[petsc-users] discontinuous viscosity stokes equation 3D staggered grid
Bishesh Khanal bisheshkh at gmail.com
Fri Aug 23 07:25:19 CDT 2013
On Fri, Aug 23, 2013 at 2:09 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Aug 23, 2013 at 4:31 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>> Thanks Matt and Mark for comments in using near null space [question I
>> asked in the thread with subject: *problem (Segmentation voilation)
>> using -pc_type hypre -pc_hypre_type -pilut with multiple nodes in a cluster
>> So I understood that I have to set a nearNullSpace to A00 block where the
>> null space correspond to the rigid body motion. I tried it but still the
>> gamg just keeps on iterating and convergence is very very slow. I am not
>> sure what the problem is, right now gamg does not even work for the
>> constant viscosity case.
>> I have set up the following in my code:
>> 1. null space for the whole system A 2. null space for the Schur
>> complement S 3. Near null space for A00 4. a user preconditioner matrix of
>> inverse viscosity in the diagonal for S.
> If you want to debug solvers, you HAVE to send -ksp_view.
When I use gamg, the -fieldsplit_0_ksp was iterating on and on so didn't
get to the end to get -ksp_view results.
Instead here I have put the -ksp_view output when running the program with
following options: (In this case I get the results)
-pc_type fieldsplit -pc_fieldsplit_type schur -pc_fieldsplit_dm_splits 0
-pc_fieldsplit_0_fields 0,1,2 -pc_fieldsplit_1_fields 3
-ksp_converged_reason -ksp_view
Linear solve converged due to CONVERGED_RTOL iterations 2
KSP Object: 1 MPI processes
  type: gmres
    GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
    GMRES: happy breakdown tolerance 1e-30
  maximum iterations=10000, initial guess is zero
  tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
  left preconditioning
  has attached null space
  using PRECONDITIONED norm type for convergence test
PC Object: 1 MPI processes
  type: fieldsplit
    FieldSplit with Schur preconditioner, blocksize = 4, factorization FULL
    Preconditioner for the Schur complement formed from user provided matrix
    Split info:
    Split number 0 Fields  0, 1, 2
    Split number 1 Fields  3
    KSP solver for A00 block
      KSP Object:      (fieldsplit_0_)       1 MPI processes
        type: gmres
      PC Object:      (fieldsplit_0_)       1 MPI processes
        type: ilu
          ILU: out-of-place factorization
          0 levels of fill
          tolerance for zero pivot 2.22045e-14
          using diagonal shift on blocks to prevent zero pivot
          matrix ordering: natural
          factor fill ratio given 1, needed 1
            Factored matrix follows:
              Matrix Object:               1 MPI processes
                type: seqaij
                rows=8232, cols=8232
                package used to perform factorization: petsc
                total: nonzeros=576000, allocated nonzeros=576000
                total number of mallocs used during MatSetValues calls =0
                  using I-node routines: found 2744 nodes, limit used is 5
        linear system matrix = precond matrix:
          type: seqaij
    KSP solver for S = A11 - A10 inv(A00) A01
      KSP Object:      (fieldsplit_1_)       1 MPI processes
        type: gmres
      PC Object:      (fieldsplit_1_)       1 MPI processes
        type: ilu
          0 levels of fill
                type: seqaij
                rows=2744, cols=2744
                total: nonzeros=64000, allocated nonzeros=64000
                  not using I-node routines
        linear system matrix followed by preconditioner matrix:
          type: schurcomplement
            Schur complement A11 - A10 inv(A00) A01
            A11
                type: seqaij
            A10
                type: seqaij
                rows=2744, cols=8232
                total: nonzeros=192000, allocated nonzeros=192000
            KSP of A00
processes
                type: gmres
Gram-Schmidt Orthogonalization with no iterative refinement
divergence=10000
processes
                type: ilu
                  0 levels of fill
                        type: seqaij
calls =0
used is 5
                  type: seqaij
            A01
                type: seqaij
                rows=8232, cols=2744
          type: seqaij
    type: seqaij
    rows=10976, cols=10976, bs=4
    total: nonzeros=1024000, allocated nonzeros=1024000
>    Matt
>> I am testing a small problem with CONSTANT viscosity for grid size of
>> 14^3 with the run time option:
>> -ksp_type gcr -pc_type fieldsplit -pc_fieldsplit_type schur
>> -pc_fieldsplit_dm_splits 0 -pc_fieldsplit_0_fields 0,1,2
>> -pc_fieldsplit_1_fields 3 -ksp_converged_reason -ksp_view
>> -fieldsplit_0_ksp_type gcr -fieldsplit_0_pc_type gamg
>> -fieldsplit_0_ksp_monitor_true_residual -fieldsplit_0_ksp_converged_reason
>> -fieldsplit_1_ksp_monitor_true_residual
>> Here is my relevant code of the solve function:
>> PetscErrorCode ierr;
>>     PetscFunctionBeginUser;
>>     ierr = DMKSPSetComputeRHS(mDa,computeRHSTaras3D,this);CHKERRQ(ierr);
>>     ierr =
>> DMKSPSetComputeOperators(mDa,computeMatrixTaras3D,this);CHKERRQ(ierr);
>>     ierr = KSPSetDM(mKsp,mDa);CHKERRQ(ierr);              //mDa with dof
>> = 4, vx,vy,vz and p.
