[petsc-users] discontinuous viscosity stokes equation 3D staggered grid
Fri Aug 23 08:34:18 CDT 2013
On Fri, Aug 23, 2013 at 8:30 AM, Bishesh Khanal <bisheshkh at gmail.com> wrote:
> On Fri, Aug 23, 2013 at 3:16 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Fri, Aug 23, 2013 at 8:01 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>> On Fri, Aug 23, 2013 at 2:53 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>> On Fri, Aug 23, 2013 at 7:46 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>>>> On Fri, Aug 23, 2013 at 2:33 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>> On Fri, Aug 23, 2013 at 7:25 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>>>>>> On Fri, Aug 23, 2013 at 2:09 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>>>> On Fri, Aug 23, 2013 at 4:31 AM, Bishesh Khanal <
>>>>>>>>> Thanks Matt and Mark for comments in using near null space
>>>>>>>>> [question I asked in the thread with subject: *problem
>>>>>>>>> (Segmentation voilation) using -pc_type hypre -pc_hypre_type -pilut with
>>>>>>>>> multiple nodes in a cluster*].
>>>>>>>>> So I understood that I have to set a nearNullSpace to A00 block
>>>>>>>>> where the null space correspond to the rigid body motion. I tried it but
>>>>>>>>> still the gamg just keeps on iterating and convergence is very very slow. I
>>>>>>>>> am not sure what the problem is, right now gamg does not even work for the
>>>>>>>>> constant viscosity case.
>>>>>>>>> I have set up the following in my code:
>>>>>>>>> 1. null space for the whole system A 2. null space for the Schur
>>>>>>>>> complement S 3. Near null space for A00 4. a user preconditioner matrix of
>>>>>>>>> inverse viscosity in the diagonal for S.
>>>>>>>> If you want to debug solvers, you HAVE to send -ksp_view.
>>>>>>> When I use gamg, the -fieldsplit_0_ksp was iterating on and on so
>>>>>>> didn't get to the end to get -ksp_view results.
>>>>>>> Instead here I have put the -ksp_view output when running the
>>>>>>> program with following options: (In this case I get the results)
>>>>>>> -pc_type fieldsplit -pc_fieldsplit_type schur
>>>>>>> -pc_fieldsplit_dm_splits 0 -pc_fieldsplit_0_fields 0,1,2
>>>>>>> -pc_fieldsplit_1_fields 3 -ksp_converged_reason -ksp_view
>>>>>> Okay, that looks fine. Does
>>>>>>   -fieldsplit_0_pc_type lu
>>>>>>   - fieldsplit_1_ksp_rtol 1.0e-10
>>>>>> converge in one Iterate?
>>>>>> What matrix did you attach as the preconditioner matrix for
>>>>>> fieldsplit_1_?
>>>>> I used a diagonal matrix with reciprocal of viscosity values of the
>>>>> corresponding cell centers as the preconditioner.
>>>>> with the options  -fieldsplit_0_pc_type lu  - fieldsplit_1_ksp_rtol
>>>>> 1.0e-10 -fieldsplit_1_ksp_converged_reason -ksp_converged_reason
>>>>> I get the following output which means the outer ksp did converge in
>>>>> one iterate I guess.
>>>>>   Linear solve converged due to CONVERGED_RTOL iterations 18
>>>> Okay, so A_00 is nonsingular, and the system seems to solve alright.
>>>> What do you get for
>>>>   -fieldsplit_0_ksp_max_it 30
>>>>   -fieldsplit_0_pc_type gamg
>>>>   -fieldsplit_0_ksp_converged_reason
>>> It fieldsplit_0_ does not converge in 30 iterations. It gives:
>>>  Linear solve converged due to CONVERGED_ATOL iterations 0
>>> Linear solve did not converge due to DIVERGED_ITS iterations 30
>>> and continues with the same message.
>> So what would you do? Give up?
>> No, I don't want to give up :)
>>   -fieldsplit_0_ksp_gmres_restart 200
>> The idea is to figure out what is going on:
>>   -fieldsplit_0_ksp_monitor_true_residual
>> I have tried these options before too, the residual is decreasing very
> very slowly,  but I've not been able to figure out why. (using hypre does
> converge although slowly again, but I had problems using hypre with
> multiple nodes in a cluster with segmentation fault (we discussed that in
> another thread!) )
Put in the Laplacian instead of the operator you have now. It should
converge in a few iterates. If not, you have a problem
in the specification.
If so, put in linear elasticity. If it is slow, you have made a mistake
specifiying the near null space. Also, you need to check
that the near null space made it to GAMG using the ksp_view output.
   Matt
> e.g a snapshot of the output:
>     Residual norms for fieldsplit_0_ solve.
