[petsc-users] discontinuous viscosity stokes equation 3D staggered grid
Fri Aug 23 07:53:20 CDT 2013
On Fri, Aug 23, 2013 at 7:46 AM, Bishesh Khanal <bisheshkh at gmail.com> wrote:
> On Fri, Aug 23, 2013 at 2:33 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Fri, Aug 23, 2013 at 7:25 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>> On Fri, Aug 23, 2013 at 2:09 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>> On Fri, Aug 23, 2013 at 4:31 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>>>> Thanks Matt and Mark for comments in using near null space [question I
>>>>> asked in the thread with subject: *problem (Segmentation voilation)
>>>>> using -pc_type hypre -pc_hypre_type -pilut with multiple nodes in a cluster
>>>>> So I understood that I have to set a nearNullSpace to A00 block where
>>>>> the null space correspond to the rigid body motion. I tried it but still
>>>>> the gamg just keeps on iterating and convergence is very very slow. I am
>>>>> not sure what the problem is, right now gamg does not even work for the
>>>>> constant viscosity case.
>>>>> I have set up the following in my code:
>>>>> 1. null space for the whole system A 2. null space for the Schur
>>>>> complement S 3. Near null space for A00 4. a user preconditioner matrix of
>>>>> inverse viscosity in the diagonal for S.
>>>> If you want to debug solvers, you HAVE to send -ksp_view.
>>> When I use gamg, the -fieldsplit_0_ksp was iterating on and on so didn't
>>> get to the end to get -ksp_view results.
>>> Instead here I have put the -ksp_view output when running the program
>>> with following options: (In this case I get the results)
>>> -pc_type fieldsplit -pc_fieldsplit_type schur -pc_fieldsplit_dm_splits 0
>>> -pc_fieldsplit_0_fields 0,1,2 -pc_fieldsplit_1_fields 3
>>> -ksp_converged_reason -ksp_view
>> Okay, that looks fine. Does
>>   -fieldsplit_0_pc_type lu
>>   - fieldsplit_1_ksp_rtol 1.0e-10
>> converge in one Iterate?
>> What matrix did you attach as the preconditioner matrix for fieldsplit_1_?
> I used a diagonal matrix with reciprocal of viscosity values of the
> corresponding cell centers as the preconditioner.
> with the options  -fieldsplit_0_pc_type lu  - fieldsplit_1_ksp_rtol
> 1.0e-10 -fieldsplit_1_ksp_converged_reason -ksp_converged_reason
> I get the following output which means the outer ksp did converge in one
> iterate I guess.
>   Linear solve converged due to CONVERGED_RTOL iterations 18
Okay, so A_00 is nonsingular, and the system seems to solve alright. What
do you get for
  -fieldsplit_0_ksp_max_it 30
  -fieldsplit_0_pc_type gamg
  -fieldsplit_0_ksp_converged_reason
This is the kind of investigation you msut be comfortable with if you want
to experiment with these solvers.
