[petsc-users] discontinuous viscosity stokes equation 3D staggered grid
Fri Aug 23 08:16:56 CDT 2013
On Fri, Aug 23, 2013 at 8:01 AM, Bishesh Khanal <bisheshkh at gmail.com> wrote:
> On Fri, Aug 23, 2013 at 2:53 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Fri, Aug 23, 2013 at 7:46 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>> On Fri, Aug 23, 2013 at 2:33 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>> On Fri, Aug 23, 2013 at 7:25 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>>>> On Fri, Aug 23, 2013 at 2:09 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>> On Fri, Aug 23, 2013 at 4:31 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>>>>>> Thanks Matt and Mark for comments in using near null space [question
>>>>>>> I asked in the thread with subject: *problem (Segmentation
>>>>>>> voilation) using -pc_type hypre -pc_hypre_type -pilut with multiple nodes
>>>>>>> in a cluster*].
>>>>>>> So I understood that I have to set a nearNullSpace to A00 block
>>>>>>> where the null space correspond to the rigid body motion. I tried it but
>>>>>>> still the gamg just keeps on iterating and convergence is very very slow. I
>>>>>>> am not sure what the problem is, right now gamg does not even work for the
>>>>>>> constant viscosity case.
>>>>>>> I have set up the following in my code:
>>>>>>> 1. null space for the whole system A 2. null space for the Schur
>>>>>>> complement S 3. Near null space for A00 4. a user preconditioner matrix of
>>>>>>> inverse viscosity in the diagonal for S.
>>>>>> If you want to debug solvers, you HAVE to send -ksp_view.
>>>>> When I use gamg, the -fieldsplit_0_ksp was iterating on and on so
>>>>> didn't get to the end to get -ksp_view results.
>>>>> Instead here I have put the -ksp_view output when running the program
>>>>> with following options: (In this case I get the results)
>>>>> -pc_type fieldsplit -pc_fieldsplit_type schur -pc_fieldsplit_dm_splits
>>>>> 0 -pc_fieldsplit_0_fields 0,1,2 -pc_fieldsplit_1_fields 3
>>>>> -ksp_converged_reason -ksp_view
>>>> Okay, that looks fine. Does
>>>>   -fieldsplit_0_pc_type lu
>>>>   - fieldsplit_1_ksp_rtol 1.0e-10
>>>> converge in one Iterate?
>>>> What matrix did you attach as the preconditioner matrix for
>>>> fieldsplit_1_?
>>> I used a diagonal matrix with reciprocal of viscosity values of the
>>> corresponding cell centers as the preconditioner.
>>> with the options  -fieldsplit_0_pc_type lu  - fieldsplit_1_ksp_rtol
>>> 1.0e-10 -fieldsplit_1_ksp_converged_reason -ksp_converged_reason
>>> I get the following output which means the outer ksp did converge in one
>>> iterate I guess.
>>>   Linear solve converged due to CONVERGED_RTOL iterations 18
>> Okay, so A_00 is nonsingular, and the system seems to solve alright. What
>> do you get for
>>   -fieldsplit_0_ksp_max_it 30
>>   -fieldsplit_0_pc_type gamg
>>   -fieldsplit_0_ksp_converged_reason
> It fieldsplit_0_ does not converge in 30 iterations. It gives:
>  Linear solve converged due to CONVERGED_ATOL iterations 0
> Linear solve did not converge due to DIVERGED_ITS iterations 30
> and continues with the same message.
So what would you do? Give up?
  -fieldsplit_0_ksp_gmres_restart 200
The idea is to figure out what is going on:
  -fieldsplit_0_ksp_monitor_true_residual
     Matt
>> This is the kind of investigation you msut be comfortable with if you
>> want to experiment with these solvers.
