[petsc-users] error with PAMI (fwd)
Inge Gutheil i.gutheil at fz-juelich.de
Tue Jul 23 01:17:54 CDT 2013
Hello,
a user here in Juelich got the same error and he said he only got it on
BlueGene with PETSc, so I believe there is a problem with PAMI and PETSc
at least PETSc 3.3-p5. Im am just now installing PETSc 3.4.2 and want to
ask the user whether the problem still occurs. I also had thought of
posting it to the PETSc list but I do not have the complete error code,
the user only sent us the PAMI error, and it was exactely the same
place. If it is still there with PETSc 3.4.2, it might be a problem with
PAMI, but IBM won't help if we can't give them a small reproducible
example. Anyway, nice to hear that we are not alone in Juelich.
Inge
On 07/19/13 18:15, Satish Balay wrote:
> Forwarding to petsc-users - perhaps other BG users have more
> experience with PAMI.
> Satish
> ---------- Forwarded message ----------
> Date: Fri, 19 Jul 2013 09:09:24 +0000
> From: g.giangaspero at utwente.nl
> To: petsc-maint at mcs.anl.gov
> Subject: [petsc-maint] error with PAMI
> Dear Authors,
> I am trying to run PETSc 3.3-p5 on a IBM Blue Gene/Q machine which features PAMI as MPI implementation and the IBM xl compiler. I would like to solve a non-linear system but as soon as the function SNESSolve is called the code crashes and I get the following error message (MooseMBFlow is the executable):
> MooseMBFlow: /bgsys/source/srcV1R2M0.14091/comm/sys/buildtools/pami/common/bgq/Memregion.h:58: pami_result_t PAMI::Memregion::createMemregion_impl(size_t*, size_t, void*, uint64_t): Assertion `rc == 0' failed
> These lines are the only ones being printed therefore I cannot tell you much more about the error.
> I know this is not directly related to PETSc but I wonder if anybody had already experienced such a problem, I did not get any real help from the user support of that machine.
> Thank you very much for your help.
> Best Regards,
> Giorgio Giangaspero
Inge Gutheil
Juelich Supercomputing Centre
Institute for Advanced Simulation
Forschungszentrum Juelich GmbH
52425 Juelich, Germany
       Phone:   +49-2461-61-3135
       Fax:     +49-2461-61-6656
       E-mail:i.gutheil at fz-juelich.de
52425 Juelich
Sitz der Gesellschaft: Juelich
Eingetragen im Handelsregister des Amtsgerichts Dueren Nr. HR B 3498
Vorsitzender des Aufsichtsrats: MinDir Dr. Karl Eugen Huthmacher
Geschaeftsfuehrung: Prof. Dr. Achim Bachem (Vorsitzender),
Karsten Beneke (stellv. Vorsitzender), Prof. Dr.-Ing. Harald Bolt,
Prof. Dr. Sebastian M. Schmidt
Das Forschungszentrum oeffnet seine Tueren am Sonntag, 29. September, von 10:00 bis 17:00 Uhr: http://www.tagderneugier.de