>     0 KSP preconditioned resid norm 0.000000000000e+00 true resid norm
> 0.000000000000e+00 ||r(i)||/||b||           -nan
>     0 KSP preconditioned resid norm 2.619231455875e-01 true resid norm
> 3.637306695895e+02 ||r(i)||/||b|| 1.000000000000e+00
>     1 KSP preconditioned resid norm 9.351491725479e-02 true resid norm
> 6.013334574957e+01 ||r(i)||/||b|| 1.653238255038e-01
>     2 KSP preconditioned resid norm 6.010357491087e-02 true resid norm
> 3.664473273769e+01 ||r(i)||/||b|| 1.007468871928e-01
>     3 KSP preconditioned resid norm 6.006968012944e-02 true resid norm
> 3.696451770148e+01 ||r(i)||/||b|| 1.016260678353e-01
>     4 KSP preconditioned resid norm 4.418407037098e-02 true resid norm
> 3.184810838034e+01 ||r(i)||/||b|| 8.755959022176e-02
>   93 KSP preconditioned resid norm 4.549506047737e-04 true resid norm
> 2.877594552685e+00 ||r(i)||/||b|| 7.911333283864e-03
>    94 KSP preconditioned resid norm 4.515424416235e-04 true resid norm
> 2.875249044668e+00 ||r(i)||/||b|| 7.904884809172e-03
>    95 KSP preconditioned resid norm 4.277647876573e-04 true resid norm
> 2.830418831358e+00 ||r(i)||/||b|| 7.781633686685e-03
>    96 KSP preconditioned resid norm 4.244529173876e-04 true resid norm
> 2.807041401408e+00 ||r(i)||/||b|| 7.717362422521e-03
>    97 KSP preconditioned resid norm 4.138326570674e-04 true resid norm
> 2.793663020386e+00 ||r(i)||/||b|| 7.680581413547e-03
>    98 KSP preconditioned resid norm 3.869979433609e-04 true resid norm
> 2.715150386650e+00 ||r(i)||/||b|| 7.464727650583e-03
>    99 KSP preconditioned resid norm 3.847873979265e-04 true resid norm
> 2.706008990336e+00 ||r(i)||/||b|| 7.439595328571e-03
>   294 KSP preconditioned resid norm 1.416482289961e-04 true resid norm
> 2.735750748819e+00 ||r(i)||/||b|| 7.521363958412e-03
>   295 KSP preconditioned resid norm 1.415389087364e-04 true resid norm
> 2.742638608355e+00 ||r(i)||/||b|| 7.540300661064e-03
>   296 KSP preconditioned resid norm 1.414967651105e-04 true resid norm
> 2.747224243968e+00 ||r(i)||/||b|| 7.552907889424e-03
>   297 KSP preconditioned resid norm 1.413843018303e-04 true resid norm
> 2.752574248710e+00 ||r(i)||/||b|| 7.567616587891e-03
>   298 KSP preconditioned resid norm 1.411747949695e-04 true resid norm
> 2.765459647367e+00 ||r(i)||/||b|| 7.603042246859e-03
>   299 KSP preconditioned resid norm 1.411609742082e-04 true resid norm
> 2.765900464868e+00 ||r(i)||/||b|| 7.604254180683e-03
>   300 KSP preconditioned resid norm 1.409844332838e-04 true resid norm
> 2.771790506811e+00 ||r(i)||/||b|| 7.620447596402e-03
>   Linear solve did not converge due to DIVERGED_ITS iterations 300
>     0 KSP preconditioned resid norm 1.294272083271e-03 true resid norm
> 1.776945075651e+00 ||r(i)||/||b|| 1.000000000000e+00
>>      Matt
>>>> This is the kind of investigation you msut be comfortable with if you
>>>> want to experiment with these solvers.
>>>>     Matt
>>>>>>   Thanks,
>>>>>>      Matt
>>>>>>> Linear solve converged due to CONVERGED_RTOL iterations 2
>>>>>>> KSP Object: 1 MPI processes
>>>>>>>   type: gmres
>>>>>>>     GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
>>>>>>> Orthogonalization with no iterative refinement
>>>>>>>     GMRES: happy breakdown tolerance 1e-30
>>>>>>>   maximum iterations=10000, initial guess is zero
>>>>>>>   tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>>>>>>>   left preconditioning
>>>>>>>   has attached null space
>>>>>>>   using PRECONDITIONED norm type for convergence test
>>>>>>> PC Object: 1 MPI processes
>>>>>>>   type: fieldsplit
>>>>>>>     FieldSplit with Schur preconditioner, blocksize = 4,
>>>>>>> factorization FULL
>>>>>>>     Preconditioner for the Schur complement formed from user
>>>>>>> provided matrix
>>>>>>>     Split info:
>>>>>>>     Split number 0 Fields  0, 1, 2
>>>>>>>     Split number 1 Fields  3
>>>>>>>     KSP solver for A00 block
>>>>>>>       KSP Object:      (fieldsplit_0_)       1 MPI processes
>>>>>>>         type: gmres
>>>>>>> Gram-Schmidt Orthogonalization with no iterative refinement
>>>>>>>       PC Object:      (fieldsplit_0_)       1 MPI processes
>>>>>>>         type: ilu
>>>>>>>           ILU: out-of-place factorization