    Matt
>>   Thanks,
>>      Matt
>>> Linear solve converged due to CONVERGED_RTOL iterations 2
>>> KSP Object: 1 MPI processes
>>>   type: gmres
>>>     GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
>>> Orthogonalization with no iterative refinement
>>>     GMRES: happy breakdown tolerance 1e-30
>>>   maximum iterations=10000, initial guess is zero
>>>   tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>>>   left preconditioning
>>>   has attached null space
>>>   using PRECONDITIONED norm type for convergence test
>>> PC Object: 1 MPI processes
>>>   type: fieldsplit
>>>     FieldSplit with Schur preconditioner, blocksize = 4, factorization
>>> FULL
>>>     Preconditioner for the Schur complement formed from user provided
>>> matrix
>>>     Split info:
>>>     Split number 0 Fields  0, 1, 2
>>>     Split number 1 Fields  3
>>>     KSP solver for A00 block
>>>       KSP Object:      (fieldsplit_0_)       1 MPI processes
>>>         type: gmres
>>>       PC Object:      (fieldsplit_0_)       1 MPI processes
>>>         type: ilu
>>>           ILU: out-of-place factorization
>>>           0 levels of fill
>>>           tolerance for zero pivot 2.22045e-14
>>>           using diagonal shift on blocks to prevent zero pivot
>>>           matrix ordering: natural
>>>           factor fill ratio given 1, needed 1
>>>             Factored matrix follows:
>>>               Matrix Object:               1 MPI processes
>>>                 type: seqaij
>>>                 rows=8232, cols=8232
>>>                 package used to perform factorization: petsc
>>>                 total: nonzeros=576000, allocated nonzeros=576000
>>>                 total number of mallocs used during MatSetValues calls =0
>>>                   using I-node routines: found 2744 nodes, limit used is
>>> 5
>>>         linear system matrix = precond matrix:
>>>           type: seqaij
>>>             using I-node routines: found 2744 nodes, limit used is 5
>>>     KSP solver for S = A11 - A10 inv(A00) A01
>>>       KSP Object:      (fieldsplit_1_)       1 MPI processes
>>>         type: gmres
>>>       PC Object:      (fieldsplit_1_)       1 MPI processes
>>>         type: ilu
>>>           0 levels of fill
>>>                 type: seqaij
>>>                 rows=2744, cols=2744
>>>                 total: nonzeros=64000, allocated nonzeros=64000
>>>                   not using I-node routines
>>>         linear system matrix followed by preconditioner matrix:
>>>           type: schurcomplement
>>>             Schur complement A11 - A10 inv(A00) A01
>>>             A11
>>>                 type: seqaij
>>>             A10
>>>                 type: seqaij
>>>                 rows=2744, cols=8232
>>>                 total: nonzeros=192000, allocated nonzeros=192000
>>>             KSP of A00
>>> MPI processes
>>>                 type: gmres
>>> Gram-Schmidt Orthogonalization with no iterative refinement
>>> divergence=10000
>>> MPI processes
>>>                 type: ilu
>>>                   0 levels of fill
>>> processes
>>>                         type: seqaij
>>> calls =0
>>> used is 5
>>>                   type: seqaij
>>> =0
>>> is 5
>>>             A01
>>>                 type: seqaij
>>>                 rows=8232, cols=2744
>>> 5
>>>           type: seqaij
>>>     type: seqaij
>>>     rows=10976, cols=10976, bs=4
>>>     total: nonzeros=1024000, allocated nonzeros=1024000
>>>>    Matt
>>>>> I am testing a small problem with CONSTANT viscosity for grid size of
>>>>> 14^3 with the run time option:
>>>>> -ksp_type gcr -pc_type fieldsplit -pc_fieldsplit_type schur
>>>>> -pc_fieldsplit_dm_splits 0 -pc_fieldsplit_0_fields 0,1,2
>>>>> -pc_fieldsplit_1_fields 3 -ksp_converged_reason -ksp_view
>>>>> -fieldsplit_0_ksp_type gcr -fieldsplit_0_pc_type gamg
>>>>> -fieldsplit_0_ksp_monitor_true_residual -fieldsplit_0_ksp_converged_reason
>>>>> -fieldsplit_1_ksp_monitor_true_residual
>>>>> Here is my relevant code of the solve function:
>>>>> PetscErrorCode ierr;
>>>>>     PetscFunctionBeginUser;
>>>>>     ierr =
>>>>> DMKSPSetComputeRHS(mDa,computeRHSTaras3D,this);CHKERRQ(ierr);
>>>>>     ierr =
>>>>> DMKSPSetComputeOperators(mDa,computeMatrixTaras3D,this);CHKERRQ(ierr);
>>>>>     ierr = KSPSetDM(mKsp,mDa);CHKERRQ(ierr);              //mDa with
>>>>> dof = 4, vx,vy,vz and p.
