[petsc-users] discontinuous viscosity stokes equation 3D staggered grid
Fri Aug 23 08:45:24 CDT 2013
On Fri, Aug 23, 2013 at 8:42 AM, Bishesh Khanal <bisheshkh at gmail.com> wrote:
> On Fri, Aug 23, 2013 at 3:34 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Fri, Aug 23, 2013 at 8:30 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>> On Fri, Aug 23, 2013 at 3:16 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>> On Fri, Aug 23, 2013 at 8:01 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>>>> On Fri, Aug 23, 2013 at 2:53 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>> On Fri, Aug 23, 2013 at 7:46 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>>>>>> On Fri, Aug 23, 2013 at 2:33 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>>>> On Fri, Aug 23, 2013 at 7:25 AM, Bishesh Khanal <
>>>>>>>>> On Fri, Aug 23, 2013 at 2:09 PM, Matthew Knepley <
>>>>>>>>> knepley at gmail.com> wrote:
>>>>>>>>>> On Fri, Aug 23, 2013 at 4:31 AM, Bishesh Khanal <
>>>>>>>>>>> Thanks Matt and Mark for comments in using near null space
>>>>>>>>>>> [question I asked in the thread with subject: *problem
>>>>>>>>>>> (Segmentation voilation) using -pc_type hypre -pc_hypre_type -pilut with
>>>>>>>>>>> multiple nodes in a cluster*].
>>>>>>>>>>> So I understood that I have to set a nearNullSpace to A00 block
>>>>>>>>>>> where the null space correspond to the rigid body motion. I tried it but
>>>>>>>>>>> still the gamg just keeps on iterating and convergence is very very slow. I
>>>>>>>>>>> am not sure what the problem is, right now gamg does not even work for the
>>>>>>>>>>> constant viscosity case.
>>>>>>>>>>> I have set up the following in my code:
>>>>>>>>>>> 1. null space for the whole system A 2. null space for the Schur
>>>>>>>>>>> complement S 3. Near null space for A00 4. a user preconditioner matrix of
>>>>>>>>>>> inverse viscosity in the diagonal for S.
>>>>>>>>>> If you want to debug solvers, you HAVE to send -ksp_view.
>>>>>>>>> When I use gamg, the -fieldsplit_0_ksp was iterating on and on so
>>>>>>>>> didn't get to the end to get -ksp_view results.
>>>>>>>>> Instead here I have put the -ksp_view output when running the
>>>>>>>>> program with following options: (In this case I get the results)
>>>>>>>>> -pc_type fieldsplit -pc_fieldsplit_type schur
>>>>>>>>> -pc_fieldsplit_dm_splits 0 -pc_fieldsplit_0_fields 0,1,2
>>>>>>>>> -pc_fieldsplit_1_fields 3 -ksp_converged_reason -ksp_view
>>>>>>>> Okay, that looks fine. Does
>>>>>>>>   -fieldsplit_0_pc_type lu
>>>>>>>>   - fieldsplit_1_ksp_rtol 1.0e-10
>>>>>>>> converge in one Iterate?
>>>>>>>> What matrix did you attach as the preconditioner matrix for
>>>>>>>> fieldsplit_1_?
>>>>>>> I used a diagonal matrix with reciprocal of viscosity values of the
>>>>>>> corresponding cell centers as the preconditioner.
>>>>>>> with the options  -fieldsplit_0_pc_type lu  - fieldsplit_1_ksp_rtol
>>>>>>> 1.0e-10 -fieldsplit_1_ksp_converged_reason -ksp_converged_reason
>>>>>>> I get the following output which means the outer ksp did converge in
>>>>>>> one iterate I guess.
>>>>>>>   Linear solve converged due to CONVERGED_RTOL iterations 18
>>>>>> Okay, so A_00 is nonsingular, and the system seems to solve alright.
>>>>>> What do you get for
>>>>>>   -fieldsplit_0_ksp_max_it 30
>>>>>>   -fieldsplit_0_pc_type gamg
>>>>>>   -fieldsplit_0_ksp_converged_reason
>>>>> It fieldsplit_0_ does not converge in 30 iterations. It gives:
>>>>>  Linear solve converged due to CONVERGED_ATOL iterations 0
>>>>> Linear solve did not converge due to DIVERGED_ITS iterations 30
>>>>> and continues with the same message.
>>>> So what would you do? Give up?
>>>> No, I don't want to give up :)
>>>>   -fieldsplit_0_ksp_gmres_restart 200
>>>> The idea is to figure out what is going on:
>>>>   -fieldsplit_0_ksp_monitor_true_residual
>>>> I have tried these options before too, the residual is decreasing very
>>> very slowly,  but I've not been able to figure out why. (using hypre does
>>> converge although slowly again, but I had problems using hypre with
>>> multiple nodes in a cluster with segmentation fault (we discussed that in
>>> another thread!) )
>> Put in the Laplacian instead of the operator you have now. It should
>> converge in a few iterates. If not, you have a problem
>> in the specification.
>> If so, put in linear elasticity. If it is slow, you have made a mistake
>> specifiying the near null space. Also, you need to check
>> that the near null space made it to GAMG using the ksp_view output.
> Which operator are you referring to ? The one in A00 block ? I'm testing
> currently with the constant viscosity case which means the A00 block has
> \mu div(grad(v)) which is a Laplacian.
> And Is it possible to view the ksp_view output before the solver actually
> converges to check if GAMG took the near null space ?
1) Make mu 1.0
2) The nullspace does not matter at all for the Laplacian, so turn it off
If it does not take < 5 iterations, that is not the Laplacian. There are
plenty of FD Laplacians in PETSc, like SNES ex5, that you can
run GAMG on to test. You should consider getting an exact solution and
testing with that as well, since it appears your operator is
not what you think it is.
