[petsc-users] Optimized run crashes on one machine but not another
Wed Aug 28 21:22:54 CDT 2013
On Wed, Aug 28, 2013 at 4:53 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Garnet Vaz <garnet.vaz at gmail.com> writes:
> > Hi Matt,
> > Within gdb how can I view an IS? I tried 'call ISView(*partition,0)'
> > following the VecView() syntax but it causes a segmentation fault
> > inside gdb.
> That'll work if you're passing an IS and it's not already corrupt.
Just to recap, I have run in both debug and optimized with complex, and
through valgrind,
and I get no problems on my machine (using downloaded MPICH).
I think we will need you to narrow it down with the debugger there.
     Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130828/977616c8/attachment.html>