>>>>>     ierr = KSPSetNullSpace(mKsp,mNullSpace);CHKERRQ(ierr);//nullSpace
>>>>> for the main system
>>>>>     ierr = KSPSetFromOptions(mKsp);CHKERRQ(ierr);
>>>>>     ierr = KSPSetUp(mKsp);CHKERRQ(ierr);                  //register
>>>>> the fieldsplits obtained from options.
>>>>>     //Setting up user PC for Schur Complement
>>>>>     ierr = KSPGetPC(mKsp,&mPc);CHKERRQ(ierr);
>>>>>     ierr =
>>>>> PCFieldSplitSchurPrecondition(mPc,PC_FIELDSPLIT_SCHUR_PRE_USER,mPcForSc);CHKERRQ(ierr);
>>>>>     KSP *subKsp;
>>>>>     PetscInt subKspPos = 0;
>>>>>     //Set up nearNullspace for A00 block.
>>>>>     ierr = PCFieldSplitGetSubKSP(mPc,&subKspPos,&subKsp);CHKERRQ(ierr);
>>>>>     MatNullSpace rigidBodyModes;
>>>>>     Vec coords;
>>>>>     ierr = DMGetCoordinates(mDa,&coords);CHKERRQ(ierr);
>>>>>     ierr =
>>>>> MatNullSpaceCreateRigidBody(coords,&rigidBodyModes);CHKERRQ(ierr);
>>>>>     Mat matA00;
>>>>>     ierr = KSPGetOperators(subKsp[0],&matA00,NULL,NULL);CHKERRQ(ierr);
>>>>>     ierr = MatSetNearNullSpace(matA00,rigidBodyModes);CHKERRQ(ierr);
>>>>>     ierr = MatNullSpaceDestroy(&rigidBodyModes);CHKERRQ(ierr);
>>>>>     //Position 1 => Ksp corresponding to Schur complement S on
>>>>> pressure space
>>>>>     subKspPos = 1;
>>>>>     //Set up the null space of constant pressure.
>>>>>     ierr = KSPSetNullSpace(subKsp[1],mNullSpaceP);CHKERRQ(ierr);
>>>>>     PetscBool isNull;
>>>>>     Mat matSc;
>>>>>     ierr = KSPGetOperators(subKsp[1],&matSc,NULL,NULL);CHKERRQ(ierr);
>>>>>     ierr = MatNullSpaceTest(mNullSpaceP,matSc,&isNull);
>>>>>     if(!isNull)
>>>>>         SETERRQ(PETSC_COMM_WORLD,PETSC_ERR_PLIB,"not a valid pressure
>>>>> null space \n");
>>>>>     ierr = KSPGetOperators(mKsp,&mA,NULL,NULL);CHKERRQ(ierr);
>>>>>     ierr = MatNullSpaceTest(mNullSpace,mA,&isNull);CHKERRQ(ierr);
>>>>>     if(!isNull)
>>>>>         SETERRQ(PETSC_COMM_WORLD,PETSC_ERR_PLIB,"not a valid system
>>>>> null space \n");
>>>>>     ierr = PetscFree(subKsp);CHKERRQ(ierr);
>>>>>     ierr = KSPSolve(mKsp,NULL,NULL);CHKERRQ(ierr);
>>>>>     ierr = KSPGetSolution(mKsp,&mX);CHKERRQ(ierr);
>>>>>     ierr = KSPGetRhs(mKsp,&mB);CHKERRQ(ierr);
>>>>>     PetscFunctionReturn(0);
>>>>> On Wed, Aug 7, 2013 at 2:15 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>> On Wed, Aug 7, 2013 at 7:07 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>>>>>> On Tue, Aug 6, 2013 at 11:34 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>>>> On Tue, Aug 6, 2013 at 10:59 AM, Bishesh Khanal <
>>>>>>>>> On Tue, Aug 6, 2013 at 4:40 PM, Matthew Knepley <knepley at gmail.com
>>>>>>>>> > wrote:
>>>>>>>>>> On Tue, Aug 6, 2013 at 8:06 AM, Bishesh Khanal <
>>>>>>>>>>> On Mon, Aug 5, 2013 at 4:14 PM, Matthew Knepley <
>>>>>>>>>>> knepley at gmail.com> wrote:
