[petsc-users] discontinuous viscosity stokes equation 3D staggered grid
Bishesh Khanal bisheshkh at gmail.com
Fri Aug 23 08:01:34 CDT 2013
On Fri, Aug 23, 2013 at 2:53 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Aug 23, 2013 at 7:46 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>> On Fri, Aug 23, 2013 at 2:33 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>> On Fri, Aug 23, 2013 at 7:25 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>>> On Fri, Aug 23, 2013 at 2:09 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>> On Fri, Aug 23, 2013 at 4:31 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>>>>> Thanks Matt and Mark for comments in using near null space [question
>>>>>> I asked in the thread with subject: *problem (Segmentation
>>>>>> voilation) using -pc_type hypre -pc_hypre_type -pilut with multiple nodes
>>>>>> in a cluster*].
>>>>>> So I understood that I have to set a nearNullSpace to A00 block where
>>>>>> the null space correspond to the rigid body motion. I tried it but still
>>>>>> the gamg just keeps on iterating and convergence is very very slow. I am
>>>>>> not sure what the problem is, right now gamg does not even work for the
>>>>>> constant viscosity case.
>>>>>> I have set up the following in my code:
>>>>>> 1. null space for the whole system A 2. null space for the Schur
>>>>>> complement S 3. Near null space for A00 4. a user preconditioner matrix of
>>>>>> inverse viscosity in the diagonal for S.
>>>>> If you want to debug solvers, you HAVE to send -ksp_view.
>>>> When I use gamg, the -fieldsplit_0_ksp was iterating on and on so
>>>> didn't get to the end to get -ksp_view results.
>>>> Instead here I have put the -ksp_view output when running the program
>>>> with following options: (In this case I get the results)
>>>> -pc_type fieldsplit -pc_fieldsplit_type schur -pc_fieldsplit_dm_splits
>>>> 0 -pc_fieldsplit_0_fields 0,1,2 -pc_fieldsplit_1_fields 3
>>>> -ksp_converged_reason -ksp_view
>>> Okay, that looks fine. Does
>>>   -fieldsplit_0_pc_type lu
>>>   - fieldsplit_1_ksp_rtol 1.0e-10
>>> converge in one Iterate?
>>> What matrix did you attach as the preconditioner matrix for
>>> fieldsplit_1_?
>> I used a diagonal matrix with reciprocal of viscosity values of the
>> corresponding cell centers as the preconditioner.
>> with the options  -fieldsplit_0_pc_type lu  - fieldsplit_1_ksp_rtol
>> 1.0e-10 -fieldsplit_1_ksp_converged_reason -ksp_converged_reason
>> I get the following output which means the outer ksp did converge in one
>> iterate I guess.
>>   Linear solve converged due to CONVERGED_RTOL iterations 18
> Okay, so A_00 is nonsingular, and the system seems to solve alright. What
> do you get for
>   -fieldsplit_0_ksp_max_it 30
>   -fieldsplit_0_pc_type gamg
>   -fieldsplit_0_ksp_converged_reason
It fieldsplit_0_ does not converge in 30 iterations. It gives:
 Linear solve converged due to CONVERGED_ATOL iterations 0
Linear solve did not converge due to DIVERGED_ITS iterations 30
and continues with the same message.
> This is the kind of investigation you msut be comfortable with if you want
> to experiment with these solvers.
