[petsc-users] discontinuous viscosity stokes equation 3D staggered grid
Bishesh Khanal bisheshkh at gmail.com
Fri Aug 23 08:30:59 CDT 2013
On Fri, Aug 23, 2013 at 3:16 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Aug 23, 2013 at 8:01 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>> On Fri, Aug 23, 2013 at 2:53 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>> On Fri, Aug 23, 2013 at 7:46 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>>> On Fri, Aug 23, 2013 at 2:33 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>> On Fri, Aug 23, 2013 at 7:25 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>>>>> On Fri, Aug 23, 2013 at 2:09 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>>> On Fri, Aug 23, 2013 at 4:31 AM, Bishesh Khanal <bisheshkh at gmail.com
>>>>>>> > wrote:
>>>>>>>> Thanks Matt and Mark for comments in using near null space
>>>>>>>> [question I asked in the thread with subject: *problem
>>>>>>>> (Segmentation voilation) using -pc_type hypre -pc_hypre_type -pilut with
>>>>>>>> multiple nodes in a cluster*].
>>>>>>>> So I understood that I have to set a nearNullSpace to A00 block
>>>>>>>> where the null space correspond to the rigid body motion. I tried it but
>>>>>>>> still the gamg just keeps on iterating and convergence is very very slow. I
>>>>>>>> am not sure what the problem is, right now gamg does not even work for the
>>>>>>>> constant viscosity case.
>>>>>>>> I have set up the following in my code:
>>>>>>>> 1. null space for the whole system A 2. null space for the Schur
>>>>>>>> complement S 3. Near null space for A00 4. a user preconditioner matrix of
>>>>>>>> inverse viscosity in the diagonal for S.
>>>>>>> If you want to debug solvers, you HAVE to send -ksp_view.
>>>>>> When I use gamg, the -fieldsplit_0_ksp was iterating on and on so
>>>>>> didn't get to the end to get -ksp_view results.
>>>>>> Instead here I have put the -ksp_view output when running the program
>>>>>> with following options: (In this case I get the results)
>>>>>> -pc_type fieldsplit -pc_fieldsplit_type schur
>>>>>> -pc_fieldsplit_dm_splits 0 -pc_fieldsplit_0_fields 0,1,2
>>>>>> -pc_fieldsplit_1_fields 3 -ksp_converged_reason -ksp_view
>>>>> Okay, that looks fine. Does
>>>>>   -fieldsplit_0_pc_type lu
>>>>>   - fieldsplit_1_ksp_rtol 1.0e-10
>>>>> converge in one Iterate?
>>>>> What matrix did you attach as the preconditioner matrix for
>>>>> fieldsplit_1_?
>>>> I used a diagonal matrix with reciprocal of viscosity values of the
>>>> corresponding cell centers as the preconditioner.
>>>> with the options  -fieldsplit_0_pc_type lu  - fieldsplit_1_ksp_rtol
>>>> 1.0e-10 -fieldsplit_1_ksp_converged_reason -ksp_converged_reason
>>>> I get the following output which means the outer ksp did converge in
>>>> one iterate I guess.
>>>>   Linear solve converged due to CONVERGED_RTOL iterations 18
>>> Okay, so A_00 is nonsingular, and the system seems to solve alright.
>>> What do you get for
>>>   -fieldsplit_0_ksp_max_it 30
>>>   -fieldsplit_0_pc_type gamg
>>>   -fieldsplit_0_ksp_converged_reason
>> It fieldsplit_0_ does not converge in 30 iterations. It gives:
>>  Linear solve converged due to CONVERGED_ATOL iterations 0
>> Linear solve did not converge due to DIVERGED_ITS iterations 30
>> and continues with the same message.
> So what would you do? Give up?
> No, I don't want to give up :)
>   -fieldsplit_0_ksp_gmres_restart 200
> The idea is to figure out what is going on:
>   -fieldsplit_0_ksp_monitor_true_residual
> I have tried these options before too, the residual is decreasing very
very slowly,  but I've not been able to figure out why. (using hypre does
converge although slowly again, but I had problems using hypre with
multiple nodes in a cluster with segmentation fault (we discussed that in
another thread!) )
e.g a snapshot of the output:
    Residual norms for fieldsplit_0_ solve.