>>>>>>>>>>>> On Mon, Aug 5, 2013 at 8:48 AM, Bishesh Khanal <
>>>>>>>>>>>>> On Mon, Aug 5, 2013 at 3:17 PM, Matthew Knepley <
>>>>>>>>>>>>>> On Mon, Aug 5, 2013 at 7:54 AM, Bishesh Khanal <
>>>>>>>>>>>>>>> On Wed, Jul 17, 2013 at 9:48 PM, Jed Brown <
>>>>>>>>>>>>>>> jedbrown at mcs.anl.gov> wrote:
>>>>>>>>>>>>>>>> Bishesh Khanal <bisheshkh at gmail.com> writes:
>>>>>>>>>>>>>>>> > Now, I implemented two different approaches, each for
>>>>>>>>>>>>>>>> both 2D and 3D, in
>>>>>>>>>>>>>>>> > MATLAB. It works for the smaller sizes but I have
>>>>>>>>>>>>>>>> problems solving it for
>>>>>>>>>>>>>>>> > the problem size I need (250^3 grid size).
>>>>>>>>>>>>>>>> > I use staggered grid with p on cell centers, and
>>>>>>>>>>>>>>>> components of v on cell
>>>>>>>>>>>>>>>> > faces. Similar split up of K to cell center and faces to
>>>>>>>>>>>>>>>> account for the
>>>>>>>>>>>>>>>> > variable viscosity case)
>>>>>>>>>>>>>>>> Okay, you're using a staggered-grid finite difference
>>>>>>>>>>>>>>>> discretization of
>>>>>>>>>>>>>>>> variable-viscosity Stokes.  This is a common problem and I
>>>>>>>>>>>>>>>> recommend
>>>>>>>>>>>>>>>> starting with PCFieldSplit with Schur complement reduction
>>>>>>>>>>>>>>>> (make that
>>>>>>>>>>>>>>>> work first, then switch to block preconditioner).  You can
>>>>>>>>>>>>>>>> use PCLSC or
>>>>>>>>>>>>>>>> (probably better for you), assemble a preconditioning
>>>>>>>>>>>>>>>> matrix containing
>>>>>>>>>>>>>>>> the inverse viscosity in the pressure-pressure block.  This
>>>>>>>>>>>>>>>> diagonal
>>>>>>>>>>>>>>>> matrix is a spectrally equivalent (or nearly so, depending
>>>>>>>>>>>>>>>> on
>>>>>>>>>>>>>>>> discretization) approximation of the Schur complement.  The
>>>>>>>>>>>>>>>> velocity
>>>>>>>>>>>>>>>> block can be solved with algebraic multigrid.  Read the
>>>>>>>>>>>>>>>> PCFieldSplit
>>>>>>>>>>>>>>>> docs (follow papers as appropriate) and let us know if you
>>>>>>>>>>>>>>>> get stuck.
>>>>>>>>>>>>>>> I was trying to assemble the inverse viscosity diagonal
>>>>>>>>>>>>>>> matrix to use as the preconditioner for the Schur complement solve step as
>>>>>>>>>>>>>>> you suggested. I've few questions about the ways to implement this in Petsc:
>>>>>>>>>>>>>>> A naive approach that I can think of would be to create a
>>>>>>>>>>>>>>> vector with its components as reciprocal viscosities of the cell centers
>>>>>>>>>>>>>>> corresponding to the pressure variables, and then create a diagonal matrix
>>>>>>>>>>>>>>> from this vector. However I'm not sure about:
>>>>>>>>>>>>>>> How can I make this matrix, (say S_p) compatible to the
>>>>>>>>>>>>>>> Petsc distribution of the different rows of the main system matrix over
>>>>>>>>>>>>>>> different processors ? The main matrix was created using the DMDA structure
>>>>>>>>>>>>>>> with 4 dof as explained before.