>     Matt
>>>   Thanks,
>>>      Matt
>>>> Linear solve converged due to CONVERGED_RTOL iterations 2
>>>> KSP Object: 1 MPI processes
>>>>   type: gmres
>>>>     GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
>>>> Orthogonalization with no iterative refinement
>>>>     GMRES: happy breakdown tolerance 1e-30
>>>>   maximum iterations=10000, initial guess is zero
>>>>   tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>>>>   left preconditioning
>>>>   has attached null space
>>>>   using PRECONDITIONED norm type for convergence test
>>>> PC Object: 1 MPI processes
>>>>   type: fieldsplit
>>>>     FieldSplit with Schur preconditioner, blocksize = 4, factorization
>>>> FULL
>>>>     Preconditioner for the Schur complement formed from user provided
>>>> matrix
>>>>     Split info:
>>>>     Split number 0 Fields  0, 1, 2
>>>>     Split number 1 Fields  3
>>>>     KSP solver for A00 block
>>>>       KSP Object:      (fieldsplit_0_)       1 MPI processes
>>>>         type: gmres
>>>>       PC Object:      (fieldsplit_0_)       1 MPI processes
>>>>         type: ilu
>>>>           ILU: out-of-place factorization
>>>>           0 levels of fill
>>>>           tolerance for zero pivot 2.22045e-14
>>>>           using diagonal shift on blocks to prevent zero pivot
>>>>           matrix ordering: natural
>>>>           factor fill ratio given 1, needed 1
>>>>             Factored matrix follows:
>>>>               Matrix Object:               1 MPI processes
>>>>                 type: seqaij
>>>>                 rows=8232, cols=8232
>>>>                 package used to perform factorization: petsc
>>>>                 total: nonzeros=576000, allocated nonzeros=576000
>>>>                 total number of mallocs used during MatSetValues calls
>>>> =0
>>>>                   using I-node routines: found 2744 nodes, limit used
>>>> is 5
>>>>         linear system matrix = precond matrix:
>>>>           type: seqaij
>>>>           total number of mallocs used during MatSetValues calls =0
>>>>             using I-node routines: found 2744 nodes, limit used is 5
>>>>     KSP solver for S = A11 - A10 inv(A00) A01
>>>>       KSP Object:      (fieldsplit_1_)       1 MPI processes
>>>>         type: gmres
>>>>       PC Object:      (fieldsplit_1_)       1 MPI processes
>>>>         type: ilu
>>>>           0 levels of fill
>>>>                 type: seqaij
>>>>                 rows=2744, cols=2744
>>>>                 total: nonzeros=64000, allocated nonzeros=64000
>>>> =0
>>>>                   not using I-node routines
>>>>         linear system matrix followed by preconditioner matrix:
>>>>           type: schurcomplement
>>>>             Schur complement A11 - A10 inv(A00) A01
>>>>             A11
>>>>                 type: seqaij
>>>> =0
>>>>             A10
>>>>                 type: seqaij
>>>>                 rows=2744, cols=8232
>>>>                 total: nonzeros=192000, allocated nonzeros=192000
>>>> =0
>>>>             KSP of A00
>>>> MPI processes
>>>>                 type: gmres
>>>> Gram-Schmidt Orthogonalization with no iterative refinement
>>>> divergence=10000
>>>> MPI processes
>>>>                 type: ilu
>>>>                   0 levels of fill
>>>> processes
>>>>                         type: seqaij
>>>> nonzeros=576000
>>>> limit used is 5
>>>>                   type: seqaij
>>>> calls =0
>>>> is 5
>>>>             A01
>>>>                 type: seqaij
>>>>                 rows=8232, cols=2744
>>>> =0
>>>> is 5
>>>>           type: seqaij
>>>>     type: seqaij
>>>>     rows=10976, cols=10976, bs=4
>>>>     total: nonzeros=1024000, allocated nonzeros=1024000
>>>>>    Matt
>>>>>> I am testing a small problem with CONSTANT viscosity for grid size of
>>>>>> 14^3 with the run time option:
>>>>>> -ksp_type gcr -pc_type fieldsplit -pc_fieldsplit_type schur
>>>>>> -pc_fieldsplit_dm_splits 0 -pc_fieldsplit_0_fields 0,1,2
>>>>>> -pc_fieldsplit_1_fields 3 -ksp_converged_reason -ksp_view
>>>>>> -fieldsplit_0_ksp_type gcr -fieldsplit_0_pc_type gamg
>>>>>> -fieldsplit_0_ksp_monitor_true_residual -fieldsplit_0_ksp_converged_reason
>>>>>> -fieldsplit_1_ksp_monitor_true_residual
>>>>>> Here is my relevant code of the solve function:
>>>>>> PetscErrorCode ierr;
>>>>>>     PetscFunctionBeginUser;
>>>>>>     ierr =
>>>>>> DMKSPSetComputeRHS(mDa,computeRHSTaras3D,this);CHKERRQ(ierr);
>>>>>>     ierr =
>>>>>> DMKSPSetComputeOperators(mDa,computeMatrixTaras3D,this);CHKERRQ(ierr);
>>>>>>     ierr = KSPSetDM(mKsp,mDa);CHKERRQ(ierr);              //mDa with
>>>>>> dof = 4, vx,vy,vz and p.
