[petsc-users] Happy New Year! Blacs configure.
w_ang_temp w_ang_temp at 163.com
Tue Jan 1 01:12:13 CST 2013
Hello,
  Happy New Year to all!
  And I have a problem about the configuration. The command is:
  ./configure --with-mpi-dir=/home/geo/soft/mpich2/ --download-f-blas-lapack=1 --download-hypre=1 --with-x=1 --with-debugging=0 --download-superlu_dist --download-parmetis --download-mumps --download-scalapack --download-blacs
  When it comes to:
  TESTING: configureLibrary from PETSc.packages.blacs(config/BuildSystem/config/package.py:417)
  It seems that the process has stopped or cannot continue because it is still here after one hour.
  The configure.log is:
TEST alternateConfigureLibrary from PETSc.packages.PTScotch(/home/geo/soft/petsc/petsc-3.2-p7/config/BuildSystem/config/package.py:471)
TESTING: alternateConfigureLibrary from PETSc.packages.PTScotch(config/BuildSystem/config/package.py:471)
  Called if --with-packagename=0; does nothing by default
TEST alternateConfigureLibrary from PETSc.packages.PaStiX(/home/geo/soft/petsc/petsc-3.2-p7/config/BuildSystem/config/package.py:471)
TESTING: alternateConfigureLibrary from PETSc.packages.PaStiX(config/BuildSystem/config/package.py:471)
sh: uname -s
Executing: uname -s
sh: Linux
sh: uname -s
Executing: uname -s
sh: Linux
      Pushing language C
TEST configureLibrary from PETSc.packages.blacs(/home/geo/soft/petsc/petsc-3.2-p7/config/BuildSystem/config/package.py:417)
  Find an installation and check if it can work with PETSc
        Checking for a functional blacs
                Looking for BLACS in directory starting with blacs
                Could not locate an existing copy of blacs:
                  ['hypre-2.7.0b', 'fblaslapack-3.1.1']
                  Downloading blacs
                    Downloading http://ftp.mcs.anl.gov/pub/petsc/externalpackages/blacs-dev.tar.gz to /home/geo/soft/petsc/petsc-3.2-p7/externalpackages/_d_blacs.tar.gz
       Thanks. Happy new year, and good luck!
                                                      Jim
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130101/f768125f/attachment.html>