>>>>>>>>>>>>>>> The main matrix correspond to the DMDA with 4 dofs but for
>>>>>>>>>>>>>>> the S_p matrix would correspond to only pressure space. Should the
>>>>>>>>>>>>>>> distribution of the rows of S_p among different processor not correspond to
>>>>>>>>>>>>>>> the distribution of the rhs vector, say h' if it is solving for p with Sp =
>>>>>>>>>>>>>>> h' where S = A11 inv(A00) A01 ?
>>>>>>>>>>>>>> PETSc distributed vertices, not dofs, so it never breaks
>>>>>>>>>>>>>> blocks. The P distribution is the same as the entire problem divided by 4.
>>>>>>>>>>>>> Thanks Matt. So if I create a new DMDA with same grid size but
>>>>>>>>>>>>> with dof=1 instead of 4, the vertices for this new DMDA will be identically
>>>>>>>>>>>>> distributed as for the original DMDA ? Or should I inform PETSc by calling
>>>>>>>>>>>>> a particular function to make these two DMDA have identical distribution of
>>>>>>>>>>>>> the vertices ?
>>>>>>>>>>>> Yes.
>>>>>>>>>>>>>  Even then I think there might be a problem due to the
>>>>>>>>>>>>> presence of "fictitious pressure vertices". The system matrix (A) contains
>>>>>>>>>>>>> an identity corresponding to these fictitious pressure nodes, thus when
>>>>>>>>>>>>> using a -pc_fieldsplit_detect_saddle_point, will detect a A11 zero block of
>>>>>>>>>>>>> size that correspond to only non-fictitious P-nodes. So the preconditioner
>>>>>>>>>>>>> S_p for the Schur complement outer solve with Sp = h' will also need to
>>>>>>>>>>>>> correspond to only the non-fictitious P-nodes. This means its size does not
>>>>>>>>>>>>> directly correspond to the DMDA grid defined for the original problem.
>>>>>>>>>>>>> Could you please suggest an efficient way of assembling this S_p matrix ?
>>>>>>>>>>>> Don't use detect_saddle, but split it by fields
>>>>>>>>>>>> -pc_fieldsplit_0_fields 0,1,2 -pc_fieldsplit_1_fields 4
>>>>>>>>>>> How can I set this split in the code itself without giving it as
>>>>>>>>>>> a command line option when the system matrix is assembled from the DMDA for
>>>>>>>>>>> the whole system with 4 dofs. (i.e. *without* using the
>>>>>>>>>>> DMComposite or *without* using the nested block matrices to
>>>>>>>>>>> assemble different blocks separately and then combine them together).
>>>>>>>>>>> I need the split to get access to the fieldsplit_1_ksp in my
>>>>>>>>>>> code, because not using detect_saddle_point means I cannot use
>>>>>>>>>>> -fieldsplit_1_ksp_constant_null_space due to the presence of identity for
>>>>>>>>>>> the fictitious pressure nodes present in the fieldsplit_1_ block. I need to
>>>>>>>>>>> use PCFieldSplitGetSubKsp() so that I can set proper null-space basis.
