[petsc-users] parallel matmult flop measure
Fri Aug 30 13:08:37 CDT 2013
On Aug 30, 2013, at 1:04 PM, France Boillod-Cerneux <boillod.france at gmail.com> wrote:
> Dear PETSc user,
> I am using MatMult() function in a C++ program.
> Currently, my matrix is MATMPIAIJ format type, and I load the matrix from a binary file at petsc format. let's call the matrix A:
> I know before the execution the global rows, columns and nnz.
> my program is doing something like:
  PetscLogDouble prevflops,myflops;
> global loop
>      //begin to measure flop rate
       PetscGetFlops(&prevFlops);
>      inner loop
>            MatMult(A,x,y)
>      end inner loop
       PetscGetFlops(&myflops);
       my flops -= prevFlops;   /* each MPI process has how many flops IT has done
>      //want to know Flop rate of Matmult at this point
> end global loop
> I am looking for a function to know at runtime the flop rate for each process regarding matmult function.
> I had a look at pdf of Loic Gouarin (introduction to pertsc, performance May 2013) but it does not correspond to what i want, or i missunderstood?
> My other solution is using the matmpiaijsetpreallocation and therefore know the complete parallel distribution of A, but this implies a pre-treatment on my matrix A.
> I was wondering if i can create my matrix A without knowing in advance the parallel distribution and then collect the information about parallel distribution?
> Or more easier, if a function like PetscGetFlops could solve my problem?
> so far i understood that this function measure the flop since the begining of program, but this is not what i want to use, i want to have the flop ratio right after ending the inner loop, and this, for each global iteration
> Any ideas/suggestions would help,
> Thank you very much,
> France
> Bien cordialement - Best regards - Mit freundlichen Grüßen,
> France BOILLOD-CERNEUX
> PhD Student, Laboratoire d'Informatique Fondamentale de Lille
> (LIFL), CNRS
> France.Boillod-Cerneux at cea.fr
> Tel. : +33 (0) 1 6908 - 9527
> Tel. : +33 (0) 6 4781 - 3059
> DEN/DANS/DM2S
> CEA Saclay
> 91191 Gif-sur-Yvette
> FRANCE
> http://www.lifl.fr/
> www-centre-saclay.cea.fr