>>     ierr = KSPSetNullSpace(mKsp,mNullSpace);CHKERRQ(ierr);//nullSpace for
>> the main system
>>     ierr = KSPSetFromOptions(mKsp);CHKERRQ(ierr);
>>     ierr = KSPSetUp(mKsp);CHKERRQ(ierr);                  //register the
>> fieldsplits obtained from options.
>>     //Setting up user PC for Schur Complement
>>     ierr = KSPGetPC(mKsp,&mPc);CHKERRQ(ierr);
>>     ierr =
>> PCFieldSplitSchurPrecondition(mPc,PC_FIELDSPLIT_SCHUR_PRE_USER,mPcForSc);CHKERRQ(ierr);
>>     KSP *subKsp;
>>     PetscInt subKspPos = 0;
>>     //Set up nearNullspace for A00 block.
>>     ierr = PCFieldSplitGetSubKSP(mPc,&subKspPos,&subKsp);CHKERRQ(ierr);
>>     MatNullSpace rigidBodyModes;
>>     Vec coords;
>>     ierr = DMGetCoordinates(mDa,&coords);CHKERRQ(ierr);
>>     ierr =
>> MatNullSpaceCreateRigidBody(coords,&rigidBodyModes);CHKERRQ(ierr);
>>     Mat matA00;
>>     ierr = KSPGetOperators(subKsp[0],&matA00,NULL,NULL);CHKERRQ(ierr);
>>     ierr = MatSetNearNullSpace(matA00,rigidBodyModes);CHKERRQ(ierr);
>>     ierr = MatNullSpaceDestroy(&rigidBodyModes);CHKERRQ(ierr);
>>     //Position 1 => Ksp corresponding to Schur complement S on pressure
>> space
>>     subKspPos = 1;
>>     //Set up the null space of constant pressure.
>>     ierr = KSPSetNullSpace(subKsp[1],mNullSpaceP);CHKERRQ(ierr);
>>     PetscBool isNull;
>>     Mat matSc;
>>     ierr = KSPGetOperators(subKsp[1],&matSc,NULL,NULL);CHKERRQ(ierr);
>>     ierr = MatNullSpaceTest(mNullSpaceP,matSc,&isNull);
>>     if(!isNull)
>>         SETERRQ(PETSC_COMM_WORLD,PETSC_ERR_PLIB,"not a valid pressure
>> null space \n");
>>     ierr = KSPGetOperators(mKsp,&mA,NULL,NULL);CHKERRQ(ierr);
>>     ierr = MatNullSpaceTest(mNullSpace,mA,&isNull);CHKERRQ(ierr);
>>     if(!isNull)
>>         SETERRQ(PETSC_COMM_WORLD,PETSC_ERR_PLIB,"not a valid system null
>> space \n");
>>     ierr = PetscFree(subKsp);CHKERRQ(ierr);
>>     ierr = KSPSolve(mKsp,NULL,NULL);CHKERRQ(ierr);
>>     ierr = KSPGetSolution(mKsp,&mX);CHKERRQ(ierr);
>>     ierr = KSPGetRhs(mKsp,&mB);CHKERRQ(ierr);
>>     PetscFunctionReturn(0);
>> On Wed, Aug 7, 2013 at 2:15 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>> On Wed, Aug 7, 2013 at 7:07 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>>> On Tue, Aug 6, 2013 at 11:34 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>> On Tue, Aug 6, 2013 at 10:59 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>>>>> On Tue, Aug 6, 2013 at 4:40 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>>> On Tue, Aug 6, 2013 at 8:06 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>>>>>>> On Mon, Aug 5, 2013 at 4:14 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>>>>> On Mon, Aug 5, 2013 at 8:48 AM, Bishesh Khanal <
>>>>>>>>> bisheshkh at gmail.com> wrote:
>>>>>>>>>> On Mon, Aug 5, 2013 at 3:17 PM, Matthew Knepley <
>>>>>>>>>>> On Mon, Aug 5, 2013 at 7:54 AM, Bishesh Khanal <