>>     Matt
>>>>   Thanks,
>>>>      Matt
>>>>> Linear solve converged due to CONVERGED_RTOL iterations 2
>>>>> KSP Object: 1 MPI processes
>>>>>   type: gmres
>>>>>     GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
>>>>> Orthogonalization with no iterative refinement
>>>>>     GMRES: happy breakdown tolerance 1e-30
>>>>>   maximum iterations=10000, initial guess is zero
>>>>>   tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>>>>>   left preconditioning
>>>>>   has attached null space
>>>>>   using PRECONDITIONED norm type for convergence test
>>>>> PC Object: 1 MPI processes
>>>>>   type: fieldsplit
>>>>>     FieldSplit with Schur preconditioner, blocksize = 4, factorization
>>>>> FULL
>>>>>     Preconditioner for the Schur complement formed from user provided
>>>>> matrix
>>>>>     Split info:
>>>>>     Split number 0 Fields  0, 1, 2
>>>>>     Split number 1 Fields  3
>>>>>     KSP solver for A00 block
>>>>>       KSP Object:      (fieldsplit_0_)       1 MPI processes
>>>>>         type: gmres
>>>>>       PC Object:      (fieldsplit_0_)       1 MPI processes
>>>>>         type: ilu
>>>>>           ILU: out-of-place factorization
>>>>>           0 levels of fill
>>>>>           tolerance for zero pivot 2.22045e-14
>>>>>           using diagonal shift on blocks to prevent zero pivot
>>>>>           matrix ordering: natural
>>>>>           factor fill ratio given 1, needed 1
>>>>>             Factored matrix follows:
>>>>>               Matrix Object:               1 MPI processes
>>>>>                 type: seqaij
>>>>>                 rows=8232, cols=8232
>>>>>                 package used to perform factorization: petsc
>>>>>                 total: nonzeros=576000, allocated nonzeros=576000
>>>>>                 total number of mallocs used during MatSetValues calls
>>>>> =0
>>>>>                   using I-node routines: found 2744 nodes, limit used
>>>>> is 5
>>>>>         linear system matrix = precond matrix:
>>>>>           type: seqaij
>>>>>           total number of mallocs used during MatSetValues calls =0
>>>>>             using I-node routines: found 2744 nodes, limit used is 5
>>>>>     KSP solver for S = A11 - A10 inv(A00) A01
>>>>>       KSP Object:      (fieldsplit_1_)       1 MPI processes
>>>>>         type: gmres
>>>>>       PC Object:      (fieldsplit_1_)       1 MPI processes
>>>>>         type: ilu
>>>>>           0 levels of fill
>>>>>                 type: seqaij
>>>>>                 rows=2744, cols=2744
>>>>>                 total: nonzeros=64000, allocated nonzeros=64000
>>>>> =0
>>>>>                   not using I-node routines
>>>>>         linear system matrix followed by preconditioner matrix:
>>>>>           type: schurcomplement
>>>>>             Schur complement A11 - A10 inv(A00) A01
>>>>>             A11
>>>>>                 type: seqaij
>>>>> =0
>>>>>             A10
>>>>>                 type: seqaij
>>>>>                 rows=2744, cols=8232
>>>>>                 total: nonzeros=192000, allocated nonzeros=192000
>>>>> =0
>>>>>             KSP of A00
>>>>> MPI processes
>>>>>                 type: gmres
>>>>> Gram-Schmidt Orthogonalization with no iterative refinement
>>>>> divergence=10000
>>>>> MPI processes
>>>>>                 type: ilu
>>>>>                   0 levels of fill
>>>>> processes
>>>>>                         type: seqaij
>>>>> nonzeros=576000
>>>>> limit used is 5
>>>>>                   type: seqaij
>>>>> calls =0
>>>>> used is 5
>>>>>             A01
>>>>>                 type: seqaij
>>>>>                 rows=8232, cols=2744
>>>>> =0
>>>>> is 5
>>>>>           type: seqaij
>>>>>     type: seqaij
>>>>>     rows=10976, cols=10976, bs=4
>>>>>     total: nonzeros=1024000, allocated nonzeros=1024000
>>>>>>    Matt
>>>>>>> I am testing a small problem with CONSTANT viscosity for grid size
>>>>>>> of 14^3 with the run time option:
>>>>>>> -ksp_type gcr -pc_type fieldsplit -pc_fieldsplit_type schur
>>>>>>> -pc_fieldsplit_dm_splits 0 -pc_fieldsplit_0_fields 0,1,2
>>>>>>> -pc_fieldsplit_1_fields 3 -ksp_converged_reason -ksp_view
>>>>>>> -fieldsplit_0_ksp_type gcr -fieldsplit_0_pc_type gamg
>>>>>>> -fieldsplit_0_ksp_monitor_true_residual -fieldsplit_0_ksp_converged_reason
>>>>>>> -fieldsplit_1_ksp_monitor_true_residual
>>>>>>> Here is my relevant code of the solve function:
>>>>>>> PetscErrorCode ierr;
>>>>>>>     PetscFunctionBeginUser;
>>>>>>>     ierr =
>>>>>>> DMKSPSetComputeRHS(mDa,computeRHSTaras3D,this);CHKERRQ(ierr);
>>>>>>>     ierr =
>>>>>>> DMKSPSetComputeOperators(mDa,computeMatrixTaras3D,this);CHKERRQ(ierr);
>>>>>>>     ierr = KSPSetDM(mKsp,mDa);CHKERRQ(ierr);              //mDa with
>>>>>>> dof = 4, vx,vy,vz and p.