    0 KSP preconditioned resid norm 0.000000000000e+00 true resid norm
0.000000000000e+00 ||r(i)||/||b||           -nan
    0 KSP preconditioned resid norm 2.619231455875e-01 true resid norm
3.637306695895e+02 ||r(i)||/||b|| 1.000000000000e+00
    1 KSP preconditioned resid norm 9.351491725479e-02 true resid norm
6.013334574957e+01 ||r(i)||/||b|| 1.653238255038e-01
    2 KSP preconditioned resid norm 6.010357491087e-02 true resid norm
3.664473273769e+01 ||r(i)||/||b|| 1.007468871928e-01
    3 KSP preconditioned resid norm 6.006968012944e-02 true resid norm
3.696451770148e+01 ||r(i)||/||b|| 1.016260678353e-01
    4 KSP preconditioned resid norm 4.418407037098e-02 true resid norm
3.184810838034e+01 ||r(i)||/||b|| 8.755959022176e-02
  93 KSP preconditioned resid norm 4.549506047737e-04 true resid norm
2.877594552685e+00 ||r(i)||/||b|| 7.911333283864e-03
   94 KSP preconditioned resid norm 4.515424416235e-04 true resid norm
2.875249044668e+00 ||r(i)||/||b|| 7.904884809172e-03
   95 KSP preconditioned resid norm 4.277647876573e-04 true resid norm
2.830418831358e+00 ||r(i)||/||b|| 7.781633686685e-03
   96 KSP preconditioned resid norm 4.244529173876e-04 true resid norm
2.807041401408e+00 ||r(i)||/||b|| 7.717362422521e-03
   97 KSP preconditioned resid norm 4.138326570674e-04 true resid norm
2.793663020386e+00 ||r(i)||/||b|| 7.680581413547e-03
   98 KSP preconditioned resid norm 3.869979433609e-04 true resid norm
2.715150386650e+00 ||r(i)||/||b|| 7.464727650583e-03
   99 KSP preconditioned resid norm 3.847873979265e-04 true resid norm
2.706008990336e+00 ||r(i)||/||b|| 7.439595328571e-03
  294 KSP preconditioned resid norm 1.416482289961e-04 true resid norm
2.735750748819e+00 ||r(i)||/||b|| 7.521363958412e-03
  295 KSP preconditioned resid norm 1.415389087364e-04 true resid norm
2.742638608355e+00 ||r(i)||/||b|| 7.540300661064e-03
  296 KSP preconditioned resid norm 1.414967651105e-04 true resid norm
2.747224243968e+00 ||r(i)||/||b|| 7.552907889424e-03
  297 KSP preconditioned resid norm 1.413843018303e-04 true resid norm
2.752574248710e+00 ||r(i)||/||b|| 7.567616587891e-03
  298 KSP preconditioned resid norm 1.411747949695e-04 true resid norm
2.765459647367e+00 ||r(i)||/||b|| 7.603042246859e-03
  299 KSP preconditioned resid norm 1.411609742082e-04 true resid norm
2.765900464868e+00 ||r(i)||/||b|| 7.604254180683e-03
  300 KSP preconditioned resid norm 1.409844332838e-04 true resid norm
2.771790506811e+00 ||r(i)||/||b|| 7.620447596402e-03
  Linear solve did not converge due to DIVERGED_ITS iterations 300
    0 KSP preconditioned resid norm 1.294272083271e-03 true resid norm
1.776945075651e+00 ||r(i)||/||b|| 1.000000000000e+00
>      Matt
>>> This is the kind of investigation you msut be comfortable with if you
>>> want to experiment with these solvers.
>>>     Matt
>>>>>   Thanks,
>>>>>      Matt
>>>>>> Linear solve converged due to CONVERGED_RTOL iterations 2
>>>>>> KSP Object: 1 MPI processes
>>>>>>   type: gmres
>>>>>>     GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
>>>>>> Orthogonalization with no iterative refinement
>>>>>>     GMRES: happy breakdown tolerance 1e-30
>>>>>>   maximum iterations=10000, initial guess is zero
>>>>>>   tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>>>>>>   left preconditioning
>>>>>>   has attached null space
>>>>>>   using PRECONDITIONED norm type for convergence test
>>>>>> PC Object: 1 MPI processes
>>>>>>   type: fieldsplit
>>>>>>     FieldSplit with Schur preconditioner, blocksize = 4,
>>>>>> factorization FULL
>>>>>>     Preconditioner for the Schur complement formed from user provided
>>>>>> matrix
>>>>>>     Split info:
>>>>>>     Split number 0 Fields  0, 1, 2
>>>>>>     Split number 1 Fields  3
>>>>>>     KSP solver for A00 block
>>>>>>       KSP Object:      (fieldsplit_0_)       1 MPI processes
>>>>>>         type: gmres
>>>>>> Gram-Schmidt Orthogonalization with no iterative refinement
>>>>>>       PC Object:      (fieldsplit_0_)       1 MPI processes
>>>>>>         type: ilu
>>>>>>           ILU: out-of-place factorization
