[petsc-users] compile petsc with intel compiler
Wed Jul 10 09:41:01 CDT 2013
Perhaps stuff is not installed correctly on this machine?
[petsc:~] petsc> dpkg -S /usr/include/c++/4.6/bits/stl_algobase.h
libstdc++6-4.6-dev: /usr/include/c++/4.6/bits/stl_algobase.h
[petsc:~] petsc> dpkg -S /usr/include/c++/4.6/x86_64-linux-gnu/bits/c++config.h
libstdc++6-4.6-dev: /usr/include/c++/4.6/x86_64-linux-gnu/bits/c++config.h
[petsc:~] petsc>
So both bits/stl_algobase.h and bits/c++config.h are installed by libstdc++ package.
What do you have for:
ls /usr/include/c++/4.7/bits/stl_algobase.h
ls /usr/include/c++/4.7/x86_64-linux-gnu/bits/c++config.h
dpkg -S /usr/include/c++/4.7/bits/stl_algobase.h
dpkg -S /usr/include/c++/4.7/x86_64-linux-gnu/bits/c++config.h
[perhaps the files exist - but the intel compiler is not finding it?]
Satish
On Wed, 10 Jul 2013, Michael Povolotskyi wrote:
> Thank you Matt.
> Unfortunately 'make all-legacy' gives the same error:
> libfast in: /home/mpovolot/Code_intel/libs/petsc/build-real/src
> libfast in: /home/mpovolot/Code_intel/libs/petsc/build-real/src/sys
> libfast in: /home/mpovolot/Code_intel/libs/petsc/build-real/src/sys/classes
> libfast in:
> /home/mpovolot/Code_intel/libs/petsc/build-real/src/sys/classes/viewer
> libfast in:
> /home/mpovolot/Code_intel/libs/petsc/build-real/src/sys/classes/viewer/impls
> libfast in:
> /home/mpovolot/Code_intel/libs/petsc/build-real/src/sys/classes/viewer/impls/socket
> /usr/include/c++/4.7/bits/stl_algobase.h(60): catastrophic error: cannot open
> source file "bits/c++config.h"
>   #include <bits/c++config.h>
> compilation aborted for send.c (code 4)
> Michael.
> On 07/10/2013 08:05 AM, Matthew Knepley wrote:
> > On Wed, Jul 10, 2013 at 12:00 AM, Michael Povolotskyi <mpovolot at purdue.edu
> > <mailto:mpovolot at purdue.edu>> wrote:
> >     Hello everybody,
> >     unfortunately building petsc without fortran cannot work for me
> >     because I need MUMPs that requires Scalapack that needs fortran. I
> >     played with the options. As result the configuration runs okay,
> >     the build gives an error that does not seem to be related to fortran:
> > Quit building with CMake. It complicates everything. Use the legacy build.
> >    Matt
> >     [  0%] Building CXX object
> >     CMakeFiles/petscsys.dir/src/sys/totalview/tv_data_display.c.o
> >     Building Fortran object
> >     CMakeFiles/petscsys.dir/src/sys/f90-mod/petscsysmod.F.o
> >     Building CXX object
> >     CMakeFiles/petscsys.dir/src/sys/python/pythonsys.c.o
> >     [  0%] /usr/include/c++/4.7/bits/stl_algobase.h(60): catastrophic
> >     error: cannot open source file "bits/c++config.h"
> >     /home/mpovolot/Code_intel/libs/petsc/build-real/src/sys/info/verboseinfo.c
> >     (code 4)
> >     /home/mpovolot/Code_intel/libs/petsc/build-real/src/sys/logging/plog.c
> >     (code 4)
> >     I attach here the log files.
> >     Any advise is highly appreciated.
> >     Michael.
> >     On 7/9/2013 4:34 PM, Matthew Knepley wrote:
> > >     On Tue, Jul 9, 2013 at 3:32 PM, Michael Povolotskyi
> > >     <mpovolot at purdue.edu <mailto:mpovolot at purdue.edu>> wrote:
> > >         If I  do not need to use petsc in fortran programs, can I
> > >         build petsc without fortran and thus avoid this situation?
> > >         Michael.
