[petsc-users] discontinuous viscosity stokes equation 3D staggered grid
Dave May dave.mayhem23 at gmail.com
Fri Aug 23 08:47:25 CDT 2013
Yes of course. Just shut all the other sub-solvers off
As Matt says, check check check your GAMG configuration.
-ksp_max_it 1
-pc_fieldsplit_0_ksp_max_it 4
-pc_fieldsplit_1_ksp_max_it 2
-ksp_view
Or if you just want to see GAMG configuration, do this
-ksp_max_it 1
-pc_fieldsplit_0_ksp_view
For your testing, I'd use FMGRES on A00 as this give you the most
flexibility with the choice of smoother.
  -pc_fieldsplit_0_ksp_type fgmres
and then do some seriously heavy smoothing on each level to see if you can
make something converge.
By "heavy" I mean something like
  gmres(20)+ILU(0)
On 23 August 2013 15:42, Bishesh Khanal <bisheshkh at gmail.com> wrote:
> On Fri, Aug 23, 2013 at 3:34 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Fri, Aug 23, 2013 at 8:30 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>> On Fri, Aug 23, 2013 at 3:16 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>> On Fri, Aug 23, 2013 at 8:01 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>>>> On Fri, Aug 23, 2013 at 2:53 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>> On Fri, Aug 23, 2013 at 7:46 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>>>>>> On Fri, Aug 23, 2013 at 2:33 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>>>> On Fri, Aug 23, 2013 at 7:25 AM, Bishesh Khanal <
>>>>>>>>> On Fri, Aug 23, 2013 at 2:09 PM, Matthew Knepley <
>>>>>>>>> knepley at gmail.com> wrote:
>>>>>>>>>> On Fri, Aug 23, 2013 at 4:31 AM, Bishesh Khanal <
>>>>>>>>>>> Thanks Matt and Mark for comments in using near null space
>>>>>>>>>>> [question I asked in the thread with subject: *problem
>>>>>>>>>>> (Segmentation voilation) using -pc_type hypre -pc_hypre_type -pilut with
>>>>>>>>>>> multiple nodes in a cluster*].
>>>>>>>>>>> So I understood that I have to set a nearNullSpace to A00 block
>>>>>>>>>>> where the null space correspond to the rigid body motion. I tried it but
>>>>>>>>>>> still the gamg just keeps on iterating and convergence is very very slow. I
>>>>>>>>>>> am not sure what the problem is, right now gamg does not even work for the
>>>>>>>>>>> constant viscosity case.
>>>>>>>>>>> I have set up the following in my code:
>>>>>>>>>>> 1. null space for the whole system A 2. null space for the Schur
>>>>>>>>>>> complement S 3. Near null space for A00 4. a user preconditioner matrix of
>>>>>>>>>>> inverse viscosity in the diagonal for S.
>>>>>>>>>> If you want to debug solvers, you HAVE to send -ksp_view.
>>>>>>>>> When I use gamg, the -fieldsplit_0_ksp was iterating on and on so
>>>>>>>>> didn't get to the end to get -ksp_view results.
>>>>>>>>> Instead here I have put the -ksp_view output when running the
>>>>>>>>> program with following options: (In this case I get the results)
>>>>>>>>> -pc_type fieldsplit -pc_fieldsplit_type schur
>>>>>>>>> -pc_fieldsplit_dm_splits 0 -pc_fieldsplit_0_fields 0,1,2
>>>>>>>>> -pc_fieldsplit_1_fields 3 -ksp_converged_reason -ksp_view
>>>>>>>> Okay, that looks fine. Does
>>>>>>>>   -fieldsplit_0_pc_type lu
>>>>>>>>   - fieldsplit_1_ksp_rtol 1.0e-10
>>>>>>>> converge in one Iterate?
>>>>>>>> What matrix did you attach as the preconditioner matrix for
>>>>>>>> fieldsplit_1_?
>>>>>>> I used a diagonal matrix with reciprocal of viscosity values of the
>>>>>>> corresponding cell centers as the preconditioner.
>>>>>>> with the options  -fieldsplit_0_pc_type lu  - fieldsplit_1_ksp_rtol
>>>>>>> 1.0e-10 -fieldsplit_1_ksp_converged_reason -ksp_converged_reason
>>>>>>> I get the following output which means the outer ksp did converge in
>>>>>>> one iterate I guess.
>>>>>>>   Linear solve converged due to CONVERGED_RTOL iterations 18
>>>>>> Okay, so A_00 is nonsingular, and the system seems to solve alright.
>>>>>> What do you get for
>>>>>>   -fieldsplit_0_ksp_max_it 30
>>>>>>   -fieldsplit_0_pc_type gamg
>>>>>>   -fieldsplit_0_ksp_converged_reason
>>>>> It fieldsplit_0_ does not converge in 30 iterations. It gives:
>>>>>  Linear solve converged due to CONVERGED_ATOL iterations 0
>>>>> Linear solve did not converge due to DIVERGED_ITS iterations 30
>>>>> and continues with the same message.
>>>> So what would you do? Give up?
>>>> No, I don't want to give up :)
>>>>   -fieldsplit_0_ksp_gmres_restart 200
>>>> The idea is to figure out what is going on:
>>>>   -fieldsplit_0_ksp_monitor_true_residual
>>>> I have tried these options before too, the residual is decreasing very
>>> very slowly,  but I've not been able to figure out why. (using hypre does
>>> converge although slowly again, but I had problems using hypre with
>>> multiple nodes in a cluster with segmentation fault (we discussed that in
>>> another thread!) )
>> Put in the Laplacian instead of the operator you have now. It should
>> converge in a few iterates. If not, you have a problem
>> in the specification.