>>>>>>           0 levels of fill
>>>>>>           tolerance for zero pivot 2.22045e-14
>>>>>>           using diagonal shift on blocks to prevent zero pivot
>>>>>>           matrix ordering: natural
>>>>>>           factor fill ratio given 1, needed 1
>>>>>>             Factored matrix follows:
>>>>>>               Matrix Object:               1 MPI processes
>>>>>>                 type: seqaij
>>>>>>                 rows=8232, cols=8232
>>>>>>                 package used to perform factorization: petsc
>>>>>>                 total: nonzeros=576000, allocated nonzeros=576000
>>>>>>                 total number of mallocs used during MatSetValues
>>>>>> calls =0
>>>>>>                   using I-node routines: found 2744 nodes, limit used
>>>>>> is 5
>>>>>>         linear system matrix = precond matrix:
>>>>>>           type: seqaij
>>>>>>           total number of mallocs used during MatSetValues calls =0
>>>>>>             using I-node routines: found 2744 nodes, limit used is 5
>>>>>>     KSP solver for S = A11 - A10 inv(A00) A01
>>>>>>       KSP Object:      (fieldsplit_1_)       1 MPI processes
>>>>>>         type: gmres
>>>>>>       PC Object:      (fieldsplit_1_)       1 MPI processes
>>>>>>         type: ilu
>>>>>>           0 levels of fill
>>>>>>                 type: seqaij
>>>>>>                 rows=2744, cols=2744
>>>>>>                 total: nonzeros=64000, allocated nonzeros=64000
>>>>>> calls =0
>>>>>>                   not using I-node routines
>>>>>>         linear system matrix followed by preconditioner matrix:
>>>>>>           type: schurcomplement
>>>>>>             Schur complement A11 - A10 inv(A00) A01
>>>>>>             A11
>>>>>>                 type: seqaij
>>>>>> calls =0
>>>>>>             A10
>>>>>>                 type: seqaij
>>>>>>                 rows=2744, cols=8232
>>>>>>                 total: nonzeros=192000, allocated nonzeros=192000
>>>>>> calls =0
>>>>>>             KSP of A00
>>>>>> 1 MPI processes
>>>>>>                 type: gmres
>>>>>> divergence=10000
>>>>>> MPI processes
>>>>>>                 type: ilu
>>>>>>                   0 levels of fill
>>>>>> processes
>>>>>>                         type: seqaij
>>>>>> nonzeros=576000
>>>>>> limit used is 5
>>>>>>                   type: seqaij
>>>>>> calls =0
>>>>>> used is 5
>>>>>>             A01
>>>>>>                 type: seqaij
>>>>>>                 rows=8232, cols=2744
>>>>>> calls =0
>>>>>> is 5
>>>>>>           type: seqaij
>>>>>>     type: seqaij
>>>>>>     rows=10976, cols=10976, bs=4
>>>>>>     total: nonzeros=1024000, allocated nonzeros=1024000
>>>>>>>    Matt
>>>>>>>> I am testing a small problem with CONSTANT viscosity for grid size
>>>>>>>> of 14^3 with the run time option:
>>>>>>>> -ksp_type gcr -pc_type fieldsplit -pc_fieldsplit_type schur
>>>>>>>> -fieldsplit_0_ksp_type gcr -fieldsplit_0_pc_type gamg
>>>>>>>> -fieldsplit_0_ksp_monitor_true_residual -fieldsplit_0_ksp_converged_reason
>>>>>>>> -fieldsplit_1_ksp_monitor_true_residual
>>>>>>>> Here is my relevant code of the solve function:
>>>>>>>> PetscErrorCode ierr;
>>>>>>>>     PetscFunctionBeginUser;
>>>>>>>>     ierr =
>>>>>>>> DMKSPSetComputeRHS(mDa,computeRHSTaras3D,this);CHKERRQ(ierr);
>>>>>>>>     ierr =
>>>>>>>> DMKSPSetComputeOperators(mDa,computeMatrixTaras3D,this);CHKERRQ(ierr);
>>>>>>>>     ierr = KSPSetDM(mKsp,mDa);CHKERRQ(ierr);              //mDa
>>>>>>>> with dof = 4, vx,vy,vz and p.
>>>>>>>>     ierr =
>>>>>>>> KSPSetNullSpace(mKsp,mNullSpace);CHKERRQ(ierr);//nullSpace for the main
>>>>>>>> system
>>>>>>>>     ierr = KSPSetFromOptions(mKsp);CHKERRQ(ierr);
>>>>>>>>     ierr = KSPSetUp(mKsp);CHKERRQ(ierr);
>>>>>>>> //register the fieldsplits obtained from options.
>>>>>>>>     //Setting up user PC for Schur Complement
>>>>>>>>     ierr = KSPGetPC(mKsp,&mPc);CHKERRQ(ierr);
>>>>>>>>     ierr =
>>>>>>>> PCFieldSplitSchurPrecondition(mPc,PC_FIELDSPLIT_SCHUR_PRE_USER,mPcForSc);CHKERRQ(ierr);
>>>>>>>>     KSP *subKsp;
>>>>>>>>     PetscInt subKspPos = 0;
>>>>>>>>     //Set up nearNullspace for A00 block.
