[petsc-users] discontinuous viscosity stokes equation 3D staggered grid
Bishesh Khanal bisheshkh at gmail.com
Fri Aug 23 11:44:20 CDT 2013
On Fri, Aug 23, 2013 at 3:45 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Aug 23, 2013 at 8:42 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>> On Fri, Aug 23, 2013 at 3:34 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>> On Fri, Aug 23, 2013 at 8:30 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>>> On Fri, Aug 23, 2013 at 3:16 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>> On Fri, Aug 23, 2013 at 8:01 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>>>>> On Fri, Aug 23, 2013 at 2:53 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>>> On Fri, Aug 23, 2013 at 7:46 AM, Bishesh Khanal <bisheshkh at gmail.com
>>>>>>> > wrote:
>>>>>>>> On Fri, Aug 23, 2013 at 2:33 PM, Matthew Knepley <knepley at gmail.com
>>>>>>>> > wrote:
>>>>>>>>> On Fri, Aug 23, 2013 at 7:25 AM, Bishesh Khanal <
>>>>>>>>> bisheshkh at gmail.com> wrote:
>>>>>>>>>> On Fri, Aug 23, 2013 at 2:09 PM, Matthew Knepley <
>>>>>>>>>>> On Fri, Aug 23, 2013 at 4:31 AM, Bishesh Khanal <
>>>>>>>>>>>> Thanks Matt and Mark for comments in using near null space
>>>>>>>>>>>> [question I asked in the thread with subject: *problem
>>>>>>>>>>>> (Segmentation voilation) using -pc_type hypre -pc_hypre_type -pilut with
>>>>>>>>>>>> multiple nodes in a cluster*].
>>>>>>>>>>>> So I understood that I have to set a nearNullSpace to A00 block
>>>>>>>>>>>> where the null space correspond to the rigid body motion. I tried it but
>>>>>>>>>>>> still the gamg just keeps on iterating and convergence is very very slow. I
>>>>>>>>>>>> am not sure what the problem is, right now gamg does not even work for the
>>>>>>>>>>>> constant viscosity case.
>>>>>>>>>>>> I have set up the following in my code:
>>>>>>>>>>>> 1. null space for the whole system A 2. null space for the
>>>>>>>>>>>> Schur complement S 3. Near null space for A00 4. a user preconditioner
>>>>>>>>>>>> matrix of inverse viscosity in the diagonal for S.
>>>>>>>>>>> If you want to debug solvers, you HAVE to send -ksp_view.
>>>>>>>>>> When I use gamg, the -fieldsplit_0_ksp was iterating on and on so
>>>>>>>>>> didn't get to the end to get -ksp_view results.
>>>>>>>>>> Instead here I have put the -ksp_view output when running the
>>>>>>>>>> program with following options: (In this case I get the results)
>>>>>>>>>> -pc_type fieldsplit -pc_fieldsplit_type schur
>>>>>>>>>> -pc_fieldsplit_dm_splits 0 -pc_fieldsplit_0_fields 0,1,2
>>>>>>>>>> -pc_fieldsplit_1_fields 3 -ksp_converged_reason -ksp_view
>>>>>>>>> Okay, that looks fine. Does
>>>>>>>>>   -fieldsplit_0_pc_type lu
>>>>>>>>>   - fieldsplit_1_ksp_rtol 1.0e-10
>>>>>>>>> converge in one Iterate?
>>>>>>>>> What matrix did you attach as the preconditioner matrix for
>>>>>>>>> fieldsplit_1_?
>>>>>>>> I used a diagonal matrix with reciprocal of viscosity values of the
>>>>>>>> corresponding cell centers as the preconditioner.
>>>>>>>> with the options  -fieldsplit_0_pc_type lu  - fieldsplit_1_ksp_rtol
>>>>>>>> 1.0e-10 -fieldsplit_1_ksp_converged_reason -ksp_converged_reason
>>>>>>>> I get the following output which means the outer ksp did converge
>>>>>>>> in one iterate I guess.
>>>>>>>>   Linear solve converged due to CONVERGED_RTOL iterations 18
>>>>>>> Okay, so A_00 is nonsingular, and the system seems to solve alright.
>>>>>>> What do you get for
>>>>>>>   -fieldsplit_0_ksp_max_it 30
>>>>>>>   -fieldsplit_0_pc_type gamg
>>>>>>>   -fieldsplit_0_ksp_converged_reason
>>>>>> It fieldsplit_0_ does not converge in 30 iterations. It gives:
>>>>>>  Linear solve converged due to CONVERGED_ATOL iterations 0
>>>>>> Linear solve did not converge due to DIVERGED_ITS iterations 30
>>>>>> and continues with the same message.
>>>>> So what would you do? Give up?
>>>>> No, I don't want to give up :)
>>>>>   -fieldsplit_0_ksp_gmres_restart 200
>>>>> The idea is to figure out what is going on:
>>>>>   -fieldsplit_0_ksp_monitor_true_residual
>>>>> I have tried these options before too, the residual is decreasing very
>>>> very slowly,  but I've not been able to figure out why. (using hypre does
>>>> converge although slowly again, but I had problems using hypre with
>>>> multiple nodes in a cluster with segmentation fault (we discussed that in
>>>> another thread!) )
>>> Put in the Laplacian instead of the operator you have now. It should
>>> converge in a few iterates. If not, you have a problem
>>> in the specification.
>>> If so, put in linear elasticity. If it is slow, you have made a mistake
>>> specifiying the near null space. Also, you need to check
>>> that the near null space made it to GAMG using the ksp_view output.
>> Which operator are you referring to ? The one in A00 block ? I'm testing
>> currently with the constant viscosity case which means the A00 block has
>> \mu div(grad(v)) which is a Laplacian.
>> And Is it possible to view the ksp_view output before the solver actually
>> converges to check if GAMG took the near null space ?
> 1) Make mu 1.0
> 2) The nullspace does not matter at all for the Laplacian, so turn it off
If it does not take < 5 iterations, that is not the Laplacian.
When making mu 1.0, the number of iterations for fieldsplit_0_ depended on
the scaling of the constant (K) I use for 0 dirichlet boundary condition on
velocity. Since I'm using a staggered grid, the rows corresponding to
Dirichlet boundary on velocity have either one element K at the diagonal or
two elements 3K and -K depending on whether v-component lies exactly on the
boundary face or interior to it. E.g. for x=0 face, boundary conditions:
K*vx(0,j,k) = 0;       3K*vy(0,j,k) - K*vy(1,j,k) = 0;
After playing around a bit, I could find a suitable K that would get me the
fieldsplit_0_ to converge in about 10 iterations. But values of K would
dramatically increase the number of iterations.
And I also checked the -fieldsplit_0_ksp_view as Dave and you suggested,
and I did not see anywhere the information if it got the nearnullspace or
not. I searched for "null" in the attached file of -fieldsplit_0_ksp_view
for that.
