[petsc-users] option values problem
Fri Aug 30 06:01:46 CDT 2013
On Fri, Aug 30, 2013 at 5:41 AM, Kathrin Burckhardt <tribur at itis.ethz.ch>wrote:
> Hi petsc people,
> how can I check if the value to a specific option is valid before getting
> an error?
Right now the options table only holds strings. The conversion is done by
the
retrieval function, so there is no centralized knowledge about an a priori
type
of the option value. The failure can occur anywhere in the code where
someone
tries to get the value with a conflicting type.
      Matt
> E.g., if the option string contains 'options_table 2' I get
> [ERROR]: --------------------- Error Message
> [ERROR]: [0]PETSC ERROR:
> [INFO]: Invalid argument!
> [INFO]: Unknown logical value: 2!
> Thank you in advance for your help,
> Kathrin
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130830/4dcec7b8/attachment-0001.html>