>> If so, put in linear elasticity. If it is slow, you have made a mistake
>> specifiying the near null space. Also, you need to check
>> that the near null space made it to GAMG using the ksp_view output.
> Which operator are you referring to ? The one in A00 block ? I'm testing
> currently with the constant viscosity case which means the A00 block has
> \mu div(grad(v)) which is a Laplacian.
> And Is it possible to view the ksp_view output before the solver actually
> converges to check if GAMG took the near null space ?
>>    Matt
>>> e.g a snapshot of the output:
>>>     Residual norms for fieldsplit_0_ solve.
>>>     0 KSP preconditioned resid norm 0.000000000000e+00 true resid norm
>>> 0.000000000000e+00 ||r(i)||/||b||           -nan
>>>     0 KSP preconditioned resid norm 2.619231455875e-01 true resid norm
>>> 3.637306695895e+02 ||r(i)||/||b|| 1.000000000000e+00
>>>     1 KSP preconditioned resid norm 9.351491725479e-02 true resid norm
>>> 6.013334574957e+01 ||r(i)||/||b|| 1.653238255038e-01
>>>     2 KSP preconditioned resid norm 6.010357491087e-02 true resid norm
>>> 3.664473273769e+01 ||r(i)||/||b|| 1.007468871928e-01
>>>     3 KSP preconditioned resid norm 6.006968012944e-02 true resid norm
>>> 3.696451770148e+01 ||r(i)||/||b|| 1.016260678353e-01
>>>     4 KSP preconditioned resid norm 4.418407037098e-02 true resid norm
>>> 3.184810838034e+01 ||r(i)||/||b|| 8.755959022176e-02
>>>   93 KSP preconditioned resid norm 4.549506047737e-04 true resid norm
>>> 2.877594552685e+00 ||r(i)||/||b|| 7.911333283864e-03
>>>    94 KSP preconditioned resid norm 4.515424416235e-04 true resid norm
>>> 2.875249044668e+00 ||r(i)||/||b|| 7.904884809172e-03
>>>    95 KSP preconditioned resid norm 4.277647876573e-04 true resid norm
>>> 2.830418831358e+00 ||r(i)||/||b|| 7.781633686685e-03
>>>    96 KSP preconditioned resid norm 4.244529173876e-04 true resid norm
>>> 2.807041401408e+00 ||r(i)||/||b|| 7.717362422521e-03
>>>    97 KSP preconditioned resid norm 4.138326570674e-04 true resid norm
>>> 2.793663020386e+00 ||r(i)||/||b|| 7.680581413547e-03
>>>    98 KSP preconditioned resid norm 3.869979433609e-04 true resid norm
>>> 2.715150386650e+00 ||r(i)||/||b|| 7.464727650583e-03
>>>    99 KSP preconditioned resid norm 3.847873979265e-04 true resid norm
>>> 2.706008990336e+00 ||r(i)||/||b|| 7.439595328571e-03
>>>   294 KSP preconditioned resid norm 1.416482289961e-04 true resid norm
>>> 2.735750748819e+00 ||r(i)||/||b|| 7.521363958412e-03
>>>   295 KSP preconditioned resid norm 1.415389087364e-04 true resid norm
>>> 2.742638608355e+00 ||r(i)||/||b|| 7.540300661064e-03
>>>   296 KSP preconditioned resid norm 1.414967651105e-04 true resid norm
>>> 2.747224243968e+00 ||r(i)||/||b|| 7.552907889424e-03
>>>   297 KSP preconditioned resid norm 1.413843018303e-04 true resid norm
>>> 2.752574248710e+00 ||r(i)||/||b|| 7.567616587891e-03
>>>   298 KSP preconditioned resid norm 1.411747949695e-04 true resid norm
>>> 2.765459647367e+00 ||r(i)||/||b|| 7.603042246859e-03
>>>   299 KSP preconditioned resid norm 1.411609742082e-04 true resid norm
>>> 2.765900464868e+00 ||r(i)||/||b|| 7.604254180683e-03
>>>   300 KSP preconditioned resid norm 1.409844332838e-04 true resid norm
>>> 2.771790506811e+00 ||r(i)||/||b|| 7.620447596402e-03
>>>   Linear solve did not converge due to DIVERGED_ITS iterations 300
>>>     0 KSP preconditioned resid norm 1.294272083271e-03 true resid norm
>>> 1.776945075651e+00 ||r(i)||/||b|| 1.000000000000e+00
>>>>      Matt
>>>>>> This is the kind of investigation you msut be comfortable with if you
>>>>>> want to experiment with these solvers.