>>>>>>>>>> This is currently a real problem with the DMDA. In the
>>>>>>>>>> unstructured case, where we always need specialized spaces, you can
>>>>>>>>>> use something like
>>>>>>>>>>     PetscObject  pressure;
>>>>>>>>>>     MatNullSpace nullSpacePres;
>>>>>>>>>>     ierr = DMGetField(dm, 1, &pressure);CHKERRQ(ierr);
>>>>>>>>>>     ierr = MatNullSpaceCreate(PetscObjectComm(pressure),
>>>>>>>>>> PETSC_TRUE, 0, NULL, &nullSpacePres);CHKERRQ(ierr);
>>>>>>>>>>     ierr = PetscObjectCompose(pressure, "nullspace",
>>>>>>>>>> (PetscObject) nullSpacePres);CHKERRQ(ierr);
>>>>>>>>>>     ierr = MatNullSpaceDestroy(&nullSpacePres);CHKERRQ(ierr);
>>>>>>>>>> and then DMGetSubDM() uses this information to attach the null
>>>>>>>>>> space to the IS that is created using the information in the PetscSection.
>>>>>>>>>> If you use a PetscSection to set the data layout over the DMDA, I
>>>>>>>>>> think this works correctly, but this has not been tested at all and is very
>>>>>>>>>> new code. Eventually, I think we want all DMs to use this
>>>>>>>>>> mechanism, but we are still working it out.
>>>>>>>>> Currently I do not use PetscSection. If this makes a cleaner
>>>>>>>>> approach, I'd try it too but may a bit later (right now I'd like test my
>>>>>>>>> model with a quickfix even if it means a little dirty code!)
>>>>>>>>>> Bottom line: For custom null spaces using the default layout in
>>>>>>>>>> DMDA, you need to take apart the PCFIELDSPLIT after it has been setup,
>>>>>>>>>> which is somewhat subtle. You need to call KSPSetUp() and then
>>>>>>>>>> reach in and get the PC, and the subKSPs. I don't like this at all, but we
>>>>>>>>>> have not reorganized that code (which could be very simple and
>>>>>>>>>> inflexible since its very structured).
>>>>>>>>> So I tried to get this approach working but I could not succeed
>>>>>>>>> and encountered some errors. Here is a code snippet:
>>>>>>>>> //mDa is the DMDA that describes the whole grid with all 4 dofs (3
>>>>>>>>> velocity components and 1 pressure comp.)
>>>>>>>>> ierr =
>>>>>>>>>     ierr =
>>>>>>>>>     ierr = KSPSetNullSpace(mKsp,mNullSpaceSystem);CHKERRQ(ierr);
>>>>>>>>> //I've the mNullSpaceSystem based on mDa, that contains a null space basis
>>>>>>>>> for the complete system.
>>>>>>>>>     ierr =
>>>>>>>>> //This I expect would register these options I give:-pc_type fieldsplit
>>>>>>>>> -pc_fieldsplit_type schur -pc_fieldsplit_0_fields 0,1,2
>>>>>>>>> //-pc_fieldsplit_1_fields 3
>>>>>>>>>     ierr = KSPGetPC(mKsp,&mPcOuter);     //Now get the PC that was
>>>>>>>>> obtained from the options (fieldsplit)
>>>>>>>>>     ierr =
>>>>>>>>> PCFieldSplitSchurPrecondition(mPcOuter,PC_FIELDSPLIT_SCHUR_PRE_USER,mPcForSc);CHKERRQ(ierr);
>>>>>>>>> //I have created the matrix mPcForSc using a DMDA with identical //size to
>>>>>>>>> mDa but with dof=1 corresponding to the pressure nodes (say mDaPressure).
>>>>>>>>>   ierr = PCSetUp(mPcOuter);CHKERRQ(ierr);
>>>>>>>>>     KSP *kspSchur;
>>>>>>>>>     PetscInt kspSchurPos = 1;
>>>>>>>>>     ierr =
>>>>>>>>> PCFieldSplitGetSubKSP(mPcOuter,&kspSchurPos,&kspSchur);CHKERRQ(ierr);
>>>>>>>>>     ierr =
>>>>>>>>> KSPSetNullSpace(kspSchur[1],mNullSpacePressure);CHKERRQ(ierr);
>>>>>>>>> //The null space is the one that correspond to only pressure nodes, created
>>>>>>>>> using the mDaPressure.