   Matt
>>    Matt
>>> e.g a snapshot of the output:
>>>     Residual norms for fieldsplit_0_ solve.
>>>     0 KSP preconditioned resid norm 0.000000000000e+00 true resid norm
>>> 0.000000000000e+00 ||r(i)||/||b||           -nan
>>>     0 KSP preconditioned resid norm 2.619231455875e-01 true resid norm
>>> 3.637306695895e+02 ||r(i)||/||b|| 1.000000000000e+00
>>>     1 KSP preconditioned resid norm 9.351491725479e-02 true resid norm
>>> 6.013334574957e+01 ||r(i)||/||b|| 1.653238255038e-01
>>>     2 KSP preconditioned resid norm 6.010357491087e-02 true resid norm
>>> 3.664473273769e+01 ||r(i)||/||b|| 1.007468871928e-01
>>>     3 KSP preconditioned resid norm 6.006968012944e-02 true resid norm
>>> 3.696451770148e+01 ||r(i)||/||b|| 1.016260678353e-01
>>>     4 KSP preconditioned resid norm 4.418407037098e-02 true resid norm
>>> 3.184810838034e+01 ||r(i)||/||b|| 8.755959022176e-02
>>>   93 KSP preconditioned resid norm 4.549506047737e-04 true resid norm
>>> 2.877594552685e+00 ||r(i)||/||b|| 7.911333283864e-03
>>>    94 KSP preconditioned resid norm 4.515424416235e-04 true resid norm
>>> 2.875249044668e+00 ||r(i)||/||b|| 7.904884809172e-03
>>>    95 KSP preconditioned resid norm 4.277647876573e-04 true resid norm
>>> 2.830418831358e+00 ||r(i)||/||b|| 7.781633686685e-03
>>>    96 KSP preconditioned resid norm 4.244529173876e-04 true resid norm
>>> 2.807041401408e+00 ||r(i)||/||b|| 7.717362422521e-03
>>>    97 KSP preconditioned resid norm 4.138326570674e-04 true resid norm
>>> 2.793663020386e+00 ||r(i)||/||b|| 7.680581413547e-03
>>>    98 KSP preconditioned resid norm 3.869979433609e-04 true resid norm
>>> 2.715150386650e+00 ||r(i)||/||b|| 7.464727650583e-03
>>>    99 KSP preconditioned resid norm 3.847873979265e-04 true resid norm
>>> 2.706008990336e+00 ||r(i)||/||b|| 7.439595328571e-03
>>>   294 KSP preconditioned resid norm 1.416482289961e-04 true resid norm
>>> 2.735750748819e+00 ||r(i)||/||b|| 7.521363958412e-03
>>>   295 KSP preconditioned resid norm 1.415389087364e-04 true resid norm
>>> 2.742638608355e+00 ||r(i)||/||b|| 7.540300661064e-03
>>>   296 KSP preconditioned resid norm 1.414967651105e-04 true resid norm
>>> 2.747224243968e+00 ||r(i)||/||b|| 7.552907889424e-03
>>>   297 KSP preconditioned resid norm 1.413843018303e-04 true resid norm
>>> 2.752574248710e+00 ||r(i)||/||b|| 7.567616587891e-03
>>>   298 KSP preconditioned resid norm 1.411747949695e-04 true resid norm
>>> 2.765459647367e+00 ||r(i)||/||b|| 7.603042246859e-03
>>>   299 KSP preconditioned resid norm 1.411609742082e-04 true resid norm
>>> 2.765900464868e+00 ||r(i)||/||b|| 7.604254180683e-03
>>>   300 KSP preconditioned resid norm 1.409844332838e-04 true resid norm
>>> 2.771790506811e+00 ||r(i)||/||b|| 7.620447596402e-03
>>>   Linear solve did not converge due to DIVERGED_ITS iterations 300
>>>     0 KSP preconditioned resid norm 1.294272083271e-03 true resid norm
>>> 1.776945075651e+00 ||r(i)||/||b|| 1.000000000000e+00
>>>>      Matt
>>>>>> This is the kind of investigation you msut be comfortable with if you
>>>>>> want to experiment with these solvers.
