[petsc-users] discontinuous viscosity stokes equation 3D staggered grid
Fri Aug 23 07:09:58 CDT 2013
On Fri, Aug 23, 2013 at 4:31 AM, Bishesh Khanal <bisheshkh at gmail.com> wrote:
> Thanks Matt and Mark for comments in using near null space [question I
> asked in the thread with subject: *problem (Segmentation voilation) using
> -pc_type hypre -pc_hypre_type -pilut with multiple nodes in a cluster*].
> So I understood that I have to set a nearNullSpace to A00 block where the
> null space correspond to the rigid body motion. I tried it but still the
> gamg just keeps on iterating and convergence is very very slow. I am not
> sure what the problem is, right now gamg does not even work for the
> constant viscosity case.
> I have set up the following in my code:
> 1. null space for the whole system A 2. null space for the Schur
> complement S 3. Near null space for A00 4. a user preconditioner matrix of
> inverse viscosity in the diagonal for S.
If you want to debug solvers, you HAVE to send -ksp_view.
   Matt
> I am testing a small problem with CONSTANT viscosity for grid size of 14^3
> with the run time option:
> -ksp_type gcr -pc_type fieldsplit -pc_fieldsplit_type schur
> -pc_fieldsplit_dm_splits 0 -pc_fieldsplit_0_fields 0,1,2
> -pc_fieldsplit_1_fields 3 -ksp_converged_reason -ksp_view
> -fieldsplit_0_ksp_type gcr -fieldsplit_0_pc_type gamg
> -fieldsplit_0_ksp_monitor_true_residual -fieldsplit_0_ksp_converged_reason
> -fieldsplit_1_ksp_monitor_true_residual
> Here is my relevant code of the solve function:
> PetscErrorCode ierr;
>     PetscFunctionBeginUser;
>     ierr = DMKSPSetComputeRHS(mDa,computeRHSTaras3D,this);CHKERRQ(ierr);
>     ierr =
> DMKSPSetComputeOperators(mDa,computeMatrixTaras3D,this);CHKERRQ(ierr);
>     ierr = KSPSetDM(mKsp,mDa);CHKERRQ(ierr);              //mDa with dof =
> 4, vx,vy,vz and p.
>     ierr = KSPSetNullSpace(mKsp,mNullSpace);CHKERRQ(ierr);//nullSpace for
> the main system
>     ierr = KSPSetFromOptions(mKsp);CHKERRQ(ierr);
>     ierr = KSPSetUp(mKsp);CHKERRQ(ierr);                  //register the
> fieldsplits obtained from options.
>     //Setting up user PC for Schur Complement
>     ierr = KSPGetPC(mKsp,&mPc);CHKERRQ(ierr);
>     ierr =
> PCFieldSplitSchurPrecondition(mPc,PC_FIELDSPLIT_SCHUR_PRE_USER,mPcForSc);CHKERRQ(ierr);
>     KSP *subKsp;
>     PetscInt subKspPos = 0;
>     //Set up nearNullspace for A00 block.
>     ierr = PCFieldSplitGetSubKSP(mPc,&subKspPos,&subKsp);CHKERRQ(ierr);
>     MatNullSpace rigidBodyModes;
>     Vec coords;
>     ierr = DMGetCoordinates(mDa,&coords);CHKERRQ(ierr);
>     ierr =
> MatNullSpaceCreateRigidBody(coords,&rigidBodyModes);CHKERRQ(ierr);
>     Mat matA00;
>     ierr = KSPGetOperators(subKsp[0],&matA00,NULL,NULL);CHKERRQ(ierr);
>     ierr = MatSetNearNullSpace(matA00,rigidBodyModes);CHKERRQ(ierr);
>     ierr = MatNullSpaceDestroy(&rigidBodyModes);CHKERRQ(ierr);
>     //Position 1 => Ksp corresponding to Schur complement S on pressure
> space
>     subKspPos = 1;
>     //Set up the null space of constant pressure.
