[petsc-users] Error message Exit Code 9
Tue Jul 9 17:57:49 CDT 2013
Garnet Vaz <garnet.vaz at gmail.com> writes:
> Hi Jed,
> Thanks. The output of quota reads "unlimited".
> The system memory is 16GB.
> Doing "ulimit -m" gives 13938212
> in kilobytes which corresponds to 13GB. I think this means
> that I should be able to use most of it. I am the only person
> running jobs on this machine right now.
> I can run with -memory_info for the smaller problem and try
> to extrapolate. Is this a good idea?
You can.  Does it run correctly for smaller problem sizes?  Look at
-log_summary for memory usage information.  The OOM killer seems the
most likely culprit.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130709/44964701/attachment.pgp>