>>>>>>     Matt
>>>>>>>>   Thanks,
>>>>>>>>      Matt
>>>>>>>>> Linear solve converged due to CONVERGED_RTOL iterations 2
>>>>>>>>> KSP Object: 1 MPI processes
>>>>>>>>>   type: gmres
>>>>>>>>>     GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
>>>>>>>>> Orthogonalization with no iterative refinement
>>>>>>>>>     GMRES: happy breakdown tolerance 1e-30
>>>>>>>>>   maximum iterations=10000, initial guess is zero
>>>>>>>>>   tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>>>>>>>>>   left preconditioning
>>>>>>>>>   has attached null space
>>>>>>>>>   using PRECONDITIONED norm type for convergence test
>>>>>>>>> PC Object: 1 MPI processes
>>>>>>>>>   type: fieldsplit
>>>>>>>>>     FieldSplit with Schur preconditioner, blocksize = 4,
>>>>>>>>> factorization FULL
>>>>>>>>>     Preconditioner for the Schur complement formed from user
>>>>>>>>> provided matrix
>>>>>>>>>     Split info:
>>>>>>>>>     Split number 0 Fields  0, 1, 2
>>>>>>>>>     Split number 1 Fields  3
>>>>>>>>>     KSP solver for A00 block
>>>>>>>>>       KSP Object:      (fieldsplit_0_)       1 MPI processes
>>>>>>>>>         type: gmres
>>>>>>>>> Gram-Schmidt Orthogonalization with no iterative refinement
>>>>>>>>> divergence=10000
>>>>>>>>>       PC Object:      (fieldsplit_0_)       1 MPI processes
>>>>>>>>>         type: ilu
>>>>>>>>>           ILU: out-of-place factorization
>>>>>>>>>           0 levels of fill
>>>>>>>>>           tolerance for zero pivot 2.22045e-14
>>>>>>>>>           using diagonal shift on blocks to prevent zero pivot
>>>>>>>>>           matrix ordering: natural
>>>>>>>>>           factor fill ratio given 1, needed 1
>>>>>>>>>             Factored matrix follows:
>>>>>>>>>               Matrix Object:               1 MPI processes
>>>>>>>>>                 type: seqaij
>>>>>>>>>                 rows=8232, cols=8232
>>>>>>>>>                 package used to perform factorization: petsc
>>>>>>>>>                 total: nonzeros=576000, allocated nonzeros=576000
>>>>>>>>>                 total number of mallocs used during MatSetValues
>>>>>>>>> calls =0
>>>>>>>>>                   using I-node routines: found 2744 nodes, limit
>>>>>>>>> used is 5
>>>>>>>>>         linear system matrix = precond matrix:
>>>>>>>>>           type: seqaij
>>>>>>>>>           total number of mallocs used during MatSetValues calls =0
>>>>>>>>>             using I-node routines: found 2744 nodes, limit used is
>>>>>>>>> 5
>>>>>>>>>     KSP solver for S = A11 - A10 inv(A00) A01
>>>>>>>>>       KSP Object:      (fieldsplit_1_)       1 MPI processes
>>>>>>>>>         type: gmres
>>>>>>>>> divergence=10000
>>>>>>>>>       PC Object:      (fieldsplit_1_)       1 MPI processes
>>>>>>>>>         type: ilu
>>>>>>>>>           0 levels of fill
>>>>>>>>>                 type: seqaij
>>>>>>>>>                 rows=2744, cols=2744
>>>>>>>>>                 total: nonzeros=64000, allocated nonzeros=64000
>>>>>>>>> calls =0
>>>>>>>>>                   not using I-node routines
>>>>>>>>>         linear system matrix followed by preconditioner matrix:
>>>>>>>>>           type: schurcomplement
>>>>>>>>>             Schur complement A11 - A10 inv(A00) A01
>>>>>>>>>             A11
>>>>>>>>>                 type: seqaij
>>>>>>>>> calls =0
>>>>>>>>>             A10
>>>>>>>>>                 type: seqaij
>>>>>>>>>                 rows=2744, cols=8232
>>>>>>>>>                 total: nonzeros=192000, allocated nonzeros=192000
>>>>>>>>> calls =0
>>>>>>>>>             KSP of A00
>>>>>>>>>               KSP Object:
>>>>>>>>>                 type: gmres
>>>>>>>>> divergence=10000
>>>>>>>>>               PC Object:
>>>>>>>>>                 type: ilu
>>>>>>>>>                   0 levels of fill
>>>>>>>>> pivot
>>>>>>>>> processes
>>>>>>>>>                         type: seqaij
>>>>>>>>> petsc
>>>>>>>>> nonzeros=576000
>>>>>>>>> limit used is 5
>>>>>>>>>                   type: seqaij
>>>>>>>>> calls =0
>>>>>>>>> used is 5
>>>>>>>>>             A01
>>>>>>>>>                 type: seqaij
>>>>>>>>>                 rows=8232, cols=2744
>>>>>>>>> calls =0
>>>>>>>>> used is 5
>>>>>>>>>           type: seqaij
>>>>>>>>>     type: seqaij
>>>>>>>>>     rows=10976, cols=10976, bs=4
>>>>>>>>>     total: nonzeros=1024000, allocated nonzeros=1024000
>>>>>>>>>       using I-node routines: found 2744 nodes, limit used is 5
>>>>>>>>>>    Matt
>>>>>>>>>>> I am testing a small problem with CONSTANT viscosity for grid
>>>>>>>>>>> size of 14^3 with the run time option:
>>>>>>>>>>> -ksp_type gcr -pc_type fieldsplit -pc_fieldsplit_type schur
>>>>>>>>>>> -fieldsplit_0_ksp_type gcr -fieldsplit_0_pc_type gamg
>>>>>>>>>>> -fieldsplit_0_ksp_monitor_true_residual -fieldsplit_0_ksp_converged_reason
>>>>>>>>>>> -fieldsplit_1_ksp_monitor_true_residual
>>>>>>>>>>> Here is my relevant code of the solve function:
>>>>>>>>>>> PetscErrorCode ierr;
>>>>>>>>>>>     PetscFunctionBeginUser;
>>>>>>>>>>>     ierr =
>>>>>>>>>>> DMKSPSetComputeRHS(mDa,computeRHSTaras3D,this);CHKERRQ(ierr);
>>>>>>>>>>>     ierr =
>>>>>>>>>>> DMKSPSetComputeOperators(mDa,computeMatrixTaras3D,this);CHKERRQ(ierr);
>>>>>>>>>>>     ierr = KSPSetDM(mKsp,mDa);CHKERRQ(ierr);              //mDa
>>>>>>>>>>> with dof = 4, vx,vy,vz and p.
>>>>>>>>>>>     ierr =
>>>>>>>>>>> KSPSetNullSpace(mKsp,mNullSpace);CHKERRQ(ierr);//nullSpace for the main
>>>>>>>>>>> system
>>>>>>>>>>>     ierr = KSPSetFromOptions(mKsp);CHKERRQ(ierr);
>>>>>>>>>>>     ierr = KSPSetUp(mKsp);CHKERRQ(ierr);
>>>>>>>>>>> //register the fieldsplits obtained from options.