>>>>>>     ierr = KSPSetNullSpace(mKsp,mNullSpace);CHKERRQ(ierr);//nullSpace
>>>>>> for the main system
>>>>>>     ierr = KSPSetFromOptions(mKsp);CHKERRQ(ierr);
>>>>>>     ierr = KSPSetUp(mKsp);CHKERRQ(ierr);                  //register
>>>>>> the fieldsplits obtained from options.
>>>>>>     //Setting up user PC for Schur Complement
>>>>>>     ierr = KSPGetPC(mKsp,&mPc);CHKERRQ(ierr);
>>>>>>     ierr =
>>>>>> PCFieldSplitSchurPrecondition(mPc,PC_FIELDSPLIT_SCHUR_PRE_USER,mPcForSc);CHKERRQ(ierr);
>>>>>>     KSP *subKsp;
>>>>>>     PetscInt subKspPos = 0;
>>>>>>     //Set up nearNullspace for A00 block.
>>>>>>     ierr =
>>>>>> PCFieldSplitGetSubKSP(mPc,&subKspPos,&subKsp);CHKERRQ(ierr);
>>>>>>     MatNullSpace rigidBodyModes;
>>>>>>     Vec coords;
>>>>>>     ierr = DMGetCoordinates(mDa,&coords);CHKERRQ(ierr);
>>>>>>     ierr =
>>>>>> MatNullSpaceCreateRigidBody(coords,&rigidBodyModes);CHKERRQ(ierr);
>>>>>>     Mat matA00;
>>>>>>     ierr = KSPGetOperators(subKsp[0],&matA00,NULL,NULL);CHKERRQ(ierr);
>>>>>>     ierr = MatSetNearNullSpace(matA00,rigidBodyModes);CHKERRQ(ierr);
>>>>>>     ierr = MatNullSpaceDestroy(&rigidBodyModes);CHKERRQ(ierr);
>>>>>>     //Position 1 => Ksp corresponding to Schur complement S on
>>>>>> pressure space
>>>>>>     subKspPos = 1;
>>>>>>     ierr =
>>>>>>     //Set up the null space of constant pressure.
>>>>>>     ierr = KSPSetNullSpace(subKsp[1],mNullSpaceP);CHKERRQ(ierr);
>>>>>>     PetscBool isNull;
>>>>>>     Mat matSc;
>>>>>>     ierr = KSPGetOperators(subKsp[1],&matSc,NULL,NULL);CHKERRQ(ierr);
>>>>>>     ierr = MatNullSpaceTest(mNullSpaceP,matSc,&isNull);
>>>>>>     if(!isNull)
>>>>>>         SETERRQ(PETSC_COMM_WORLD,PETSC_ERR_PLIB,"not a valid pressure
>>>>>> null space \n");
>>>>>>     ierr = KSPGetOperators(mKsp,&mA,NULL,NULL);CHKERRQ(ierr);
>>>>>>     ierr = MatNullSpaceTest(mNullSpace,mA,&isNull);CHKERRQ(ierr);
>>>>>>     if(!isNull)
>>>>>>         SETERRQ(PETSC_COMM_WORLD,PETSC_ERR_PLIB,"not a valid system
>>>>>> null space \n");
>>>>>>     ierr = PetscFree(subKsp);CHKERRQ(ierr);
>>>>>>     ierr = KSPSolve(mKsp,NULL,NULL);CHKERRQ(ierr);
>>>>>>     ierr = KSPGetSolution(mKsp,&mX);CHKERRQ(ierr);
>>>>>>     ierr = KSPGetRhs(mKsp,&mB);CHKERRQ(ierr);
>>>>>>     PetscFunctionReturn(0);
>>>>>> On Wed, Aug 7, 2013 at 2:15 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>>> On Wed, Aug 7, 2013 at 7:07 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>>>>>>> On Tue, Aug 6, 2013 at 11:34 PM, Matthew Knepley <knepley at gmail.com