>>>>>>>     ierr =
>>>>>>> KSPSetNullSpace(mKsp,mNullSpace);CHKERRQ(ierr);//nullSpace for the main
>>>>>>> system
>>>>>>>     ierr = KSPSetFromOptions(mKsp);CHKERRQ(ierr);
>>>>>>>     ierr = KSPSetUp(mKsp);CHKERRQ(ierr);                  //register
>>>>>>> the fieldsplits obtained from options.
>>>>>>>     //Setting up user PC for Schur Complement
>>>>>>>     ierr = KSPGetPC(mKsp,&mPc);CHKERRQ(ierr);
>>>>>>>     ierr =
>>>>>>> PCFieldSplitSchurPrecondition(mPc,PC_FIELDSPLIT_SCHUR_PRE_USER,mPcForSc);CHKERRQ(ierr);
>>>>>>>     KSP *subKsp;
>>>>>>>     PetscInt subKspPos = 0;
>>>>>>>     //Set up nearNullspace for A00 block.
>>>>>>>     ierr =
>>>>>>> PCFieldSplitGetSubKSP(mPc,&subKspPos,&subKsp);CHKERRQ(ierr);
>>>>>>>     MatNullSpace rigidBodyModes;
>>>>>>>     Vec coords;
>>>>>>>     ierr = DMGetCoordinates(mDa,&coords);CHKERRQ(ierr);
>>>>>>>     ierr =
>>>>>>> MatNullSpaceCreateRigidBody(coords,&rigidBodyModes);CHKERRQ(ierr);
>>>>>>>     Mat matA00;
>>>>>>>     ierr =
>>>>>>> KSPGetOperators(subKsp[0],&matA00,NULL,NULL);CHKERRQ(ierr);
>>>>>>>     ierr = MatSetNearNullSpace(matA00,rigidBodyModes);CHKERRQ(ierr);
>>>>>>>     ierr = MatNullSpaceDestroy(&rigidBodyModes);CHKERRQ(ierr);
>>>>>>>     //Position 1 => Ksp corresponding to Schur complement S on
>>>>>>> pressure space
>>>>>>>     subKspPos = 1;
>>>>>>>     ierr =
>>>>>>>     //Set up the null space of constant pressure.
>>>>>>>     ierr = KSPSetNullSpace(subKsp[1],mNullSpaceP);CHKERRQ(ierr);
>>>>>>>     PetscBool isNull;
>>>>>>>     Mat matSc;
>>>>>>>     ierr = KSPGetOperators(subKsp[1],&matSc,NULL,NULL);CHKERRQ(ierr);
>>>>>>>     ierr = MatNullSpaceTest(mNullSpaceP,matSc,&isNull);
>>>>>>>     if(!isNull)
>>>>>>>         SETERRQ(PETSC_COMM_WORLD,PETSC_ERR_PLIB,"not a valid
>>>>>>> pressure null space \n");
>>>>>>>     ierr = KSPGetOperators(mKsp,&mA,NULL,NULL);CHKERRQ(ierr);
>>>>>>>     ierr = MatNullSpaceTest(mNullSpace,mA,&isNull);CHKERRQ(ierr);
>>>>>>>     if(!isNull)
>>>>>>>         SETERRQ(PETSC_COMM_WORLD,PETSC_ERR_PLIB,"not a valid system
>>>>>>> null space \n");
>>>>>>>     ierr = PetscFree(subKsp);CHKERRQ(ierr);
>>>>>>>     ierr = KSPSolve(mKsp,NULL,NULL);CHKERRQ(ierr);
>>>>>>>     ierr = KSPGetSolution(mKsp,&mX);CHKERRQ(ierr);
>>>>>>>     ierr = KSPGetRhs(mKsp,&mB);CHKERRQ(ierr);
>>>>>>>     PetscFunctionReturn(0);
>>>>>>> On Wed, Aug 7, 2013 at 2:15 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>>>> On Wed, Aug 7, 2013 at 7:07 AM, Bishesh Khanal <bisheshkh at gmail.com