I don't know why it does not take the near-null space!
> There are plenty of FD Laplacians in PETSc, like SNES ex5, that you can
> run GAMG on to test. You should consider getting an exact solution and
> testing with that as well, since it appears your operator is
> not what you think it is.
>    Matt
>>>    Matt
>>>> e.g a snapshot of the output:
>>>>     Residual norms for fieldsplit_0_ solve.
>>>>     0 KSP preconditioned resid norm 0.000000000000e+00 true resid norm
>>>> 0.000000000000e+00 ||r(i)||/||b||           -nan
>>>>     0 KSP preconditioned resid norm 2.619231455875e-01 true resid norm
>>>> 3.637306695895e+02 ||r(i)||/||b|| 1.000000000000e+00
>>>>     1 KSP preconditioned resid norm 9.351491725479e-02 true resid norm
>>>> 6.013334574957e+01 ||r(i)||/||b|| 1.653238255038e-01
>>>>     2 KSP preconditioned resid norm 6.010357491087e-02 true resid norm
>>>> 3.664473273769e+01 ||r(i)||/||b|| 1.007468871928e-01
>>>>     3 KSP preconditioned resid norm 6.006968012944e-02 true resid norm
>>>> 3.696451770148e+01 ||r(i)||/||b|| 1.016260678353e-01
>>>>     4 KSP preconditioned resid norm 4.418407037098e-02 true resid norm
>>>> 3.184810838034e+01 ||r(i)||/||b|| 8.755959022176e-02
>>>>   93 KSP preconditioned resid norm 4.549506047737e-04 true resid norm
>>>> 2.877594552685e+00 ||r(i)||/||b|| 7.911333283864e-03
>>>>    94 KSP preconditioned resid norm 4.515424416235e-04 true resid norm
>>>> 2.875249044668e+00 ||r(i)||/||b|| 7.904884809172e-03
>>>>    95 KSP preconditioned resid norm 4.277647876573e-04 true resid norm
>>>> 2.830418831358e+00 ||r(i)||/||b|| 7.781633686685e-03
>>>>    96 KSP preconditioned resid norm 4.244529173876e-04 true resid norm
>>>> 2.807041401408e+00 ||r(i)||/||b|| 7.717362422521e-03
>>>>    97 KSP preconditioned resid norm 4.138326570674e-04 true resid norm
>>>> 2.793663020386e+00 ||r(i)||/||b|| 7.680581413547e-03
>>>>    98 KSP preconditioned resid norm 3.869979433609e-04 true resid norm
>>>> 2.715150386650e+00 ||r(i)||/||b|| 7.464727650583e-03
>>>>    99 KSP preconditioned resid norm 3.847873979265e-04 true resid norm
>>>> 2.706008990336e+00 ||r(i)||/||b|| 7.439595328571e-03
>>>>   294 KSP preconditioned resid norm 1.416482289961e-04 true resid norm
>>>> 2.735750748819e+00 ||r(i)||/||b|| 7.521363958412e-03
>>>>   295 KSP preconditioned resid norm 1.415389087364e-04 true resid norm
>>>> 2.742638608355e+00 ||r(i)||/||b|| 7.540300661064e-03
>>>>   296 KSP preconditioned resid norm 1.414967651105e-04 true resid norm
>>>> 2.747224243968e+00 ||r(i)||/||b|| 7.552907889424e-03
>>>>   297 KSP preconditioned resid norm 1.413843018303e-04 true resid norm
>>>> 2.752574248710e+00 ||r(i)||/||b|| 7.567616587891e-03
>>>>   298 KSP preconditioned resid norm 1.411747949695e-04 true resid norm
>>>> 2.765459647367e+00 ||r(i)||/||b|| 7.603042246859e-03
>>>>   299 KSP preconditioned resid norm 1.411609742082e-04 true resid norm
>>>> 2.765900464868e+00 ||r(i)||/||b|| 7.604254180683e-03
>>>>   300 KSP preconditioned resid norm 1.409844332838e-04 true resid norm
>>>> 2.771790506811e+00 ||r(i)||/||b|| 7.620447596402e-03
>>>>   Linear solve did not converge due to DIVERGED_ITS iterations 300
>>>>     0 KSP preconditioned resid norm 1.294272083271e-03 true resid norm
>>>> 1.776945075651e+00 ||r(i)||/||b|| 1.000000000000e+00
>>>>>      Matt
>>>>>>> This is the kind of investigation you msut be comfortable with if
>>>>>>> you want to experiment with these solvers.
>>>>>>>     Matt
>>>>>>>>>   Thanks,
>>>>>>>>>      Matt
>>>>>>>>>> Linear solve converged due to CONVERGED_RTOL iterations 2
>>>>>>>>>> KSP Object: 1 MPI processes
>>>>>>>>>>   type: gmres
>>>>>>>>>>     GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
>>>>>>>>>> Orthogonalization with no iterative refinement
>>>>>>>>>>     GMRES: happy breakdown tolerance 1e-30
>>>>>>>>>>   maximum iterations=10000, initial guess is zero
>>>>>>>>>>   tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>>>>>>>>>>   left preconditioning
>>>>>>>>>>   has attached null space
>>>>>>>>>>   using PRECONDITIONED norm type for convergence test
>>>>>>>>>> PC Object: 1 MPI processes
>>>>>>>>>>   type: fieldsplit
>>>>>>>>>>     FieldSplit with Schur preconditioner, blocksize = 4,
>>>>>>>>>> factorization FULL
>>>>>>>>>>     Preconditioner for the Schur complement formed from user
>>>>>>>>>> provided matrix
>>>>>>>>>>     Split info:
>>>>>>>>>>     Split number 0 Fields  0, 1, 2
>>>>>>>>>>     Split number 1 Fields  3
>>>>>>>>>>     KSP solver for A00 block
>>>>>>>>>>       KSP Object:      (fieldsplit_0_)       1 MPI processes
>>>>>>>>>>         type: gmres
>>>>>>>>>> Gram-Schmidt Orthogonalization with no iterative refinement
>>>>>>>>>> divergence=10000
>>>>>>>>>>       PC Object:      (fieldsplit_0_)       1 MPI processes
>>>>>>>>>>         type: ilu
