[petsc-users] Happy New Year! Blacs configure.
Tue Jan 1 04:22:54 CST 2013
On Tue, Jan 1, 2013 at 1:12 AM, w_ang_temp <w_ang_temp at 163.com> wrote:
> Hello,
>   Happy New Year to all!
>   And I have a problem about the configuration. The command is:
>   ./configure --with-mpi-dir=/home/geo/soft/mpich2/
> --download-f-blas-lapack=1 --download-hypre=1 --with-x=1 --with-debugging=0
> --download-superlu_dist --download-parmetis --download-mumps
> --download-scalapack --download-blacs
>   When it comes to:
>   TESTING: configureLibrary from
> PETSc.packages.blacs(config/BuildSystem/config/package.py:417)
>   It seems that the process has stopped or cannot continue because it is
> still here after one hour
Perhaps there is a problem with your connection. Download the tarball from
that location and use
--download-blacs=<tarball>. Also note that petsc-dev has removed blacs as a
dependency.
    Matt
>   The configure.log is:
> TEST alternateConfigureLibrary from
> PETSc.packages.PTScotch(/home/geo/soft/petsc/petsc-3.2-p7/config/BuildSystem/config/package.py:471)
> TESTING: alternateConfigureLibrary from
> PETSc.packages.PTScotch(config/BuildSystem/config/package.py:471)
>   Called if --with-packagename=0; does nothing by default
> PETSc.packages.PaStiX(/home/geo/soft/petsc/petsc-3.2-p7/config/BuildSystem/config/package.py:471)
> PETSc.packages.PaStiX(config/BuildSystem/config/package.py:471)
> sh: uname -s
> Executing: uname -s
> sh: Linux
> sh: uname -s
> Executing: uname -s
> sh: Linux
>       Pushing language C
> TEST configureLibrary from
> PETSc.packages.blacs(/home/geo/soft/petsc/petsc-3.2-p7/config/BuildSystem/config/package.py:417)
>   Find an installation and check if it can work with PETSc
>         Checking for a functional blacs
>                 Looking for BLACS in directory starting with blacs
>                 Could not locate an existing copy of blacs:
>                   ['hypre-2 .7.0b', 'fblaslapack-3.1.1']
>                   Downloading blacs
>                     Downloading
> http://ftp.mcs.anl.gov/pub/petsc/externalpackages/blacs-dev.tar.gz to
> /home/geo/soft/petsc/petsc-3.2-p7/externalpackages/_d_blacs.tar.gz
>        Thanks. Happy new year, and good luck!
>                                                       Jim
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130101/617f1d8a/attachment.html>