>>>>>>>>     ierr =
>>>>>>>> PCFieldSplitGetSubKSP(mPc,&subKspPos,&subKsp);CHKERRQ(ierr);
>>>>>>>>     MatNullSpace rigidBodyModes;
>>>>>>>>     Vec coords;
>>>>>>>>     ierr = DMGetCoordinates(mDa,&coords);CHKERRQ(ierr);
>>>>>>>>     ierr =
>>>>>>>> MatNullSpaceCreateRigidBody(coords,&rigidBodyModes);CHKERRQ(ierr);
>>>>>>>>     Mat matA00;
>>>>>>>>     ierr =
>>>>>>>> KSPGetOperators(subKsp[0],&matA00,NULL,NULL);CHKERRQ(ierr);
>>>>>>>>     ierr = MatSetNearNullSpace(matA00,rigidBodyModes);CHKERRQ(ierr);
>>>>>>>>     ierr = MatNullSpaceDestroy(&rigidBodyModes);CHKERRQ(ierr);
>>>>>>>>     //Position 1 => Ksp corresponding to Schur complement S on
>>>>>>>> pressure space
>>>>>>>>     subKspPos = 1;
>>>>>>>>     ierr =
>>>>>>>>     //Set up the null space of constant pressure.
>>>>>>>>     ierr = KSPSetNullSpace(subKsp[1],mNullSpaceP);CHKERRQ(ierr);
>>>>>>>>     PetscBool isNull;
>>>>>>>>     Mat matSc;
>>>>>>>>     ierr =
>>>>>>>> KSPGetOperators(subKsp[1],&matSc,NULL,NULL);CHKERRQ(ierr);
>>>>>>>>     ierr = MatNullSpaceTest(mNullSpaceP,matSc,&isNull);
>>>>>>>>     if(!isNull)
>>>>>>>>         SETERRQ(PETSC_COMM_WORLD,PETSC_ERR_PLIB,"not a valid
>>>>>>>> pressure null space \n");
>>>>>>>>     ierr = KSPGetOperators(mKsp,&mA,NULL,NULL);CHKERRQ(ierr);
>>>>>>>>     ierr = MatNullSpaceTest(mNullSpace,mA,&isNull);CHKERRQ(ierr);
>>>>>>>>     if(!isNull)
>>>>>>>>         SETERRQ(PETSC_COMM_WORLD,PETSC_ERR_PLIB,"not a valid system
>>>>>>>> null space \n");
>>>>>>>>     ierr = PetscFree(subKsp);CHKERRQ(ierr);
>>>>>>>>     ierr = KSPSolve(mKsp,NULL,NULL);CHKERRQ(ierr);
>>>>>>>>     ierr = KSPGetSolution(mKsp,&mX);CHKERRQ(ierr);
>>>>>>>>     ierr = KSPGetRhs(mKsp,&mB);CHKERRQ(ierr);
>>>>>>>>     PetscFunctionReturn(0);
>>>>>>>> On Wed, Aug 7, 2013 at 2:15 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>>>>> On Wed, Aug 7, 2013 at 7:07 AM, Bishesh Khanal <
>>>>>>>>> bisheshkh at gmail.com> wrote:
>>>>>>>>>> On Tue, Aug 6, 2013 at 11:34 PM, Matthew Knepley <
>>>>>>>>>>> On Tue, Aug 6, 2013 at 10:59 AM, Bishesh Khanal <
>>>>>>>>>>>> On Tue, Aug 6, 2013 at 4:40 PM, Matthew Knepley <
>>>>>>>>>>>>> On Tue, Aug 6, 2013 at 8:06 AM, Bishesh Khanal <
>>>>>>>>>>>>>> On Mon, Aug 5, 2013 at 4:14 PM, Matthew Knepley <
>>>>>>>>>>>>>>> On Mon, Aug 5, 2013 at 8:48 AM, Bishesh Khanal <
>>>>>>>>>>>>>>>> On Mon, Aug 5, 2013 at 3:17 PM, Matthew Knepley <
>>>>>>>>>>>>>>>>> On Mon, Aug 5, 2013 at 7:54 AM, Bishesh Khanal <
>>>>>>>>>>>>>>>>>> On Wed, Jul 17, 2013 at 9:48 PM, Jed Brown <
>>>>>>>>>>>>>>>>>> jedbrown at mcs.anl.gov> wrote:
>>>>>>>>>>>>>>>>>>> Bishesh Khanal <bisheshkh at gmail.com> writes:
>>>>>>>>>>>>>>>>>>> > Now, I implemented two different approaches, each for
>>>>>>>>>>>>>>>>>>> both 2D and 3D, in
>>>>>>>>>>>>>>>>>>> > MATLAB. It works for the smaller sizes but I have
>>>>>>>>>>>>>>>>>>> problems solving it for
>>>>>>>>>>>>>>>>>>> > the problem size I need (250^3 grid size).
