[petsc-users] Error message Exit Code 9
Tue Jul 9 19:25:00 CDT 2013
Garnet Vaz <garnet.vaz at gmail.com> writes:
> Hi Jed,
> Yes. It has been running fine for problems up to 3M triangles.
> /var/log/messages does say that the process is killed.
> Changed the oom options to allow over-commiting. I think it
> should work now.
Hmm, normally when over-commit is turned off, malloc will return NULL,
but when turned on (default on most systems), _some_ process will be
killed when you run out of memory.  The process receiving SIGKILL is
somehow evaluated to be a memory offender by the operating system, but
may not be the process "responsible".
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130709/61ba3892/attachment.pgp>