>>>>>>>           0 levels of fill
>>>>>>>           tolerance for zero pivot 2.22045e-14
>>>>>>>           using diagonal shift on blocks to prevent zero pivot
>>>>>>>           matrix ordering: natural
>>>>>>>           factor fill ratio given 1, needed 1
>>>>>>>             Factored matrix follows:
>>>>>>>               Matrix Object:               1 MPI processes
>>>>>>>                 type: seqaij
>>>>>>>                 rows=8232, cols=8232
>>>>>>>                 package used to perform factorization: petsc
>>>>>>>                 total: nonzeros=576000, allocated nonzeros=576000
>>>>>>>                 total number of mallocs used during MatSetValues
>>>>>>> calls =0
>>>>>>>                   using I-node routines: found 2744 nodes, limit
>>>>>>> used is 5
>>>>>>>         linear system matrix = precond matrix:
>>>>>>>           type: seqaij
>>>>>>>           total number of mallocs used during MatSetValues calls =0
>>>>>>>             using I-node routines: found 2744 nodes, limit used is 5
>>>>>>>     KSP solver for S = A11 - A10 inv(A00) A01
>>>>>>>       KSP Object:      (fieldsplit_1_)       1 MPI processes
>>>>>>>         type: gmres
>>>>>>>       PC Object:      (fieldsplit_1_)       1 MPI processes
>>>>>>>         type: ilu
>>>>>>>           0 levels of fill
>>>>>>>                 type: seqaij
>>>>>>>                 rows=2744, cols=2744
>>>>>>>                 total: nonzeros=64000, allocated nonzeros=64000
>>>>>>> calls =0
>>>>>>>                   not using I-node routines
>>>>>>>         linear system matrix followed by preconditioner matrix:
>>>>>>>           type: schurcomplement
>>>>>>>             Schur complement A11 - A10 inv(A00) A01
>>>>>>>             A11
>>>>>>>                 type: seqaij
>>>>>>> calls =0
>>>>>>>             A10
>>>>>>>                 type: seqaij
>>>>>>>                 rows=2744, cols=8232
>>>>>>>                 total: nonzeros=192000, allocated nonzeros=192000
>>>>>>> calls =0
>>>>>>>             KSP of A00
>>>>>>> 1 MPI processes
>>>>>>>                 type: gmres
>>>>>>> divergence=10000
>>>>>>> 1 MPI processes
>>>>>>>                 type: ilu
>>>>>>>                   0 levels of fill
>>>>>>> pivot
>>>>>>> processes
>>>>>>>                         type: seqaij
>>>>>>> nonzeros=576000
>>>>>>> limit used is 5
>>>>>>>                   type: seqaij
>>>>>>> calls =0
>>>>>>> used is 5
>>>>>>>             A01
>>>>>>>                 type: seqaij
>>>>>>>                 rows=8232, cols=2744
>>>>>>> calls =0
>>>>>>> used is 5
>>>>>>>           type: seqaij
>>>>>>>     type: seqaij
>>>>>>>     rows=10976, cols=10976, bs=4
>>>>>>>     total: nonzeros=1024000, allocated nonzeros=1024000
>>>>>>>>    Matt
>>>>>>>>> I am testing a small problem with CONSTANT viscosity for grid size
>>>>>>>>> of 14^3 with the run time option:
>>>>>>>>> -ksp_type gcr -pc_type fieldsplit -pc_fieldsplit_type schur
>>>>>>>>> -fieldsplit_0_ksp_type gcr -fieldsplit_0_pc_type gamg
>>>>>>>>> -fieldsplit_0_ksp_monitor_true_residual -fieldsplit_0_ksp_converged_reason
>>>>>>>>> -fieldsplit_1_ksp_monitor_true_residual
>>>>>>>>> Here is my relevant code of the solve function:
>>>>>>>>> PetscErrorCode ierr;
>>>>>>>>>     PetscFunctionBeginUser;
>>>>>>>>>     ierr =
>>>>>>>>> DMKSPSetComputeRHS(mDa,computeRHSTaras3D,this);CHKERRQ(ierr);
>>>>>>>>>     ierr =
>>>>>>>>> DMKSPSetComputeOperators(mDa,computeMatrixTaras3D,this);CHKERRQ(ierr);
>>>>>>>>>     ierr = KSPSetDM(mKsp,mDa);CHKERRQ(ierr);              //mDa
>>>>>>>>> with dof = 4, vx,vy,vz and p.
>>>>>>>>>     ierr =
>>>>>>>>> KSPSetNullSpace(mKsp,mNullSpace);CHKERRQ(ierr);//nullSpace for the main
>>>>>>>>> system
>>>>>>>>>     ierr = KSPSetFromOptions(mKsp);CHKERRQ(ierr);
>>>>>>>>>     ierr = KSPSetUp(mKsp);CHKERRQ(ierr);
>>>>>>>>> //register the fieldsplits obtained from options.
>>>>>>>>>     //Setting up user PC for Schur Complement
>>>>>>>>>     ierr = KSPGetPC(mKsp,&mPc);CHKERRQ(ierr);
>>>>>>>>>     ierr =
>>>>>>>>> PCFieldSplitSchurPrecondition(mPc,PC_FIELDSPLIT_SCHUR_PRE_USER,mPcForSc);CHKERRQ(ierr);
>>>>>>>>>     KSP *subKsp;
>>>>>>>>>     PetscInt subKspPos = 0;
>>>>>>>>>     //Set up nearNullspace for A00 block.
