[petsc-users] Fortran Example problem with MPI_COMM_WORLD
Inge Gutheil i.gutheil at fz-juelich.de
Wed Jul 24 09:00:02 CDT 2013
Hello,
in
petsc-3.4.2/src/snes/examples/tests/ex12f.F it says
   8 !  In this example the application context is a Fortran integer array:
   9 !      ctx(1) = da    - distributed array
  10 !          2  = F     - global vector where the function is stored
  11 !          3  = xl    - local work vector
  12 !          4  = comm  - MPI communictor
  13 !          5  = unused
  14 !          6  = N     - system size
This array is declared as
34       PetscFortranAddr ctx(6)
thus for a 64-Bit machine this will be 8-Byte integer.  Now the address
of the distributed array and of the vector F should be 64-Bit, but comm,
the MPI communicator must not be 64Bit on many machines, for example on
BlueGene/Q, where it always results in an invalid communicator if you
have an
  INTEGER*8 ICOMM
  ICOMM=MPI_COMM_WORLD
  call MPI_COMM_SIZE(ICOMM,size,ierr)
The communicator must be given to the subroutines as INTEGER*4, even on
some 64-Bit machines.
Also the system size N is INTEGER *4 if you did not compile with
PETSC_INT=8, so I think you will need two arrays , one with the
addresses and one with the normal PetscInt for comm and N.
Regards
Inge Gutheil
Inge Gutheil
Juelich Supercomputing Centre
Institute for Advanced Simulation
Forschungszentrum Juelich GmbH
52425 Juelich, Germany
       Phone:   +49-2461-61-3135
       Fax:     +49-2461-61-6656
       E-mail:i.gutheil at fz-juelich.de
52425 Juelich
Sitz der Gesellschaft: Juelich
Eingetragen im Handelsregister des Amtsgerichts Dueren Nr. HR B 3498
Vorsitzender des Aufsichtsrats: MinDir Dr. Karl Eugen Huthmacher
Geschaeftsfuehrung: Prof. Dr. Achim Bachem (Vorsitzender),
Karsten Beneke (stellv. Vorsitzender), Prof. Dr.-Ing. Harald Bolt,
Prof. Dr. Sebastian M. Schmidt
Das Forschungszentrum oeffnet seine Tueren am Sonntag, 29. September, von 10:00 bis 17:00 Uhr: http://www.tagderneugier.de