>>>>>>>>>>>>>>>>>>> > I use staggered grid with p on cell centers, and
>>>>>>>>>>>>>>>>>>> components of v on cell
>>>>>>>>>>>>>>>>>>> > faces. Similar split up of K to cell center and faces
>>>>>>>>>>>>>>>>>>> to account for the
>>>>>>>>>>>>>>>>>>> > variable viscosity case)
>>>>>>>>>>>>>>>>>>> Okay, you're using a staggered-grid finite difference
>>>>>>>>>>>>>>>>>>> discretization of
>>>>>>>>>>>>>>>>>>> variable-viscosity Stokes.  This is a common problem and
>>>>>>>>>>>>>>>>>>> I recommend
>>>>>>>>>>>>>>>>>>> starting with PCFieldSplit with Schur complement
>>>>>>>>>>>>>>>>>>> reduction (make that
>>>>>>>>>>>>>>>>>>> work first, then switch to block preconditioner).  You
>>>>>>>>>>>>>>>>>>> can use PCLSC or
>>>>>>>>>>>>>>>>>>> (probably better for you), assemble a preconditioning
>>>>>>>>>>>>>>>>>>> matrix containing
>>>>>>>>>>>>>>>>>>> the inverse viscosity in the pressure-pressure block.
>>>>>>>>>>>>>>>>>>>  This diagonal
>>>>>>>>>>>>>>>>>>> matrix is a spectrally equivalent (or nearly so,
>>>>>>>>>>>>>>>>>>> depending on
>>>>>>>>>>>>>>>>>>> discretization) approximation of the Schur complement.
>>>>>>>>>>>>>>>>>>>  The velocity
>>>>>>>>>>>>>>>>>>> block can be solved with algebraic multigrid.  Read the
>>>>>>>>>>>>>>>>>>> PCFieldSplit
>>>>>>>>>>>>>>>>>>> docs (follow papers as appropriate) and let us know if
>>>>>>>>>>>>>>>>>>> you get stuck.
>>>>>>>>>>>>>>>>>> I was trying to assemble the inverse viscosity diagonal
>>>>>>>>>>>>>>>>>> matrix to use as the preconditioner for the Schur complement solve step as
>>>>>>>>>>>>>>>>>> you suggested. I've few questions about the ways to implement this in Petsc:
>>>>>>>>>>>>>>>>>> A naive approach that I can think of would be to create a
>>>>>>>>>>>>>>>>>> vector with its components as reciprocal viscosities of the cell centers
>>>>>>>>>>>>>>>>>> corresponding to the pressure variables, and then create a diagonal matrix
>>>>>>>>>>>>>>>>>> from this vector. However I'm not sure about:
>>>>>>>>>>>>>>>>>> How can I make this matrix, (say S_p) compatible to the
>>>>>>>>>>>>>>>>>> Petsc distribution of the different rows of the main system matrix over
>>>>>>>>>>>>>>>>>> different processors ? The main matrix was created using the DMDA structure
>>>>>>>>>>>>>>>>>> with 4 dof as explained before.
>>>>>>>>>>>>>>>>>> The main matrix correspond to the DMDA with 4 dofs but
>>>>>>>>>>>>>>>>>> for the S_p matrix would correspond to only pressure space. Should the
>>>>>>>>>>>>>>>>>> distribution of the rows of S_p among different processor not correspond to
>>>>>>>>>>>>>>>>>> the distribution of the rhs vector, say h' if it is solving for p with Sp =
>>>>>>>>>>>>>>>>>> h' where S = A11 inv(A00) A01 ?
>>>>>>>>>>>>>>>>> PETSc distributed vertices, not dofs, so it never breaks
>>>>>>>>>>>>>>>>> blocks. The P distribution is the same as the entire problem divided by 4.
>>>>>>>>>>>>>>>> Thanks Matt. So if I create a new DMDA with same grid size
>>>>>>>>>>>>>>>> but with dof=1 instead of 4, the vertices for this new DMDA will be
>>>>>>>>>>>>>>>> identically distributed as for the original DMDA ? Or should I inform PETSc
>>>>>>>>>>>>>>>> by calling a particular function to make these two DMDA have identical
>>>>>>>>>>>>>>>> distribution of the vertices ?
>>>>>>>>>>>>>>> Yes.
>>>>>>>>>>>>>>>>  Even then I think there might be a problem due to the
>>>>>>>>>>>>>>>> presence of "fictitious pressure vertices". The system matrix (A) contains
>>>>>>>>>>>>>>>> an identity corresponding to these fictitious pressure nodes, thus when
>>>>>>>>>>>>>>>> using a -pc_fieldsplit_detect_saddle_point, will detect a A11 zero block of
>>>>>>>>>>>>>>>> size that correspond to only non-fictitious P-nodes. So the preconditioner
>>>>>>>>>>>>>>>> S_p for the Schur complement outer solve with Sp = h' will also need to
>>>>>>>>>>>>>>>> correspond to only the non-fictitious P-nodes. This means its size does not
>>>>>>>>>>>>>>>> directly correspond to the DMDA grid defined for the original problem.
>>>>>>>>>>>>>>>> Could you please suggest an efficient way of assembling this S_p matrix ?