>>>>>>>>>>>     //Setting up user PC for Schur Complement
>>>>>>>>>>>     ierr = KSPGetPC(mKsp,&mPc);CHKERRQ(ierr);
>>>>>>>>>>>     ierr =
>>>>>>>>>>> PCFieldSplitSchurPrecondition(mPc,PC_FIELDSPLIT_SCHUR_PRE_USER,mPcForSc);CHKERRQ(ierr);
>>>>>>>>>>>     KSP *subKsp;
>>>>>>>>>>>     PetscInt subKspPos = 0;
>>>>>>>>>>>     //Set up nearNullspace for A00 block.
>>>>>>>>>>>     ierr =
>>>>>>>>>>> PCFieldSplitGetSubKSP(mPc,&subKspPos,&subKsp);CHKERRQ(ierr);
>>>>>>>>>>>     MatNullSpace rigidBodyModes;
>>>>>>>>>>>     Vec coords;
>>>>>>>>>>>     ierr = DMGetCoordinates(mDa,&coords);CHKERRQ(ierr);
>>>>>>>>>>>     ierr =
>>>>>>>>>>> MatNullSpaceCreateRigidBody(coords,&rigidBodyModes);CHKERRQ(ierr);
>>>>>>>>>>>     Mat matA00;
>>>>>>>>>>>     ierr =
>>>>>>>>>>> KSPGetOperators(subKsp[0],&matA00,NULL,NULL);CHKERRQ(ierr);
>>>>>>>>>>>     ierr =
>>>>>>>>>>> MatSetNearNullSpace(matA00,rigidBodyModes);CHKERRQ(ierr);
>>>>>>>>>>>     ierr = MatNullSpaceDestroy(&rigidBodyModes);CHKERRQ(ierr);
>>>>>>>>>>>     //Position 1 => Ksp corresponding to Schur complement S on
>>>>>>>>>>> pressure space
>>>>>>>>>>>     subKspPos = 1;
>>>>>>>>>>>     ierr =
>>>>>>>>>>>     //Set up the null space of constant pressure.
>>>>>>>>>>>     ierr = KSPSetNullSpace(subKsp[1],mNullSpaceP);CHKERRQ(ierr);
>>>>>>>>>>>     PetscBool isNull;
>>>>>>>>>>>     Mat matSc;
>>>>>>>>>>>     ierr =
>>>>>>>>>>> KSPGetOperators(subKsp[1],&matSc,NULL,NULL);CHKERRQ(ierr);
>>>>>>>>>>>     ierr = MatNullSpaceTest(mNullSpaceP,matSc,&isNull);
>>>>>>>>>>>     if(!isNull)
>>>>>>>>>>>         SETERRQ(PETSC_COMM_WORLD,PETSC_ERR_PLIB,"not a valid
>>>>>>>>>>> pressure null space \n");
>>>>>>>>>>>     ierr = KSPGetOperators(mKsp,&mA,NULL,NULL);CHKERRQ(ierr);
>>>>>>>>>>>     ierr = MatNullSpaceTest(mNullSpace,mA,&isNull);CHKERRQ(ierr);
>>>>>>>>>>>     if(!isNull)
>>>>>>>>>>> system null space \n");
>>>>>>>>>>>     ierr = PetscFree(subKsp);CHKERRQ(ierr);
>>>>>>>>>>>     ierr = KSPSolve(mKsp,NULL,NULL);CHKERRQ(ierr);
>>>>>>>>>>>     ierr = KSPGetSolution(mKsp,&mX);CHKERRQ(ierr);
>>>>>>>>>>>     ierr = KSPGetRhs(mKsp,&mB);CHKERRQ(ierr);
>>>>>>>>>>>     PetscFunctionReturn(0);
>>>>>>>>>>> On Wed, Aug 7, 2013 at 2:15 PM, Matthew Knepley <
>>>>>>>>>>>> On Wed, Aug 7, 2013 at 7:07 AM, Bishesh Khanal <
>>>>>>>>>>>>> On Tue, Aug 6, 2013 at 11:34 PM, Matthew Knepley <
>>>>>>>>>>>>>> On Tue, Aug 6, 2013 at 10:59 AM, Bishesh Khanal <
>>>>>>>>>>>>>>> On Tue, Aug 6, 2013 at 4:40 PM, Matthew Knepley <
>>>>>>>>>>>>>>>> On Tue, Aug 6, 2013 at 8:06 AM, Bishesh Khanal <
>>>>>>>>>>>>>>>>> On Mon, Aug 5, 2013 at 4:14 PM, Matthew Knepley <
>>>>>>>>>>>>>>>>>> On Mon, Aug 5, 2013 at 8:48 AM, Bishesh Khanal <
>>>>>>>>>>>>>>>>>>> On Mon, Aug 5, 2013 at 3:17 PM, Matthew Knepley <
>>>>>>>>>>>>>>>>>>>> On Mon, Aug 5, 2013 at 7:54 AM, Bishesh Khanal <
>>>>>>>>>>>>>>>>>>>>> On Wed, Jul 17, 2013 at 9:48 PM, Jed Brown <
>>>>>>>>>>>>>>>>>>>>> jedbrown at mcs.anl.gov> wrote:
>>>>>>>>>>>>>>>>>>>>>> Bishesh Khanal <bisheshkh at gmail.com> writes:
>>>>>>>>>>>>>>>>>>>>>> > Now, I implemented two different approaches, each
>>>>>>>>>>>>>>>>>>>>>> for both 2D and 3D, in
>>>>>>>>>>>>>>>>>>>>>> > MATLAB. It works for the smaller sizes but I have
>>>>>>>>>>>>>>>>>>>>>> problems solving it for
>>>>>>>>>>>>>>>>>>>>>> > the problem size I need (250^3 grid size).