>     ierr = KSPSetNullSpace(subKsp[1],mNullSpaceP);CHKERRQ(ierr);
>     PetscBool isNull;
>     Mat matSc;
>     ierr = KSPGetOperators(subKsp[1],&matSc,NULL,NULL);CHKERRQ(ierr);
>     ierr = MatNullSpaceTest(mNullSpaceP,matSc,&isNull);
>     if(!isNull)
>         SETERRQ(PETSC_COMM_WORLD,PETSC_ERR_PLIB,"not a valid pressure null
> space \n");
>     ierr = KSPGetOperators(mKsp,&mA,NULL,NULL);CHKERRQ(ierr);
>     ierr = MatNullSpaceTest(mNullSpace,mA,&isNull);CHKERRQ(ierr);
>     if(!isNull)
>         SETERRQ(PETSC_COMM_WORLD,PETSC_ERR_PLIB,"not a valid system null
> space \n");
>     ierr = PetscFree(subKsp);CHKERRQ(ierr);
>     ierr = KSPSolve(mKsp,NULL,NULL);CHKERRQ(ierr);
>     ierr = KSPGetSolution(mKsp,&mX);CHKERRQ(ierr);
>     ierr = KSPGetRhs(mKsp,&mB);CHKERRQ(ierr);
>     PetscFunctionReturn(0);
> On Wed, Aug 7, 2013 at 2:15 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Wed, Aug 7, 2013 at 7:07 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>> On Tue, Aug 6, 2013 at 11:34 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>> On Tue, Aug 6, 2013 at 10:59 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>>>> On Tue, Aug 6, 2013 at 4:40 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>> On Tue, Aug 6, 2013 at 8:06 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>>>>>> On Mon, Aug 5, 2013 at 4:14 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>>>> On Mon, Aug 5, 2013 at 8:48 AM, Bishesh Khanal <bisheshkh at gmail.com
>>>>>>>> > wrote:
>>>>>>>>> On Mon, Aug 5, 2013 at 3:17 PM, Matthew Knepley <knepley at gmail.com
>>>>>>>>> > wrote:
>>>>>>>>>> On Mon, Aug 5, 2013 at 7:54 AM, Bishesh Khanal <
>>>>>>>>>>> On Wed, Jul 17, 2013 at 9:48 PM, Jed Brown <jedbrown at mcs.anl.gov
>>>>>>>>>>> > wrote:
>>>>>>>>>>>> Bishesh Khanal <bisheshkh at gmail.com> writes:
>>>>>>>>>>>> > Now, I implemented two different approaches, each for both 2D
>>>>>>>>>>>> and 3D, in
>>>>>>>>>>>> > MATLAB. It works for the smaller sizes but I have problems
>>>>>>>>>>>> solving it for
>>>>>>>>>>>> > the problem size I need (250^3 grid size).
>>>>>>>>>>>> > I use staggered grid with p on cell centers, and components
>>>>>>>>>>>> of v on cell
>>>>>>>>>>>> > faces. Similar split up of K to cell center and faces to
>>>>>>>>>>>> account for the
>>>>>>>>>>>> > variable viscosity case)
>>>>>>>>>>>> Okay, you're using a staggered-grid finite difference
>>>>>>>>>>>> discretization of
>>>>>>>>>>>> variable-viscosity Stokes.  This is a common problem and I
>>>>>>>>>>>> recommend
>>>>>>>>>>>> starting with PCFieldSplit with Schur complement reduction
>>>>>>>>>>>> (make that
>>>>>>>>>>>> work first, then switch to block preconditioner).  You can use
>>>>>>>>>>>> PCLSC or
>>>>>>>>>>>> (probably better for you), assemble a preconditioning matrix
>>>>>>>>>>>> containing
>>>>>>>>>>>> the inverse viscosity in the pressure-pressure block.  This
>>>>>>>>>>>> diagonal
>>>>>>>>>>>> matrix is a spectrally equivalent (or nearly so, depending on
>>>>>>>>>>>> discretization) approximation of the Schur complement.  The
>>>>>>>>>>>> velocity
>>>>>>>>>>>> block can be solved with algebraic multigrid.  Read the
>>>>>>>>>>>> PCFieldSplit
>>>>>>>>>>>> docs (follow papers as appropriate) and let us know if you get
>>>>>>>>>>>> stuck.