>>>>>>>> > wrote:
>>>>>>>>> On Tue, Aug 6, 2013 at 11:34 PM, Matthew Knepley <
>>>>>>>>> knepley at gmail.com> wrote:
>>>>>>>>>> On Tue, Aug 6, 2013 at 10:59 AM, Bishesh Khanal <
>>>>>>>>>>> On Tue, Aug 6, 2013 at 4:40 PM, Matthew Knepley <
>>>>>>>>>>>> On Tue, Aug 6, 2013 at 8:06 AM, Bishesh Khanal <
>>>>>>>>>>>>> On Mon, Aug 5, 2013 at 4:14 PM, Matthew Knepley <
>>>>>>>>>>>>>> On Mon, Aug 5, 2013 at 8:48 AM, Bishesh Khanal <
>>>>>>>>>>>>>>> On Mon, Aug 5, 2013 at 3:17 PM, Matthew Knepley <
>>>>>>>>>>>>>>>> On Mon, Aug 5, 2013 at 7:54 AM, Bishesh Khanal <
>>>>>>>>>>>>>>>>> On Wed, Jul 17, 2013 at 9:48 PM, Jed Brown <
>>>>>>>>>>>>>>>>> jedbrown at mcs.anl.gov> wrote:
>>>>>>>>>>>>>>>>>> Bishesh Khanal <bisheshkh at gmail.com> writes:
>>>>>>>>>>>>>>>>>> > Now, I implemented two different approaches, each for
>>>>>>>>>>>>>>>>>> both 2D and 3D, in
>>>>>>>>>>>>>>>>>> > MATLAB. It works for the smaller sizes but I have
>>>>>>>>>>>>>>>>>> problems solving it for
>>>>>>>>>>>>>>>>>> > the problem size I need (250^3 grid size).
>>>>>>>>>>>>>>>>>> > I use staggered grid with p on cell centers, and
>>>>>>>>>>>>>>>>>> components of v on cell
>>>>>>>>>>>>>>>>>> > faces. Similar split up of K to cell center and faces
>>>>>>>>>>>>>>>>>> to account for the
>>>>>>>>>>>>>>>>>> > variable viscosity case)
>>>>>>>>>>>>>>>>>> Okay, you're using a staggered-grid finite difference
>>>>>>>>>>>>>>>>>> discretization of
>>>>>>>>>>>>>>>>>> variable-viscosity Stokes.  This is a common problem and
>>>>>>>>>>>>>>>>>> I recommend
>>>>>>>>>>>>>>>>>> starting with PCFieldSplit with Schur complement
>>>>>>>>>>>>>>>>>> reduction (make that
>>>>>>>>>>>>>>>>>> work first, then switch to block preconditioner).  You
>>>>>>>>>>>>>>>>>> can use PCLSC or
>>>>>>>>>>>>>>>>>> (probably better for you), assemble a preconditioning
>>>>>>>>>>>>>>>>>> matrix containing
>>>>>>>>>>>>>>>>>> the inverse viscosity in the pressure-pressure block.
>>>>>>>>>>>>>>>>>>  This diagonal
>>>>>>>>>>>>>>>>>> matrix is a spectrally equivalent (or nearly so,
>>>>>>>>>>>>>>>>>> depending on
>>>>>>>>>>>>>>>>>> discretization) approximation of the Schur complement.
>>>>>>>>>>>>>>>>>>  The velocity
>>>>>>>>>>>>>>>>>> block can be solved with algebraic multigrid.  Read the
>>>>>>>>>>>>>>>>>> PCFieldSplit
>>>>>>>>>>>>>>>>>> docs (follow papers as appropriate) and let us know if
>>>>>>>>>>>>>>>>>> you get stuck.