>>>>>>>>>     ierr =
>>>>>>>>> PCFieldSplitGetSubKSP(mPc,&subKspPos,&subKsp);CHKERRQ(ierr);
>>>>>>>>>     MatNullSpace rigidBodyModes;
>>>>>>>>>     Vec coords;
>>>>>>>>>     ierr = DMGetCoordinates(mDa,&coords);CHKERRQ(ierr);
>>>>>>>>>     ierr =
>>>>>>>>> MatNullSpaceCreateRigidBody(coords,&rigidBodyModes);CHKERRQ(ierr);
>>>>>>>>>     Mat matA00;
>>>>>>>>>     ierr =
>>>>>>>>> KSPGetOperators(subKsp[0],&matA00,NULL,NULL);CHKERRQ(ierr);
>>>>>>>>>     ierr =
>>>>>>>>> MatSetNearNullSpace(matA00,rigidBodyModes);CHKERRQ(ierr);
>>>>>>>>>     ierr = MatNullSpaceDestroy(&rigidBodyModes);CHKERRQ(ierr);
>>>>>>>>>     //Position 1 => Ksp corresponding to Schur complement S on
>>>>>>>>> pressure space
>>>>>>>>>     subKspPos = 1;
>>>>>>>>>     ierr =
>>>>>>>>>     //Set up the null space of constant pressure.
>>>>>>>>>     ierr = KSPSetNullSpace(subKsp[1],mNullSpaceP);CHKERRQ(ierr);
>>>>>>>>>     PetscBool isNull;
>>>>>>>>>     Mat matSc;
>>>>>>>>>     ierr =
>>>>>>>>> KSPGetOperators(subKsp[1],&matSc,NULL,NULL);CHKERRQ(ierr);
>>>>>>>>>     ierr = MatNullSpaceTest(mNullSpaceP,matSc,&isNull);
>>>>>>>>>     if(!isNull)
>>>>>>>>>         SETERRQ(PETSC_COMM_WORLD,PETSC_ERR_PLIB,"not a valid
>>>>>>>>> pressure null space \n");
>>>>>>>>>     ierr = KSPGetOperators(mKsp,&mA,NULL,NULL);CHKERRQ(ierr);
>>>>>>>>>     ierr = MatNullSpaceTest(mNullSpace,mA,&isNull);CHKERRQ(ierr);
>>>>>>>>>     if(!isNull)
>>>>>>>>> system null space \n");
>>>>>>>>>     ierr = PetscFree(subKsp);CHKERRQ(ierr);
>>>>>>>>>     ierr = KSPSolve(mKsp,NULL,NULL);CHKERRQ(ierr);
>>>>>>>>>     ierr = KSPGetSolution(mKsp,&mX);CHKERRQ(ierr);
>>>>>>>>>     ierr = KSPGetRhs(mKsp,&mB);CHKERRQ(ierr);
>>>>>>>>>     PetscFunctionReturn(0);
>>>>>>>>> On Wed, Aug 7, 2013 at 2:15 PM, Matthew Knepley <knepley at gmail.com
>>>>>>>>> > wrote:
>>>>>>>>>> On Wed, Aug 7, 2013 at 7:07 AM, Bishesh Khanal <
>>>>>>>>>>> On Tue, Aug 6, 2013 at 11:34 PM, Matthew Knepley <
>>>>>>>>>>> knepley at gmail.com> wrote:
>>>>>>>>>>>> On Tue, Aug 6, 2013 at 10:59 AM, Bishesh Khanal <
>>>>>>>>>>>>> On Tue, Aug 6, 2013 at 4:40 PM, Matthew Knepley <
>>>>>>>>>>>>>> On Tue, Aug 6, 2013 at 8:06 AM, Bishesh Khanal <
>>>>>>>>>>>>>>> On Mon, Aug 5, 2013 at 4:14 PM, Matthew Knepley <
>>>>>>>>>>>>>>>> On Mon, Aug 5, 2013 at 8:48 AM, Bishesh Khanal <
>>>>>>>>>>>>>>>>> On Mon, Aug 5, 2013 at 3:17 PM, Matthew Knepley <
>>>>>>>>>>>>>>>>>> On Mon, Aug 5, 2013 at 7:54 AM, Bishesh Khanal <
>>>>>>>>>>>>>>>>>>> On Wed, Jul 17, 2013 at 9:48 PM, Jed Brown <
>>>>>>>>>>>>>>>>>>> jedbrown at mcs.anl.gov> wrote:
>>>>>>>>>>>>>>>>>>>> Bishesh Khanal <bisheshkh at gmail.com> writes:
>>>>>>>>>>>>>>>>>>>> > Now, I implemented two different approaches, each for
>>>>>>>>>>>>>>>>>>>> both 2D and 3D, in
>>>>>>>>>>>>>>>>>>>> > MATLAB. It works for the smaller sizes but I have
>>>>>>>>>>>>>>>>>>>> problems solving it for
>>>>>>>>>>>>>>>>>>>> > the problem size I need (250^3 grid size).