>>>>>>>>>>>>>>> Don't use detect_saddle, but split it by fields
>>>>>>>>>>>>>>> -pc_fieldsplit_0_fields 0,1,2 -pc_fieldsplit_1_fields 4
>>>>>>>>>>>>>> How can I set this split in the code itself without giving it
>>>>>>>>>>>>>> as a command line option when the system matrix is assembled from the DMDA
>>>>>>>>>>>>>> for the whole system with 4 dofs. (i.e. *without* using the
>>>>>>>>>>>>>> DMComposite or *without* using the nested block matrices to
>>>>>>>>>>>>>> assemble different blocks separately and then combine them together).
>>>>>>>>>>>>>> I need the split to get access to the fieldsplit_1_ksp in my
>>>>>>>>>>>>>> code, because not using detect_saddle_point means I cannot use
>>>>>>>>>>>>>> -fieldsplit_1_ksp_constant_null_space due to the presence of identity for
>>>>>>>>>>>>>> the fictitious pressure nodes present in the fieldsplit_1_ block. I need to
>>>>>>>>>>>>>> use PCFieldSplitGetSubKsp() so that I can set proper null-space basis.
>>>>>>>>>>>>> This is currently a real problem with the DMDA. In the
>>>>>>>>>>>>> unstructured case, where we always need specialized spaces, you can
>>>>>>>>>>>>> use something like
>>>>>>>>>>>>>     PetscObject  pressure;
>>>>>>>>>>>>>     MatNullSpace nullSpacePres;
>>>>>>>>>>>>>     ierr = DMGetField(dm, 1, &pressure);CHKERRQ(ierr);
>>>>>>>>>>>>>     ierr = MatNullSpaceCreate(PetscObjectComm(pressure),
>>>>>>>>>>>>> PETSC_TRUE, 0, NULL, &nullSpacePres);CHKERRQ(ierr);
>>>>>>>>>>>>>     ierr = PetscObjectCompose(pressure, "nullspace",
>>>>>>>>>>>>> (PetscObject) nullSpacePres);CHKERRQ(ierr);
>>>>>>>>>>>>>     ierr = MatNullSpaceDestroy(&nullSpacePres);CHKERRQ(ierr);
>>>>>>>>>>>>> and then DMGetSubDM() uses this information to attach the null
>>>>>>>>>>>>> space to the IS that is created using the information in the PetscSection.
>>>>>>>>>>>>> If you use a PetscSection to set the data layout over the
>>>>>>>>>>>>> DMDA, I think this works correctly, but this has not been tested at all and
>>>>>>>>>>>>> is very
>>>>>>>>>>>>> new code. Eventually, I think we want all DMs to use this
>>>>>>>>>>>>> mechanism, but we are still working it out.
>>>>>>>>>>>> Currently I do not use PetscSection. If this makes a cleaner
>>>>>>>>>>>> approach, I'd try it too but may a bit later (right now I'd like test my
>>>>>>>>>>>> model with a quickfix even if it means a little dirty code!)
>>>>>>>>>>>>> Bottom line: For custom null spaces using the default layout
>>>>>>>>>>>>> in DMDA, you need to take apart the PCFIELDSPLIT after it has been setup,
>>>>>>>>>>>>> which is somewhat subtle. You need to call KSPSetUp() and then
>>>>>>>>>>>>> reach in and get the PC, and the subKSPs. I don't like this at all, but we
>>>>>>>>>>>>> have not reorganized that code (which could be very simple and
>>>>>>>>>>>>> inflexible since its very structured).
>>>>>>>>>>>> So I tried to get this approach working but I could not succeed
>>>>>>>>>>>> and encountered some errors. Here is a code snippet:
>>>>>>>>>>>> //mDa is the DMDA that describes the whole grid with all 4 dofs
>>>>>>>>>>>> (3 velocity components and 1 pressure comp.)
>>>>>>>>>>>> ierr =
>>>>>>>>>>>>     ierr =
>>>>>>>>>>>>     ierr =
>>>>>>>>>>>> KSPSetNullSpace(mKsp,mNullSpaceSystem);CHKERRQ(ierr);   //I've the
>>>>>>>>>>>> mNullSpaceSystem based on mDa, that contains a null space basis for the
>>>>>>>>>>>> complete system.
>>>>>>>>>>>>     ierr =
>>>>>>>>>>>> //This I expect would register these options I give:-pc_type fieldsplit
>>>>>>>>>>>> -pc_fieldsplit_type schur -pc_fieldsplit_0_fields 0,1,2
>>>>>>>>>>>> //-pc_fieldsplit_1_fields 3
>>>>>>>>>>>>     ierr = KSPGetPC(mKsp,&mPcOuter);     //Now get the PC that
>>>>>>>>>>>> was obtained from the options (fieldsplit)
>>>>>>>>>>>>     ierr =
>>>>>>>>>>>> PCFieldSplitSchurPrecondition(mPcOuter,PC_FIELDSPLIT_SCHUR_PRE_USER,mPcForSc);CHKERRQ(ierr);
>>>>>>>>>>>> //I have created the matrix mPcForSc using a DMDA with identical //size to
>>>>>>>>>>>> mDa but with dof=1 corresponding to the pressure nodes (say mDaPressure).
