[petsc-users] error with PAMI (fwd)
Inge Gutheil i.gutheil at fz-juelich.de
Tue Jul 23 02:06:34 CDT 2013
Sorry,
I just found out that it is the user of our BlueGene/Q who sent the
error message.
Inge
On 07/23/13 08:17, Inge Gutheil wrote:
> Hello,
> a user here in Juelich got the same error and he said he only got it on
> BlueGene with PETSc, so I believe there is a problem with PAMI and PETSc
> at least PETSc 3.3-p5. Im am just now installing PETSc 3.4.2 and want to
> ask the user whether the problem still occurs. I also had thought of
> posting it to the PETSc list but I do not have the complete error code,
> the user only sent us the PAMI error, and it was exactely the same
> place. If it is still there with PETSc 3.4.2, it might be a problem with
> PAMI, but IBM won't help if we can't give them a small reproducible
> example. Anyway, nice to hear that we are not alone in Juelich.
> Inge
> On 07/19/13 18:15, Satish Balay wrote:
>> Forwarding to petsc-users - perhaps other BG users have more
>> experience with PAMI.
>> Satish
>> ---------- Forwarded message ----------
>> Date: Fri, 19 Jul 2013 09:09:24 +0000
>> From: g.giangaspero at utwente.nl
>> To: petsc-maint at mcs.anl.gov
>> Subject: [petsc-maint] error with PAMI
>> Dear Authors,
>> I am trying to run PETSc 3.3-p5 on a IBM Blue Gene/Q machine which
>> features PAMI as MPI implementation and the IBM xl compiler. I would
>> like to solve a non-linear system but as soon as the function
>> SNESSolve is called the code crashes and I get the following error
>> message (MooseMBFlow is the executable):
>> MooseMBFlow:
>> /bgsys/source/srcV1R2M0.14091/comm/sys/buildtools/pami/common/bgq/Memregion.h:58:
>> pami_result_t PAMI::Memregion::createMemregion_impl(size_t*, size_t,
>> void*, uint64_t): Assertion `rc == 0' failed
>> These lines are the only ones being printed therefore I cannot tell
>> you much more about the error.
>> I know this is not directly related to PETSc but I wonder if anybody
>> had already experienced such a problem, I did not get any real help
>> from the user support of that machine.
>> Thank you very much for your help.
>> Best Regards,
>> Giorgio Giangaspero
> Inge Gutheil
> Juelich Supercomputing Centre
> Institute for Advanced Simulation
> Forschungszentrum Juelich GmbH
> 52425 Juelich, Germany
>       Phone:   +49-2461-61-3135
>       Fax:     +49-2461-61-6656
>       E-mail:i.gutheil at fz-juelich.de
> 52425 Juelich
> Sitz der Gesellschaft: Juelich
> Eingetragen im Handelsregister des Amtsgerichts Dueren Nr. HR B 3498
> Vorsitzender des Aufsichtsrats: MinDir Dr. Karl Eugen Huthmacher
> Geschaeftsfuehrung: Prof. Dr. Achim Bachem (Vorsitzender),
> Karsten Beneke (stellv. Vorsitzender), Prof. Dr.-Ing. Harald Bolt,
> Prof. Dr. Sebastian M. Schmidt
> Das Forschungszentrum oeffnet seine Tueren am Sonntag, 29. September,
> von 10:00 bis 17:00 Uhr: http://www.tagderneugier.de
Inge Gutheil
