unused database options. They are:
>>> Could someone explain to me why PETSc is reading the Sundials options that
>>> I've supplied but is not using them?
>> 1) Your solver might have an options prefix
>> 2) You might forget to call TSSetFromOptions()
>> The easiest thing to do is run with -start_in_debugger and set a breakpoint
>> in TSSetFromOptions()
> Also use -ts_view to check if sundials is actually getting set/used..
> Satish
>>   Matt
>>> Kind regards
>>> Les
>>> The University of Edinburgh is a charitable body, registered in
>>> Scotland, with registration number SC005336.