>>>>>>>>>>>> On Wed, Jul 17, 2013 at 9:48 PM, Jed Brown <
>>>>>>>>>>>> jedbrown at mcs.anl.gov> wrote:
>>>>>>>>>>>>> Bishesh Khanal <bisheshkh at gmail.com> writes:
>>>>>>>>>>>>> > Now, I implemented two different approaches, each for both
>>>>>>>>>>>>> 2D and 3D, in
>>>>>>>>>>>>> > MATLAB. It works for the smaller sizes but I have problems
>>>>>>>>>>>>> solving it for
>>>>>>>>>>>>> > the problem size I need (250^3 grid size).
>>>>>>>>>>>>> > I use staggered grid with p on cell centers, and components
>>>>>>>>>>>>> of v on cell
>>>>>>>>>>>>> > faces. Similar split up of K to cell center and faces to
>>>>>>>>>>>>> account for the
>>>>>>>>>>>>> > variable viscosity case)
>>>>>>>>>>>>> Okay, you're using a staggered-grid finite difference
>>>>>>>>>>>>> discretization of
>>>>>>>>>>>>> variable-viscosity Stokes.  This is a common problem and I
>>>>>>>>>>>>> recommend
>>>>>>>>>>>>> starting with PCFieldSplit with Schur complement reduction
>>>>>>>>>>>>> (make that
>>>>>>>>>>>>> work first, then switch to block preconditioner).  You can use
>>>>>>>>>>>>> PCLSC or
>>>>>>>>>>>>> (probably better for you), assemble a preconditioning matrix
>>>>>>>>>>>>> containing
>>>>>>>>>>>>> the inverse viscosity in the pressure-pressure block.  This
>>>>>>>>>>>>> diagonal
>>>>>>>>>>>>> matrix is a spectrally equivalent (or nearly so, depending on
>>>>>>>>>>>>> discretization) approximation of the Schur complement.  The
>>>>>>>>>>>>> velocity
>>>>>>>>>>>>> block can be solved with algebraic multigrid.  Read the
>>>>>>>>>>>>> PCFieldSplit
>>>>>>>>>>>>> docs (follow papers as appropriate) and let us know if you get
>>>>>>>>>>>>> stuck.
>>>>>>>>>>>> I was trying to assemble the inverse viscosity diagonal matrix
>>>>>>>>>>>> to use as the preconditioner for the Schur complement solve step as you
>>>>>>>>>>>> suggested. I've few questions about the ways to implement this in Petsc:
>>>>>>>>>>>> A naive approach that I can think of would be to create a
>>>>>>>>>>>> vector with its components as reciprocal viscosities of the cell centers
>>>>>>>>>>>> corresponding to the pressure variables, and then create a diagonal matrix
>>>>>>>>>>>> from this vector. However I'm not sure about:
>>>>>>>>>>>> How can I make this matrix, (say S_p) compatible to the Petsc
>>>>>>>>>>>> distribution of the different rows of the main system matrix over different
>>>>>>>>>>>> processors ? The main matrix was created using the DMDA structure with 4
>>>>>>>>>>>> dof as explained before.
>>>>>>>>>>>> The main matrix correspond to the DMDA with 4 dofs but for the
>>>>>>>>>>>> S_p matrix would correspond to only pressure space. Should the distribution
>>>>>>>>>>>> of the rows of S_p among different processor not correspond to the
>>>>>>>>>>>> distribution of the rhs vector, say h' if it is solving for p with Sp = h'
>>>>>>>>>>>> where S = A11 inv(A00) A01 ?
>>>>>>>>>>> PETSc distributed vertices, not dofs, so it never breaks blocks.