>>>>>>>>>>           ILU: out-of-place factorization
>>>>>>>>>>           0 levels of fill
>>>>>>>>>>           tolerance for zero pivot 2.22045e-14
>>>>>>>>>>           using diagonal shift on blocks to prevent zero pivot
>>>>>>>>>>           matrix ordering: natural
>>>>>>>>>>           factor fill ratio given 1, needed 1
>>>>>>>>>>             Factored matrix follows:
>>>>>>>>>>               Matrix Object:               1 MPI processes
>>>>>>>>>>                 type: seqaij
>>>>>>>>>>                 rows=8232, cols=8232
>>>>>>>>>>                 package used to perform factorization: petsc
>>>>>>>>>>                 total: nonzeros=576000, allocated nonzeros=576000
>>>>>>>>>>                 total number of mallocs used during MatSetValues
>>>>>>>>>> calls =0
>>>>>>>>>>                   using I-node routines: found 2744 nodes, limit
>>>>>>>>>> used is 5
>>>>>>>>>>         linear system matrix = precond matrix:
>>>>>>>>>>           type: seqaij
>>>>>>>>>>           total number of mallocs used during MatSetValues calls
>>>>>>>>>> =0
>>>>>>>>>>             using I-node routines: found 2744 nodes, limit used
>>>>>>>>>> is 5
>>>>>>>>>>     KSP solver for S = A11 - A10 inv(A00) A01
>>>>>>>>>>       KSP Object:      (fieldsplit_1_)       1 MPI processes
>>>>>>>>>>         type: gmres
>>>>>>>>>> divergence=10000
>>>>>>>>>>       PC Object:      (fieldsplit_1_)       1 MPI processes
>>>>>>>>>>         type: ilu
>>>>>>>>>>           0 levels of fill
>>>>>>>>>>                 type: seqaij
>>>>>>>>>>                 rows=2744, cols=2744
>>>>>>>>>>                 total: nonzeros=64000, allocated nonzeros=64000
>>>>>>>>>> calls =0
>>>>>>>>>>                   not using I-node routines
>>>>>>>>>>         linear system matrix followed by preconditioner matrix:
>>>>>>>>>>           type: schurcomplement
>>>>>>>>>>             Schur complement A11 - A10 inv(A00) A01
>>>>>>>>>>             A11
>>>>>>>>>>                 type: seqaij
>>>>>>>>>> calls =0
>>>>>>>>>>             A10
>>>>>>>>>>                 type: seqaij
>>>>>>>>>>                 rows=2744, cols=8232
>>>>>>>>>>                 total: nonzeros=192000, allocated nonzeros=192000
>>>>>>>>>> calls =0
>>>>>>>>>>             KSP of A00
>>>>>>>>>>               KSP Object:
>>>>>>>>>>                 type: gmres
>>>>>>>>>> divergence=10000
>>>>>>>>>> test
>>>>>>>>>>               PC Object:
>>>>>>>>>>                 type: ilu
>>>>>>>>>>                   0 levels of fill
>>>>>>>>>> pivot
>>>>>>>>>> processes
>>>>>>>>>>                         type: seqaij
>>>>>>>>>> petsc
>>>>>>>>>> nonzeros=576000
>>>>>>>>>> MatSetValues calls =0
>>>>>>>>>> nodes, limit used is 5
>>>>>>>>>>                   type: seqaij
>>>>>>>>>> nonzeros=576000
>>>>>>>>>> limit used is 5
>>>>>>>>>>             A01
>>>>>>>>>>                 type: seqaij
>>>>>>>>>>                 rows=8232, cols=2744
>>>>>>>>>> calls =0
>>>>>>>>>> used is 5
>>>>>>>>>>           type: seqaij
>>>>>>>>>> =0
>>>>>>>>>>     type: seqaij
>>>>>>>>>>     rows=10976, cols=10976, bs=4
>>>>>>>>>>     total: nonzeros=1024000, allocated nonzeros=1024000
>>>>>>>>>>     total number of mallocs used during MatSetValues calls =0
>>>>>>>>>>       using I-node routines: found 2744 nodes, limit used is 5
>>>>>>>>>>>    Matt
>>>>>>>>>>>> I am testing a small problem with CONSTANT viscosity for grid
>>>>>>>>>>>> size of 14^3 with the run time option:
>>>>>>>>>>>> -ksp_type gcr -pc_type fieldsplit -pc_fieldsplit_type schur
>>>>>>>>>>>> -fieldsplit_0_ksp_type gcr -fieldsplit_0_pc_type gamg
>>>>>>>>>>>> -fieldsplit_0_ksp_monitor_true_residual -fieldsplit_0_ksp_converged_reason
>>>>>>>>>>>> -fieldsplit_1_ksp_monitor_true_residual
>>>>>>>>>>>> Here is my relevant code of the solve function:
>>>>>>>>>>>> PetscErrorCode ierr;
>>>>>>>>>>>>     PetscFunctionBeginUser;
>>>>>>>>>>>>     ierr =
>>>>>>>>>>>> DMKSPSetComputeRHS(mDa,computeRHSTaras3D,this);CHKERRQ(ierr);
>>>>>>>>>>>>     ierr =
>>>>>>>>>>>> DMKSPSetComputeOperators(mDa,computeMatrixTaras3D,this);CHKERRQ(ierr);
>>>>>>>>>>>>     ierr = KSPSetDM(mKsp,mDa);CHKERRQ(ierr);              //mDa
>>>>>>>>>>>> with dof = 4, vx,vy,vz and p.
>>>>>>>>>>>>     ierr =
>>>>>>>>>>>> KSPSetNullSpace(mKsp,mNullSpace);CHKERRQ(ierr);//nullSpace for the main
>>>>>>>>>>>> system
>>>>>>>>>>>>     ierr = KSPSetFromOptions(mKsp);CHKERRQ(ierr);
>>>>>>>>>>>>     ierr = KSPSetUp(mKsp);CHKERRQ(ierr);
>>>>>>>>>>>> //register the fieldsplits obtained from options.
>>>>>>>>>>>>     //Setting up user PC for Schur Complement
>>>>>>>>>>>>     ierr = KSPGetPC(mKsp,&mPc);CHKERRQ(ierr);
>>>>>>>>>>>>     ierr =
>>>>>>>>>>>> PCFieldSplitSchurPrecondition(mPc,PC_FIELDSPLIT_SCHUR_PRE_USER,mPcForSc);CHKERRQ(ierr);
>>>>>>>>>>>>     KSP *subKsp;
>>>>>>>>>>>>     PetscInt subKspPos = 0;
>>>>>>>>>>>>     //Set up nearNullspace for A00 block.
