[petsc-users] compile petsc with intel compiler
Michael Povolotskyi mpovolot at purdue.edu
Wed Jul 10 09:26:44 CDT 2013
Thank you Matt.
Unfortunately 'make all-legacy' gives the same error:
libfast in: /home/mpovolot/Code_intel/libs/petsc/build-real/src
libfast in: /home/mpovolot/Code_intel/libs/petsc/build-real/src/sys
libfast in: /home/mpovolot/Code_intel/libs/petsc/build-real/src/sys/classes
libfast in:
/home/mpovolot/Code_intel/libs/petsc/build-real/src/sys/classes/viewer
libfast in:
/home/mpovolot/Code_intel/libs/petsc/build-real/src/sys/classes/viewer/impls
libfast in:
/home/mpovolot/Code_intel/libs/petsc/build-real/src/sys/classes/viewer/impls/socket
/usr/include/c++/4.7/bits/stl_algobase.h(60): catastrophic error: cannot
open source file "bits/c++config.h"
   #include <bits/c++config.h>
compilation aborted for send.c (code 4)
Michael.
On 07/10/2013 08:05 AM, Matthew Knepley wrote:
> On Wed, Jul 10, 2013 at 12:00 AM, Michael Povolotskyi
> <mpovolot at purdue.edu <mailto:mpovolot at purdue.edu>> wrote:
>     Hello everybody,
>     unfortunately building petsc without fortran cannot work for me
>     because I need MUMPs that requires Scalapack that needs fortran. I
>     played with the options. As result the configuration runs okay,
>     the build gives an error that does not seem to be related to fortran:
> Quit building with CMake. It complicates everything. Use the legacy build.
>    Matt
>     [  0%] Building CXX object
>     CMakeFiles/petscsys.dir/src/sys/totalview/tv_data_display.c.o
>     Building Fortran object
>     CMakeFiles/petscsys.dir/src/sys/f90-mod/petscsysmod.F.o
>     Building CXX object
>     CMakeFiles/petscsys.dir/src/sys/python/pythonsys.c.o
>     [  0%] /usr/include/c++/4.7/bits/stl_algobase.h(60): catastrophic
>     error: cannot open source file "bits/c++config.h"
>     /home/mpovolot/Code_intel/libs/petsc/build-real/src/sys/info/verboseinfo.c
>     (code 4)
>     /home/mpovolot/Code_intel/libs/petsc/build-real/src/sys/logging/plog.c
>     (code 4)
>     I attach here the log files.
>     Any advise is highly appreciated.
>     Michael.
>     On 7/9/2013 4:34 PM, Matthew Knepley wrote:
>>     On Tue, Jul 9, 2013 at 3:32 PM, Michael Povolotskyi
>>         If I  do not need to use petsc in fortran programs, can I
>>         build petsc without fortran and thus avoid this situation?
>>         Michael.
>>         On 07/09/2013 04:31 PM, Satish Balay wrote:
>>             For some reason this issue comes up with mpi.mod provided
>>             by intel
>>             mpi.
>>             We have a configure test for it - but looks like its not
>>             sufficient to
>>             catch this issue.
>>             satish
>>             On Tue, 9 Jul 2013, Matthew Knepley wrote:
>>                 On Tue, Jul 9, 2013 at 3:11 PM, Michael Povolotskyi
>>                 <mpovolot at purdue.edu <mailto:mpovolot at purdue.edu>>wrote:
>>                     Dear Petsc users and developers,
>>                     I'm trying to build petsc with Intel compiler.
>>                 1) First, ask yourself whether you really want to
>>                 build with the Intel
>>                 compiler. Then ask again.
>>                 2) Do you need Fortran? If not, turn it off --with-fc=0.
>>          Matt
>>                 3) If you want Fortran and Intel (and have a hatred
>>                 of free time), try the
>>                 legacy build
>>                     make all-legacy
>>                 4) If this is still broken, send the new make.log
>>                    Thanks,
>>                      Matt
>>                     The configuration process runs okay (I attach the
>>                     log here),
>>                     but I get an error when I build it:
>>                     -- Configuring done
>>                     -- Generating done
>>                     -- Build files have been written to:
>>                     /home/mpovolot/Code_intel/**
>>                     libs/petsc/build-real/linux
>>                     Scanning dependencies of target petscsys
>>                     [  0%] [  0%] [  0%] Building CXX object
>>                     CMakeFiles/petscsys.dir/src/**
>>                     sys/info/verboseinfo.c.o
>>                     Building CXX object CMakeFiles/petscsys.dir/src/**
>>                     sys/totalview/tv_data_display.**c.o
>>                     Building CXX object
>>                     CMakeFiles/petscsys.dir/src/**sys/python/pythonsys.c.o
>>                     Building CXX object
>>                     CMakeFiles/petscsys.dir/src/**sys/logging/plog.c.o
>>                     /home/mpovolot/Code_intel/**libs/petsc/build-real/src/sys/**
>>                     f90-mod/petscsysmod.F:6.11:
>>                              use mpi
>>                                 1
>>                     Fatal Error: File 'mpi.mod' opened at (1) is not
>>                     a GFORTRAN module file
>>                     make[6]: ***
>>                     [CMakeFiles/petscsys.dir/src/**sys/f90-mod/petscsysmod.F.o]
>>                     Error 1
>>                     make[6]: *** Waiting for unfinished jobs....
>>                     make[5]: *** [CMakeFiles/petscsys.dir/all] Error 2
>>                     make[4]: *** [all] Error 2
>>                     make[3]: *** [ccmake] Error 2
>>                     make[2]: *** [cmake] Error 2
>>                     ****************************ERROR**************************************
>>                        Error during compile, check linux/conf/make.log
>>                        Send it and linux/conf/configure.log to
>>                     petsc-maint at mcs.anl.gov
>>                     <mailto:petsc-maint at mcs.anl.gov>
>>                     I attach here the make.log
>>                     What is strange to me that it has something to do
>>                     with Gfortran, while I
>>                     want to build everything with Intel.
>>                     Thank you for help,
>>                     Michael.
>>                     Michael Povolotskyi, PhD
>>                     Research Assistant Professor
>>                     Network for Computational Nanotechnology
>>                     207 S Martin Jischke Drive
>>                     Purdue University, DLR, room 441-10
>>                     West Lafayette, Indiana 47907
>>                     phone: +1-765-494-9396 <tel:%2B1-765-494-9396>
>>                     fax: +1-765-496-6026 <tel:%2B1-765-496-6026>
>>     What most experimenters take for granted before they begin their
>>     experiments is infinitely more interesting than any results to
>>     which their experiments lead.
>>     -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130710/0750488e/attachment-0001.html>