>>>>>>>>>>> The P distribution is the same as the entire problem divided by 4.
>>>>>>>>>> Thanks Matt. So if I create a new DMDA with same grid size but
>>>>>>>>>> with dof=1 instead of 4, the vertices for this new DMDA will be identically
>>>>>>>>>> distributed as for the original DMDA ? Or should I inform PETSc by calling
>>>>>>>>>> a particular function to make these two DMDA have identical distribution of
>>>>>>>>>> the vertices ?
>>>>>>>>> Yes.
>>>>>>>>>>  Even then I think there might be a problem due to the presence
>>>>>>>>>> of "fictitious pressure vertices". The system matrix (A) contains an
>>>>>>>>>> identity corresponding to these fictitious pressure nodes, thus when using
>>>>>>>>>> a -pc_fieldsplit_detect_saddle_point, will detect a A11 zero block of size
>>>>>>>>>> that correspond to only non-fictitious P-nodes. So the preconditioner S_p
>>>>>>>>>> for the Schur complement outer solve with Sp = h' will also need to
>>>>>>>>>> correspond to only the non-fictitious P-nodes. This means its size does not
>>>>>>>>>> directly correspond to the DMDA grid defined for the original problem.
>>>>>>>>>> Could you please suggest an efficient way of assembling this S_p matrix ?
>>>>>>>>> Don't use detect_saddle, but split it by fields
>>>>>>>>> -pc_fieldsplit_0_fields 0,1,2 -pc_fieldsplit_1_fields 4
>>>>>>>> How can I set this split in the code itself without giving it as a
>>>>>>>> command line option when the system matrix is assembled from the DMDA for
>>>>>>>> the whole system with 4 dofs. (i.e. *without* using the
>>>>>>>> DMComposite or *without* using the nested block matrices to
>>>>>>>> assemble different blocks separately and then combine them together).
>>>>>>>> I need the split to get access to the fieldsplit_1_ksp in my code,
>>>>>>>> because not using detect_saddle_point means I cannot use
>>>>>>>> -fieldsplit_1_ksp_constant_null_space due to the presence of identity for
>>>>>>>> the fictitious pressure nodes present in the fieldsplit_1_ block. I need to
>>>>>>>> use PCFieldSplitGetSubKsp() so that I can set proper null-space basis.
>>>>>>> This is currently a real problem with the DMDA. In the unstructured
>>>>>>> case, where we always need specialized spaces, you can
>>>>>>> use something like
>>>>>>>     PetscObject  pressure;
>>>>>>>     MatNullSpace nullSpacePres;
>>>>>>>     ierr = DMGetField(dm, 1, &pressure);CHKERRQ(ierr);
>>>>>>>     ierr = MatNullSpaceCreate(PetscObjectComm(pressure), PETSC_TRUE,
>>>>>>> 0, NULL, &nullSpacePres);CHKERRQ(ierr);
>>>>>>>     ierr = PetscObjectCompose(pressure, "nullspace", (PetscObject)
>>>>>>>     ierr = MatNullSpaceDestroy(&nullSpacePres);CHKERRQ(ierr);
>>>>>>> and then DMGetSubDM() uses this information to attach the null space
>>>>>>> to the IS that is created using the information in the PetscSection.
>>>>>>> If you use a PetscSection to set the data layout over the DMDA, I
>>>>>>> think this works correctly, but this has not been tested at all and is very
>>>>>>> new code. Eventually, I think we want all DMs to use this mechanism,
>>>>>>> but we are still working it out.
>>>>>> Currently I do not use PetscSection. If this makes a cleaner
>>>>>> approach, I'd try it too but may a bit later (right now I'd like test my
>>>>>> model with a quickfix even if it means a little dirty code!)
>>>>>>> Bottom line: For custom null spaces using the default layout in
>>>>>>> DMDA, you need to take apart the PCFIELDSPLIT after it has been setup,
>>>>>>> which is somewhat subtle. You need to call KSPSetUp() and then reach
>>>>>>> in and get the PC, and the subKSPs. I don't like this at all, but we
>>>>>>> have not reorganized that code (which could be very simple and
>>>>>>> inflexible since its very structured).
>>>>>> So I tried to get this approach working but I could not succeed and
>>>>>> encountered some errors. Here is a code snippet:
>>>>>> //mDa is the DMDA that describes the whole grid with all 4 dofs (3
>>>>>> velocity components and 1 pressure comp.)