>>>>>>>>>>>>>>>>>>>>>> > I use staggered grid with p on cell centers, and
>>>>>>>>>>>>>>>>>>>>>> components of v on cell
>>>>>>>>>>>>>>>>>>>>>> > faces. Similar split up of K to cell center and
>>>>>>>>>>>>>>>>>>>>>> faces to account for the
>>>>>>>>>>>>>>>>>>>>>> > variable viscosity case)
>>>>>>>>>>>>>>>>>>>>>> Okay, you're using a staggered-grid finite difference
>>>>>>>>>>>>>>>>>>>>>> discretization of
>>>>>>>>>>>>>>>>>>>>>> variable-viscosity Stokes.  This is a common problem
>>>>>>>>>>>>>>>>>>>>>> and I recommend
>>>>>>>>>>>>>>>>>>>>>> starting with PCFieldSplit with Schur complement
>>>>>>>>>>>>>>>>>>>>>> reduction (make that
>>>>>>>>>>>>>>>>>>>>>> work first, then switch to block preconditioner).
>>>>>>>>>>>>>>>>>>>>>>  You can use PCLSC or
>>>>>>>>>>>>>>>>>>>>>> (probably better for you), assemble a preconditioning
>>>>>>>>>>>>>>>>>>>>>> matrix containing
>>>>>>>>>>>>>>>>>>>>>> the inverse viscosity in the pressure-pressure block.
>>>>>>>>>>>>>>>>>>>>>>  This diagonal
>>>>>>>>>>>>>>>>>>>>>> matrix is a spectrally equivalent (or nearly so,
>>>>>>>>>>>>>>>>>>>>>> depending on
>>>>>>>>>>>>>>>>>>>>>> discretization) approximation of the Schur
>>>>>>>>>>>>>>>>>>>>>> complement.  The velocity
>>>>>>>>>>>>>>>>>>>>>> block can be solved with algebraic multigrid.  Read
>>>>>>>>>>>>>>>>>>>>>> the PCFieldSplit
>>>>>>>>>>>>>>>>>>>>>> docs (follow papers as appropriate) and let us know
>>>>>>>>>>>>>>>>>>>>>> if you get stuck.
>>>>>>>>>>>>>>>>>>>>> I was trying to assemble the inverse viscosity
>>>>>>>>>>>>>>>>>>>>> diagonal matrix to use as the preconditioner for the Schur complement solve
>>>>>>>>>>>>>>>>>>>>> step as you suggested. I've few questions about the ways to implement this
>>>>>>>>>>>>>>>>>>>>> in Petsc:
>>>>>>>>>>>>>>>>>>>>> A naive approach that I can think of would be to
>>>>>>>>>>>>>>>>>>>>> create a vector with its components as reciprocal viscosities of the cell
>>>>>>>>>>>>>>>>>>>>> centers corresponding to the pressure variables, and then create a diagonal
>>>>>>>>>>>>>>>>>>>>> matrix from this vector. However I'm not sure about:
>>>>>>>>>>>>>>>>>>>>> How can I make this matrix, (say S_p) compatible to
>>>>>>>>>>>>>>>>>>>>> the Petsc distribution of the different rows of the main system matrix over
>>>>>>>>>>>>>>>>>>>>> different processors ? The main matrix was created using the DMDA structure
>>>>>>>>>>>>>>>>>>>>> with 4 dof as explained before.
>>>>>>>>>>>>>>>>>>>>> The main matrix correspond to the DMDA with 4 dofs but
>>>>>>>>>>>>>>>>>>>>> for the S_p matrix would correspond to only pressure space. Should the
>>>>>>>>>>>>>>>>>>>>> distribution of the rows of S_p among different processor not correspond to
>>>>>>>>>>>>>>>>>>>>> the distribution of the rhs vector, say h' if it is solving for p with Sp =
>>>>>>>>>>>>>>>>>>>>> h' where S = A11 inv(A00) A01 ?
>>>>>>>>>>>>>>>>>>>> PETSc distributed vertices, not dofs, so it never
>>>>>>>>>>>>>>>>>>>> breaks blocks. The P distribution is the same as the entire problem divided
>>>>>>>>>>>>>>>>>>>> by 4.
>>>>>>>>>>>>>>>>>>> Thanks Matt. So if I create a new DMDA with same grid
>>>>>>>>>>>>>>>>>>> size but with dof=1 instead of 4, the vertices for this new DMDA will be
>>>>>>>>>>>>>>>>>>> identically distributed as for the original DMDA ? Or should I inform PETSc
>>>>>>>>>>>>>>>>>>> by calling a particular function to make these two DMDA have identical
>>>>>>>>>>>>>>>>>>> distribution of the vertices ?
>>>>>>>>>>>>>>>>>> Yes.
>>>>>>>>>>>>>>>>>>>  Even then I think there might be a problem due to the
>>>>>>>>>>>>>>>>>>> presence of "fictitious pressure vertices". The system matrix (A) contains
>>>>>>>>>>>>>>>>>>> an identity corresponding to these fictitious pressure nodes, thus when
>>>>>>>>>>>>>>>>>>> using a -pc_fieldsplit_detect_saddle_point, will detect a A11 zero block of
>>>>>>>>>>>>>>>>>>> size that correspond to only non-fictitious P-nodes. So the preconditioner
>>>>>>>>>>>>>>>>>>> S_p for the Schur complement outer solve with Sp = h' will also need to
>>>>>>>>>>>>>>>>>>> correspond to only the non-fictitious P-nodes. This means its size does not
>>>>>>>>>>>>>>>>>>> directly correspond to the DMDA grid defined for the original problem.
>>>>>>>>>>>>>>>>>>> Could you please suggest an efficient way of assembling this S_p matrix ?