>>>>>>>>>>>>     ierr =
>>>>>>>>>>>> PCFieldSplitGetSubKSP(mPc,&subKspPos,&subKsp);CHKERRQ(ierr);
>>>>>>>>>>>>     MatNullSpace rigidBodyModes;
>>>>>>>>>>>>     Vec coords;
>>>>>>>>>>>>     ierr = DMGetCoordinates(mDa,&coords);CHKERRQ(ierr);
>>>>>>>>>>>>     ierr =
>>>>>>>>>>>> MatNullSpaceCreateRigidBody(coords,&rigidBodyModes);CHKERRQ(ierr);
>>>>>>>>>>>>     Mat matA00;
>>>>>>>>>>>>     ierr =
>>>>>>>>>>>> KSPGetOperators(subKsp[0],&matA00,NULL,NULL);CHKERRQ(ierr);
>>>>>>>>>>>>     ierr =
>>>>>>>>>>>> MatSetNearNullSpace(matA00,rigidBodyModes);CHKERRQ(ierr);
>>>>>>>>>>>>     ierr = MatNullSpaceDestroy(&rigidBodyModes);CHKERRQ(ierr);
>>>>>>>>>>>>     //Position 1 => Ksp corresponding to Schur complement S on
>>>>>>>>>>>> pressure space
>>>>>>>>>>>>     subKspPos = 1;
>>>>>>>>>>>>     ierr =
>>>>>>>>>>>>     //Set up the null space of constant pressure.
>>>>>>>>>>>>     ierr = KSPSetNullSpace(subKsp[1],mNullSpaceP);CHKERRQ(ierr);
>>>>>>>>>>>>     PetscBool isNull;
>>>>>>>>>>>>     Mat matSc;
>>>>>>>>>>>>     ierr =
>>>>>>>>>>>> KSPGetOperators(subKsp[1],&matSc,NULL,NULL);CHKERRQ(ierr);
>>>>>>>>>>>>     ierr = MatNullSpaceTest(mNullSpaceP,matSc,&isNull);
>>>>>>>>>>>>     if(!isNull)
>>>>>>>>>>>>         SETERRQ(PETSC_COMM_WORLD,PETSC_ERR_PLIB,"not a valid
>>>>>>>>>>>> pressure null space \n");
>>>>>>>>>>>>     ierr = KSPGetOperators(mKsp,&mA,NULL,NULL);CHKERRQ(ierr);
>>>>>>>>>>>>     ierr =
>>>>>>>>>>>> MatNullSpaceTest(mNullSpace,mA,&isNull);CHKERRQ(ierr);
>>>>>>>>>>>>     if(!isNull)
>>>>>>>>>>>> system null space \n");
>>>>>>>>>>>>     ierr = PetscFree(subKsp);CHKERRQ(ierr);
>>>>>>>>>>>>     ierr = KSPSolve(mKsp,NULL,NULL);CHKERRQ(ierr);
>>>>>>>>>>>>     ierr = KSPGetSolution(mKsp,&mX);CHKERRQ(ierr);
>>>>>>>>>>>>     ierr = KSPGetRhs(mKsp,&mB);CHKERRQ(ierr);
>>>>>>>>>>>>     PetscFunctionReturn(0);
>>>>>>>>>>>> On Wed, Aug 7, 2013 at 2:15 PM, Matthew Knepley <
>>>>>>>>>>>>> On Wed, Aug 7, 2013 at 7:07 AM, Bishesh Khanal <
>>>>>>>>>>>>>> On Tue, Aug 6, 2013 at 11:34 PM, Matthew Knepley <
>>>>>>>>>>>>>>> On Tue, Aug 6, 2013 at 10:59 AM, Bishesh Khanal <
>>>>>>>>>>>>>>>> On Tue, Aug 6, 2013 at 4:40 PM, Matthew Knepley <
>>>>>>>>>>>>>>>>> On Tue, Aug 6, 2013 at 8:06 AM, Bishesh Khanal <
>>>>>>>>>>>>>>>>>> On Mon, Aug 5, 2013 at 4:14 PM, Matthew Knepley <
>>>>>>>>>>>>>>>>>>> On Mon, Aug 5, 2013 at 8:48 AM, Bishesh Khanal <
>>>>>>>>>>>>>>>>>>>> On Mon, Aug 5, 2013 at 3:17 PM, Matthew Knepley <
>>>>>>>>>>>>>>>>>>>>> On Mon, Aug 5, 2013 at 7:54 AM, Bishesh Khanal <
>>>>>>>>>>>>>>>>>>>>>> On Wed, Jul 17, 2013 at 9:48 PM, Jed Brown <
>>>>>>>>>>>>>>>>>>>>>> jedbrown at mcs.anl.gov> wrote:
>>>>>>>>>>>>>>>>>>>>>>> Bishesh Khanal <bisheshkh at gmail.com> writes:
>>>>>>>>>>>>>>>>>>>>>>> > Now, I implemented two different approaches, each
>>>>>>>>>>>>>>>>>>>>>>> for both 2D and 3D, in
>>>>>>>>>>>>>>>>>>>>>>> > MATLAB. It works for the smaller sizes but I have
>>>>>>>>>>>>>>>>>>>>>>> problems solving it for
>>>>>>>>>>>>>>>>>>>>>>> > the problem size I need (250^3 grid size).
>>>>>>>>>>>>>>>>>>>>>>> > I use staggered grid with p on cell centers, and
>>>>>>>>>>>>>>>>>>>>>>> components of v on cell
>>>>>>>>>>>>>>>>>>>>>>> > faces. Similar split up of K to cell center and
>>>>>>>>>>>>>>>>>>>>>>> faces to account for the
>>>>>>>>>>>>>>>>>>>>>>> > variable viscosity case)
>>>>>>>>>>>>>>>>>>>>>>> Okay, you're using a staggered-grid finite
>>>>>>>>>>>>>>>>>>>>>>> difference discretization of
>>>>>>>>>>>>>>>>>>>>>>> variable-viscosity Stokes.  This is a common problem
>>>>>>>>>>>>>>>>>>>>>>> and I recommend
>>>>>>>>>>>>>>>>>>>>>>> starting with PCFieldSplit with Schur complement
>>>>>>>>>>>>>>>>>>>>>>> reduction (make that
>>>>>>>>>>>>>>>>>>>>>>> work first, then switch to block preconditioner).
>>>>>>>>>>>>>>>>>>>>>>>  You can use PCLSC or
>>>>>>>>>>>>>>>>>>>>>>> (probably better for you), assemble a
>>>>>>>>>>>>>>>>>>>>>>> preconditioning matrix containing
>>>>>>>>>>>>>>>>>>>>>>> the inverse viscosity in the pressure-pressure
>>>>>>>>>>>>>>>>>>>>>>> block.  This diagonal
>>>>>>>>>>>>>>>>>>>>>>> matrix is a spectrally equivalent (or nearly so,
>>>>>>>>>>>>>>>>>>>>>>> depending on
>>>>>>>>>>>>>>>>>>>>>>> discretization) approximation of the Schur
>>>>>>>>>>>>>>>>>>>>>>> complement.  The velocity
>>>>>>>>>>>>>>>>>>>>>>> block can be solved with algebraic multigrid.  Read
>>>>>>>>>>>>>>>>>>>>>>> the PCFieldSplit
>>>>>>>>>>>>>>>>>>>>>>> docs (follow papers as appropriate) and let us know
>>>>>>>>>>>>>>>>>>>>>>> if you get stuck.
