[petsc-users] Setting PETSc Sundials Options Using PETSC_OPTIONS
Lesleis Nagy l.nagy at ed.ac.uk
Thu Jul 25 11:59:09 CDT 2013
Hi Satish, Matthew,
Thank you very much for your help. Everything seems to work with the exception that PETSc now doesn't pick up the 'ts_view' option!
For completeness, when using PETSc / petsc4py / FEniCS I simply called 'ts.setFromOptions()' on my on my petsc4py time stepper object (called 'ts').
Is the appearance of 'ts_view' in the unused database options list something I should be concerned about? When I call the 'view()' method on my time stepper object it seems to output information that I would expect to see.
Many thanks
Les
On 25 Jul 2013, at 17:29, Satish Balay wrote:
> Then as Matt refered to  - TSSetFromOptions() isn't getting called.
> Satish
> On Thu, 25 Jul 2013, Lesleis Nagy wrote:
>> Hi Satish, Matthew,
>> I'm just about to compile a version of PETSc with debugging symbols included, so that I can use gdb. Satish, I've passed the option that you suggest and the output is as follows:
>> #PETSc Option Table entries:
>> -options_left
>> -options_table
>> -ts_sundials_gramschmidt_type modified
>> -ts_sundials_monitor_steps
>> -ts_sundials_type bdf
>> -ts_view
>> #End of PETSc Option Table entries
>> There are 7 unused database options. They are:
>> Option left: name:-ts_sundials_gramschmidt_type value: modified
>> Option left: name:-ts_sundials_monitor_steps no value
>> Option left: name:-ts_sundials_type value: bdf
>> Option left: name:-ts_view no value
>> It appears as though PETSc ignores the 'ts_view' option.
>> Les
>> On 25 Jul 2013, at 17:15, Satish Balay wrote:
>>> On Thu, 25 Jul 2013, Matthew Knepley wrote:
>>>> On Thu, Jul 25, 2013 at 9:53 AM, Lesleis Nagy <l.nagy at ed.ac.uk> wrote:
>>>>> Hello,
>>>>> I currently use PETSc (version: 3.3-p7) and petsc4py along with the
>>>>> Sundials interface to perform time stepping for some FEM code that I have
>>>>> written (for completeness I make use of FEniCS). I would like to pass
>>>>> options to PETSc from the command line using the PETSC_OPTIONS environment
>>>>> variable. I set it with the following values:
>>>>>       $ export PETSC_OPTIONS="-ts_sundials_type bdf
>>>>> -ts_sundials_gramschmidt_type modified -ts_sundials_monitor_steps
>>>>> -options_table -options_left"
>>>>> I then run the code using:
>>>>>       $ mpiexec -n 2 python script.py
>>>>> Everything appears to work and my code terminates. However at the end of
>>>>> the run, '-options_table' / '-options_left' reports that
>>>>> -options_left
>>>>> -options_table
>>>>> There are 3 unused database options. They are:
>>>>> Could someone explain to me why PETSc is reading the Sundials options that
>>>>> I've supplied but is not using them?
>>>> 1) Your solver might have an options prefix
>>>> 2) You might forget to call TSSetFromOptions()
>>>> The easiest thing to do is run with -start_in_debugger and set a breakpoint
>>>> in TSSetFromOptions()
>>> Also use -ts_view to check if sundials is actually getting set/used..
>>> Satish
>>>>  Matt
>>>>> Kind regards
>>>>> Les
>>>>> The University of Edinburgh is a charitable body, registered in
>>>>> Scotland, with registration number SC005336.
