[petsc-users] compile petsc with intel compiler
Michael Povolotskyi mpovolot at purdue.edu
Wed Jul 10 10:05:11 CDT 2013
Hi Satish,
it looks like I have this file but not in "standard" location:
locate bits/c++config.h
/usr/include/x86_64-linux-gnu/c++/4.7/bits/c++config.h
/usr/share/gccxml-0.9/GCC/4.4/bits/c++config.h
/usr/share/gccxml-0.9/GCC/4.6/bits/c++config.h
/usr/share/gccxml-0.9/GCC/4.7/bits/c++config.h
Should I try to add -I usr/include/x86_64-linux-gnu/c++/4.7/ to the CPPLAGS?
Michael.
On 07/10/2013 10:41 AM, Satish Balay wrote:
> Perhaps stuff is not installed correctly on this machine?
> [petsc:~] petsc> dpkg -S /usr/include/c++/4.6/bits/stl_algobase.h
> libstdc++6-4.6-dev: /usr/include/c++/4.6/bits/stl_algobase.h
> [petsc:~] petsc> dpkg -S /usr/include/c++/4.6/x86_64-linux-gnu/bits/c++config.h
> libstdc++6-4.6-dev: /usr/include/c++/4.6/x86_64-linux-gnu/bits/c++config.h
> [petsc:~] petsc>
> So both bits/stl_algobase.h and bits/c++config.h are installed by libstdc++ package.
> What do you have for:
> ls /usr/include/c++/4.7/bits/stl_algobase.h
> ls /usr/include/c++/4.7/x86_64-linux-gnu/bits/c++config.h
> dpkg -S /usr/include/c++/4.7/bits/stl_algobase.h
> dpkg -S /usr/include/c++/4.7/x86_64-linux-gnu/bits/c++config.h
> [perhaps the files exist - but the intel compiler is not finding it?]
> Satish
> On Wed, 10 Jul 2013, Michael Povolotskyi wrote:
>> Thank you Matt.
>> Unfortunately 'make all-legacy' gives the same error:
>> libfast in: /home/mpovolot/Code_intel/libs/petsc/build-real/src
>> libfast in: /home/mpovolot/Code_intel/libs/petsc/build-real/src/sys
>> libfast in: /home/mpovolot/Code_intel/libs/petsc/build-real/src/sys/classes
>> libfast in:
>> /home/mpovolot/Code_intel/libs/petsc/build-real/src/sys/classes/viewer
>> libfast in:
>> /home/mpovolot/Code_intel/libs/petsc/build-real/src/sys/classes/viewer/impls
>> libfast in:
>> /home/mpovolot/Code_intel/libs/petsc/build-real/src/sys/classes/viewer/impls/socket
>> /usr/include/c++/4.7/bits/stl_algobase.h(60): catastrophic error: cannot open
>> source file "bits/c++config.h"
>>    #include <bits/c++config.h>
>> compilation aborted for send.c (code 4)
>> Michael.
>> On 07/10/2013 08:05 AM, Matthew Knepley wrote:
>>> On Wed, Jul 10, 2013 at 12:00 AM, Michael Povolotskyi <mpovolot at purdue.edu
>>> <mailto:mpovolot at purdue.edu>> wrote:
>>>      Hello everybody,
>>>      unfortunately building petsc without fortran cannot work for me
>>>      because I need MUMPs that requires Scalapack that needs fortran. I
>>>      played with the options. As result the configuration runs okay,
>>>      the build gives an error that does not seem to be related to fortran:
>>> Quit building with CMake. It complicates everything. Use the legacy build.
>>>     Matt
>>>      [  0%] Building CXX object
>>>      CMakeFiles/petscsys.dir/src/sys/totalview/tv_data_display.c.o
>>>      Building Fortran object
>>>      CMakeFiles/petscsys.dir/src/sys/f90-mod/petscsysmod.F.o
>>>      Building CXX object
>>>      CMakeFiles/petscsys.dir/src/sys/python/pythonsys.c.o
>>>      [  0%] /usr/include/c++/4.7/bits/stl_algobase.h(60): catastrophic
>>>      error: cannot open source file "bits/c++config.h"
>>>      /home/mpovolot/Code_intel/libs/petsc/build-real/src/sys/info/verboseinfo.c
>>>      (code 4)
>>>      /home/mpovolot/Code_intel/libs/petsc/build-real/src/sys/logging/plog.c
>>>      (code 4)
>>>      I attach here the log files.
>>>      Any advise is highly appreciated.
>>>      Michael.