>>>>>>>>>>>>>>>>>>>>>> I was trying to assemble the inverse viscosity
>>>>>>>>>>>>>>>>>>>>>> diagonal matrix to use as the preconditioner for the Schur complement solve
>>>>>>>>>>>>>>>>>>>>>> step as you suggested. I've few questions about the ways to implement this
>>>>>>>>>>>>>>>>>>>>>> in Petsc:
>>>>>>>>>>>>>>>>>>>>>> A naive approach that I can think of would be to
>>>>>>>>>>>>>>>>>>>>>> create a vector with its components as reciprocal viscosities of the cell
>>>>>>>>>>>>>>>>>>>>>> centers corresponding to the pressure variables, and then create a diagonal
>>>>>>>>>>>>>>>>>>>>>> matrix from this vector. However I'm not sure about:
>>>>>>>>>>>>>>>>>>>>>> How can I make this matrix, (say S_p) compatible to
>>>>>>>>>>>>>>>>>>>>>> the Petsc distribution of the different rows of the main system matrix over
>>>>>>>>>>>>>>>>>>>>>> different processors ? The main matrix was created using the DMDA structure
>>>>>>>>>>>>>>>>>>>>>> with 4 dof as explained before.
>>>>>>>>>>>>>>>>>>>>>> The main matrix correspond to the DMDA with 4 dofs
>>>>>>>>>>>>>>>>>>>>>> but for the S_p matrix would correspond to only pressure space. Should the
>>>>>>>>>>>>>>>>>>>>>> distribution of the rows of S_p among different processor not correspond to
>>>>>>>>>>>>>>>>>>>>>> the distribution of the rhs vector, say h' if it is solving for p with Sp =
>>>>>>>>>>>>>>>>>>>>>> h' where S = A11 inv(A00) A01 ?
>>>>>>>>>>>>>>>>>>>>> PETSc distributed vertices, not dofs, so it never
>>>>>>>>>>>>>>>>>>>>> breaks blocks. The P distribution is the same as the entire problem divided
>>>>>>>>>>>>>>>>>>>>> by 4.
>>>>>>>>>>>>>>>>>>>> Thanks Matt. So if I create a new DMDA with same grid
>>>>>>>>>>>>>>>>>>>> size but with dof=1 instead of 4, the vertices for this new DMDA will be
>>>>>>>>>>>>>>>>>>>> identically distributed as for the original DMDA ? Or should I inform PETSc
>>>>>>>>>>>>>>>>>>>> by calling a particular function to make these two DMDA have identical
>>>>>>>>>>>>>>>>>>>> distribution of the vertices ?
>>>>>>>>>>>>>>>>>>> Yes.
>>>>>>>>>>>>>>>>>>>>  Even then I think there might be a problem due to the
>>>>>>>>>>>>>>>>>>>> presence of "fictitious pressure vertices". The system matrix (A) contains
>>>>>>>>>>>>>>>>>>>> an identity corresponding to these fictitious pressure nodes, thus when
>>>>>>>>>>>>>>>>>>>> using a -pc_fieldsplit_detect_saddle_point, will detect a A11 zero block of
>>>>>>>>>>>>>>>>>>>> size that correspond to only non-fictitious P-nodes. So the preconditioner
>>>>>>>>>>>>>>>>>>>> S_p for the Schur complement outer solve with Sp = h' will also need to
>>>>>>>>>>>>>>>>>>>> correspond to only the non-fictitious P-nodes. This means its size does not
>>>>>>>>>>>>>>>>>>>> directly correspond to the DMDA grid defined for the original problem.
>>>>>>>>>>>>>>>>>>>> Could you please suggest an efficient way of assembling this S_p matrix ?
>>>>>>>>>>>>>>>>>>> Don't use detect_saddle, but split it by fields
>>>>>>>>>>>>>>>>>>> -pc_fieldsplit_0_fields 0,1,2 -pc_fieldsplit_1_fields 4
>>>>>>>>>>>>>>>>>> How can I set this split in the code itself without
>>>>>>>>>>>>>>>>>> giving it as a command line option when the system matrix is assembled from
>>>>>>>>>>>>>>>>>> the DMDA for the whole system with 4 dofs. (i.e. *without
>>>>>>>>>>>>>>>>>> * using the DMComposite or *without* using the nested
>>>>>>>>>>>>>>>>>> block matrices to assemble different blocks separately and then combine
>>>>>>>>>>>>>>>>>> them together).
>>>>>>>>>>>>>>>>>> I need the split to get access to the fieldsplit_1_ksp in
>>>>>>>>>>>>>>>>>> my code, because not using detect_saddle_point means I cannot use
>>>>>>>>>>>>>>>>>> -fieldsplit_1_ksp_constant_null_space due to the presence of identity for
>>>>>>>>>>>>>>>>>> the fictitious pressure nodes present in the fieldsplit_1_ block. I need to
>>>>>>>>>>>>>>>>>> use PCFieldSplitGetSubKsp() so that I can set proper null-space basis.
>>>>>>>>>>>>>>>>> This is currently a real problem with the DMDA. In the
>>>>>>>>>>>>>>>>> unstructured case, where we always need specialized spaces, you can
>>>>>>>>>>>>>>>>> use something like
>>>>>>>>>>>>>>>>>     PetscObject  pressure;
>>>>>>>>>>>>>>>>>     MatNullSpace nullSpacePres;
>>>>>>>>>>>>>>>>>     ierr = DMGetField(dm, 1, &pressure);CHKERRQ(ierr);
>>>>>>>>>>>>>>>>>     ierr = MatNullSpaceCreate(PetscObjectComm(pressure),
>>>>>>>>>>>>>>>>> PETSC_TRUE, 0, NULL, &nullSpacePres);CHKERRQ(ierr);
>>>>>>>>>>>>>>>>>     ierr = PetscObjectCompose(pressure, "nullspace",
>>>>>>>>>>>>>>>>> (PetscObject) nullSpacePres);CHKERRQ(ierr);
>>>>>>>>>>>>>>>>>     ierr =
>>>>>>>>>>>>>>>>> MatNullSpaceDestroy(&nullSpacePres);CHKERRQ(ierr);
>>>>>>>>>>>>>>>>> and then DMGetSubDM() uses this information to attach the
>>>>>>>>>>>>>>>>> null space to the IS that is created using the information in the
>>>>>>>>>>>>>>>>> PetscSection.
>>>>>>>>>>>>>>>>> If you use a PetscSection to set the data layout over the
>>>>>>>>>>>>>>>>> DMDA, I think this works correctly, but this has not been tested at all and
>>>>>>>>>>>>>>>>> is very
>>>>>>>>>>>>>>>>> new code. Eventually, I think we want all DMs to use this
>>>>>>>>>>>>>>>>> mechanism, but we are still working it out.