>>>>>>>> > wrote:
>>>>>>>>> On Tue, Aug 6, 2013 at 10:59 AM, Bishesh Khanal <
>>>>>>>>> bisheshkh at gmail.com> wrote:
>>>>>>>>>> On Tue, Aug 6, 2013 at 4:40 PM, Matthew Knepley <
>>>>>>>>>>> On Tue, Aug 6, 2013 at 8:06 AM, Bishesh Khanal <
>>>>>>>>>>>> On Mon, Aug 5, 2013 at 4:14 PM, Matthew Knepley <
>>>>>>>>>>>>> On Mon, Aug 5, 2013 at 8:48 AM, Bishesh Khanal <
>>>>>>>>>>>>>> On Mon, Aug 5, 2013 at 3:17 PM, Matthew Knepley <
>>>>>>>>>>>>>>> On Mon, Aug 5, 2013 at 7:54 AM, Bishesh Khanal <
>>>>>>>>>>>>>>>> On Wed, Jul 17, 2013 at 9:48 PM, Jed Brown <
>>>>>>>>>>>>>>>> jedbrown at mcs.anl.gov> wrote:
>>>>>>>>>>>>>>>>> Bishesh Khanal <bisheshkh at gmail.com> writes:
>>>>>>>>>>>>>>>>> > Now, I implemented two different approaches, each for
>>>>>>>>>>>>>>>>> both 2D and 3D, in
>>>>>>>>>>>>>>>>> > MATLAB. It works for the smaller sizes but I have
>>>>>>>>>>>>>>>>> problems solving it for
>>>>>>>>>>>>>>>>> > the problem size I need (250^3 grid size).
>>>>>>>>>>>>>>>>> > I use staggered grid with p on cell centers, and
>>>>>>>>>>>>>>>>> components of v on cell
>>>>>>>>>>>>>>>>> > faces. Similar split up of K to cell center and faces to
>>>>>>>>>>>>>>>>> account for the
>>>>>>>>>>>>>>>>> > variable viscosity case)
>>>>>>>>>>>>>>>>> Okay, you're using a staggered-grid finite difference
>>>>>>>>>>>>>>>>> discretization of
>>>>>>>>>>>>>>>>> variable-viscosity Stokes.  This is a common problem and I
>>>>>>>>>>>>>>>>> recommend
>>>>>>>>>>>>>>>>> starting with PCFieldSplit with Schur complement reduction
>>>>>>>>>>>>>>>>> (make that
>>>>>>>>>>>>>>>>> work first, then switch to block preconditioner).  You can
>>>>>>>>>>>>>>>>> use PCLSC or
>>>>>>>>>>>>>>>>> (probably better for you), assemble a preconditioning
>>>>>>>>>>>>>>>>> matrix containing
>>>>>>>>>>>>>>>>> the inverse viscosity in the pressure-pressure block.
>>>>>>>>>>>>>>>>>  This diagonal
>>>>>>>>>>>>>>>>> matrix is a spectrally equivalent (or nearly so, depending
>>>>>>>>>>>>>>>>> on
>>>>>>>>>>>>>>>>> discretization) approximation of the Schur complement.
>>>>>>>>>>>>>>>>>  The velocity
>>>>>>>>>>>>>>>>> block can be solved with algebraic multigrid.  Read the
>>>>>>>>>>>>>>>>> PCFieldSplit
>>>>>>>>>>>>>>>>> docs (follow papers as appropriate) and let us know if you
>>>>>>>>>>>>>>>>> get stuck.