>>>>>>     Matt
>>>>>>>>   Thanks,
>>>>>>>>      Matt
>>>>>>>>> Linear solve converged due to CONVERGED_RTOL iterations 2
>>>>>>>>> KSP Object: 1 MPI processes
>>>>>>>>>   type: gmres
>>>>>>>>>     GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
>>>>>>>>> Orthogonalization with no iterative refinement
>>>>>>>>>     GMRES: happy breakdown tolerance 1e-30
>>>>>>>>>   maximum iterations=10000, initial guess is zero
>>>>>>>>>   tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>>>>>>>>>   left preconditioning
>>>>>>>>>   has attached null space
>>>>>>>>>   using PRECONDITIONED norm type for convergence test
>>>>>>>>> PC Object: 1 MPI processes
>>>>>>>>>   type: fieldsplit
>>>>>>>>>     FieldSplit with Schur preconditioner, blocksize = 4,
>>>>>>>>> factorization FULL
>>>>>>>>>     Preconditioner for the Schur complement formed from user
>>>>>>>>> provided matrix
>>>>>>>>>     Split info:
>>>>>>>>>     Split number 0 Fields  0, 1, 2
>>>>>>>>>     Split number 1 Fields  3
>>>>>>>>>     KSP solver for A00 block
>>>>>>>>>       KSP Object:      (fieldsplit_0_)       1 MPI processes
>>>>>>>>>         type: gmres
>>>>>>>>> Gram-Schmidt Orthogonalization with no iterative refinement
>>>>>>>>> divergence=10000
>>>>>>>>>       PC Object:      (fieldsplit_0_)       1 MPI processes
>>>>>>>>>         type: ilu
>>>>>>>>>           ILU: out-of-place factorization
>>>>>>>>>           0 levels of fill
>>>>>>>>>           tolerance for zero pivot 2.22045e-14
>>>>>>>>>           using diagonal shift on blocks to prevent zero pivot
>>>>>>>>>           matrix ordering: natural
>>>>>>>>>           factor fill ratio given 1, needed 1
>>>>>>>>>             Factored matrix follows:
>>>>>>>>>               Matrix Object:               1 MPI processes
>>>>>>>>>                 type: seqaij
>>>>>>>>>                 rows=8232, cols=8232
>>>>>>>>>                 package used to perform factorization: petsc
>>>>>>>>>                 total: nonzeros=576000, allocated nonzeros=576000
>>>>>>>>>                 total number of mallocs used during MatSetValues
>>>>>>>>> calls =0
>>>>>>>>>                   using I-node routines: found 2744 nodes, limit
>>>>>>>>> used is 5
>>>>>>>>>         linear system matrix = precond matrix:
>>>>>>>>>           type: seqaij
>>>>>>>>>           total number of mallocs used during MatSetValues calls =0
>>>>>>>>>             using I-node routines: found 2744 nodes, limit used is
>>>>>>>>> 5
>>>>>>>>>     KSP solver for S = A11 - A10 inv(A00) A01
>>>>>>>>>       KSP Object:      (fieldsplit_1_)       1 MPI processes
>>>>>>>>>         type: gmres
>>>>>>>>> divergence=10000
>>>>>>>>>       PC Object:      (fieldsplit_1_)       1 MPI processes
>>>>>>>>>         type: ilu
>>>>>>>>>           0 levels of fill
>>>>>>>>>                 type: seqaij
>>>>>>>>>                 rows=2744, cols=2744
>>>>>>>>>                 total: nonzeros=64000, allocated nonzeros=64000
>>>>>>>>> calls =0
>>>>>>>>>                   not using I-node routines
>>>>>>>>>         linear system matrix followed by preconditioner matrix:
>>>>>>>>>           type: schurcomplement
>>>>>>>>>             Schur complement A11 - A10 inv(A00) A01
>>>>>>>>>             A11
>>>>>>>>>                 type: seqaij
>>>>>>>>> calls =0
>>>>>>>>>             A10
>>>>>>>>>                 type: seqaij
>>>>>>>>>                 rows=2744, cols=8232
>>>>>>>>>                 total: nonzeros=192000, allocated nonzeros=192000
>>>>>>>>> calls =0
>>>>>>>>>             KSP of A00
>>>>>>>>>               KSP Object:
>>>>>>>>>                 type: gmres
>>>>>>>>> divergence=10000
>>>>>>>>>               PC Object:
>>>>>>>>>                 type: ilu
>>>>>>>>>                   0 levels of fill
>>>>>>>>> pivot
>>>>>>>>> processes
>>>>>>>>>                         type: seqaij
>>>>>>>>> petsc
>>>>>>>>> nonzeros=576000
>>>>>>>>> limit used is 5
>>>>>>>>>                   type: seqaij
>>>>>>>>> calls =0
>>>>>>>>> used is 5
>>>>>>>>>             A01
>>>>>>>>>                 type: seqaij
>>>>>>>>>                 rows=8232, cols=2744
>>>>>>>>> calls =0
>>>>>>>>> used is 5
>>>>>>>>>           type: seqaij
>>>>>>>>>     type: seqaij
>>>>>>>>>     rows=10976, cols=10976, bs=4
>>>>>>>>>     total: nonzeros=1024000, allocated nonzeros=1024000
>>>>>>>>>       using I-node routines: found 2744 nodes, limit used is 5
>>>>>>>>>>    Matt
>>>>>>>>>>> I am testing a small problem with CONSTANT viscosity for grid
>>>>>>>>>>> size of 14^3 with the run time option:
>>>>>>>>>>> -ksp_type gcr -pc_type fieldsplit -pc_fieldsplit_type schur
>>>>>>>>>>> -fieldsplit_0_ksp_type gcr -fieldsplit_0_pc_type gamg
>>>>>>>>>>> -fieldsplit_0_ksp_monitor_true_residual -fieldsplit_0_ksp_converged_reason
>>>>>>>>>>> -fieldsplit_1_ksp_monitor_true_residual
>>>>>>>>>>> Here is my relevant code of the solve function:
>>>>>>>>>>> PetscErrorCode ierr;
>>>>>>>>>>>     PetscFunctionBeginUser;
>>>>>>>>>>>     ierr =
>>>>>>>>>>> DMKSPSetComputeRHS(mDa,computeRHSTaras3D,this);CHKERRQ(ierr);
>>>>>>>>>>>     ierr =
>>>>>>>>>>> DMKSPSetComputeOperators(mDa,computeMatrixTaras3D,this);CHKERRQ(ierr);
>>>>>>>>>>>     ierr = KSPSetDM(mKsp,mDa);CHKERRQ(ierr);              //mDa
>>>>>>>>>>> with dof = 4, vx,vy,vz and p.
>>>>>>>>>>>     ierr =
>>>>>>>>>>> KSPSetNullSpace(mKsp,mNullSpace);CHKERRQ(ierr);//nullSpace for the main
>>>>>>>>>>> system
>>>>>>>>>>>     ierr = KSPSetFromOptions(mKsp);CHKERRQ(ierr);
>>>>>>>>>>>     ierr = KSPSetUp(mKsp);CHKERRQ(ierr);
>>>>>>>>>>> //register the fieldsplits obtained from options.
