[petsc-users] Happy New Year! Blacs configure.
w_ang_temp w_ang_temp at 163.com
Tue Jan 1 10:50:06 CST 2013
 Thanks. I have solved it. As Matt says, --download-blacs=/.../blacs-dev.tar.gz.
                                        Jim
>>On 2013-01-01 18:22:54,"Matthew Knepley" <knepley at gmail.com> 写道:
>>On Tue, Jan 1, 2013 at 1:12 AM, w_ang_temp <w_ang_temp at 163.com> wrote:
>>Hello,
>>  Happy New Year to all!
>>  And I have a problem about the configuration. The command is:
>>  ./configure --with-mpi-dir=/home/geo/soft/mpich2/ --download-f-blas-lapack=1 --download-hypre=1 --with-x=1 --with-debugging=0 --download->>superlu_dist --download-parmetis --download-mumps --download-scalapack --download-blacs
>>  When it comes to:
>>  TESTING: configureLibrary from PETSc.packages.blacs(config/BuildSystem/config/package.py:417)
>>  It seems that the process has stopped or cannot continue because it is still here after one hour
>Perhaps there is a problem with your connection. Download the tarball from that location and use
>--download-blacs=<tarball>. Also note that petsc-dev has removed blacs as a dependency.
    Matt
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130102/fee04597/attachment.html>