>>>>>>>>>>>>>>>> I was trying to assemble the inverse viscosity diagonal
>>>>>>>>>>>>>>>> matrix to use as the preconditioner for the Schur complement solve step as
>>>>>>>>>>>>>>>> you suggested. I've few questions about the ways to implement this in Petsc:
>>>>>>>>>>>>>>>> A naive approach that I can think of would be to create a
>>>>>>>>>>>>>>>> vector with its components as reciprocal viscosities of the cell centers
>>>>>>>>>>>>>>>> corresponding to the pressure variables, and then create a diagonal matrix
>>>>>>>>>>>>>>>> from this vector. However I'm not sure about:
>>>>>>>>>>>>>>>> How can I make this matrix, (say S_p) compatible to the
>>>>>>>>>>>>>>>> Petsc distribution of the different rows of the main system matrix over
>>>>>>>>>>>>>>>> different processors ? The main matrix was created using the DMDA structure
>>>>>>>>>>>>>>>> with 4 dof as explained before.
>>>>>>>>>>>>>>>> The main matrix correspond to the DMDA with 4 dofs but for
>>>>>>>>>>>>>>>> the S_p matrix would correspond to only pressure space. Should the
>>>>>>>>>>>>>>>> distribution of the rows of S_p among different processor not correspond to
>>>>>>>>>>>>>>>> the distribution of the rhs vector, say h' if it is solving for p with Sp =
>>>>>>>>>>>>>>>> h' where S = A11 inv(A00) A01 ?
>>>>>>>>>>>>>>> PETSc distributed vertices, not dofs, so it never breaks
>>>>>>>>>>>>>>> blocks. The P distribution is the same as the entire problem divided by 4.
>>>>>>>>>>>>>> Thanks Matt. So if I create a new DMDA with same grid size
>>>>>>>>>>>>>> but with dof=1 instead of 4, the vertices for this new DMDA will be
>>>>>>>>>>>>>> identically distributed as for the original DMDA ? Or should I inform PETSc
>>>>>>>>>>>>>> by calling a particular function to make these two DMDA have identical
>>>>>>>>>>>>>> distribution of the vertices ?
>>>>>>>>>>>>> Yes.
>>>>>>>>>>>>>>  Even then I think there might be a problem due to the
>>>>>>>>>>>>>> presence of "fictitious pressure vertices". The system matrix (A) contains
>>>>>>>>>>>>>> an identity corresponding to these fictitious pressure nodes, thus when
>>>>>>>>>>>>>> using a -pc_fieldsplit_detect_saddle_point, will detect a A11 zero block of
>>>>>>>>>>>>>> size that correspond to only non-fictitious P-nodes. So the preconditioner
>>>>>>>>>>>>>> S_p for the Schur complement outer solve with Sp = h' will also need to
>>>>>>>>>>>>>> correspond to only the non-fictitious P-nodes. This means its size does not
>>>>>>>>>>>>>> directly correspond to the DMDA grid defined for the original problem.
>>>>>>>>>>>>>> Could you please suggest an efficient way of assembling this S_p matrix ?
>>>>>>>>>>>>> Don't use detect_saddle, but split it by fields
>>>>>>>>>>>>> -pc_fieldsplit_0_fields 0,1,2 -pc_fieldsplit_1_fields 4
>>>>>>>>>>>> How can I set this split in the code itself without giving it
>>>>>>>>>>>> as a command line option when the system matrix is assembled from the DMDA
>>>>>>>>>>>> for the whole system with 4 dofs. (i.e. *without* using the
>>>>>>>>>>>> DMComposite or *without* using the nested block matrices to
>>>>>>>>>>>> assemble different blocks separately and then combine them together).
>>>>>>>>>>>> I need the split to get access to the fieldsplit_1_ksp in my
>>>>>>>>>>>> code, because not using detect_saddle_point means I cannot use
>>>>>>>>>>>> -fieldsplit_1_ksp_constant_null_space due to the presence of identity for
>>>>>>>>>>>> the fictitious pressure nodes present in the fieldsplit_1_ block. I need to
>>>>>>>>>>>> use PCFieldSplitGetSubKsp() so that I can set proper null-space basis.