>>>>>>>>>>>     //Setting up user PC for Schur Complement
>>>>>>>>>>>     ierr = KSPGetPC(mKsp,&mPc);CHKERRQ(ierr);
>>>>>>>>>>>     ierr =
>>>>>>>>>>> PCFieldSplitSchurPrecondition(mPc,PC_FIELDSPLIT_SCHUR_PRE_USER,mPcForSc);CHKERRQ(ierr);
>>>>>>>>>>>     KSP *subKsp;
>>>>>>>>>>>     PetscInt subKspPos = 0;
>>>>>>>>>>>     //Set up nearNullspace for A00 block.
>>>>>>>>>>>     ierr =
>>>>>>>>>>> PCFieldSplitGetSubKSP(mPc,&subKspPos,&subKsp);CHKERRQ(ierr);
>>>>>>>>>>>     MatNullSpace rigidBodyModes;
>>>>>>>>>>>     Vec coords;
>>>>>>>>>>>     ierr = DMGetCoordinates(mDa,&coords);CHKERRQ(ierr);
>>>>>>>>>>>     ierr =
>>>>>>>>>>> MatNullSpaceCreateRigidBody(coords,&rigidBodyModes);CHKERRQ(ierr);
>>>>>>>>>>>     Mat matA00;
>>>>>>>>>>>     ierr =
>>>>>>>>>>> KSPGetOperators(subKsp[0],&matA00,NULL,NULL);CHKERRQ(ierr);
>>>>>>>>>>>     ierr =
>>>>>>>>>>> MatSetNearNullSpace(matA00,rigidBodyModes);CHKERRQ(ierr);
>>>>>>>>>>>     ierr = MatNullSpaceDestroy(&rigidBodyModes);CHKERRQ(ierr);
>>>>>>>>>>>     //Position 1 => Ksp corresponding to Schur complement S on
>>>>>>>>>>> pressure space
>>>>>>>>>>>     subKspPos = 1;
>>>>>>>>>>>     ierr =
>>>>>>>>>>>     //Set up the null space of constant pressure.
>>>>>>>>>>>     ierr = KSPSetNullSpace(subKsp[1],mNullSpaceP);CHKERRQ(ierr);
>>>>>>>>>>>     PetscBool isNull;
>>>>>>>>>>>     Mat matSc;
>>>>>>>>>>>     ierr =
>>>>>>>>>>> KSPGetOperators(subKsp[1],&matSc,NULL,NULL);CHKERRQ(ierr);
>>>>>>>>>>>     ierr = MatNullSpaceTest(mNullSpaceP,matSc,&isNull);
>>>>>>>>>>>     if(!isNull)
>>>>>>>>>>>         SETERRQ(PETSC_COMM_WORLD,PETSC_ERR_PLIB,"not a valid
>>>>>>>>>>> pressure null space \n");
>>>>>>>>>>>     ierr = KSPGetOperators(mKsp,&mA,NULL,NULL);CHKERRQ(ierr);
>>>>>>>>>>>     ierr = MatNullSpaceTest(mNullSpace,mA,&isNull);CHKERRQ(ierr);
>>>>>>>>>>>     if(!isNull)
>>>>>>>>>>> system null space \n");
>>>>>>>>>>>     ierr = PetscFree(subKsp);CHKERRQ(ierr);
>>>>>>>>>>>     ierr = KSPSolve(mKsp,NULL,NULL);CHKERRQ(ierr);
>>>>>>>>>>>     ierr = KSPGetSolution(mKsp,&mX);CHKERRQ(ierr);
>>>>>>>>>>>     ierr = KSPGetRhs(mKsp,&mB);CHKERRQ(ierr);
>>>>>>>>>>>     PetscFunctionReturn(0);
>>>>>>>>>>> On Wed, Aug 7, 2013 at 2:15 PM, Matthew Knepley <
>>>>>>>>>>>> On Wed, Aug 7, 2013 at 7:07 AM, Bishesh Khanal <
>>>>>>>>>>>>> On Tue, Aug 6, 2013 at 11:34 PM, Matthew Knepley <
>>>>>>>>>>>>>> On Tue, Aug 6, 2013 at 10:59 AM, Bishesh Khanal <
>>>>>>>>>>>>>>> On Tue, Aug 6, 2013 at 4:40 PM, Matthew Knepley <
>>>>>>>>>>>>>>>> On Tue, Aug 6, 2013 at 8:06 AM, Bishesh Khanal <
>>>>>>>>>>>>>>>>> On Mon, Aug 5, 2013 at 4:14 PM, Matthew Knepley <
>>>>>>>>>>>>>>>>>> On Mon, Aug 5, 2013 at 8:48 AM, Bishesh Khanal <
>>>>>>>>>>>>>>>>>>> On Mon, Aug 5, 2013 at 3:17 PM, Matthew Knepley <
>>>>>>>>>>>>>>>>>>>> On Mon, Aug 5, 2013 at 7:54 AM, Bishesh Khanal <
>>>>>>>>>>>>>>>>>>>>> On Wed, Jul 17, 2013 at 9:48 PM, Jed Brown <
>>>>>>>>>>>>>>>>>>>>> jedbrown at mcs.anl.gov> wrote:
>>>>>>>>>>>>>>>>>>>>>> Bishesh Khanal <bisheshkh at gmail.com> writes:
>>>>>>>>>>>>>>>>>>>>>> > Now, I implemented two different approaches, each
>>>>>>>>>>>>>>>>>>>>>> for both 2D and 3D, in
>>>>>>>>>>>>>>>>>>>>>> > MATLAB. It works for the smaller sizes but I have
>>>>>>>>>>>>>>>>>>>>>> problems solving it for
>>>>>>>>>>>>>>>>>>>>>> > the problem size I need (250^3 grid size).