>>>>>>>>>>> I was trying to assemble the inverse viscosity diagonal matrix
>>>>>>>>>>> to use as the preconditioner for the Schur complement solve step as you
>>>>>>>>>>> suggested. I've few questions about the ways to implement this in Petsc:
>>>>>>>>>>> A naive approach that I can think of would be to create a vector
>>>>>>>>>>> with its components as reciprocal viscosities of the cell centers
>>>>>>>>>>> corresponding to the pressure variables, and then create a diagonal matrix
>>>>>>>>>>> from this vector. However I'm not sure about:
>>>>>>>>>>> How can I make this matrix, (say S_p) compatible to the Petsc
>>>>>>>>>>> distribution of the different rows of the main system matrix over different
>>>>>>>>>>> processors ? The main matrix was created using the DMDA structure with 4
>>>>>>>>>>> dof as explained before.
>>>>>>>>>>> The main matrix correspond to the DMDA with 4 dofs but for the
>>>>>>>>>>> S_p matrix would correspond to only pressure space. Should the distribution
>>>>>>>>>>> of the rows of S_p among different processor not correspond to the
>>>>>>>>>>> distribution of the rhs vector, say h' if it is solving for p with Sp = h'
>>>>>>>>>>> where S = A11 inv(A00) A01 ?
>>>>>>>>>> PETSc distributed vertices, not dofs, so it never breaks blocks.
>>>>>>>>>> The P distribution is the same as the entire problem divided by 4.
>>>>>>>>> Thanks Matt. So if I create a new DMDA with same grid size but
>>>>>>>>> with dof=1 instead of 4, the vertices for this new DMDA will be identically
>>>>>>>>> distributed as for the original DMDA ? Or should I inform PETSc by calling
>>>>>>>>> a particular function to make these two DMDA have identical distribution of
>>>>>>>>> the vertices ?
>>>>>>>> Yes.
>>>>>>>>>  Even then I think there might be a problem due to the presence
>>>>>>>>> of "fictitious pressure vertices". The system matrix (A) contains an
>>>>>>>>> identity corresponding to these fictitious pressure nodes, thus when using
>>>>>>>>> a -pc_fieldsplit_detect_saddle_point, will detect a A11 zero block of size
>>>>>>>>> that correspond to only non-fictitious P-nodes. So the preconditioner S_p
>>>>>>>>> for the Schur complement outer solve with Sp = h' will also need to
>>>>>>>>> correspond to only the non-fictitious P-nodes. This means its size does not
>>>>>>>>> directly correspond to the DMDA grid defined for the original problem.
>>>>>>>>> Could you please suggest an efficient way of assembling this S_p matrix ?
>>>>>>>> Don't use detect_saddle, but split it by fields
>>>>>>>> -pc_fieldsplit_0_fields 0,1,2 -pc_fieldsplit_1_fields 4
>>>>>>> How can I set this split in the code itself without giving it as a
>>>>>>> command line option when the system matrix is assembled from the DMDA for
>>>>>>> the whole system with 4 dofs. (i.e. *without* using the DMComposite
>>>>>>> or *without* using the nested block matrices to assemble different
>>>>>>> blocks separately and then combine them together).
>>>>>>> I need the split to get access to the fieldsplit_1_ksp in my code,
>>>>>>> because not using detect_saddle_point means I cannot use
>>>>>>> -fieldsplit_1_ksp_constant_null_space due to the presence of identity for
>>>>>>> the fictitious pressure nodes present in the fieldsplit_1_ block. I need to
>>>>>>> use PCFieldSplitGetSubKsp() so that I can set proper null-space basis.
