[petsc-users] Error message Exit Code 9
Garnet Vaz garnet.vaz at gmail.com
Tue Jul 9 22:46:04 CDT 2013
Hi Jed,
The problem is being caused from Out of Memory error.
So I am going to stick to the smaller problems.
Thanks a lot.
Garnet Vaz
On Tue, Jul 9, 2013 at 5:25 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Garnet Vaz <garnet.vaz at gmail.com> writes:
> > Hi Jed,
> > Yes. It has been running fine for problems up to 3M triangles.
> > /var/log/messages does say that the process is killed.
> > Changed the oom options to allow over-commiting. I think it
> > should work now.
> Hmm, normally when over-commit is turned off, malloc will return NULL,
> but when turned on (default on most systems), _some_ process will be
> killed when you run out of memory.  The process receiving SIGKILL is
> somehow evaluated to be a memory offender by the operating system, but
> may not be the process "responsible".
Garnet
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130709/93b8632c/attachment-0001.html>