>>>>>>>>>>>>>>>>>> Don't use detect_saddle, but split it by fields
>>>>>>>>>>>>>>>>>> -pc_fieldsplit_0_fields 0,1,2 -pc_fieldsplit_1_fields 4
>>>>>>>>>>>>>>>>> How can I set this split in the code itself without giving
>>>>>>>>>>>>>>>>> it as a command line option when the system matrix is assembled from the
>>>>>>>>>>>>>>>>> DMDA for the whole system with 4 dofs. (i.e. *without*using the DMComposite or
>>>>>>>>>>>>>>>>> *without* using the nested block matrices to assemble
>>>>>>>>>>>>>>>>> different blocks separately and then combine them together).
>>>>>>>>>>>>>>>>> I need the split to get access to the fieldsplit_1_ksp in
>>>>>>>>>>>>>>>>> my code, because not using detect_saddle_point means I cannot use
>>>>>>>>>>>>>>>>> -fieldsplit_1_ksp_constant_null_space due to the presence of identity for
>>>>>>>>>>>>>>>>> the fictitious pressure nodes present in the fieldsplit_1_ block. I need to
>>>>>>>>>>>>>>>>> use PCFieldSplitGetSubKsp() so that I can set proper null-space basis.
>>>>>>>>>>>>>>>> This is currently a real problem with the DMDA. In the
>>>>>>>>>>>>>>>> unstructured case, where we always need specialized spaces, you can
>>>>>>>>>>>>>>>> use something like
>>>>>>>>>>>>>>>>     PetscObject  pressure;
>>>>>>>>>>>>>>>>     MatNullSpace nullSpacePres;
>>>>>>>>>>>>>>>>     ierr = DMGetField(dm, 1, &pressure);CHKERRQ(ierr);
>>>>>>>>>>>>>>>>     ierr = MatNullSpaceCreate(PetscObjectComm(pressure),
>>>>>>>>>>>>>>>> PETSC_TRUE, 0, NULL, &nullSpacePres);CHKERRQ(ierr);
>>>>>>>>>>>>>>>>     ierr = PetscObjectCompose(pressure, "nullspace",
>>>>>>>>>>>>>>>> (PetscObject) nullSpacePres);CHKERRQ(ierr);
>>>>>>>>>>>>>>>>     ierr =
>>>>>>>>>>>>>>>> MatNullSpaceDestroy(&nullSpacePres);CHKERRQ(ierr);
>>>>>>>>>>>>>>>> and then DMGetSubDM() uses this information to attach the
>>>>>>>>>>>>>>>> null space to the IS that is created using the information in the
>>>>>>>>>>>>>>>> PetscSection.
>>>>>>>>>>>>>>>> If you use a PetscSection to set the data layout over the
>>>>>>>>>>>>>>>> DMDA, I think this works correctly, but this has not been tested at all and
>>>>>>>>>>>>>>>> is very
>>>>>>>>>>>>>>>> new code. Eventually, I think we want all DMs to use this
>>>>>>>>>>>>>>>> mechanism, but we are still working it out.
>>>>>>>>>>>>>>> Currently I do not use PetscSection. If this makes a cleaner
>>>>>>>>>>>>>>> approach, I'd try it too but may a bit later (right now I'd like test my
>>>>>>>>>>>>>>> model with a quickfix even if it means a little dirty code!)
>>>>>>>>>>>>>>>> Bottom line: For custom null spaces using the default
>>>>>>>>>>>>>>>> layout in DMDA, you need to take apart the PCFIELDSPLIT after it has been
>>>>>>>>>>>>>>>> setup,
>>>>>>>>>>>>>>>> which is somewhat subtle. You need to call KSPSetUp() and
>>>>>>>>>>>>>>>> then reach in and get the PC, and the subKSPs. I don't like this at all,
>>>>>>>>>>>>>>>> but we
>>>>>>>>>>>>>>>> have not reorganized that code (which could be very simple
>>>>>>>>>>>>>>>> and inflexible since its very structured).
>>>>>>>>>>>>>>> So I tried to get this approach working but I could not
>>>>>>>>>>>>>>> succeed and encountered some errors. Here is a code snippet:
>>>>>>>>>>>>>>> //mDa is the DMDA that describes the whole grid with all 4
>>>>>>>>>>>>>>> dofs (3 velocity components and 1 pressure comp.)
>>>>>>>>>>>>>>> ierr =
>>>>>>>>>>>>>>>     ierr =
>>>>>>>>>>>>>>>     ierr =
>>>>>>>>>>>>>>> KSPSetNullSpace(mKsp,mNullSpaceSystem);CHKERRQ(ierr);   //I've the
>>>>>>>>>>>>>>> mNullSpaceSystem based on mDa, that contains a null space basis for the
>>>>>>>>>>>>>>> complete system.
>>>>>>>>>>>>>>>     ierr =
>>>>>>>>>>>>>>> //This I expect would register these options I give:-pc_type fieldsplit
>>>>>>>>>>>>>>> -pc_fieldsplit_type schur -pc_fieldsplit_0_fields 0,1,2
>>>>>>>>>>>>>>> //-pc_fieldsplit_1_fields 3
>>>>>>>>>>>>>>>     ierr = KSPGetPC(mKsp,&mPcOuter);     //Now get the PC
>>>>>>>>>>>>>>> that was obtained from the options (fieldsplit)
>>>>>>>>>>>>>>>     ierr =
>>>>>>>>>>>>>>> PCFieldSplitSchurPrecondition(mPcOuter,PC_FIELDSPLIT_SCHUR_PRE_USER,mPcForSc);CHKERRQ(ierr);
>>>>>>>>>>>>>>> //I have created the matrix mPcForSc using a DMDA with identical //size to
>>>>>>>>>>>>>>> mDa but with dof=1 corresponding to the pressure nodes (say mDaPressure).