>>>>>>>>>>>>>>>>>>>> > I use staggered grid with p on cell centers, and
>>>>>>>>>>>>>>>>>>>> components of v on cell
>>>>>>>>>>>>>>>>>>>> > faces. Similar split up of K to cell center and faces
>>>>>>>>>>>>>>>>>>>> to account for the
>>>>>>>>>>>>>>>>>>>> > variable viscosity case)
>>>>>>>>>>>>>>>>>>>> Okay, you're using a staggered-grid finite difference
>>>>>>>>>>>>>>>>>>>> discretization of
>>>>>>>>>>>>>>>>>>>> variable-viscosity Stokes.  This is a common problem
>>>>>>>>>>>>>>>>>>>> and I recommend
>>>>>>>>>>>>>>>>>>>> starting with PCFieldSplit with Schur complement
>>>>>>>>>>>>>>>>>>>> reduction (make that
>>>>>>>>>>>>>>>>>>>> work first, then switch to block preconditioner).  You
>>>>>>>>>>>>>>>>>>>> can use PCLSC or
>>>>>>>>>>>>>>>>>>>> (probably better for you), assemble a preconditioning
>>>>>>>>>>>>>>>>>>>> matrix containing
>>>>>>>>>>>>>>>>>>>> the inverse viscosity in the pressure-pressure block.
>>>>>>>>>>>>>>>>>>>>  This diagonal
>>>>>>>>>>>>>>>>>>>> matrix is a spectrally equivalent (or nearly so,
>>>>>>>>>>>>>>>>>>>> depending on
>>>>>>>>>>>>>>>>>>>> discretization) approximation of the Schur complement.
>>>>>>>>>>>>>>>>>>>>  The velocity
>>>>>>>>>>>>>>>>>>>> block can be solved with algebraic multigrid.  Read the
>>>>>>>>>>>>>>>>>>>> PCFieldSplit
>>>>>>>>>>>>>>>>>>>> docs (follow papers as appropriate) and let us know if
>>>>>>>>>>>>>>>>>>>> you get stuck.
>>>>>>>>>>>>>>>>>>> I was trying to assemble the inverse viscosity diagonal
>>>>>>>>>>>>>>>>>>> matrix to use as the preconditioner for the Schur complement solve step as
>>>>>>>>>>>>>>>>>>> you suggested. I've few questions about the ways to implement this in Petsc:
>>>>>>>>>>>>>>>>>>> A naive approach that I can think of would be to create
>>>>>>>>>>>>>>>>>>> a vector with its components as reciprocal viscosities of the cell centers
>>>>>>>>>>>>>>>>>>> corresponding to the pressure variables, and then create a diagonal matrix
>>>>>>>>>>>>>>>>>>> from this vector. However I'm not sure about:
>>>>>>>>>>>>>>>>>>> How can I make this matrix, (say S_p) compatible to the
>>>>>>>>>>>>>>>>>>> Petsc distribution of the different rows of the main system matrix over
>>>>>>>>>>>>>>>>>>> different processors ? The main matrix was created using the DMDA structure
>>>>>>>>>>>>>>>>>>> with 4 dof as explained before.
>>>>>>>>>>>>>>>>>>> The main matrix correspond to the DMDA with 4 dofs but
>>>>>>>>>>>>>>>>>>> for the S_p matrix would correspond to only pressure space. Should the
>>>>>>>>>>>>>>>>>>> distribution of the rows of S_p among different processor not correspond to
>>>>>>>>>>>>>>>>>>> the distribution of the rhs vector, say h' if it is solving for p with Sp =
>>>>>>>>>>>>>>>>>>> h' where S = A11 inv(A00) A01 ?
>>>>>>>>>>>>>>>>>> PETSc distributed vertices, not dofs, so it never breaks
>>>>>>>>>>>>>>>>>> blocks. The P distribution is the same as the entire problem divided by 4.
>>>>>>>>>>>>>>>>> Thanks Matt. So if I create a new DMDA with same grid size
>>>>>>>>>>>>>>>>> but with dof=1 instead of 4, the vertices for this new DMDA will be
>>>>>>>>>>>>>>>>> identically distributed as for the original DMDA ? Or should I inform PETSc
>>>>>>>>>>>>>>>>> by calling a particular function to make these two DMDA have identical
>>>>>>>>>>>>>>>>> distribution of the vertices ?
>>>>>>>>>>>>>>>> Yes.
>>>>>>>>>>>>>>>>>  Even then I think there might be a problem due to the
>>>>>>>>>>>>>>>>> presence of "fictitious pressure vertices". The system matrix (A) contains
>>>>>>>>>>>>>>>>> an identity corresponding to these fictitious pressure nodes, thus when
>>>>>>>>>>>>>>>>> using a -pc_fieldsplit_detect_saddle_point, will detect a A11 zero block of
>>>>>>>>>>>>>>>>> size that correspond to only non-fictitious P-nodes. So the preconditioner
>>>>>>>>>>>>>>>>> S_p for the Schur complement outer solve with Sp = h' will also need to
>>>>>>>>>>>>>>>>> correspond to only the non-fictitious P-nodes. This means its size does not
>>>>>>>>>>>>>>>>> directly correspond to the DMDA grid defined for the original problem.
>>>>>>>>>>>>>>>>> Could you please suggest an efficient way of assembling this S_p matrix ?
>>>>>>>>>>>>>>>> Don't use detect_saddle, but split it by fields
>>>>>>>>>>>>>>>> -pc_fieldsplit_0_fields 0,1,2 -pc_fieldsplit_1_fields 4
>>>>>>>>>>>>>>> How can I set this split in the code itself without giving
>>>>>>>>>>>>>>> it as a command line option when the system matrix is assembled from the
>>>>>>>>>>>>>>> DMDA for the whole system with 4 dofs. (i.e. *without*using the DMComposite or
>>>>>>>>>>>>>>> *without* using the nested block matrices to assemble
>>>>>>>>>>>>>>> different blocks separately and then combine them together).