>>>>>>>>>>>>>>>>>>>>>> > I use staggered grid with p on cell centers, and
>>>>>>>>>>>>>>>>>>>>>> components of v on cell
>>>>>>>>>>>>>>>>>>>>>> > faces. Similar split up of K to cell center and
>>>>>>>>>>>>>>>>>>>>>> faces to account for the
>>>>>>>>>>>>>>>>>>>>>> > variable viscosity case)
>>>>>>>>>>>>>>>>>>>>>> Okay, you're using a staggered-grid finite difference
>>>>>>>>>>>>>>>>>>>>>> discretization of
>>>>>>>>>>>>>>>>>>>>>> variable-viscosity Stokes.  This is a common problem
>>>>>>>>>>>>>>>>>>>>>> and I recommend
>>>>>>>>>>>>>>>>>>>>>> starting with PCFieldSplit with Schur complement
>>>>>>>>>>>>>>>>>>>>>> reduction (make that
>>>>>>>>>>>>>>>>>>>>>> work first, then switch to block preconditioner).
>>>>>>>>>>>>>>>>>>>>>>  You can use PCLSC or
>>>>>>>>>>>>>>>>>>>>>> (probably better for you), assemble a preconditioning
>>>>>>>>>>>>>>>>>>>>>> matrix containing
>>>>>>>>>>>>>>>>>>>>>> the inverse viscosity in the pressure-pressure block.
>>>>>>>>>>>>>>>>>>>>>>  This diagonal
>>>>>>>>>>>>>>>>>>>>>> matrix is a spectrally equivalent (or nearly so,
>>>>>>>>>>>>>>>>>>>>>> depending on
>>>>>>>>>>>>>>>>>>>>>> discretization) approximation of the Schur
>>>>>>>>>>>>>>>>>>>>>> complement.  The velocity
>>>>>>>>>>>>>>>>>>>>>> block can be solved with algebraic multigrid.  Read
>>>>>>>>>>>>>>>>>>>>>> the PCFieldSplit
>>>>>>>>>>>>>>>>>>>>>> docs (follow papers as appropriate) and let us know
>>>>>>>>>>>>>>>>>>>>>> if you get stuck.
>>>>>>>>>>>>>>>>>>>>> I was trying to assemble the inverse viscosity
>>>>>>>>>>>>>>>>>>>>> diagonal matrix to use as the preconditioner for the Schur complement solve
>>>>>>>>>>>>>>>>>>>>> step as you suggested. I've few questions about the ways to implement this
>>>>>>>>>>>>>>>>>>>>> in Petsc:
>>>>>>>>>>>>>>>>>>>>> A naive approach that I can think of would be to
>>>>>>>>>>>>>>>>>>>>> create a vector with its components as reciprocal viscosities of the cell
>>>>>>>>>>>>>>>>>>>>> centers corresponding to the pressure variables, and then create a diagonal
>>>>>>>>>>>>>>>>>>>>> matrix from this vector. However I'm not sure about:
>>>>>>>>>>>>>>>>>>>>> How can I make this matrix, (say S_p) compatible to
>>>>>>>>>>>>>>>>>>>>> the Petsc distribution of the different rows of the main system matrix over
>>>>>>>>>>>>>>>>>>>>> different processors ? The main matrix was created using the DMDA structure
>>>>>>>>>>>>>>>>>>>>> with 4 dof as explained before.
>>>>>>>>>>>>>>>>>>>>> The main matrix correspond to the DMDA with 4 dofs but
>>>>>>>>>>>>>>>>>>>>> for the S_p matrix would correspond to only pressure space. Should the
>>>>>>>>>>>>>>>>>>>>> distribution of the rows of S_p among different processor not correspond to
>>>>>>>>>>>>>>>>>>>>> the distribution of the rhs vector, say h' if it is solving for p with Sp =
>>>>>>>>>>>>>>>>>>>>> h' where S = A11 inv(A00) A01 ?
>>>>>>>>>>>>>>>>>>>> PETSc distributed vertices, not dofs, so it never
>>>>>>>>>>>>>>>>>>>> breaks blocks. The P distribution is the same as the entire problem divided
>>>>>>>>>>>>>>>>>>>> by 4.
>>>>>>>>>>>>>>>>>>> Thanks Matt. So if I create a new DMDA with same grid
>>>>>>>>>>>>>>>>>>> size but with dof=1 instead of 4, the vertices for this new DMDA will be
>>>>>>>>>>>>>>>>>>> identically distributed as for the original DMDA ? Or should I inform PETSc
>>>>>>>>>>>>>>>>>>> by calling a particular function to make these two DMDA have identical
>>>>>>>>>>>>>>>>>>> distribution of the vertices ?
>>>>>>>>>>>>>>>>>> Yes.
>>>>>>>>>>>>>>>>>>>  Even then I think there might be a problem due to the
>>>>>>>>>>>>>>>>>>> presence of "fictitious pressure vertices". The system matrix (A) contains
>>>>>>>>>>>>>>>>>>> an identity corresponding to these fictitious pressure nodes, thus when
>>>>>>>>>>>>>>>>>>> using a -pc_fieldsplit_detect_saddle_point, will detect a A11 zero block of
>>>>>>>>>>>>>>>>>>> size that correspond to only non-fictitious P-nodes. So the preconditioner
>>>>>>>>>>>>>>>>>>> S_p for the Schur complement outer solve with Sp = h' will also need to
>>>>>>>>>>>>>>>>>>> correspond to only the non-fictitious P-nodes. This means its size does not
>>>>>>>>>>>>>>>>>>> directly correspond to the DMDA grid defined for the original problem.