>>>>>> This is currently a real problem with the DMDA. In the unstructured
>>>>>> case, where we always need specialized spaces, you can
>>>>>> use something like
>>>>>>     PetscObject  pressure;
>>>>>>     MatNullSpace nullSpacePres;
>>>>>>     ierr = DMGetField(dm, 1, &pressure);CHKERRQ(ierr);
>>>>>>     ierr = MatNullSpaceCreate(PetscObjectComm(pressure), PETSC_TRUE,
>>>>>> 0, NULL, &nullSpacePres);CHKERRQ(ierr);
>>>>>>     ierr = PetscObjectCompose(pressure, "nullspace", (PetscObject)
>>>>>>     ierr = MatNullSpaceDestroy(&nullSpacePres);CHKERRQ(ierr);
>>>>>> and then DMGetSubDM() uses this information to attach the null space
>>>>>> to the IS that is created using the information in the PetscSection.
>>>>>> If you use a PetscSection to set the data layout over the DMDA, I
>>>>>> think this works correctly, but this has not been tested at all and is very
>>>>>> new code. Eventually, I think we want all DMs to use this mechanism,
>>>>>> but we are still working it out.
>>>>> Currently I do not use PetscSection. If this makes a cleaner approach,
>>>>> I'd try it too but may a bit later (right now I'd like test my model with a
>>>>> quickfix even if it means a little dirty code!)
>>>>>> Bottom line: For custom null spaces using the default layout in DMDA,
>>>>>> you need to take apart the PCFIELDSPLIT after it has been setup,
>>>>>> which is somewhat subtle. You need to call KSPSetUp() and then reach
>>>>>> in and get the PC, and the subKSPs. I don't like this at all, but we
>>>>>> have not reorganized that code (which could be very simple and
>>>>>> inflexible since its very structured).
>>>>> So I tried to get this approach working but I could not succeed and
>>>>> encountered some errors. Here is a code snippet:
>>>>> //mDa is the DMDA that describes the whole grid with all 4 dofs (3
>>>>> velocity components and 1 pressure comp.)
>>>>>     ierr =
>>>>>     ierr = KSPSetNullSpace(mKsp,mNullSpaceSystem);CHKERRQ(ierr);
>>>>> //I've the mNullSpaceSystem based on mDa, that contains a null space basis
>>>>> for the complete system.
>>>>>     ierr =
>>>>> //This I expect would register these options I give:-pc_type fieldsplit
>>>>> -pc_fieldsplit_type schur -pc_fieldsplit_0_fields 0,1,2
>>>>> //-pc_fieldsplit_1_fields 3
>>>>>     ierr = KSPGetPC(mKsp,&mPcOuter);     //Now get the PC that was
>>>>> obtained from the options (fieldsplit)
>>>>>     ierr =
>>>>> PCFieldSplitSchurPrecondition(mPcOuter,PC_FIELDSPLIT_SCHUR_PRE_USER,mPcForSc);CHKERRQ(ierr);
>>>>> //I have created the matrix mPcForSc using a DMDA with identical //size to
>>>>> mDa but with dof=1 corresponding to the pressure nodes (say mDaPressure).
>>>>>   ierr = PCSetUp(mPcOuter);CHKERRQ(ierr);
>>>>>     KSP *kspSchur;
>>>>>     PetscInt kspSchurPos = 1;
>>>>>     ierr =
>>>>> PCFieldSplitGetSubKSP(mPcOuter,&kspSchurPos,&kspSchur);CHKERRQ(ierr);
>>>>>     ierr =
>>>>> KSPSetNullSpace(kspSchur[1],mNullSpacePressure);CHKERRQ(ierr);
>>>>> //The null space is the one that correspond to only pressure nodes, created
>>>>> using the mDaPressure.
>>>>>     ierr = PetscFree(kspSchur);CHKERRQ(ierr);
>>>> Sorry, you need to return to the old DMDA behavior, so you want
>>> Thanks, with this it seems I can attach the null space properly, but I
>>> have a question regarding whether the Schur complement ksp solver is
>>> actually using the preconditioner matrix I provide.