>>>>>>>>>>>>>>> I need the split to get access to the fieldsplit_1_ksp in my
>>>>>>>>>>>>>>> code, because not using detect_saddle_point means I cannot use
>>>>>>>>>>>>>>> -fieldsplit_1_ksp_constant_null_space due to the presence of identity for
>>>>>>>>>>>>>>> the fictitious pressure nodes present in the fieldsplit_1_ block. I need to
>>>>>>>>>>>>>>> use PCFieldSplitGetSubKsp() so that I can set proper null-space basis.
>>>>>>>>>>>>>> This is currently a real problem with the DMDA. In the
>>>>>>>>>>>>>> unstructured case, where we always need specialized spaces, you can
>>>>>>>>>>>>>> use something like
>>>>>>>>>>>>>>     PetscObject  pressure;
>>>>>>>>>>>>>>     MatNullSpace nullSpacePres;
>>>>>>>>>>>>>>     ierr = DMGetField(dm, 1, &pressure);CHKERRQ(ierr);
>>>>>>>>>>>>>>     ierr = MatNullSpaceCreate(PetscObjectComm(pressure),
>>>>>>>>>>>>>> PETSC_TRUE, 0, NULL, &nullSpacePres);CHKERRQ(ierr);
>>>>>>>>>>>>>>     ierr = PetscObjectCompose(pressure, "nullspace",
>>>>>>>>>>>>>> (PetscObject) nullSpacePres);CHKERRQ(ierr);
>>>>>>>>>>>>>>     ierr = MatNullSpaceDestroy(&nullSpacePres);CHKERRQ(ierr);
>>>>>>>>>>>>>> and then DMGetSubDM() uses this information to attach the
>>>>>>>>>>>>>> null space to the IS that is created using the information in the
>>>>>>>>>>>>>> PetscSection.
>>>>>>>>>>>>>> If you use a PetscSection to set the data layout over the
>>>>>>>>>>>>>> DMDA, I think this works correctly, but this has not been tested at all and
>>>>>>>>>>>>>> is very
>>>>>>>>>>>>>> new code. Eventually, I think we want all DMs to use this
>>>>>>>>>>>>>> mechanism, but we are still working it out.
>>>>>>>>>>>>> Currently I do not use PetscSection. If this makes a cleaner
>>>>>>>>>>>>> approach, I'd try it too but may a bit later (right now I'd like test my
>>>>>>>>>>>>> model with a quickfix even if it means a little dirty code!)
>>>>>>>>>>>>>> Bottom line: For custom null spaces using the default layout
>>>>>>>>>>>>>> in DMDA, you need to take apart the PCFIELDSPLIT after it has been setup,
>>>>>>>>>>>>>> which is somewhat subtle. You need to call KSPSetUp() and
>>>>>>>>>>>>>> then reach in and get the PC, and the subKSPs. I don't like this at all,
>>>>>>>>>>>>>> but we
>>>>>>>>>>>>>> have not reorganized that code (which could be very simple
>>>>>>>>>>>>>> and inflexible since its very structured).
>>>>>>>>>>>>> So I tried to get this approach working but I could not
>>>>>>>>>>>>> succeed and encountered some errors. Here is a code snippet:
>>>>>>>>>>>>> //mDa is the DMDA that describes the whole grid with all 4
>>>>>>>>>>>>> dofs (3 velocity components and 1 pressure comp.)
>>>>>>>>>>>>> ierr =
>>>>>>>>>>>>>     ierr =
>>>>>>>>>>>>>     ierr =
>>>>>>>>>>>>> KSPSetNullSpace(mKsp,mNullSpaceSystem);CHKERRQ(ierr);   //I've the
>>>>>>>>>>>>> mNullSpaceSystem based on mDa, that contains a null space basis for the
>>>>>>>>>>>>> complete system.
>>>>>>>>>>>>>     ierr =
>>>>>>>>>>>>> //This I expect would register these options I give:-pc_type fieldsplit
>>>>>>>>>>>>> -pc_fieldsplit_type schur -pc_fieldsplit_0_fields 0,1,2
>>>>>>>>>>>>> //-pc_fieldsplit_1_fields 3
>>>>>>>>>>>>>     ierr = KSPGetPC(mKsp,&mPcOuter);     //Now get the PC that
>>>>>>>>>>>>> was obtained from the options (fieldsplit)
>>>>>>>>>>>>>     ierr =
>>>>>>>>>>>>> PCFieldSplitSchurPrecondition(mPcOuter,PC_FIELDSPLIT_SCHUR_PRE_USER,mPcForSc);CHKERRQ(ierr);
>>>>>>>>>>>>> //I have created the matrix mPcForSc using a DMDA with identical //size to
>>>>>>>>>>>>> mDa but with dof=1 corresponding to the pressure nodes (say mDaPressure).