>>>>>>>>>>> This is currently a real problem with the DMDA. In the
>>>>>>>>>>> unstructured case, where we always need specialized spaces, you can
>>>>>>>>>>> use something like
>>>>>>>>>>>     PetscObject  pressure;
>>>>>>>>>>>     MatNullSpace nullSpacePres;
>>>>>>>>>>>     ierr = DMGetField(dm, 1, &pressure);CHKERRQ(ierr);
>>>>>>>>>>>     ierr = MatNullSpaceCreate(PetscObjectComm(pressure),
>>>>>>>>>>> PETSC_TRUE, 0, NULL, &nullSpacePres);CHKERRQ(ierr);
>>>>>>>>>>>     ierr = PetscObjectCompose(pressure, "nullspace",
>>>>>>>>>>> (PetscObject) nullSpacePres);CHKERRQ(ierr);
>>>>>>>>>>>     ierr = MatNullSpaceDestroy(&nullSpacePres);CHKERRQ(ierr);
>>>>>>>>>>> and then DMGetSubDM() uses this information to attach the null
>>>>>>>>>>> space to the IS that is created using the information in the PetscSection.
>>>>>>>>>>> If you use a PetscSection to set the data layout over the DMDA,
>>>>>>>>>>> I think this works correctly, but this has not been tested at all and is
>>>>>>>>>>> very
>>>>>>>>>>> new code. Eventually, I think we want all DMs to use this
>>>>>>>>>>> mechanism, but we are still working it out.
>>>>>>>>>> Currently I do not use PetscSection. If this makes a cleaner
>>>>>>>>>> approach, I'd try it too but may a bit later (right now I'd like test my
>>>>>>>>>> model with a quickfix even if it means a little dirty code!)
>>>>>>>>>>> Bottom line: For custom null spaces using the default layout in
>>>>>>>>>>> DMDA, you need to take apart the PCFIELDSPLIT after it has been setup,
>>>>>>>>>>> which is somewhat subtle. You need to call KSPSetUp() and then
>>>>>>>>>>> reach in and get the PC, and the subKSPs. I don't like this at all, but we
>>>>>>>>>>> have not reorganized that code (which could be very simple and
>>>>>>>>>>> inflexible since its very structured).
>>>>>>>>>> So I tried to get this approach working but I could not succeed
>>>>>>>>>> and encountered some errors. Here is a code snippet:
>>>>>>>>>> //mDa is the DMDA that describes the whole grid with all 4 dofs
>>>>>>>>>> (3 velocity components and 1 pressure comp.)
>>>>>>>>>> ierr =
>>>>>>>>>>     ierr =
>>>>>>>>>>     ierr =
>>>>>>>>>> KSPSetNullSpace(mKsp,mNullSpaceSystem);CHKERRQ(ierr);   //I've the
>>>>>>>>>> mNullSpaceSystem based on mDa, that contains a null space basis for the
>>>>>>>>>> complete system.
>>>>>>>>>>     ierr =
>>>>>>>>>> //This I expect would register these options I give:-pc_type fieldsplit
>>>>>>>>>> -pc_fieldsplit_type schur -pc_fieldsplit_0_fields 0,1,2
>>>>>>>>>> //-pc_fieldsplit_1_fields 3
>>>>>>>>>>     ierr = KSPGetPC(mKsp,&mPcOuter);     //Now get the PC that
>>>>>>>>>> was obtained from the options (fieldsplit)
>>>>>>>>>>     ierr =
>>>>>>>>>> PCFieldSplitSchurPrecondition(mPcOuter,PC_FIELDSPLIT_SCHUR_PRE_USER,mPcForSc);CHKERRQ(ierr);
>>>>>>>>>> //I have created the matrix mPcForSc using a DMDA with identical //size to
>>>>>>>>>> mDa but with dof=1 corresponding to the pressure nodes (say mDaPressure).
>>>>>>>>>>   ierr = PCSetUp(mPcOuter);CHKERRQ(ierr);
>>>>>>>>>>     KSP *kspSchur;
>>>>>>>>>>     PetscInt kspSchurPos = 1;
>>>>>>>>>>     ierr =
>>>>>>>>>> PCFieldSplitGetSubKSP(mPcOuter,&kspSchurPos,&kspSchur);CHKERRQ(ierr);
>>>>>>>>>>     ierr =
>>>>>>>>>> KSPSetNullSpace(kspSchur[1],mNullSpacePressure);CHKERRQ(ierr);
>>>>>>>>>> //The null space is the one that correspond to only pressure nodes, created
>>>>>>>>>> using the mDaPressure.