>>>>>>>>>>>>>>>> Currently I do not use PetscSection. If this makes a
>>>>>>>>>>>>>>>> cleaner approach, I'd try it too but may a bit later (right now I'd like
>>>>>>>>>>>>>>>> test my model with a quickfix even if it means a little dirty code!)
>>>>>>>>>>>>>>>>> Bottom line: For custom null spaces using the default
>>>>>>>>>>>>>>>>> layout in DMDA, you need to take apart the PCFIELDSPLIT after it has been
>>>>>>>>>>>>>>>>> setup,
>>>>>>>>>>>>>>>>> which is somewhat subtle. You need to call KSPSetUp() and
>>>>>>>>>>>>>>>>> then reach in and get the PC, and the subKSPs. I don't like this at all,
>>>>>>>>>>>>>>>>> but we
>>>>>>>>>>>>>>>>> have not reorganized that code (which could be very simple
>>>>>>>>>>>>>>>>> and inflexible since its very structured).
>>>>>>>>>>>>>>>> So I tried to get this approach working but I could not
>>>>>>>>>>>>>>>> succeed and encountered some errors. Here is a code snippet:
>>>>>>>>>>>>>>>> //mDa is the DMDA that describes the whole grid with all 4
>>>>>>>>>>>>>>>> dofs (3 velocity components and 1 pressure comp.)
>>>>>>>>>>>>>>>> ierr =
>>>>>>>>>>>>>>>>     ierr =
>>>>>>>>>>>>>>>>     ierr =
>>>>>>>>>>>>>>>> KSPSetNullSpace(mKsp,mNullSpaceSystem);CHKERRQ(ierr);   //I've the
>>>>>>>>>>>>>>>> mNullSpaceSystem based on mDa, that contains a null space basis for the
>>>>>>>>>>>>>>>> complete system.
>>>>>>>>>>>>>>>>     ierr =
>>>>>>>>>>>>>>>> //This I expect would register these options I give:-pc_type fieldsplit
>>>>>>>>>>>>>>>> -pc_fieldsplit_type schur -pc_fieldsplit_0_fields 0,1,2
>>>>>>>>>>>>>>>> //-pc_fieldsplit_1_fields 3
>>>>>>>>>>>>>>>>     ierr = KSPGetPC(mKsp,&mPcOuter);     //Now get the PC
>>>>>>>>>>>>>>>> that was obtained from the options (fieldsplit)
>>>>>>>>>>>>>>>>     ierr =
>>>>>>>>>>>>>>>> PCFieldSplitSchurPrecondition(mPcOuter,PC_FIELDSPLIT_SCHUR_PRE_USER,mPcForSc);CHKERRQ(ierr);
>>>>>>>>>>>>>>>> //I have created the matrix mPcForSc using a DMDA with identical //size to
>>>>>>>>>>>>>>>> mDa but with dof=1 corresponding to the pressure nodes (say mDaPressure).
>>>>>>>>>>>>>>>>   ierr = PCSetUp(mPcOuter);CHKERRQ(ierr);
>>>>>>>>>>>>>>>>     KSP *kspSchur;
>>>>>>>>>>>>>>>>     PetscInt kspSchurPos = 1;
>>>>>>>>>>>>>>>>     ierr =
>>>>>>>>>>>>>>>> PCFieldSplitGetSubKSP(mPcOuter,&kspSchurPos,&kspSchur);CHKERRQ(ierr);
>>>>>>>>>>>>>>>>     ierr =
>>>>>>>>>>>>>>>> KSPSetNullSpace(kspSchur[1],mNullSpacePressure);CHKERRQ(ierr);
>>>>>>>>>>>>>>>> //The null space is the one that correspond to only pressure nodes, created
>>>>>>>>>>>>>>>> using the mDaPressure.
>>>>>>>>>>>>>>>>     ierr = PetscFree(kspSchur);CHKERRQ(ierr);
>>>>>>>>>>>>>>> Sorry, you need to return to the old DMDA behavior, so you
>>>>>>>>>>>>>>> want
>>>>>>>>>>>>>> Thanks, with this it seems I can attach the null space
>>>>>>>>>>>>>> properly, but I have a question regarding whether the Schur complement ksp
>>>>>>>>>>>>>> solver is actually using the preconditioner matrix I provide.
>>>>>>>>>>>>>> When using -ksp_view, the outer level pc object of type
>>>>>>>>>>>>>> fieldsplit does report that: "Preconditioner for the Schur complement
>>>>>>>>>>>>>> formed from user provided matrix", but in the KSP solver for Schur
>>>>>>>>>>>>>> complement S, the pc object (fieldsplit_1_) is of type ilu and doesn't say
>>>>>>>>>>>>>> that it is using the matrix I provide. Am I missing something here ?
>>>>>>>>>>>>>> Below are the relevant commented code snippet and the output
>>>>>>>>>>>>>> of the -ksp_view
>>>>>>>>>>>>>> (The options I used: -pc_type fieldsplit -pc_fieldsplit_type
>>>>>>>>>>>>>> schur -pc_fieldsplit_dm_splits 0 -pc_fieldsplit_0_fields 0,1,2
>>>>>>>>>>>>>> -pc_fieldsplit_1_fields 3 -ksp_converged_reason -ksp_view )
>>>>>>>>>>>>> If ILU does not error, it means it is using your matrix,
>>>>>>>>>>>>> because the Schur complement matrix cannot be factored, and FS says it is
>>>>>>>>>>>>> using your matrix.
>>>>>>>>>>>>>    Matt
>>>>>>>>>>>>>> Code snippet:
>>>>>>>>>>>>>> ierr =
>>>>>>>>>>>>>> KSPSetNullSpace(mKsp,mNullSpaceSystem);CHKERRQ(ierr);   //The nullspace for
>>>>>>>>>>>>>> the whole system
>>>>>>>>>>>>>>     ierr =
>>>>>>>>>>>>>> //Set up mKsp with the options provided with fieldsplit and the fields
>>>>>>>>>>>>>> associated with the two splits.
>>>>>>>>>>>>>>     ierr = KSPGetPC(mKsp,&mPcOuter);CHKERRQ(ierr);
>>>>>>>>>>>>>>                //Get the fieldsplit pc set up from the options
>>>>>>>>>>>>>>     ierr =
>>>>>>>>>>>>>> //Use mPcForSc as the preconditioner for Schur Complement
>>>>>>>>>>>>>>     KSP *kspSchur;
>>>>>>>>>>>>>>     ierr =
>>>>>>>>>>>>>>     ierr =
>>>>>>>>>>>>>> //Attach the null-space for the Schur complement ksp solver.