>>>>>>>>>>>>>   ierr = PCSetUp(mPcOuter);CHKERRQ(ierr);
>>>>>>>>>>>>>     KSP *kspSchur;
>>>>>>>>>>>>>     PetscInt kspSchurPos = 1;
>>>>>>>>>>>>>     ierr =
>>>>>>>>>>>>> PCFieldSplitGetSubKSP(mPcOuter,&kspSchurPos,&kspSchur);CHKERRQ(ierr);
>>>>>>>>>>>>>     ierr =
>>>>>>>>>>>>> KSPSetNullSpace(kspSchur[1],mNullSpacePressure);CHKERRQ(ierr);
>>>>>>>>>>>>> //The null space is the one that correspond to only pressure nodes, created
>>>>>>>>>>>>> using the mDaPressure.
>>>>>>>>>>>>>     ierr = PetscFree(kspSchur);CHKERRQ(ierr);
>>>>>>>>>>>> Sorry, you need to return to the old DMDA behavior, so you want
>>>>>>>>>>> Thanks, with this it seems I can attach the null space properly,
>>>>>>>>>>> but I have a question regarding whether the Schur complement ksp solver is
>>>>>>>>>>> actually using the preconditioner matrix I provide.
>>>>>>>>>>> When using -ksp_view, the outer level pc object of type
>>>>>>>>>>> fieldsplit does report that: "Preconditioner for the Schur complement
>>>>>>>>>>> formed from user provided matrix", but in the KSP solver for Schur
>>>>>>>>>>> complement S, the pc object (fieldsplit_1_) is of type ilu and doesn't say
>>>>>>>>>>> that it is using the matrix I provide. Am I missing something here ?
>>>>>>>>>>> Below are the relevant commented code snippet and the output of
>>>>>>>>>>> the -ksp_view
>>>>>>>>>>> (The options I used: -pc_type fieldsplit -pc_fieldsplit_type
>>>>>>>>>>> schur -pc_fieldsplit_dm_splits 0 -pc_fieldsplit_0_fields 0,1,2
>>>>>>>>>>> -pc_fieldsplit_1_fields 3 -ksp_converged_reason -ksp_view )
>>>>>>>>>> If ILU does not error, it means it is using your matrix, because
>>>>>>>>>> the Schur complement matrix cannot be factored, and FS says it is using
>>>>>>>>>> your matrix.
>>>>>>>>>>    Matt
>>>>>>>>>>> Code snippet:
>>>>>>>>>>> ierr = KSPSetNullSpace(mKsp,mNullSpaceSystem);CHKERRQ(ierr);
>>>>>>>>>>> //The nullspace for the whole system
>>>>>>>>>>>     ierr =
>>>>>>>>>>>     ierr = KSPSetUp(mKsp);CHKERRQ(ierr);                   //Set
>>>>>>>>>>> up mKsp with the options provided with fieldsplit and the fields associated
>>>>>>>>>>> with the two splits.
>>>>>>>>>>>     ierr = KSPGetPC(mKsp,&mPcOuter);CHKERRQ(ierr);
>>>>>>>>>>>                //Get the fieldsplit pc set up from the options
>>>>>>>>>>>     ierr =
>>>>>>>>>>> //Use mPcForSc as the preconditioner for Schur Complement
>>>>>>>>>>>     KSP *kspSchur;
>>>>>>>>>>>     ierr =
>>>>>>>>>>>     ierr =
>>>>>>>>>>> //Attach the null-space for the Schur complement ksp solver.
>>>>>>>>>>> the output of the -ksp_view
>>>>>>>>>>>   type: gmres
>>>>>>>>>>>   type: fieldsplit
>>>>>>>>>>> factorization FULL
>>>>>>>>>>> provided matrix
>>>>>>>>>>>     Split info:
>>>>>>>>>>>         type: gmres
>>>>>>>>>>> divergence=10000
>>>>>>>>>>>         type: ilu
>>>>>>>>>>>           0 levels of fill
>>>>>>>>>>>                 type: seqaij
>>>>>>>>>>>                 rows=2187, cols=2187
>>>>>>>>>>>                 total: nonzeros=140625, allocated nonzeros=140625
>>>>>>>>>>> calls =0
>>>>>>>>>>>                   using I-node routines: found 729 nodes, limit
>>>>>>>>>>> used is 5
>>>>>>>>>>>           type: seqaij
>>>>>>>>>>> =0
>>>>>>>>>>>             using I-node routines: found 729 nodes, limit used
>>>>>>>>>>> is 5
>>>>>>>>>>>         type: gmres
>>>>>>>>>>> divergence=10000
>>>>>>>>>>>         type: ilu
>>>>>>>>>>>           0 levels of fill
>>>>>>>>>>>                 type: seqaij
>>>>>>>>>>>                 rows=729, cols=729
>>>>>>>>>>>                 total: nonzeros=15625, allocated nonzeros=15625
>>>>>>>>>>> calls =0
>>>>>>>>>>>           rows=729, cols=729
>>>>>>>>>>>             A11
>>>>>>>>>>>                 type: seqaij
>>>>>>>>>>>                 rows=729, cols=729
>>>>>>>>>>> calls =0
>>>>>>>>>>>             A10
>>>>>>>>>>>                 type: seqaij
>>>>>>>>>>>                 rows=729, cols=2187
>>>>>>>>>>>                 total: nonzeros=46875, allocated nonzeros=46875
>>>>>>>>>>> calls =0
>>>>>>>>>>>             KSP of A00