>>>>>>>>>>>>>>>>> I was trying to assemble the inverse viscosity diagonal
>>>>>>>>>>>>>>>>> matrix to use as the preconditioner for the Schur complement solve step as
>>>>>>>>>>>>>>>>> you suggested. I've few questions about the ways to implement this in Petsc:
>>>>>>>>>>>>>>>>> A naive approach that I can think of would be to create a
>>>>>>>>>>>>>>>>> vector with its components as reciprocal viscosities of the cell centers
>>>>>>>>>>>>>>>>> corresponding to the pressure variables, and then create a diagonal matrix
>>>>>>>>>>>>>>>>> from this vector. However I'm not sure about:
>>>>>>>>>>>>>>>>> How can I make this matrix, (say S_p) compatible to the
>>>>>>>>>>>>>>>>> Petsc distribution of the different rows of the main system matrix over
>>>>>>>>>>>>>>>>> different processors ? The main matrix was created using the DMDA structure
>>>>>>>>>>>>>>>>> with 4 dof as explained before.
>>>>>>>>>>>>>>>>> The main matrix correspond to the DMDA with 4 dofs but for
>>>>>>>>>>>>>>>>> the S_p matrix would correspond to only pressure space. Should the
>>>>>>>>>>>>>>>>> distribution of the rows of S_p among different processor not correspond to
>>>>>>>>>>>>>>>>> the distribution of the rhs vector, say h' if it is solving for p with Sp =
>>>>>>>>>>>>>>>>> h' where S = A11 inv(A00) A01 ?
>>>>>>>>>>>>>>>> PETSc distributed vertices, not dofs, so it never breaks
>>>>>>>>>>>>>>>> blocks. The P distribution is the same as the entire problem divided by 4.
>>>>>>>>>>>>>>> Thanks Matt. So if I create a new DMDA with same grid size
>>>>>>>>>>>>>>> but with dof=1 instead of 4, the vertices for this new DMDA will be
>>>>>>>>>>>>>>> identically distributed as for the original DMDA ? Or should I inform PETSc
>>>>>>>>>>>>>>> by calling a particular function to make these two DMDA have identical
>>>>>>>>>>>>>>> distribution of the vertices ?
>>>>>>>>>>>>>> Yes.
>>>>>>>>>>>>>>>  Even then I think there might be a problem due to the
>>>>>>>>>>>>>>> presence of "fictitious pressure vertices". The system matrix (A) contains
>>>>>>>>>>>>>>> an identity corresponding to these fictitious pressure nodes, thus when
>>>>>>>>>>>>>>> using a -pc_fieldsplit_detect_saddle_point, will detect a A11 zero block of
>>>>>>>>>>>>>>> size that correspond to only non-fictitious P-nodes. So the preconditioner
>>>>>>>>>>>>>>> S_p for the Schur complement outer solve with Sp = h' will also need to
>>>>>>>>>>>>>>> correspond to only the non-fictitious P-nodes. This means its size does not
>>>>>>>>>>>>>>> directly correspond to the DMDA grid defined for the original problem.
>>>>>>>>>>>>>>> Could you please suggest an efficient way of assembling this S_p matrix ?
>>>>>>>>>>>>>> Don't use detect_saddle, but split it by fields
>>>>>>>>>>>>>> -pc_fieldsplit_0_fields 0,1,2 -pc_fieldsplit_1_fields 4
>>>>>>>>>>>>> How can I set this split in the code itself without giving it
>>>>>>>>>>>>> as a command line option when the system matrix is assembled from the DMDA
>>>>>>>>>>>>> for the whole system with 4 dofs. (i.e. *without* using the
>>>>>>>>>>>>> DMComposite or *without* using the nested block matrices to
>>>>>>>>>>>>> assemble different blocks separately and then combine them together).
>>>>>>>>>>>>> I need the split to get access to the fieldsplit_1_ksp in my
>>>>>>>>>>>>> code, because not using detect_saddle_point means I cannot use
>>>>>>>>>>>>> -fieldsplit_1_ksp_constant_null_space due to the presence of identity for
>>>>>>>>>>>>> the fictitious pressure nodes present in the fieldsplit_1_ block. I need to
>>>>>>>>>>>>> use PCFieldSplitGetSubKsp() so that I can set proper null-space basis.