>>>>>>>>>>>>>> the output of the -ksp_view
>>>>>>>>>>>>>>   type: gmres
>>>>>>>>>>>>>> divergence=10000
>>>>>>>>>>>>>>   type: fieldsplit
>>>>>>>>>>>>>> factorization FULL
>>>>>>>>>>>>>> provided matrix
>>>>>>>>>>>>>>     Split info:
>>>>>>>>>>>>>>         type: gmres
>>>>>>>>>>>>>> divergence=10000
>>>>>>>>>>>>>>         type: ilu
>>>>>>>>>>>>>>           0 levels of fill
>>>>>>>>>>>>>>                 type: seqaij
>>>>>>>>>>>>>>                 rows=2187, cols=2187
>>>>>>>>>>>>>>                 total: nonzeros=140625, allocated
>>>>>>>>>>>>>> nonzeros=140625
>>>>>>>>>>>>>>                   using I-node routines: found 729 nodes,
>>>>>>>>>>>>>> limit used is 5
>>>>>>>>>>>>>>           type: seqaij
>>>>>>>>>>>>>>           total: nonzeros=140625, allocated nonzeros=140625
>>>>>>>>>>>>>> calls =0
>>>>>>>>>>>>>>             using I-node routines: found 729 nodes, limit
>>>>>>>>>>>>>> used is 5
>>>>>>>>>>>>>>         type: gmres
>>>>>>>>>>>>>> divergence=10000
>>>>>>>>>>>>>>         type: ilu
>>>>>>>>>>>>>>           0 levels of fill
>>>>>>>>>>>>>>                 type: seqaij
>>>>>>>>>>>>>>                 rows=729, cols=729
>>>>>>>>>>>>>>                 total: nonzeros=15625, allocated
>>>>>>>>>>>>>> nonzeros=15625
>>>>>>>>>>>>>> matrix:
>>>>>>>>>>>>>>           rows=729, cols=729
>>>>>>>>>>>>>>             A11
>>>>>>>>>>>>>>                 type: seqaij
>>>>>>>>>>>>>>                 rows=729, cols=729
>>>>>>>>>>>>>> nonzeros=15625
>>>>>>>>>>>>>>             A10
>>>>>>>>>>>>>>                 type: seqaij
>>>>>>>>>>>>>>                 rows=729, cols=2187
>>>>>>>>>>>>>>                 total: nonzeros=46875, allocated
>>>>>>>>>>>>>> nonzeros=46875
>>>>>>>>>>>>>>             KSP of A00
>>>>>>>>>>>>>>               KSP Object:
>>>>>>>>>>>>>>                 type: gmres
>>>>>>>>>>>>>> (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
>>>>>>>>>>>>>> zero
>>>>>>>>>>>>>> divergence=10000
>>>>>>>>>>>>>> convergence test
>>>>>>>>>>>>>>               PC Object:
>>>>>>>>>>>>>>                 type: ilu
>>>>>>>>>>>>>>                   0 levels of fill
>>>>>>>>>>>>>> zero pivot
>>>>>>>>>>>>>>                       Matrix Object:                       1
>>>>>>>>>>>>>> MPI processes
>>>>>>>>>>>>>>                         type: seqaij
>>>>>>>>>>>>>> nonzeros=140625
>>>>>>>>>>>>>>                   type: seqaij
>>>>>>>>>>>>>> nonzeros=140625
>>>>>>>>>>>>>> limit used is 5
>>>>>>>>>>>>>>             A01
>>>>>>>>>>>>>>                 type: seqaij
>>>>>>>>>>>>>>                 rows=2187, cols=729
>>>>>>>>>>>>>> nonzeros=46875
>>>>>>>>>>>>>> limit used is 5
>>>>>>>>>>>>>>           type: seqaij
>>>>>>>>>>>>>>           rows=729, cols=729
>>>>>>>>>>>>>>           total: nonzeros=15625, allocated nonzeros=15625
>>>>>>>>>>>>>> calls =0
>>>>>>>>>>>>>>     type: seqaij
>>>>>>>>>>>>>>     rows=2916, cols=2916, bs=4
>>>>>>>>>>>>>>     total: nonzeros=250000, allocated nonzeros=250000
>>>>>>>>>>>>>>       using I-node routines: found 729 nodes, limit used is 5
>>>>>>>>>>>>>>> or
>>>>>>>>>>>>>>>   PCFieldSplitSetDMSplits(pc, PETSC_FALSE)
>>>>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>>>>      Matt
>>>>>>>>>>>>>>>> The errors I get when running with options: -pc_type
>>>>>>>>>>>>>>>> fieldsplit -pc_fieldsplit_type schur -pc_fieldsplit_0_fields 0,1,2
>>>>>>>>>>>>>>>> [0]PETSC ERROR: --------------------- Error Message
>>>>>>>>>>>>>>>> [0]PETSC ERROR: No support for this operation for this
>>>>>>>>>>>>>>>> object type!
>>>>>>>>>>>>>>>> [0]PETSC ERROR: Support only implemented for 2d!
>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>> [0]PETSC ERROR: Petsc Release Version 3.4.2, Jul, 02, 2013
>>>>>>>>>>>>>>>> [0]PETSC ERROR: See docs/changes/index.html for recent
>>>>>>>>>>>>>>>> updates.
>>>>>>>>>>>>>>>> [0]PETSC ERROR: See docs/faq.html for hints about trouble
>>>>>>>>>>>>>>>> shooting.
>>>>>>>>>>>>>>>> [0]PETSC ERROR: See docs/index.html for manual pages.
>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>> [0]PETSC ERROR: src/AdLemMain on a arch-linux2-cxx-debug
>>>>>>>>>>>>>>>> named edwards by bkhanal Tue Aug  6 17:35:30 2013
>>>>>>>>>>>>>>>> [0]PETSC ERROR: Libraries linked from
>>>>>>>>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/arch-linux2-cxx-debug/lib
>>>>>>>>>>>>>>>> [0]PETSC ERROR: Configure run at Fri Jul 19 14:25:01 2013
>>>>>>>>>>>>>>>> [0]PETSC ERROR: Configure options --with-cc=gcc
>>>>>>>>>>>>>>>> --with-fc=g77 --with-cxx=g++ --download-f-blas-lapack=1 --download-mpich=1
>>>>>>>>>>>>>>>> -with-clanguage=cxx --download-hypre=1
>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>> [0]PETSC ERROR: DMCreateSubDM_DA() line 188 in
>>>>>>>>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/dm/impls/da/dacreate.c
>>>>>>>>>>>>>>>> [0]PETSC ERROR: DMCreateSubDM() line 1267 in
>>>>>>>>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/dm/interface/dm.c
>>>>>>>>>>>>>>>> [0]PETSC ERROR: PCFieldSplitSetDefaults() line 337 in
>>>>>>>>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/ksp/pc/impls/fieldsplit/fieldsplit.c
>>>>>>>>>>>>>>>> [0]PETSC ERROR: PCSetUp_FieldSplit() line 458 in
>>>>>>>>>>>>>>>> [0]PETSC ERROR: PCSetUp() line 890 in
>>>>>>>>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/ksp/pc/interface/precon.c
>>>>>>>>>>>>>>>> [0]PETSC ERROR: KSPSetUp() line 278 in
>>>>>>>>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/ksp/ksp/interface/itfunc.c
>>>>>>>>>>>>>>>> [0]PETSC ERROR: solveModel() line 181 in
>>>>>>>>>>>>>>>> "unknowndirectory/"/user/bkhanal/home/works/AdLemModel/src/PetscAdLemTaras3D.cxx
>>>>>>>>>>>>>>>> WARNING! There are options you set that were not used!