>>>>>>>>>>>               KSP Object:
>>>>>>>>>>>                 type: gmres
>>>>>>>>>>> (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
>>>>>>>>>>> divergence=10000
>>>>>>>>>>> test
>>>>>>>>>>>               PC Object:
>>>>>>>>>>>                 type: ilu
>>>>>>>>>>>                   0 levels of fill
>>>>>>>>>>> pivot
>>>>>>>>>>> processes
>>>>>>>>>>>                         type: seqaij
>>>>>>>>>>> petsc
>>>>>>>>>>> nonzeros=140625
>>>>>>>>>>>                   type: seqaij
>>>>>>>>>>> nonzeros=140625
>>>>>>>>>>> limit used is 5
>>>>>>>>>>>             A01
>>>>>>>>>>>                 type: seqaij
>>>>>>>>>>>                 rows=2187, cols=729
>>>>>>>>>>> calls =0
>>>>>>>>>>> used is 5
>>>>>>>>>>>           type: seqaij
>>>>>>>>>>>           rows=729, cols=729
>>>>>>>>>>> =0
>>>>>>>>>>>     type: seqaij
>>>>>>>>>>>     rows=2916, cols=2916, bs=4
>>>>>>>>>>>     total: nonzeros=250000, allocated nonzeros=250000
>>>>>>>>>>>       using I-node routines: found 729 nodes, limit used is 5
>>>>>>>>>>>> or
>>>>>>>>>>>>   PCFieldSplitSetDMSplits(pc, PETSC_FALSE)
>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>      Matt
>>>>>>>>>>>>> The errors I get when running with options: -pc_type
>>>>>>>>>>>>> fieldsplit -pc_fieldsplit_type schur -pc_fieldsplit_0_fields 0,1,2
>>>>>>>>>>>>> [0]PETSC ERROR: --------------------- Error Message
>>>>>>>>>>>>> [0]PETSC ERROR: No support for this operation for this object
>>>>>>>>>>>>> type!
>>>>>>>>>>>>> [0]PETSC ERROR: Support only implemented for 2d!
>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>> [0]PETSC ERROR: Petsc Release Version 3.4.2, Jul, 02, 2013
>>>>>>>>>>>>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>>>>>>>>>>>>> [0]PETSC ERROR: See docs/faq.html for hints about trouble
>>>>>>>>>>>>> shooting.
>>>>>>>>>>>>> [0]PETSC ERROR: See docs/index.html for manual pages.
>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>> [0]PETSC ERROR: src/AdLemMain on a arch-linux2-cxx-debug named
>>>>>>>>>>>>> edwards by bkhanal Tue Aug  6 17:35:30 2013
>>>>>>>>>>>>> [0]PETSC ERROR: Libraries linked from
>>>>>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/arch-linux2-cxx-debug/lib
>>>>>>>>>>>>> [0]PETSC ERROR: Configure run at Fri Jul 19 14:25:01 2013
>>>>>>>>>>>>> [0]PETSC ERROR: Configure options --with-cc=gcc --with-fc=g77
>>>>>>>>>>>>> --with-cxx=g++ --download-f-blas-lapack=1 --download-mpich=1
>>>>>>>>>>>>> -with-clanguage=cxx --download-hypre=1
>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>> [0]PETSC ERROR: DMCreateSubDM_DA() line 188 in
>>>>>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/dm/impls/da/dacreate.c
>>>>>>>>>>>>> [0]PETSC ERROR: DMCreateSubDM() line 1267 in
>>>>>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/dm/interface/dm.c
>>>>>>>>>>>>> [0]PETSC ERROR: PCFieldSplitSetDefaults() line 337 in
>>>>>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/ksp/pc/impls/fieldsplit/fieldsplit.c
>>>>>>>>>>>>> [0]PETSC ERROR: PCSetUp_FieldSplit() line 458 in
>>>>>>>>>>>>> [0]PETSC ERROR: PCSetUp() line 890 in
>>>>>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/ksp/pc/interface/precon.c
>>>>>>>>>>>>> [0]PETSC ERROR: KSPSetUp() line 278 in
>>>>>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/ksp/ksp/interface/itfunc.c
>>>>>>>>>>>>> [0]PETSC ERROR: solveModel() line 181 in
>>>>>>>>>>>>> "unknowndirectory/"/user/bkhanal/home/works/AdLemModel/src/PetscAdLemTaras3D.cxx
>>>>>>>>>>>>> WARNING! There are options you set that were not used!
>>>>>>>>>>>>> WARNING! could be spelling mistake, etc!
>>>>>>>>>>>>> Option left: name:-pc_fieldsplit_1_fields value: 3
>>>>>>>>>>>>>>    Matt
>>>>>>>>>>>>>>>>    Matt
>>>>>>>>>>>>>>>>>>    Matt
>>>>>>>>>>>>>>>>>> What most experimenters take for granted before they
>>>>>>>>>>>>>>>>>> begin their experiments is infinitely more interesting than any results to
>>>>>>>>>>>>>>>>>> which their experiments lead.
>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130823/511a35c5/attachment-0001.html>