>>>>>>>>>>>>>>>>>>> Could you please suggest an efficient way of assembling this S_p matrix ?
>>>>>>>>>>>>>>>>>> Don't use detect_saddle, but split it by fields
>>>>>>>>>>>>>>>>>> -pc_fieldsplit_0_fields 0,1,2 -pc_fieldsplit_1_fields 4
>>>>>>>>>>>>>>>>> How can I set this split in the code itself without giving
>>>>>>>>>>>>>>>>> it as a command line option when the system matrix is assembled from the
>>>>>>>>>>>>>>>>> DMDA for the whole system with 4 dofs. (i.e. *without*using the DMComposite or
>>>>>>>>>>>>>>>>> *without* using the nested block matrices to assemble
>>>>>>>>>>>>>>>>> different blocks separately and then combine them together).
>>>>>>>>>>>>>>>>> I need the split to get access to the fieldsplit_1_ksp in
>>>>>>>>>>>>>>>>> my code, because not using detect_saddle_point means I cannot use
>>>>>>>>>>>>>>>>> -fieldsplit_1_ksp_constant_null_space due to the presence of identity for
>>>>>>>>>>>>>>>>> the fictitious pressure nodes present in the fieldsplit_1_ block. I need to
>>>>>>>>>>>>>>>>> use PCFieldSplitGetSubKsp() so that I can set proper null-space basis.
>>>>>>>>>>>>>>>> This is currently a real problem with the DMDA. In the
>>>>>>>>>>>>>>>> unstructured case, where we always need specialized spaces, you can
>>>>>>>>>>>>>>>> use something like
>>>>>>>>>>>>>>>>     PetscObject  pressure;
>>>>>>>>>>>>>>>>     MatNullSpace nullSpacePres;
>>>>>>>>>>>>>>>>     ierr = DMGetField(dm, 1, &pressure);CHKERRQ(ierr);
>>>>>>>>>>>>>>>>     ierr = MatNullSpaceCreate(PetscObjectComm(pressure),
>>>>>>>>>>>>>>>> PETSC_TRUE, 0, NULL, &nullSpacePres);CHKERRQ(ierr);
>>>>>>>>>>>>>>>>     ierr = PetscObjectCompose(pressure, "nullspace",
>>>>>>>>>>>>>>>> (PetscObject) nullSpacePres);CHKERRQ(ierr);
>>>>>>>>>>>>>>>>     ierr =
>>>>>>>>>>>>>>>> MatNullSpaceDestroy(&nullSpacePres);CHKERRQ(ierr);
>>>>>>>>>>>>>>>> and then DMGetSubDM() uses this information to attach the
>>>>>>>>>>>>>>>> null space to the IS that is created using the information in the
>>>>>>>>>>>>>>>> PetscSection.
>>>>>>>>>>>>>>>> If you use a PetscSection to set the data layout over the
>>>>>>>>>>>>>>>> DMDA, I think this works correctly, but this has not been tested at all and
>>>>>>>>>>>>>>>> is very
>>>>>>>>>>>>>>>> new code. Eventually, I think we want all DMs to use this
>>>>>>>>>>>>>>>> mechanism, but we are still working it out.
>>>>>>>>>>>>>>> Currently I do not use PetscSection. If this makes a cleaner
>>>>>>>>>>>>>>> approach, I'd try it too but may a bit later (right now I'd like test my
>>>>>>>>>>>>>>> model with a quickfix even if it means a little dirty code!)
>>>>>>>>>>>>>>>> Bottom line: For custom null spaces using the default
>>>>>>>>>>>>>>>> layout in DMDA, you need to take apart the PCFIELDSPLIT after it has been
>>>>>>>>>>>>>>>> setup,
>>>>>>>>>>>>>>>> which is somewhat subtle. You need to call KSPSetUp() and
>>>>>>>>>>>>>>>> then reach in and get the PC, and the subKSPs. I don't like this at all,
>>>>>>>>>>>>>>>> but we
>>>>>>>>>>>>>>>> have not reorganized that code (which could be very simple
>>>>>>>>>>>>>>>> and inflexible since its very structured).
>>>>>>>>>>>>>>> So I tried to get this approach working but I could not
>>>>>>>>>>>>>>> succeed and encountered some errors. Here is a code snippet:
>>>>>>>>>>>>>>> //mDa is the DMDA that describes the whole grid with all 4
>>>>>>>>>>>>>>> dofs (3 velocity components and 1 pressure comp.)
>>>>>>>>>>>>>>> ierr =
>>>>>>>>>>>>>>>     ierr =
>>>>>>>>>>>>>>>     ierr =
>>>>>>>>>>>>>>> KSPSetNullSpace(mKsp,mNullSpaceSystem);CHKERRQ(ierr);   //I've the
>>>>>>>>>>>>>>> mNullSpaceSystem based on mDa, that contains a null space basis for the
>>>>>>>>>>>>>>> complete system.
>>>>>>>>>>>>>>>     ierr =
>>>>>>>>>>>>>>> //This I expect would register these options I give:-pc_type fieldsplit
>>>>>>>>>>>>>>> -pc_fieldsplit_type schur -pc_fieldsplit_0_fields 0,1,2
>>>>>>>>>>>>>>> //-pc_fieldsplit_1_fields 3
>>>>>>>>>>>>>>>     ierr = KSPGetPC(mKsp,&mPcOuter);     //Now get the PC
>>>>>>>>>>>>>>> that was obtained from the options (fieldsplit)
>>>>>>>>>>>>>>>     ierr =
>>>>>>>>>>>>>>> PCFieldSplitSchurPrecondition(mPcOuter,PC_FIELDSPLIT_SCHUR_PRE_USER,mPcForSc);CHKERRQ(ierr);
>>>>>>>>>>>>>>> //I have created the matrix mPcForSc using a DMDA with identical //size to
>>>>>>>>>>>>>>> mDa but with dof=1 corresponding to the pressure nodes (say mDaPressure).