>>>>>>     ierr =
>>>>>>     ierr = KSPSetNullSpace(mKsp,mNullSpaceSystem);CHKERRQ(ierr);
>>>>>> //I've the mNullSpaceSystem based on mDa, that contains a null space basis
>>>>>> for the complete system.
>>>>>>     ierr =
>>>>>> //This I expect would register these options I give:-pc_type fieldsplit
>>>>>> -pc_fieldsplit_type schur -pc_fieldsplit_0_fields 0,1,2
>>>>>> //-pc_fieldsplit_1_fields 3
>>>>>>     ierr = KSPGetPC(mKsp,&mPcOuter);     //Now get the PC that was
>>>>>> obtained from the options (fieldsplit)
>>>>>>     ierr =
>>>>>> PCFieldSplitSchurPrecondition(mPcOuter,PC_FIELDSPLIT_SCHUR_PRE_USER,mPcForSc);CHKERRQ(ierr);
>>>>>> //I have created the matrix mPcForSc using a DMDA with identical //size to
>>>>>> mDa but with dof=1 corresponding to the pressure nodes (say mDaPressure).
>>>>>>   ierr = PCSetUp(mPcOuter);CHKERRQ(ierr);
>>>>>>     KSP *kspSchur;
>>>>>>     PetscInt kspSchurPos = 1;
>>>>>>     ierr =
>>>>>> PCFieldSplitGetSubKSP(mPcOuter,&kspSchurPos,&kspSchur);CHKERRQ(ierr);
>>>>>>     ierr =
>>>>>> KSPSetNullSpace(kspSchur[1],mNullSpacePressure);CHKERRQ(ierr);
>>>>>> //The null space is the one that correspond to only pressure nodes, created
>>>>>> using the mDaPressure.
>>>>>>     ierr = PetscFree(kspSchur);CHKERRQ(ierr);
>>>>> Sorry, you need to return to the old DMDA behavior, so you want
>>>> Thanks, with this it seems I can attach the null space properly, but I
>>>> have a question regarding whether the Schur complement ksp solver is
>>>> actually using the preconditioner matrix I provide.
>>>> When using -ksp_view, the outer level pc object of type fieldsplit does
>>>> report that: "Preconditioner for the Schur complement formed from user
>>>> provided matrix", but in the KSP solver for Schur complement S, the pc
>>>> object (fieldsplit_1_) is of type ilu and doesn't say that it is using the
>>>> matrix I provide. Am I missing something here ?
>>>> Below are the relevant commented code snippet and the output of the
>>>> -ksp_view
>>>> (The options I used: -pc_type fieldsplit -pc_fieldsplit_type schur
>>>> -pc_fieldsplit_1_fields 3 -ksp_converged_reason -ksp_view )
>>> If ILU does not error, it means it is using your matrix, because the
>>> Schur complement matrix cannot be factored, and FS says it is using your
>>> matrix.
>>>    Matt
>>>> Code snippet:
>>>> ierr = KSPSetNullSpace(mKsp,mNullSpaceSystem);CHKERRQ(ierr);   //The
>>>> nullspace for the whole system
>>>>     ierr = KSPSetUp(mKsp);CHKERRQ(ierr);                   //Set up
>>>> mKsp with the options provided with fieldsplit and the fields associated
>>>> with the two splits.
>>>>     ierr = KSPGetPC(mKsp,&mPcOuter);CHKERRQ(ierr);                //Get
>>>> the fieldsplit pc set up from the options
>>>>     ierr =
>>>> //Use mPcForSc as the preconditioner for Schur Complement
>>>>     KSP *kspSchur;
>>>>     ierr =
>>>>     ierr =
>>>> //Attach the null-space for the Schur complement ksp solver.