>>>>>>>>>>>>   ierr = PCSetUp(mPcOuter);CHKERRQ(ierr);
>>>>>>>>>>>>     KSP *kspSchur;
>>>>>>>>>>>>     PetscInt kspSchurPos = 1;
>>>>>>>>>>>>     ierr =
>>>>>>>>>>>> PCFieldSplitGetSubKSP(mPcOuter,&kspSchurPos,&kspSchur);CHKERRQ(ierr);
>>>>>>>>>>>>     ierr =
>>>>>>>>>>>> KSPSetNullSpace(kspSchur[1],mNullSpacePressure);CHKERRQ(ierr);
>>>>>>>>>>>> //The null space is the one that correspond to only pressure nodes, created
>>>>>>>>>>>> using the mDaPressure.
>>>>>>>>>>>>     ierr = PetscFree(kspSchur);CHKERRQ(ierr);
>>>>>>>>>>> Sorry, you need to return to the old DMDA behavior, so you want
>>>>>>>>>> Thanks, with this it seems I can attach the null space properly,
>>>>>>>>>> but I have a question regarding whether the Schur complement ksp solver is
>>>>>>>>>> actually using the preconditioner matrix I provide.
>>>>>>>>>> When using -ksp_view, the outer level pc object of type
>>>>>>>>>> fieldsplit does report that: "Preconditioner for the Schur complement
>>>>>>>>>> formed from user provided matrix", but in the KSP solver for Schur
>>>>>>>>>> complement S, the pc object (fieldsplit_1_) is of type ilu and doesn't say
>>>>>>>>>> that it is using the matrix I provide. Am I missing something here ?
>>>>>>>>>> Below are the relevant commented code snippet and the output of
>>>>>>>>>> the -ksp_view
>>>>>>>>>> (The options I used: -pc_type fieldsplit -pc_fieldsplit_type
>>>>>>>>>> schur -pc_fieldsplit_dm_splits 0 -pc_fieldsplit_0_fields 0,1,2
>>>>>>>>>> -pc_fieldsplit_1_fields 3 -ksp_converged_reason -ksp_view )
>>>>>>>>> If ILU does not error, it means it is using your matrix, because
>>>>>>>>> the Schur complement matrix cannot be factored, and FS says it is using
>>>>>>>>> your matrix.
>>>>>>>>>    Matt
>>>>>>>>>> Code snippet:
>>>>>>>>>> ierr = KSPSetNullSpace(mKsp,mNullSpaceSystem);CHKERRQ(ierr);
>>>>>>>>>> //The nullspace for the whole system
>>>>>>>>>>     ierr =
>>>>>>>>>>     ierr = KSPSetUp(mKsp);CHKERRQ(ierr);                   //Set
>>>>>>>>>> up mKsp with the options provided with fieldsplit and the fields associated
>>>>>>>>>> with the two splits.
>>>>>>>>>>     ierr = KSPGetPC(mKsp,&mPcOuter);CHKERRQ(ierr);
>>>>>>>>>> //Get the fieldsplit pc set up from the options
>>>>>>>>>>     ierr =
>>>>>>>>>> //Use mPcForSc as the preconditioner for Schur Complement
>>>>>>>>>>     KSP *kspSchur;
>>>>>>>>>>     ierr =
>>>>>>>>>>     ierr =
>>>>>>>>>> //Attach the null-space for the Schur complement ksp solver.
>>>>>>>>>> the output of the -ksp_view
>>>>>>>>>>   type: gmres
>>>>>>>>>>   type: fieldsplit
>>>>>>>>>> factorization FULL
>>>>>>>>>> provided matrix
>>>>>>>>>>     Split info:
>>>>>>>>>>         type: gmres
>>>>>>>>>> divergence=10000
>>>>>>>>>>         type: ilu
>>>>>>>>>>           0 levels of fill
>>>>>>>>>>                 type: seqaij
>>>>>>>>>>                 rows=2187, cols=2187
>>>>>>>>>>                 total: nonzeros=140625, allocated nonzeros=140625
>>>>>>>>>> calls =0
>>>>>>>>>>                   using I-node routines: found 729 nodes, limit
>>>>>>>>>> used is 5
>>>>>>>>>>           type: seqaij
>>>>>>>>>> =0
>>>>>>>>>>             using I-node routines: found 729 nodes, limit used is
>>>>>>>>>> 5
>>>>>>>>>>         type: gmres
>>>>>>>>>> divergence=10000
>>>>>>>>>>         type: ilu
>>>>>>>>>>           0 levels of fill
>>>>>>>>>>                 type: seqaij
>>>>>>>>>>                 rows=729, cols=729
>>>>>>>>>>                 total: nonzeros=15625, allocated nonzeros=15625
>>>>>>>>>> calls =0
>>>>>>>>>>           rows=729, cols=729
>>>>>>>>>>             A11
>>>>>>>>>>                 type: seqaij
>>>>>>>>>>                 rows=729, cols=729
>>>>>>>>>> calls =0
>>>>>>>>>>             A10
>>>>>>>>>>                 type: seqaij
>>>>>>>>>>                 rows=729, cols=2187
>>>>>>>>>>                 total: nonzeros=46875, allocated nonzeros=46875
>>>>>>>>>> calls =0