>>>>>>>>>>>>>>>> WARNING! could be spelling mistake, etc!
>>>>>>>>>>>>>>>> Option left: name:-pc_fieldsplit_1_fields value: 3
>>>>>>>>>>>>>>>>>    Matt
>>>>>>>>>>>>>>>>>>>    Matt
>>>>>>>>>>>>>>>>>>>>>    Matt
>>>>>>>>>>>>>>>>>>>>> What most experimenters take for granted before they
>>>>>>>>>>>>>>>>>>>>> begin their experiments is infinitely more interesting than any results to
>>>>>>>>>>>>>>>>>>>>> which their experiments lead.
>>>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>>> experiments lead.
>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>> experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130823/45054bc4/attachment-0001.html>
KSP Object:(fieldsplit_0_) 1 MPI processes
  type: gmres
    GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
  maximum iterations=4, initial guess is zero
PC Object:(fieldsplit_0_) 1 MPI processes
  type: gamg
    MG: type is MULTIPLICATIVE, levels=3 cycles=v
      Cycles per PCApply=1
      Using Galerkin computed coarse grid matrices
  Coarse grid solver -- level -------------------------------
    KSP Object:    (fieldsplit_0_mg_coarse_)     1 MPI processes
      type: preonly
      maximum iterations=1, initial guess is zero
      using NONE norm type for convergence test
    PC Object:    (fieldsplit_0_mg_coarse_)     1 MPI processes
      type: bjacobi
        block Jacobi: number of blocks = 1
        Local solve info for each block is in the following KSP and PC objects:
      [0] number of local blocks = 1, first local block number = 0
        [0] local block number 0
        KSP Object:        (fieldsplit_0_mg_coarse_sub_)         1 MPI processes
          type: preonly
        PC Object:        (fieldsplit_0_mg_coarse_sub_)         1 MPI processes
          type: lu
            matrix ordering: nd
            factor fill ratio given 5, needed 1
                  type: seqaij
                  rows=96, cols=96, bs=6
                  total: nonzeros=9216, allocated nonzeros=9216
                    using I-node routines: found 20 nodes, limit used is 5
            type: seqaij
        type: seqaij
  Down solver (pre-smoother) on level 1 -------------------------------
    KSP Object:    (fieldsplit_0_mg_levels_1_)     1 MPI processes
      type: chebyshev
        Chebyshev: eigenvalue estimates:  min = 3.45879, max = 72.6346
      maximum iterations=2
      using nonzero initial guess
    PC Object:    (fieldsplit_0_mg_levels_1_)     1 MPI processes
      type: jacobi
        type: seqaij
        rows=4074, cols=4074, bs=6
        total: nonzeros=2248308, allocated nonzeros=2248308
          using I-node routines: found 1348 nodes, limit used is 5
  Up solver (post-smoother) same as down solver (pre-smoother)
  Down solver (pre-smoother) on level 2 -------------------------------
    KSP Object:    (fieldsplit_0_mg_levels_2_)     1 MPI processes
      type: chebyshev
        Chebyshev: eigenvalue estimates:  min = 0.143329, max = 3.0099
    PC Object:    (fieldsplit_0_mg_levels_2_)     1 MPI processes
      type: jacobi
        type: seqaij
    type: seqaij
  type: gmres
  type: gamg
      type: preonly
      type: bjacobi
          type: preonly
          type: lu
            matrix ordering: nd
                  type: seqaij
            type: seqaij
        type: seqaij
      type: chebyshev
      type: jacobi
        type: seqaij
      type: chebyshev
      type: jacobi
        type: seqaij
    type: seqaij
  type: gmres
  type: gamg
      type: preonly
      type: bjacobi
          type: preonly
          type: lu
            matrix ordering: nd
                  type: seqaij
            type: seqaij
        type: seqaij
      type: chebyshev
      type: jacobi
        type: seqaij
      type: chebyshev
      type: jacobi
        type: seqaij
    type: seqaij
  type: gmres
  type: gamg
      type: preonly
      type: bjacobi
          type: preonly
          type: lu
            matrix ordering: nd
                  type: seqaij
            type: seqaij
        type: seqaij
      type: chebyshev
      type: jacobi
        type: seqaij
      type: chebyshev
      type: jacobi
        type: seqaij
    type: seqaij
  type: gmres
  type: gamg
      type: preonly
      type: bjacobi
          type: preonly
          type: lu
            matrix ordering: nd
                  type: seqaij
            type: seqaij
        type: seqaij
      type: chebyshev
      type: jacobi
        type: seqaij
      type: chebyshev
      type: jacobi
        type: seqaij
    type: seqaij
  type: gmres
  type: gamg
      type: preonly
      type: bjacobi
          type: preonly
          type: lu
            matrix ordering: nd
                  type: seqaij
            type: seqaij
        type: seqaij
      type: chebyshev
      type: jacobi
        type: seqaij
      type: chebyshev
      type: jacobi
        type: seqaij
    type: seqaij
  type: gmres
  type: gamg
      type: preonly
      type: bjacobi
          type: preonly
          type: lu
            matrix ordering: nd
                  type: seqaij
            type: seqaij
        type: seqaij
      type: chebyshev
      type: jacobi
        type: seqaij
      type: chebyshev
      type: jacobi
        type: seqaij
    type: seqaij
  type: gmres
  type: gamg
      type: preonly
      type: bjacobi
          type: preonly
          type: lu
            matrix ordering: nd
                  type: seqaij
            type: seqaij
        type: seqaij
      type: chebyshev
      type: jacobi
        type: seqaij
      type: chebyshev
      type: jacobi
        type: seqaij
    type: seqaij
  type: gmres
  type: gamg
      type: preonly
      type: bjacobi
          type: preonly
          type: lu
            matrix ordering: nd
                  type: seqaij
            type: seqaij
        type: seqaij
      type: chebyshev
      type: jacobi
        type: seqaij
      type: chebyshev
      type: jacobi
        type: seqaij
    type: seqaij
Linear solve did not converge due to DIVERGED_ITS iterations 1