> > >         On 07/09/2013 04:31 PM, Satish Balay wrote:
> > >             For some reason this issue comes up with mpi.mod provided
> > >             by intel
> > >             mpi.
> > >             We have a configure test for it - but looks like its not
> > >             sufficient to
> > >             catch this issue.
> > >             satish
> > >             On Tue, 9 Jul 2013, Matthew Knepley wrote:
> > >                 On Tue, Jul 9, 2013 at 3:11 PM, Michael Povolotskyi
> > >                 <mpovolot at purdue.edu <mailto:mpovolot at purdue.edu>>wrote:
> > >                     Dear Petsc users and developers,
> > >                     I'm trying to build petsc with Intel compiler.
> > >                 1) First, ask yourself whether you really want to
> > >                 build with the Intel
> > >                 compiler. Then ask again.
> > >                 2) Do you need Fortran? If not, turn it off --with-fc=0.
> > >          Matt
> > >                 3) If you want Fortran and Intel (and have a hatred
> > >                 of free time), try the
> > >                 legacy build
> > >                     make all-legacy
> > >                 4) If this is still broken, send the new make.log
> > >                    Thanks,
> > >                      Matt
> > >                     The configuration process runs okay (I attach the
> > >                     log here),
> > >                     but I get an error when I build it:
> > >                     -- Configuring done
> > >                     -- Generating done
> > >                     -- Build files have been written to:
> > >                     /home/mpovolot/Code_intel/**
> > >                     libs/petsc/build-real/linux
> > >                     Scanning dependencies of target petscsys
> > >                     [  0%] [  0%] [  0%] Building CXX object
> > >                     CMakeFiles/petscsys.dir/src/**
> > >                     sys/info/verboseinfo.c.o
> > >                     Building CXX object CMakeFiles/petscsys.dir/src/**
> > >                     sys/totalview/tv_data_display.**c.o
> > >                     Building CXX object
> > >                     CMakeFiles/petscsys.dir/src/**sys/python/pythonsys.c.o
> > >                     Building CXX object
> > >                     CMakeFiles/petscsys.dir/src/**sys/logging/plog.c.o
> > >                     /home/mpovolot/Code_intel/**libs/petsc/build-real/src/sys/**
> > >                     f90-mod/petscsysmod.F:6.11:
> > >                              use mpi
> > >                                 1
> > >                     Fatal Error: File 'mpi.mod' opened at (1) is not
> > >                     a GFORTRAN module file
> > >                     make[6]: ***
> > >                     [CMakeFiles/petscsys.dir/src/**sys/f90-mod/petscsysmod.F.o]
> > >                     Error 1
> > >                     make[6]: *** Waiting for unfinished jobs....
> > >                     make[5]: *** [CMakeFiles/petscsys.dir/all] Error 2
> > >                     make[4]: *** [all] Error 2
> > >                     make[3]: *** [ccmake] Error 2
> > >                     make[2]: *** [cmake] Error 2
> > >                     ****************************ERROR**************************************
> > >                        Error during compile, check linux/conf/make.log
> > >                        Send it and linux/conf/configure.log to
> > >                     petsc-maint at mcs.anl.gov
> > >                     <mailto:petsc-maint at mcs.anl.gov>
> > >                     I attach here the make.log
> > >                     What is strange to me that it has something to do
> > >                     with Gfortran, while I
> > >                     want to build everything with Intel.
> > >                     Thank you for help,
> > >                     Michael.
> > >                     Michael Povolotskyi, PhD
> > >                     Research Assistant Professor
> > >                     Network for Computational Nanotechnology
> > >                     207 S Martin Jischke Drive
> > >                     Purdue University, DLR, room 441-10
> > >                     West Lafayette, Indiana 47907
> > >                     phone: +1-765-494-9396 <tel:%2B1-765-494-9396>
> > >                     fax: +1-765-496-6026 <tel:%2B1-765-496-6026>
> > >     --     What most experimenters take for granted before they begin
> > > their
> > >     experiments is infinitely more interesting than any results to
> > >     which their experiments lead.
> > >     -- Norbert Wiener
> > What most experimenters take for granted before they begin their experiments
> > is infinitely more interesting than any results to which their experiments
> > lead.
> > -- Norbert Wiener