>>>>>>>>>>     ierr = PetscFree(kspSchur);CHKERRQ(ierr);
>>>>>>>>> Sorry, you need to return to the old DMDA behavior, so you want
>>>>>>>> Thanks, with this it seems I can attach the null space properly,
>>>>>>>> but I have a question regarding whether the Schur complement ksp solver is
>>>>>>>> actually using the preconditioner matrix I provide.
>>>>>>>> When using -ksp_view, the outer level pc object of type fieldsplit
>>>>>>>> does report that: "Preconditioner for the Schur complement formed from user
>>>>>>>> provided matrix", but in the KSP solver for Schur complement S, the pc
>>>>>>>> object (fieldsplit_1_) is of type ilu and doesn't say that it is using the
>>>>>>>> matrix I provide. Am I missing something here ?
>>>>>>>> Below are the relevant commented code snippet and the output of the
>>>>>>>> -ksp_view
>>>>>>>> (The options I used: -pc_type fieldsplit -pc_fieldsplit_type schur
>>>>>>>> -pc_fieldsplit_1_fields 3 -ksp_converged_reason -ksp_view )
>>>>>>> If ILU does not error, it means it is using your matrix, because the
>>>>>>> Schur complement matrix cannot be factored, and FS says it is using your
>>>>>>> matrix.
>>>>>>>    Matt
>>>>>>>> Code snippet:
>>>>>>>> ierr = KSPSetNullSpace(mKsp,mNullSpaceSystem);CHKERRQ(ierr);
>>>>>>>> //The nullspace for the whole system
>>>>>>>>     ierr =
>>>>>>>>     ierr = KSPSetUp(mKsp);CHKERRQ(ierr);                   //Set up
>>>>>>>> mKsp with the options provided with fieldsplit and the fields associated
>>>>>>>> with the two splits.
>>>>>>>>     ierr = KSPGetPC(mKsp,&mPcOuter);CHKERRQ(ierr);
>>>>>>>> //Get the fieldsplit pc set up from the options
>>>>>>>>     ierr =
>>>>>>>> //Use mPcForSc as the preconditioner for Schur Complement
>>>>>>>>     KSP *kspSchur;
>>>>>>>>     ierr =
>>>>>>>>     ierr =
>>>>>>>> //Attach the null-space for the Schur complement ksp solver.
>>>>>>>> the output of the -ksp_view
>>>>>>>>   type: gmres
>>>>>>>>   type: fieldsplit
>>>>>>>> factorization FULL
>>>>>>>> provided matrix
>>>>>>>>     Split info:
>>>>>>>>         type: gmres
>>>>>>>> divergence=10000
>>>>>>>>         type: ilu
>>>>>>>>           0 levels of fill
>>>>>>>>                 type: seqaij
>>>>>>>>                 rows=2187, cols=2187
>>>>>>>>                 total: nonzeros=140625, allocated nonzeros=140625
>>>>>>>> calls =0
>>>>>>>>                   using I-node routines: found 729 nodes, limit
>>>>>>>> used is 5
>>>>>>>>           type: seqaij
>>>>>>>>             using I-node routines: found 729 nodes, limit used is 5
>>>>>>>>         type: gmres
>>>>>>>> divergence=10000
>>>>>>>>         type: ilu
>>>>>>>>           0 levels of fill
>>>>>>>>                 type: seqaij
>>>>>>>>                 rows=729, cols=729
>>>>>>>>                 total: nonzeros=15625, allocated nonzeros=15625
>>>>>>>> calls =0
>>>>>>>>           rows=729, cols=729
>>>>>>>>             A11
>>>>>>>>                 type: seqaij
>>>>>>>>                 rows=729, cols=729
>>>>>>>> calls =0
>>>>>>>>             A10
>>>>>>>>                 type: seqaij
>>>>>>>>                 rows=729, cols=2187
>>>>>>>>                 total: nonzeros=46875, allocated nonzeros=46875
>>>>>>>> calls =0
>>>>>>>>             KSP of A00
>>>>>>>>               KSP Object:
>>>>>>>>                 type: gmres
>>>>>>>> divergence=10000
>>>>>>>> 1 MPI processes
>>>>>>>>                 type: ilu