>>>>>>>>>     ierr = PetscFree(kspSchur);CHKERRQ(ierr);
>>>>>>>> Sorry, you need to return to the old DMDA behavior, so you want
>>>>>>> Thanks, with this it seems I can attach the null space properly, but
>>>>>>> I have a question regarding whether the Schur complement ksp solver is
>>>>>>> actually using the preconditioner matrix I provide.
>>>>>>> When using -ksp_view, the outer level pc object of type fieldsplit
>>>>>>> does report that: "Preconditioner for the Schur complement formed from user
>>>>>>> provided matrix", but in the KSP solver for Schur complement S, the pc
>>>>>>> object (fieldsplit_1_) is of type ilu and doesn't say that it is using the
>>>>>>> matrix I provide. Am I missing something here ?
>>>>>>> Below are the relevant commented code snippet and the output of the
>>>>>>> -ksp_view
>>>>>>> (The options I used: -pc_type fieldsplit -pc_fieldsplit_type schur
>>>>>>> -pc_fieldsplit_1_fields 3 -ksp_converged_reason -ksp_view )
>>>>>> If ILU does not error, it means it is using your matrix, because the
>>>>>> Schur complement matrix cannot be factored, and FS says it is using your
>>>>>> matrix.
>>>>>>    Matt
>>>>>>> Code snippet:
>>>>>>> ierr = KSPSetNullSpace(mKsp,mNullSpaceSystem);CHKERRQ(ierr);   //The
>>>>>>> nullspace for the whole system
>>>>>>>     ierr = KSPSetUp(mKsp);CHKERRQ(ierr);                   //Set up
>>>>>>> mKsp with the options provided with fieldsplit and the fields associated
>>>>>>> with the two splits.
>>>>>>>     ierr = KSPGetPC(mKsp,&mPcOuter);CHKERRQ(ierr);
>>>>>>> //Get the fieldsplit pc set up from the options
>>>>>>>     ierr =
>>>>>>> //Use mPcForSc as the preconditioner for Schur Complement
>>>>>>>     KSP *kspSchur;
>>>>>>>     ierr =
>>>>>>>     ierr =
>>>>>>> //Attach the null-space for the Schur complement ksp solver.
>>>>>>> the output of the -ksp_view
>>>>>>>   type: gmres
>>>>>>>   type: fieldsplit
>>>>>>> factorization FULL
>>>>>>> provided matrix
>>>>>>>     Split info:
>>>>>>>         type: gmres
>>>>>>>         type: ilu
>>>>>>>           0 levels of fill
>>>>>>>                 type: seqaij
>>>>>>>                 rows=2187, cols=2187
>>>>>>>                 total: nonzeros=140625, allocated nonzeros=140625
>>>>>>> calls =0
>>>>>>>                   using I-node routines: found 729 nodes, limit used
>>>>>>> is 5
>>>>>>>           type: seqaij
>>>>>>>             using I-node routines: found 729 nodes, limit used is 5
>>>>>>>         type: gmres
>>>>>>>         type: ilu
>>>>>>>           0 levels of fill
>>>>>>>                 type: seqaij
>>>>>>>                 rows=729, cols=729
>>>>>>>                 total: nonzeros=15625, allocated nonzeros=15625
>>>>>>> calls =0
>>>>>>>           rows=729, cols=729
>>>>>>>             A11
>>>>>>>                 type: seqaij
>>>>>>>                 rows=729, cols=729
>>>>>>> calls =0
>>>>>>>             A10
>>>>>>>                 type: seqaij
>>>>>>>                 rows=729, cols=2187
>>>>>>>                 total: nonzeros=46875, allocated nonzeros=46875
>>>>>>> calls =0
>>>>>>>             KSP of A00
>>>>>>> 1 MPI processes
>>>>>>>                 type: gmres
>>>>>>> divergence=10000
>>>>>>> 1 MPI processes