>>>>>>>>>>>>>>>   ierr = PCSetUp(mPcOuter);CHKERRQ(ierr);
>>>>>>>>>>>>>>>     KSP *kspSchur;
>>>>>>>>>>>>>>>     PetscInt kspSchurPos = 1;
>>>>>>>>>>>>>>>     ierr =
>>>>>>>>>>>>>>> PCFieldSplitGetSubKSP(mPcOuter,&kspSchurPos,&kspSchur);CHKERRQ(ierr);
>>>>>>>>>>>>>>>     ierr =
>>>>>>>>>>>>>>> KSPSetNullSpace(kspSchur[1],mNullSpacePressure);CHKERRQ(ierr);
>>>>>>>>>>>>>>> //The null space is the one that correspond to only pressure nodes, created
>>>>>>>>>>>>>>> using the mDaPressure.
>>>>>>>>>>>>>>>     ierr = PetscFree(kspSchur);CHKERRQ(ierr);
>>>>>>>>>>>>>> Sorry, you need to return to the old DMDA behavior, so you
>>>>>>>>>>>>>> want
>>>>>>>>>>>>> Thanks, with this it seems I can attach the null space
>>>>>>>>>>>>> properly, but I have a question regarding whether the Schur complement ksp
>>>>>>>>>>>>> solver is actually using the preconditioner matrix I provide.
>>>>>>>>>>>>> When using -ksp_view, the outer level pc object of type
>>>>>>>>>>>>> fieldsplit does report that: "Preconditioner for the Schur complement
>>>>>>>>>>>>> formed from user provided matrix", but in the KSP solver for Schur
>>>>>>>>>>>>> complement S, the pc object (fieldsplit_1_) is of type ilu and doesn't say
>>>>>>>>>>>>> that it is using the matrix I provide. Am I missing something here ?
>>>>>>>>>>>>> Below are the relevant commented code snippet and the output
>>>>>>>>>>>>> of the -ksp_view
>>>>>>>>>>>>> (The options I used: -pc_type fieldsplit -pc_fieldsplit_type
>>>>>>>>>>>>> schur -pc_fieldsplit_dm_splits 0 -pc_fieldsplit_0_fields 0,1,2
>>>>>>>>>>>>> -pc_fieldsplit_1_fields 3 -ksp_converged_reason -ksp_view )
>>>>>>>>>>>> If ILU does not error, it means it is using your matrix,
>>>>>>>>>>>> because the Schur complement matrix cannot be factored, and FS says it is
>>>>>>>>>>>> using your matrix.
>>>>>>>>>>>>    Matt
>>>>>>>>>>>>> Code snippet:
>>>>>>>>>>>>> ierr = KSPSetNullSpace(mKsp,mNullSpaceSystem);CHKERRQ(ierr);
>>>>>>>>>>>>> //The nullspace for the whole system
>>>>>>>>>>>>>     ierr =
>>>>>>>>>>>>> //Set up mKsp with the options provided with fieldsplit and the fields
>>>>>>>>>>>>> associated with the two splits.
>>>>>>>>>>>>>     ierr = KSPGetPC(mKsp,&mPcOuter);CHKERRQ(ierr);
>>>>>>>>>>>>>                //Get the fieldsplit pc set up from the options
>>>>>>>>>>>>>     ierr =
>>>>>>>>>>>>> //Use mPcForSc as the preconditioner for Schur Complement
>>>>>>>>>>>>>     KSP *kspSchur;
>>>>>>>>>>>>>     ierr =
>>>>>>>>>>>>>     ierr =
>>>>>>>>>>>>> //Attach the null-space for the Schur complement ksp solver.
>>>>>>>>>>>>> the output of the -ksp_view
>>>>>>>>>>>>>   type: gmres
>>>>>>>>>>>>>   type: fieldsplit
>>>>>>>>>>>>> factorization FULL
>>>>>>>>>>>>> provided matrix
>>>>>>>>>>>>>     Split info:
>>>>>>>>>>>>>         type: gmres
>>>>>>>>>>>>> divergence=10000
>>>>>>>>>>>>>         type: ilu
>>>>>>>>>>>>>           0 levels of fill
>>>>>>>>>>>>>                 type: seqaij
>>>>>>>>>>>>>                 rows=2187, cols=2187
>>>>>>>>>>>>>                 total: nonzeros=140625, allocated
>>>>>>>>>>>>> nonzeros=140625
>>>>>>>>>>>>>                   using I-node routines: found 729 nodes,
>>>>>>>>>>>>> limit used is 5
>>>>>>>>>>>>>           type: seqaij
>>>>>>>>>>>>>           total: nonzeros=140625, allocated nonzeros=140625
>>>>>>>>>>>>> calls =0
>>>>>>>>>>>>>             using I-node routines: found 729 nodes, limit used
>>>>>>>>>>>>> is 5
>>>>>>>>>>>>>         type: gmres
>>>>>>>>>>>>> divergence=10000
>>>>>>>>>>>>>         type: ilu
>>>>>>>>>>>>>           0 levels of fill
>>>>>>>>>>>>>                 type: seqaij
>>>>>>>>>>>>>                 rows=729, cols=729
>>>>>>>>>>>>>                 total: nonzeros=15625, allocated nonzeros=15625
>>>>>>>>>>>>>           rows=729, cols=729
>>>>>>>>>>>>>             A11
>>>>>>>>>>>>>                 type: seqaij
>>>>>>>>>>>>>                 rows=729, cols=729
>>>>>>>>>>>>>             A10
>>>>>>>>>>>>>                 type: seqaij
>>>>>>>>>>>>>                 rows=729, cols=2187
>>>>>>>>>>>>>                 total: nonzeros=46875, allocated nonzeros=46875
>>>>>>>>>>>>>             KSP of A00
>>>>>>>>>>>>>               KSP Object:
>>>>>>>>>>>>>                 type: gmres