>>>>>>>>>>>>>>>   ierr = PCSetUp(mPcOuter);CHKERRQ(ierr);
>>>>>>>>>>>>>>>     KSP *kspSchur;
>>>>>>>>>>>>>>>     PetscInt kspSchurPos = 1;
>>>>>>>>>>>>>>>     ierr =
>>>>>>>>>>>>>>> PCFieldSplitGetSubKSP(mPcOuter,&kspSchurPos,&kspSchur);CHKERRQ(ierr);
>>>>>>>>>>>>>>>     ierr =
>>>>>>>>>>>>>>> KSPSetNullSpace(kspSchur[1],mNullSpacePressure);CHKERRQ(ierr);
>>>>>>>>>>>>>>> //The null space is the one that correspond to only pressure nodes, created
>>>>>>>>>>>>>>> using the mDaPressure.
>>>>>>>>>>>>>>>     ierr = PetscFree(kspSchur);CHKERRQ(ierr);
>>>>>>>>>>>>>> Sorry, you need to return to the old DMDA behavior, so you
>>>>>>>>>>>>>> want
>>>>>>>>>>>>> Thanks, with this it seems I can attach the null space
>>>>>>>>>>>>> properly, but I have a question regarding whether the Schur complement ksp
>>>>>>>>>>>>> solver is actually using the preconditioner matrix I provide.
>>>>>>>>>>>>> When using -ksp_view, the outer level pc object of type
>>>>>>>>>>>>> fieldsplit does report that: "Preconditioner for the Schur complement
>>>>>>>>>>>>> formed from user provided matrix", but in the KSP solver for Schur
>>>>>>>>>>>>> complement S, the pc object (fieldsplit_1_) is of type ilu and doesn't say
>>>>>>>>>>>>> that it is using the matrix I provide. Am I missing something here ?
>>>>>>>>>>>>> Below are the relevant commented code snippet and the output
>>>>>>>>>>>>> of the -ksp_view
>>>>>>>>>>>>> (The options I used: -pc_type fieldsplit -pc_fieldsplit_type
>>>>>>>>>>>>> schur -pc_fieldsplit_dm_splits 0 -pc_fieldsplit_0_fields 0,1,2
>>>>>>>>>>>>> -pc_fieldsplit_1_fields 3 -ksp_converged_reason -ksp_view )
>>>>>>>>>>>> If ILU does not error, it means it is using your matrix,
>>>>>>>>>>>> because the Schur complement matrix cannot be factored, and FS says it is
>>>>>>>>>>>> using your matrix.
>>>>>>>>>>>>    Matt
>>>>>>>>>>>>> Code snippet:
>>>>>>>>>>>>> ierr = KSPSetNullSpace(mKsp,mNullSpaceSystem);CHKERRQ(ierr);
>>>>>>>>>>>>> //The nullspace for the whole system
>>>>>>>>>>>>>     ierr =
>>>>>>>>>>>>> //Set up mKsp with the options provided with fieldsplit and the fields
>>>>>>>>>>>>> associated with the two splits.
>>>>>>>>>>>>>     ierr = KSPGetPC(mKsp,&mPcOuter);CHKERRQ(ierr);
>>>>>>>>>>>>>                //Get the fieldsplit pc set up from the options
>>>>>>>>>>>>>     ierr =
>>>>>>>>>>>>> //Use mPcForSc as the preconditioner for Schur Complement
>>>>>>>>>>>>>     KSP *kspSchur;
>>>>>>>>>>>>>     ierr =
>>>>>>>>>>>>>     ierr =
>>>>>>>>>>>>> //Attach the null-space for the Schur complement ksp solver.
>>>>>>>>>>>>> the output of the -ksp_view
>>>>>>>>>>>>>   type: gmres
>>>>>>>>>>>>>   type: fieldsplit
>>>>>>>>>>>>> factorization FULL
>>>>>>>>>>>>> provided matrix
>>>>>>>>>>>>>     Split info:
>>>>>>>>>>>>>         type: gmres
>>>>>>>>>>>>> divergence=10000
>>>>>>>>>>>>>         type: ilu
>>>>>>>>>>>>>           0 levels of fill
>>>>>>>>>>>>>                 type: seqaij
>>>>>>>>>>>>>                 rows=2187, cols=2187
>>>>>>>>>>>>>                 total: nonzeros=140625, allocated
>>>>>>>>>>>>> nonzeros=140625
>>>>>>>>>>>>>                   using I-node routines: found 729 nodes,
>>>>>>>>>>>>> limit used is 5
>>>>>>>>>>>>>           type: seqaij
>>>>>>>>>>>>>           total: nonzeros=140625, allocated nonzeros=140625
>>>>>>>>>>>>> calls =0
>>>>>>>>>>>>>             using I-node routines: found 729 nodes, limit used
>>>>>>>>>>>>> is 5
>>>>>>>>>>>>>         type: gmres
>>>>>>>>>>>>> divergence=10000
>>>>>>>>>>>>>         type: ilu
>>>>>>>>>>>>>           0 levels of fill
>>>>>>>>>>>>>                 type: seqaij
>>>>>>>>>>>>>                 rows=729, cols=729
>>>>>>>>>>>>>                 total: nonzeros=15625, allocated nonzeros=15625
>>>>>>>>>>>>>           rows=729, cols=729
>>>>>>>>>>>>>             A11
>>>>>>>>>>>>>                 type: seqaij
>>>>>>>>>>>>>                 rows=729, cols=729
>>>>>>>>>>>>>             A10
>>>>>>>>>>>>>                 type: seqaij
>>>>>>>>>>>>>                 rows=729, cols=2187
>>>>>>>>>>>>>                 total: nonzeros=46875, allocated nonzeros=46875
>>>>>>>>>>>>>             KSP of A00
>>>>>>>>>>>>>               KSP Object:
>>>>>>>>>>>>>                 type: gmres