>>>>>>>>>>             KSP of A00
>>>>>>>>>>               KSP Object:
>>>>>>>>>>                 type: gmres
>>>>>>>>>> divergence=10000
>>>>>>>>>> test
>>>>>>>>>>               PC Object:
>>>>>>>>>>                 type: ilu
>>>>>>>>>>                   0 levels of fill
>>>>>>>>>> pivot
>>>>>>>>>> processes
>>>>>>>>>>                         type: seqaij
>>>>>>>>>> petsc
>>>>>>>>>> nonzeros=140625
>>>>>>>>>> limit used is 5
>>>>>>>>>>                   type: seqaij
>>>>>>>>>> nonzeros=140625
>>>>>>>>>> used is 5
>>>>>>>>>>             A01
>>>>>>>>>>                 type: seqaij
>>>>>>>>>>                 rows=2187, cols=729
>>>>>>>>>> calls =0
>>>>>>>>>> used is 5
>>>>>>>>>>           type: seqaij
>>>>>>>>>>           rows=729, cols=729
>>>>>>>>>> =0
>>>>>>>>>>     type: seqaij
>>>>>>>>>>     rows=2916, cols=2916, bs=4
>>>>>>>>>>     total: nonzeros=250000, allocated nonzeros=250000
>>>>>>>>>>       using I-node routines: found 729 nodes, limit used is 5
>>>>>>>>>>> or
>>>>>>>>>>>   PCFieldSplitSetDMSplits(pc, PETSC_FALSE)
>>>>>>>>>>>   Thanks,
>>>>>>>>>>>      Matt
>>>>>>>>>>>> The errors I get when running with options: -pc_type fieldsplit
>>>>>>>>>>>> [0]PETSC ERROR: --------------------- Error Message
>>>>>>>>>>>> [0]PETSC ERROR: No support for this operation for this object
>>>>>>>>>>>> type!
>>>>>>>>>>>> [0]PETSC ERROR: Support only implemented for 2d!
>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>> [0]PETSC ERROR: Petsc Release Version 3.4.2, Jul, 02, 2013
>>>>>>>>>>>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>>>>>>>>>>>> [0]PETSC ERROR: See docs/faq.html for hints about trouble
>>>>>>>>>>>> shooting.
>>>>>>>>>>>> [0]PETSC ERROR: See docs/index.html for manual pages.
>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>> [0]PETSC ERROR: src/AdLemMain on a arch-linux2-cxx-debug named
>>>>>>>>>>>> edwards by bkhanal Tue Aug  6 17:35:30 2013
>>>>>>>>>>>> [0]PETSC ERROR: Libraries linked from
>>>>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/arch-linux2-cxx-debug/lib
>>>>>>>>>>>> [0]PETSC ERROR: Configure run at Fri Jul 19 14:25:01 2013
>>>>>>>>>>>> [0]PETSC ERROR: Configure options --with-cc=gcc --with-fc=g77
>>>>>>>>>>>> --with-cxx=g++ --download-f-blas-lapack=1 --download-mpich=1
>>>>>>>>>>>> -with-clanguage=cxx --download-hypre=1
>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>> [0]PETSC ERROR: DMCreateSubDM_DA() line 188 in
>>>>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/dm/impls/da/dacreate.c
>>>>>>>>>>>> [0]PETSC ERROR: DMCreateSubDM() line 1267 in
>>>>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/dm/interface/dm.c
>>>>>>>>>>>> [0]PETSC ERROR: PCFieldSplitSetDefaults() line 337 in
>>>>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/ksp/pc/impls/fieldsplit/fieldsplit.c
>>>>>>>>>>>> [0]PETSC ERROR: PCSetUp_FieldSplit() line 458 in
>>>>>>>>>>>> [0]PETSC ERROR: PCSetUp() line 890 in
>>>>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/ksp/pc/interface/precon.c
>>>>>>>>>>>> [0]PETSC ERROR: KSPSetUp() line 278 in
>>>>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/ksp/ksp/interface/itfunc.c
>>>>>>>>>>>> [0]PETSC ERROR: solveModel() line 181 in
>>>>>>>>>>>> "unknowndirectory/"/user/bkhanal/home/works/AdLemModel/src/PetscAdLemTaras3D.cxx
>>>>>>>>>>>> WARNING! There are options you set that were not used!
>>>>>>>>>>>> WARNING! could be spelling mistake, etc!
>>>>>>>>>>>> Option left: name:-pc_fieldsplit_1_fields value: 3
>>>>>>>>>>>>>    Matt
>>>>>>>>>>>>>>>    Matt
>>>>>>>>>>>>>>>>>    Matt
>>>>>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>>>>>> their experiments lead.
>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>>> experiments lead.
>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>> experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130823/98b6aeea/attachment-0001.html>
