[petsc-users] Variable ordering in PC FieldSplit
subramanya sadasiva subramanya.g at gmail.com
Tue Jul 9 20:41:08 CDT 2013
I have a small question about the use of PC field split, does it expect variables to be arranged in a particular fashion? Should it be variable major (all degrees of freedom corresponding to the first followed by all degrees of freedom corresponding to the next) or node major ( all degrees of freedom corresponding to each node - with a sub block structure . Is there some way of switching between the two ?Thanks,
Subramanya Sadasiva
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130709/086389e2/attachment.html>