>>>      On 7/9/2013 4:34 PM, Matthew Knepley wrote:
>>>>      On Tue, Jul 9, 2013 at 3:32 PM, Michael Povolotskyi
>>>>      <mpovolot at purdue.edu <mailto:mpovolot at purdue.edu>> wrote:
>>>>          If I  do not need to use petsc in fortran programs, can I
>>>>          build petsc without fortran and thus avoid this situation?
>>>>          Michael.
>>>>          On 07/09/2013 04:31 PM, Satish Balay wrote:
>>>>              For some reason this issue comes up with mpi.mod provided
>>>>              by intel
>>>>              mpi.
>>>>              We have a configure test for it - but looks like its not
>>>>              sufficient to
>>>>              catch this issue.
>>>>              satish
>>>>              On Tue, 9 Jul 2013, Matthew Knepley wrote:
>>>>                  On Tue, Jul 9, 2013 at 3:11 PM, Michael Povolotskyi
>>>>                  <mpovolot at purdue.edu <mailto:mpovolot at purdue.edu>>wrote:
>>>>                      Dear Petsc users and developers,
>>>>                      I'm trying to build petsc with Intel compiler.
>>>>                  1) First, ask yourself whether you really want to
>>>>                  build with the Intel
>>>>                  compiler. Then ask again.
>>>>                  2) Do you need Fortran? If not, turn it off --with-fc=0.
>>>>           Matt
>>>>                  3) If you want Fortran and Intel (and have a hatred
>>>>                  of free time), try the
>>>>                  legacy build
>>>>                      make all-legacy
>>>>                  4) If this is still broken, send the new make.log
>>>>                     Thanks,
>>>>                       Matt
>>>>                      The configuration process runs okay (I attach the
>>>>                      log here),
>>>>                      but I get an error when I build it:
>>>>                      -- Configuring done
>>>>                      -- Generating done
>>>>                      -- Build files have been written to:
>>>>                      /home/mpovolot/Code_intel/**
>>>>                      libs/petsc/build-real/linux
>>>>                      Scanning dependencies of target petscsys
>>>>                      [  0%] [  0%] [  0%] Building CXX object
>>>>                      CMakeFiles/petscsys.dir/src/**
>>>>                      sys/info/verboseinfo.c.o
>>>>                      Building CXX object CMakeFiles/petscsys.dir/src/**
>>>>                      sys/totalview/tv_data_display.**c.o
>>>>                      Building CXX object
>>>>                      CMakeFiles/petscsys.dir/src/**sys/python/pythonsys.c.o
>>>>                      Building CXX object
>>>>                      CMakeFiles/petscsys.dir/src/**sys/logging/plog.c.o
>>>>                      /home/mpovolot/Code_intel/**libs/petsc/build-real/src/sys/**
>>>>                      f90-mod/petscsysmod.F:6.11:
>>>>                               use mpi
>>>>                                  1
>>>>                      Fatal Error: File 'mpi.mod' opened at (1) is not
>>>>                      a GFORTRAN module file
>>>>                      make[6]: ***
>>>>                      [CMakeFiles/petscsys.dir/src/**sys/f90-mod/petscsysmod.F.o]
>>>>                      Error 1
>>>>                      make[6]: *** Waiting for unfinished jobs....
>>>>                      make[5]: *** [CMakeFiles/petscsys.dir/all] Error 2
>>>>                      make[4]: *** [all] Error 2
>>>>                      make[3]: *** [ccmake] Error 2
>>>>                      make[2]: *** [cmake] Error 2
>>>>                      ****************************ERROR**************************************
>>>>                         Error during compile, check linux/conf/make.log
>>>>                         Send it and linux/conf/configure.log to
>>>>                      petsc-maint at mcs.anl.gov
>>>>                      <mailto:petsc-maint at mcs.anl.gov>
>>>>                      I attach here the make.log
>>>>                      What is strange to me that it has something to do
>>>>                      with Gfortran, while I
>>>>                      want to build everything with Intel.
>>>>                      Thank you for help,
>>>>                      Michael.
>>>>                      Michael Povolotskyi, PhD
>>>>                      Research Assistant Professor
>>>>                      Network for Computational Nanotechnology
>>>>                      207 S Martin Jischke Drive
>>>>                      Purdue University, DLR, room 441-10
>>>>                      West Lafayette, Indiana 47907
>>>>                      phone: +1-765-494-9396 <tel:%2B1-765-494-9396>
>>>>                      fax: +1-765-496-6026 <tel:%2B1-765-496-6026>
>>>>      --     What most experimenters take for granted before they begin
>>>> their
>>>>      experiments is infinitely more interesting than any results to
>>>>      which their experiments lead.
>>>>      -- Norbert Wiener
>>> What most experimenters take for granted before they begin their experiments
>>> is infinitely more interesting than any results to which their experiments
>>> lead.
>>> -- Norbert Wiener