>>>>>>>>>>>>> (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
>>>>>>>>>>>>> divergence=10000
>>>>>>>>>>>>> test
>>>>>>>>>>>>>               PC Object:
>>>>>>>>>>>>>                 type: ilu
>>>>>>>>>>>>>                   0 levels of fill
>>>>>>>>>>>>> zero pivot
>>>>>>>>>>>>>                       Matrix Object:                       1
>>>>>>>>>>>>> MPI processes
>>>>>>>>>>>>>                         type: seqaij
>>>>>>>>>>>>> petsc
>>>>>>>>>>>>> nonzeros=140625
>>>>>>>>>>>>>                   type: seqaij
>>>>>>>>>>>>> nonzeros=140625
>>>>>>>>>>>>> limit used is 5
>>>>>>>>>>>>>             A01
>>>>>>>>>>>>>                 type: seqaij
>>>>>>>>>>>>>                 rows=2187, cols=729
>>>>>>>>>>>>> limit used is 5
>>>>>>>>>>>>>           type: seqaij
>>>>>>>>>>>>>           rows=729, cols=729
>>>>>>>>>>>>> calls =0
>>>>>>>>>>>>>     type: seqaij
>>>>>>>>>>>>>     rows=2916, cols=2916, bs=4
>>>>>>>>>>>>>     total: nonzeros=250000, allocated nonzeros=250000
>>>>>>>>>>>>>       using I-node routines: found 729 nodes, limit used is 5
>>>>>>>>>>>>>> or
>>>>>>>>>>>>>>   PCFieldSplitSetDMSplits(pc, PETSC_FALSE)
>>>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>>>      Matt
>>>>>>>>>>>>>>> The errors I get when running with options: -pc_type
>>>>>>>>>>>>>>> fieldsplit -pc_fieldsplit_type schur -pc_fieldsplit_0_fields 0,1,2
>>>>>>>>>>>>>>> [0]PETSC ERROR: --------------------- Error Message
>>>>>>>>>>>>>>> [0]PETSC ERROR: No support for this operation for this
>>>>>>>>>>>>>>> object type!
>>>>>>>>>>>>>>> [0]PETSC ERROR: Support only implemented for 2d!
>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>> [0]PETSC ERROR: Petsc Release Version 3.4.2, Jul, 02, 2013
>>>>>>>>>>>>>>> [0]PETSC ERROR: See docs/changes/index.html for recent
>>>>>>>>>>>>>>> updates.
>>>>>>>>>>>>>>> [0]PETSC ERROR: See docs/faq.html for hints about trouble
>>>>>>>>>>>>>>> shooting.
>>>>>>>>>>>>>>> [0]PETSC ERROR: See docs/index.html for manual pages.
>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>> [0]PETSC ERROR: src/AdLemMain on a arch-linux2-cxx-debug
>>>>>>>>>>>>>>> named edwards by bkhanal Tue Aug  6 17:35:30 2013
>>>>>>>>>>>>>>> [0]PETSC ERROR: Libraries linked from
>>>>>>>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/arch-linux2-cxx-debug/lib
>>>>>>>>>>>>>>> [0]PETSC ERROR: Configure run at Fri Jul 19 14:25:01 2013
>>>>>>>>>>>>>>> [0]PETSC ERROR: Configure options --with-cc=gcc
>>>>>>>>>>>>>>> --with-fc=g77 --with-cxx=g++ --download-f-blas-lapack=1 --download-mpich=1
>>>>>>>>>>>>>>> -with-clanguage=cxx --download-hypre=1
>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>> [0]PETSC ERROR: DMCreateSubDM_DA() line 188 in
>>>>>>>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/dm/impls/da/dacreate.c
>>>>>>>>>>>>>>> [0]PETSC ERROR: DMCreateSubDM() line 1267 in
>>>>>>>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/dm/interface/dm.c
>>>>>>>>>>>>>>> [0]PETSC ERROR: PCFieldSplitSetDefaults() line 337 in
>>>>>>>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/ksp/pc/impls/fieldsplit/fieldsplit.c
>>>>>>>>>>>>>>> [0]PETSC ERROR: PCSetUp_FieldSplit() line 458 in
>>>>>>>>>>>>>>> [0]PETSC ERROR: PCSetUp() line 890 in
>>>>>>>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/ksp/pc/interface/precon.c
>>>>>>>>>>>>>>> [0]PETSC ERROR: KSPSetUp() line 278 in
>>>>>>>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/ksp/ksp/interface/itfunc.c
>>>>>>>>>>>>>>> [0]PETSC ERROR: solveModel() line 181 in
>>>>>>>>>>>>>>> "unknowndirectory/"/user/bkhanal/home/works/AdLemModel/src/PetscAdLemTaras3D.cxx
>>>>>>>>>>>>>>> WARNING! There are options you set that were not used!
>>>>>>>>>>>>>>> WARNING! could be spelling mistake, etc!
>>>>>>>>>>>>>>> Option left: name:-pc_fieldsplit_1_fields value: 3
>>>>>>>>>>>>>>>>    Matt
>>>>>>>>>>>>>>>>>>    Matt
>>>>>>>>>>>>>>>>>>>>    Matt
>>>>>>>>>>>>>>>>>>>> What most experimenters take for granted before they
>>>>>>>>>>>>>>>>>>>> begin their experiments is infinitely more interesting than any results to
>>>>>>>>>>>>>>>>>>>> which their experiments lead.
>>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130823/e95b296e/attachment-0001.html>