>>>>>>>>                   0 levels of fill
>>>>>>>> pivot
>>>>>>>> processes
>>>>>>>>                         type: seqaij
>>>>>>>> nonzeros=140625
>>>>>>>> limit used is 5
>>>>>>>>                   type: seqaij
>>>>>>>> calls =0
>>>>>>>> used is 5
>>>>>>>>             A01
>>>>>>>>                 type: seqaij
>>>>>>>>                 rows=2187, cols=729
>>>>>>>> calls =0
>>>>>>>> used is 5
>>>>>>>>           type: seqaij
>>>>>>>>           rows=729, cols=729
>>>>>>>>     type: seqaij
>>>>>>>>     rows=2916, cols=2916, bs=4
>>>>>>>>     total: nonzeros=250000, allocated nonzeros=250000
>>>>>>>>> or
>>>>>>>>>   PCFieldSplitSetDMSplits(pc, PETSC_FALSE)
>>>>>>>>>   Thanks,
>>>>>>>>>      Matt
>>>>>>>>>> The errors I get when running with options: -pc_type fieldsplit
>>>>>>>>>> [0]PETSC ERROR: --------------------- Error Message
>>>>>>>>>> [0]PETSC ERROR: No support for this operation for this object
>>>>>>>>>> type!
>>>>>>>>>> [0]PETSC ERROR: Support only implemented for 2d!
>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>> [0]PETSC ERROR: Petsc Release Version 3.4.2, Jul, 02, 2013
>>>>>>>>>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>>>>>>>>>> [0]PETSC ERROR: See docs/faq.html for hints about trouble
>>>>>>>>>> shooting.
>>>>>>>>>> [0]PETSC ERROR: See docs/index.html for manual pages.
>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>> [0]PETSC ERROR: src/AdLemMain on a arch-linux2-cxx-debug named
>>>>>>>>>> edwards by bkhanal Tue Aug  6 17:35:30 2013
>>>>>>>>>> [0]PETSC ERROR: Libraries linked from
>>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/arch-linux2-cxx-debug/lib
>>>>>>>>>> [0]PETSC ERROR: Configure run at Fri Jul 19 14:25:01 2013
>>>>>>>>>> [0]PETSC ERROR: Configure options --with-cc=gcc --with-fc=g77
>>>>>>>>>> --with-cxx=g++ --download-f-blas-lapack=1 --download-mpich=1
>>>>>>>>>> -with-clanguage=cxx --download-hypre=1
>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>> [0]PETSC ERROR: DMCreateSubDM_DA() line 188 in
>>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/dm/impls/da/dacreate.c
>>>>>>>>>> [0]PETSC ERROR: DMCreateSubDM() line 1267 in
>>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/dm/interface/dm.c
>>>>>>>>>> [0]PETSC ERROR: PCFieldSplitSetDefaults() line 337 in
>>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/ksp/pc/impls/fieldsplit/fieldsplit.c
>>>>>>>>>> [0]PETSC ERROR: PCSetUp_FieldSplit() line 458 in
>>>>>>>>>> [0]PETSC ERROR: PCSetUp() line 890 in
>>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/ksp/pc/interface/precon.c
>>>>>>>>>> [0]PETSC ERROR: KSPSetUp() line 278 in
>>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/ksp/ksp/interface/itfunc.c
>>>>>>>>>> [0]PETSC ERROR: solveModel() line 181 in
>>>>>>>>>> "unknowndirectory/"/user/bkhanal/home/works/AdLemModel/src/PetscAdLemTaras3D.cxx
>>>>>>>>>> WARNING! There are options you set that were not used!
>>>>>>>>>> WARNING! could be spelling mistake, etc!
>>>>>>>>>> Option left: name:-pc_fieldsplit_1_fields value: 3
>>>>>>>>>>>    Matt
>>>>>>>>>>>>>    Matt
>>>>>>>>>>>>>>>    Matt
>>>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>>>> their experiments lead.
>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>>> experiments lead.
>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>> experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130823/c9f08dd1/attachment-0001.html>