>>>>>>>                 type: ilu
>>>>>>>                   0 levels of fill
>>>>>>> pivot
>>>>>>> processes
>>>>>>>                         type: seqaij
>>>>>>> nonzeros=140625
>>>>>>> limit used is 5
>>>>>>>                   type: seqaij
>>>>>>> calls =0
>>>>>>> used is 5
>>>>>>>             A01
>>>>>>>                 type: seqaij
>>>>>>>                 rows=2187, cols=729
>>>>>>> calls =0
>>>>>>> is 5
>>>>>>>           type: seqaij
>>>>>>>           rows=729, cols=729
>>>>>>>     type: seqaij
>>>>>>>     rows=2916, cols=2916, bs=4
>>>>>>>     total: nonzeros=250000, allocated nonzeros=250000
>>>>>>>> or
>>>>>>>>   PCFieldSplitSetDMSplits(pc, PETSC_FALSE)
>>>>>>>>   Thanks,
>>>>>>>>      Matt
>>>>>>>>> The errors I get when running with options: -pc_type fieldsplit
>>>>>>>>> [0]PETSC ERROR: --------------------- Error Message
>>>>>>>>> [0]PETSC ERROR: No support for this operation for this object type!
>>>>>>>>> [0]PETSC ERROR: Support only implemented for 2d!
>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>> [0]PETSC ERROR: Petsc Release Version 3.4.2, Jul, 02, 2013
>>>>>>>>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>>>>>>>>> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>>>>>>>> [0]PETSC ERROR: See docs/index.html for manual pages.
>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>> [0]PETSC ERROR: src/AdLemMain on a arch-linux2-cxx-debug named
>>>>>>>>> edwards by bkhanal Tue Aug  6 17:35:30 2013
>>>>>>>>> [0]PETSC ERROR: Libraries linked from
>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/arch-linux2-cxx-debug/lib
>>>>>>>>> [0]PETSC ERROR: Configure run at Fri Jul 19 14:25:01 2013
>>>>>>>>> [0]PETSC ERROR: Configure options --with-cc=gcc --with-fc=g77
>>>>>>>>> --with-cxx=g++ --download-f-blas-lapack=1 --download-mpich=1
>>>>>>>>> -with-clanguage=cxx --download-hypre=1
>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>> [0]PETSC ERROR: DMCreateSubDM_DA() line 188 in
>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/dm/impls/da/dacreate.c
>>>>>>>>> [0]PETSC ERROR: DMCreateSubDM() line 1267 in
>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/dm/interface/dm.c
>>>>>>>>> [0]PETSC ERROR: PCFieldSplitSetDefaults() line 337 in
>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/ksp/pc/impls/fieldsplit/fieldsplit.c
>>>>>>>>> [0]PETSC ERROR: PCSetUp_FieldSplit() line 458 in
>>>>>>>>> [0]PETSC ERROR: PCSetUp() line 890 in
>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/ksp/pc/interface/precon.c
>>>>>>>>> [0]PETSC ERROR: KSPSetUp() line 278 in
>>>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/ksp/ksp/interface/itfunc.c
>>>>>>>>> [0]PETSC ERROR: solveModel() line 181 in
>>>>>>>>> "unknowndirectory/"/user/bkhanal/home/works/AdLemModel/src/PetscAdLemTaras3D.cxx
>>>>>>>>> WARNING! There are options you set that were not used!
>>>>>>>>> WARNING! could be spelling mistake, etc!
>>>>>>>>> Option left: name:-pc_fieldsplit_1_fields value: 3
>>>>>>>>>>    Matt
>>>>>>>>>>>>    Matt
>>>>>>>>>>>>>>    Matt
>>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>>> their experiments lead.
>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130823/7d8c0d51/attachment-0001.html>