>>>>>>>>>>>> This is currently a real problem with the DMDA. In the
>>>>>>>>>>>> unstructured case, where we always need specialized spaces, you can
>>>>>>>>>>>> use something like
>>>>>>>>>>>>     PetscObject  pressure;
>>>>>>>>>>>>     MatNullSpace nullSpacePres;
>>>>>>>>>>>>     ierr = DMGetField(dm, 1, &pressure);CHKERRQ(ierr);
>>>>>>>>>>>>     ierr = MatNullSpaceCreate(PetscObjectComm(pressure),
>>>>>>>>>>>> PETSC_TRUE, 0, NULL, &nullSpacePres);CHKERRQ(ierr);
>>>>>>>>>>>>     ierr = PetscObjectCompose(pressure, "nullspace",
>>>>>>>>>>>> (PetscObject) nullSpacePres);CHKERRQ(ierr);
>>>>>>>>>>>>     ierr = MatNullSpaceDestroy(&nullSpacePres);CHKERRQ(ierr);
>>>>>>>>>>>> and then DMGetSubDM() uses this information to attach the null
>>>>>>>>>>>> space to the IS that is created using the information in the PetscSection.
>>>>>>>>>>>> If you use a PetscSection to set the data layout over the DMDA,
>>>>>>>>>>>> I think this works correctly, but this has not been tested at all and is
>>>>>>>>>>>> very
>>>>>>>>>>>> new code. Eventually, I think we want all DMs to use this
>>>>>>>>>>>> mechanism, but we are still working it out.
>>>>>>>>>>> Currently I do not use PetscSection. If this makes a cleaner
>>>>>>>>>>> approach, I'd try it too but may a bit later (right now I'd like test my
>>>>>>>>>>> model with a quickfix even if it means a little dirty code!)
>>>>>>>>>>>> Bottom line: For custom null spaces using the default layout in
>>>>>>>>>>>> DMDA, you need to take apart the PCFIELDSPLIT after it has been setup,
>>>>>>>>>>>> which is somewhat subtle. You need to call KSPSetUp() and then
>>>>>>>>>>>> reach in and get the PC, and the subKSPs. I don't like this at all, but we
>>>>>>>>>>>> have not reorganized that code (which could be very simple and
>>>>>>>>>>>> inflexible since its very structured).
>>>>>>>>>>> So I tried to get this approach working but I could not succeed
>>>>>>>>>>> and encountered some errors. Here is a code snippet:
>>>>>>>>>>> //mDa is the DMDA that describes the whole grid with all 4 dofs
>>>>>>>>>>> (3 velocity components and 1 pressure comp.)
>>>>>>>>>>> ierr =
>>>>>>>>>>>     ierr =
>>>>>>>>>>>     ierr =
>>>>>>>>>>> KSPSetNullSpace(mKsp,mNullSpaceSystem);CHKERRQ(ierr);   //I've the
>>>>>>>>>>> mNullSpaceSystem based on mDa, that contains a null space basis for the
>>>>>>>>>>> complete system.
>>>>>>>>>>>     ierr =
>>>>>>>>>>> //This I expect would register these options I give:-pc_type fieldsplit
>>>>>>>>>>> -pc_fieldsplit_type schur -pc_fieldsplit_0_fields 0,1,2
>>>>>>>>>>> //-pc_fieldsplit_1_fields 3
>>>>>>>>>>>     ierr = KSPGetPC(mKsp,&mPcOuter);     //Now get the PC that
>>>>>>>>>>> was obtained from the options (fieldsplit)
>>>>>>>>>>>     ierr =
>>>>>>>>>>> PCFieldSplitSchurPrecondition(mPcOuter,PC_FIELDSPLIT_SCHUR_PRE_USER,mPcForSc);CHKERRQ(ierr);
>>>>>>>>>>> //I have created the matrix mPcForSc using a DMDA with identical //size to
>>>>>>>>>>> mDa but with dof=1 corresponding to the pressure nodes (say mDaPressure).
>>>>>>>>>>>   ierr = PCSetUp(mPcOuter);CHKERRQ(ierr);
>>>>>>>>>>>     KSP *kspSchur;
>>>>>>>>>>>     PetscInt kspSchurPos = 1;
>>>>>>>>>>>     ierr =
>>>>>>>>>>> PCFieldSplitGetSubKSP(mPcOuter,&kspSchurPos,&kspSchur);CHKERRQ(ierr);
>>>>>>>>>>>     ierr =
>>>>>>>>>>> KSPSetNullSpace(kspSchur[1],mNullSpacePressure);CHKERRQ(ierr);
>>>>>>>>>>> //The null space is the one that correspond to only pressure nodes, created
>>>>>>>>>>> using the mDaPressure.
