[petsc-users] Error message Exit Code 9
Garnet Vaz garnet.vaz at gmail.com
Tue Jul 9 18:48:36 CDT 2013
Hi Jed,
Yes. It has been running fine for problems up to 3M triangles.
/var/log/messages does say that the process is killed.
Changed the oom options to allow over-commiting. I think it
should work now.
Thanks.
Garnet
On Tue, Jul 9, 2013 at 3:57 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Garnet Vaz <garnet.vaz at gmail.com> writes:
> > Hi Jed,
> > Thanks. The output of quota reads "unlimited".
> > The system memory is 16GB.
> > Doing "ulimit -m" gives 13938212
> > in kilobytes which corresponds to 13GB. I think this means
> > that I should be able to use most of it. I am the only person
> > running jobs on this machine right now.
> > I can run with -memory_info for the smaller problem and try
> > to extrapolate. Is this a good idea?
> You can.  Does it run correctly for smaller problem sizes?  Look at
> -log_summary for memory usage information.  The OOM killer seems the
> most likely culprit.
Garnet
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130709/a491db3f/attachment.html>