>>>>>>>>>>>>> (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
>>>>>>>>>>>>> divergence=10000
>>>>>>>>>>>>> test
>>>>>>>>>>>>>               PC Object:
>>>>>>>>>>>>>                 type: ilu
>>>>>>>>>>>>>                   0 levels of fill
>>>>>>>>>>>>> zero pivot
>>>>>>>>>>>>>                       Matrix Object:                       1
>>>>>>>>>>>>> MPI processes
>>>>>>>>>>>>>                         type: seqaij
>>>>>>>>>>>>> petsc
>>>>>>>>>>>>> nonzeros=140625
>>>>>>>>>>>>>                   type: seqaij
>>>>>>>>>>>>> nonzeros=140625
>>>>>>>>>>>>> limit used is 5
>>>>>>>>>>>>>             A01
>>>>>>>>>>>>>                 type: seqaij
>>>>>>>>>>>>>                 rows=2187, cols=729
>>>>>>>>>>>>> limit used is 5
>>>>>>>>>>>>>           type: seqaij
>>>>>>>>>>>>>           rows=729, cols=729
>>>>>>>>>>>>> calls =0
>>>>>>>>>>>>>     type: seqaij
>>>>>>>>>>>>>     rows=2916, cols=2916, bs=4
>>>>>>>>>>>>>     total: nonzeros=250000, allocated nonzeros=250000
>>>>>>>>>>>>>       using I-node routines: found 729 nodes, limit used is 5
>>>>>>>>>>>>>> or
>>>>>>>>>>>>>>   PCFieldSplitSetDMSplits(pc, PETSC_FALSE)
>>>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>>>      Matt
>>>>>>>>>>>>>>> The errors I get when running with options: -pc_type
>>>>>>>>>>>>>>> fieldsplit -pc_fieldsplit_type schur -pc_fieldsplit_0_fields 0,1,2
>>>>>>>>>>>>>>> [0]PETSC ERROR: --------------------- Error Message
>>>>>>>>>>>>>>> [0]PETSC ERROR: No support for this operation for this
>>>>>>>>>>>>>>> object type!
>>>>>>>>>>>>>>> [0]PETSC ERROR: Support only implemented for 2d!
>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>> [0]PETSC ERROR: Petsc Release Version 3.4.2, Jul, 02, 2013
>>>>>>>>>>>>>>> [0]PETSC ERROR: See docs/changes/index.html for recent
>>>>>>>>>>>>>>> updates.
>>>>>>>>>>>>>>> [0]PETSC ERROR: See docs/faq.html for hints about trouble
>>>>>>>>>>>>>>> shooting.
>>>>>>>>>>>>>>> [0]PETSC ERROR: See docs/index.html for manual pages.
>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>> [0]PETSC ERROR: src/AdLemMain on a arch-linux2-cxx-debug
>>>>>>>>>>>>>>> named edwards by bkhanal Tue Aug  6 17:35:30 2013
>>>>>>>>>>>>>>> [0]PETSC ERROR: Libraries linked from
>>>>>>>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/arch-linux2-cxx-debug/lib
>>>>>>>>>>>>>>> [0]PETSC ERROR: Configure run at Fri Jul 19 14:25:01 2013
>>>>>>>>>>>>>>> [0]PETSC ERROR: Configure options --with-cc=gcc
>>>>>>>>>>>>>>> --with-fc=g77 --with-cxx=g++ --download-f-blas-lapack=1 --download-mpich=1
>>>>>>>>>>>>>>> -with-clanguage=cxx --download-hypre=1
>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>> [0]PETSC ERROR: DMCreateSubDM_DA() line 188 in
>>>>>>>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/dm/impls/da/dacreate.c
>>>>>>>>>>>>>>> [0]PETSC ERROR: DMCreateSubDM() line 1267 in
>>>>>>>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/dm/interface/dm.c
>>>>>>>>>>>>>>> [0]PETSC ERROR: PCFieldSplitSetDefaults() line 337 in
>>>>>>>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/ksp/pc/impls/fieldsplit/fieldsplit.c
>>>>>>>>>>>>>>> [0]PETSC ERROR: PCSetUp_FieldSplit() line 458 in
>>>>>>>>>>>>>>> [0]PETSC ERROR: PCSetUp() line 890 in
>>>>>>>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/ksp/pc/interface/precon.c
>>>>>>>>>>>>>>> [0]PETSC ERROR: KSPSetUp() line 278 in
>>>>>>>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/ksp/ksp/interface/itfunc.c
>>>>>>>>>>>>>>> [0]PETSC ERROR: solveModel() line 181 in
>>>>>>>>>>>>>>> "unknowndirectory/"/user/bkhanal/home/works/AdLemModel/src/PetscAdLemTaras3D.cxx
>>>>>>>>>>>>>>> WARNING! There are options you set that were not used!
>>>>>>>>>>>>>>> WARNING! could be spelling mistake, etc!
>>>>>>>>>>>>>>> Option left: name:-pc_fieldsplit_1_fields value: 3
>>>>>>>>>>>>>>>>    Matt
>>>>>>>>>>>>>>>>>>    Matt
>>>>>>>>>>>>>>>>>>>>    Matt
>>>>>>>>>>>>>>>>>>>> What most experimenters take for granted before they
>>>>>>>>>>>>>>>>>>>> begin their experiments is infinitely more interesting than any results to
>>>>>>>>>>>>>>>>>>>> which their experiments lead.
>>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130823/9ad4a008/attachment-0001.html>