>>>>>>>>>>>     ierr = PetscFree(kspSchur);CHKERRQ(ierr);
>>>>>>>>>> Sorry, you need to return to the old DMDA behavior, so you want
>>>>>>>>> Thanks, with this it seems I can attach the null space properly,
>>>>>>>>> but I have a question regarding whether the Schur complement ksp solver is
>>>>>>>>> actually using the preconditioner matrix I provide.
>>>>>>>>> When using -ksp_view, the outer level pc object of type fieldsplit
>>>>>>>>> does report that: "Preconditioner for the Schur complement formed from user
>>>>>>>>> provided matrix", but in the KSP solver for Schur complement S, the pc
>>>>>>>>> object (fieldsplit_1_) is of type ilu and doesn't say that it is using the
>>>>>>>>> matrix I provide. Am I missing something here ?
>>>>>>>>> Below are the relevant commented code snippet and the output of
>>>>>>>>> the -ksp_view
>>>>>>>>> (The options I used: -pc_type fieldsplit -pc_fieldsplit_type schur
>>>>>>>>> -pc_fieldsplit_1_fields 3 -ksp_converged_reason -ksp_view )
>>>>>>>> If ILU does not error, it means it is using your matrix, because
>>>>>>>> the Schur complement matrix cannot be factored, and FS says it is using
>>>>>>>> your matrix.
>>>>>>>>    Matt
>>>>>>>>> Code snippet:
>>>>>>>>> ierr = KSPSetNullSpace(mKsp,mNullSpaceSystem);CHKERRQ(ierr);
>>>>>>>>> //The nullspace for the whole system
>>>>>>>>>     ierr =
>>>>>>>>>     ierr = KSPSetUp(mKsp);CHKERRQ(ierr);                   //Set
>>>>>>>>> up mKsp with the options provided with fieldsplit and the fields associated
>>>>>>>>> with the two splits.
>>>>>>>>>     ierr = KSPGetPC(mKsp,&mPcOuter);CHKERRQ(ierr);
>>>>>>>>> //Get the fieldsplit pc set up from the options
>>>>>>>>>     ierr =
>>>>>>>>> //Use mPcForSc as the preconditioner for Schur Complement
>>>>>>>>>     KSP *kspSchur;
>>>>>>>>>     ierr =
>>>>>>>>>     ierr =
>>>>>>>>> //Attach the null-space for the Schur complement ksp solver.
>>>>>>>>> the output of the -ksp_view
>>>>>>>>>   type: gmres
>>>>>>>>>   type: fieldsplit
>>>>>>>>> factorization FULL
>>>>>>>>> provided matrix
>>>>>>>>>     Split info:
>>>>>>>>>         type: gmres
>>>>>>>>> divergence=10000
>>>>>>>>>         type: ilu
>>>>>>>>>           0 levels of fill
>>>>>>>>>                 type: seqaij
>>>>>>>>>                 rows=2187, cols=2187
>>>>>>>>>                 total: nonzeros=140625, allocated nonzeros=140625
>>>>>>>>> calls =0
>>>>>>>>>                   using I-node routines: found 729 nodes, limit
>>>>>>>>> used is 5
>>>>>>>>>           type: seqaij
>>>>>>>>>             using I-node routines: found 729 nodes, limit used is 5
>>>>>>>>>         type: gmres
>>>>>>>>> divergence=10000
>>>>>>>>>         type: ilu
>>>>>>>>>           0 levels of fill
>>>>>>>>>                 type: seqaij
>>>>>>>>>                 rows=729, cols=729
>>>>>>>>>                 total: nonzeros=15625, allocated nonzeros=15625
>>>>>>>>> calls =0
>>>>>>>>>           rows=729, cols=729
>>>>>>>>>             A11
>>>>>>>>>                 type: seqaij
>>>>>>>>>                 rows=729, cols=729
>>>>>>>>> calls =0
>>>>>>>>>             A10
>>>>>>>>>                 type: seqaij
>>>>>>>>>                 rows=729, cols=2187
>>>>>>>>>                 total: nonzeros=46875, allocated nonzeros=46875
>>>>>>>>> calls =0
>>>>>>>>>             KSP of A00
>>>>>>>>>               KSP Object:
>>>>>>>>>                 type: gmres
>>>>>>>>> divergence=10000
