[petsc-users] parallel matmult flop measure
France Boillod-Cerneux boillod.france at gmail.com
Fri Aug 30 13:04:00 CDT 2013
Dear PETSc user,
I am using MatMult() function in a C++ program.
Currently, my matrix is MATMPIAIJ format type, and I load the matrix from a
binary file at petsc format. let's call the matrix A:
I know before the execution the global rows, columns and nnz.
my program is doing something like:
global loop
     //begin to measure flop rate
     inner loop
           MatMult(A,x,y)
     end inner loop
     //want to know Flop rate of Matmult at this point
end global loop
I am looking for a function to know at runtime the flop rate for each
process regarding matmult function.
I had a look at pdf of Loic Gouarin (introduction to pertsc, performance
May 2013) but it does not correspond to what i want, or i missunderstood?
My other solution is using the matmpiaijsetpreallocation and therefore know
the complete parallel distribution of A, but this implies a pre-treatment
on my matrix A.
I was wondering if i can create my matrix A without knowing in advance the
parallel distribution and then collect the information about parallel
distribution?
Or more easier, if a function like PetscGetFlops could solve my problem?
so far i understood that this function measure the flop since the begining
of program, but this is not what i want to use, i want to have the flop
ratio right after ending the inner loop, and this, for each global iteration
Any ideas/suggestions would help,
Thank you very much,
France
Bien cordialement - Best regards - Mit freundlichen Grüßen,
*France BOILLOD-CERNEUX *
*PhD Student, Laboratoire d'Informatique Fondamentale de Lille *
*(LIFL), CNRS*
France.Boillod-Cerneux at cea.fr
Tel. : +33 (0) 1 6908 - 9527
Tel. : +33 (0) 6 4781 - 3059
DEN/DANS/DM2S
CEA Saclay
91191 Gif-sur-Yvette
FRANCE
http://www.lifl.fr/
www-centre-saclay.cea.fr <http://www-centre-saclay.cea.fr/en>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130830/8a11aeea/attachment.html>