>>>> the output of the -ksp_view
>>>>   type: gmres
>>>>   type: fieldsplit
>>>> FULL
>>>> matrix
>>>>     Split info:
>>>>         type: gmres
>>>>         type: ilu
>>>>           0 levels of fill
>>>>                 type: seqaij
>>>>                 rows=2187, cols=2187
>>>>                 total: nonzeros=140625, allocated nonzeros=140625
>>>> =0
>>>>                   using I-node routines: found 729 nodes, limit used is
>>>> 5
>>>>           type: seqaij
>>>>             using I-node routines: found 729 nodes, limit used is 5
>>>>         type: gmres
>>>>         type: ilu
>>>>           0 levels of fill
>>>>                 type: seqaij
>>>>                 rows=729, cols=729
>>>>                 total: nonzeros=15625, allocated nonzeros=15625
>>>> =0
>>>>           rows=729, cols=729
>>>>             A11
>>>>                 type: seqaij
>>>>                 rows=729, cols=729
>>>> =0
>>>>             A10
>>>>                 type: seqaij
>>>>                 rows=729, cols=2187
>>>>                 total: nonzeros=46875, allocated nonzeros=46875
>>>> =0
>>>>             KSP of A00
>>>> MPI processes
>>>>                 type: gmres
>>>> divergence=10000
>>>> MPI processes
>>>>                 type: ilu
>>>>                   0 levels of fill
>>>> processes
>>>>                         type: seqaij
>>>> nonzeros=140625
>>>> used is 5
>>>>                   type: seqaij
>>>> calls =0
>>>> is 5
>>>>             A01
>>>>                 type: seqaij
>>>>                 rows=2187, cols=729
>>>> =0
>>>> 5
>>>>           type: seqaij
>>>>           rows=729, cols=729
>>>>     type: seqaij
>>>>     rows=2916, cols=2916, bs=4
>>>>     total: nonzeros=250000, allocated nonzeros=250000
>>>>> or
>>>>>   PCFieldSplitSetDMSplits(pc, PETSC_FALSE)
>>>>>   Thanks,
>>>>>      Matt
>>>>>> The errors I get when running with options: -pc_type fieldsplit
>>>>>> [0]PETSC ERROR: --------------------- Error Message
>>>>>> [0]PETSC ERROR: No support for this operation for this object type!
>>>>>> [0]PETSC ERROR: Support only implemented for 2d!
>>>>>> [0]PETSC ERROR:
>>>>>> [0]PETSC ERROR: Petsc Release Version 3.4.2, Jul, 02, 2013
>>>>>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>>>>>> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>>>>> [0]PETSC ERROR: See docs/index.html for manual pages.
>>>>>> [0]PETSC ERROR:
>>>>>> [0]PETSC ERROR: src/AdLemMain on a arch-linux2-cxx-debug named
>>>>>> edwards by bkhanal Tue Aug  6 17:35:30 2013
>>>>>> [0]PETSC ERROR: Libraries linked from
>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/arch-linux2-cxx-debug/lib
>>>>>> [0]PETSC ERROR: Configure run at Fri Jul 19 14:25:01 2013
>>>>>> [0]PETSC ERROR: Configure options --with-cc=gcc --with-fc=g77
>>>>>> --with-cxx=g++ --download-f-blas-lapack=1 --download-mpich=1
>>>>>> -with-clanguage=cxx --download-hypre=1
>>>>>> [0]PETSC ERROR:
>>>>>> [0]PETSC ERROR: DMCreateSubDM_DA() line 188 in
>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/dm/impls/da/dacreate.c
>>>>>> [0]PETSC ERROR: DMCreateSubDM() line 1267 in
>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/dm/interface/dm.c
>>>>>> [0]PETSC ERROR: PCFieldSplitSetDefaults() line 337 in
>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/ksp/pc/impls/fieldsplit/fieldsplit.c
>>>>>> [0]PETSC ERROR: PCSetUp_FieldSplit() line 458 in
>>>>>> [0]PETSC ERROR: PCSetUp() line 890 in
>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/ksp/pc/interface/precon.c
>>>>>> [0]PETSC ERROR: KSPSetUp() line 278 in
>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/ksp/ksp/interface/itfunc.c
>>>>>> [0]PETSC ERROR: solveModel() line 181 in
>>>>>> "unknowndirectory/"/user/bkhanal/home/works/AdLemModel/src/PetscAdLemTaras3D.cxx
>>>>>> WARNING! There are options you set that were not used!
>>>>>> WARNING! could be spelling mistake, etc!
>>>>>> Option left: name:-pc_fieldsplit_1_fields value: 3
>>>>>>>    Matt
>>>>>>>>>    Matt
>>>>>>>>>>>    Matt
>>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>>> experiments lead.
>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>> experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130823/a73d5cf8/attachment-0001.html>