>>>>>>>>>               PC Object:
>>>>>>>>>                 type: ilu
>>>>>>>>>                   0 levels of fill
>>>>>>>>> pivot
>>>>>>>>> processes
>>>>>>>>>                         type: seqaij
>>>>>>>>> petsc
>>>>>>>>> nonzeros=140625
>>>>>>>>> limit used is 5
>>>>>>>>>                   type: seqaij
>>>>>>>>> calls =0
>>>>>>>>> used is 5
>>>>>>>>>             A01
>>>>>>>>>                 type: seqaij
>>>>>>>>>                 rows=2187, cols=729
>>>>>>>>> calls =0
>>>>>>>>> used is 5
>>>>>>>>>           type: seqaij
>>>>>>>>>           rows=729, cols=729
>>>>>>>>>     type: seqaij
>>>>>>>>>     rows=2916, cols=2916, bs=4
>>>>>>>>>     total: nonzeros=250000, allocated nonzeros=250000
>>>>>>>>>> or
>>>>>>>>>>   PCFieldSplitSetDMSplits(pc, PETSC_FALSE)
>>>>>>>>>>   Thanks,
>>>>>>>>>>      Matt
>>>>>>>>>>> The errors I get when running with options: -pc_type fieldsplit
>>>>>>>>>>> [0]PETSC ERROR: --------------------- Error Message
>>>>>>>>>>> [0]PETSC ERROR: No support for this operation for this object
>>>>>>>>>>> type!
>>>>>>>>>>> [0]PETSC ERROR: Support only implemented for 2d!
>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>> [0]PETSC ERROR: Petsc Release Version 3.4.2, Jul, 02, 2013
>>>>>>>>>>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>>>>>>>>>>> [0]PETSC ERROR: See docs/faq.html for hints about trouble
>>>>>>>>>>> shooting.
>>>>>>>>>>> [0]PETSC ERROR: See docs/index.html for manual pages.
>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>> [0]PETSC ERROR: src/AdLemMain on a arch-linux2-cxx-debug named
>>>>>>>>>>> edwards by bkhanal Tue Aug  6 17:35:30 2013
>>>>>>>>>>> [0]PETSC ERROR: Libraries linked from
>>>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/arch-linux2-cxx-debug/lib
>>>>>>>>>>> [0]PETSC ERROR: Configure run at Fri Jul 19 14:25:01 2013
>>>>>>>>>>> [0]PETSC ERROR: Configure options --with-cc=gcc --with-fc=g77
>>>>>>>>>>> --with-cxx=g++ --download-f-blas-lapack=1 --download-mpich=1
>>>>>>>>>>> -with-clanguage=cxx --download-hypre=1
>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>> [0]PETSC ERROR: DMCreateSubDM_DA() line 188 in
>>>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/dm/impls/da/dacreate.c
>>>>>>>>>>> [0]PETSC ERROR: DMCreateSubDM() line 1267 in
>>>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/dm/interface/dm.c
>>>>>>>>>>> [0]PETSC ERROR: PCFieldSplitSetDefaults() line 337 in
>>>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/ksp/pc/impls/fieldsplit/fieldsplit.c
>>>>>>>>>>> [0]PETSC ERROR: PCSetUp_FieldSplit() line 458 in
>>>>>>>>>>> [0]PETSC ERROR: PCSetUp() line 890 in
>>>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/ksp/pc/interface/precon.c
>>>>>>>>>>> [0]PETSC ERROR: KSPSetUp() line 278 in
>>>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/ksp/ksp/interface/itfunc.c
>>>>>>>>>>> [0]PETSC ERROR: solveModel() line 181 in
>>>>>>>>>>> "unknowndirectory/"/user/bkhanal/home/works/AdLemModel/src/PetscAdLemTaras3D.cxx
>>>>>>>>>>> WARNING! There are options you set that were not used!
>>>>>>>>>>> WARNING! could be spelling mistake, etc!
>>>>>>>>>>> Option left: name:-pc_fieldsplit_1_fields value: 3
>>>>>>>>>>>>    Matt
>>>>>>>>>>>>>>    Matt
>>>>>>>>>>>>>>>>    Matt
>>>>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>>>>> their experiments lead.
>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130823/d938c824/attachment-0001.html>
