[petsc-users] Optimized run crashes on one machine but not another
Wed Aug 28 16:53:10 CDT 2013
Garnet Vaz <garnet.vaz at gmail.com> writes:
> Hi Matt,
> Within gdb how can I view an IS? I tried 'call ISView(*partition,0)'
> following the VecView() syntax but it causes a segmentation fault
> inside gdb.
That'll work if you're passing an IS and it's not already corrupt.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130828/76bbb929/attachment.pgp>