>>> When using -ksp_view, the outer level pc object of type fieldsplit does
>>> report that: "Preconditioner for the Schur complement formed from user
>>> provided matrix", but in the KSP solver for Schur complement S, the pc
>>> object (fieldsplit_1_) is of type ilu and doesn't say that it is using the
>>> matrix I provide. Am I missing something here ?
>>> Below are the relevant commented code snippet and the output of the
>>> -ksp_view
>>> (The options I used: -pc_type fieldsplit -pc_fieldsplit_type schur
>>> -pc_fieldsplit_1_fields 3 -ksp_converged_reason -ksp_view )
>> If ILU does not error, it means it is using your matrix, because the
>> Schur complement matrix cannot be factored, and FS says it is using your
>> matrix.
>>    Matt
>>> Code snippet:
>>> ierr = KSPSetNullSpace(mKsp,mNullSpaceSystem);CHKERRQ(ierr);   //The
>>> nullspace for the whole system
>>>     ierr = KSPSetUp(mKsp);CHKERRQ(ierr);                   //Set up mKsp
>>> with the options provided with fieldsplit and the fields associated with
>>> the two splits.
>>>     ierr = KSPGetPC(mKsp,&mPcOuter);CHKERRQ(ierr);                //Get
>>> the fieldsplit pc set up from the options
>>>     ierr =
>>> //Use mPcForSc as the preconditioner for Schur Complement
>>>     KSP *kspSchur;
>>>     ierr =
>>>     ierr =
>>> //Attach the null-space for the Schur complement ksp solver.
>>> the output of the -ksp_view
>>> KSP Object: 1 MPI processes
>>>   type: gmres
>>>     GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
>>> Orthogonalization with no iterative refinement
>>>     GMRES: happy breakdown tolerance 1e-30
>>>   maximum iterations=10000, initial guess is zero
>>>   tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>>>   left preconditioning
>>>   has attached null space
>>>   using PRECONDITIONED norm type for convergence test
>>> PC Object: 1 MPI processes
>>>   type: fieldsplit
>>>     FieldSplit with Schur preconditioner, blocksize = 4, factorization
>>> FULL
>>>     Preconditioner for the Schur complement formed from user provided
>>> matrix
>>>     Split info:
>>>     Split number 0 Fields  0, 1, 2
>>>     Split number 1 Fields  3
>>>     KSP solver for A00 block
>>>       KSP Object:      (fieldsplit_0_)       1 MPI processes
>>>         type: gmres
>>>       PC Object:      (fieldsplit_0_)       1 MPI processes
>>>         type: ilu
>>>           ILU: out-of-place factorization
>>>           0 levels of fill
>>>           tolerance for zero pivot 2.22045e-14
>>>           using diagonal shift on blocks to prevent zero pivot
>>>           matrix ordering: natural
>>>           factor fill ratio given 1, needed 1
>>>             Factored matrix follows:
>>>               Matrix Object:               1 MPI processes
>>>                 type: seqaij
>>>                 rows=2187, cols=2187
>>>                 package used to perform factorization: petsc
>>>                 total: nonzeros=140625, allocated nonzeros=140625
>>>                 total number of mallocs used during MatSetValues calls =0
>>>                   using I-node routines: found 729 nodes, limit used is 5
>>>         linear system matrix = precond matrix:
>>>           type: seqaij
>>>     KSP solver for S = A11 - A10 inv(A00) A01
>>>       KSP Object:      (fieldsplit_1_)       1 MPI processes
>>>         type: gmres
>>>       PC Object:      (fieldsplit_1_)       1 MPI processes
>>>         type: ilu
>>>           0 levels of fill
>>>                 type: seqaij
>>>                 rows=729, cols=729
>>>                 total: nonzeros=15625, allocated nonzeros=15625
>>>                   not using I-node routines
>>>         linear system matrix followed by preconditioner matrix:
>>>           type: schurcomplement
>>>           rows=729, cols=729
>>>             Schur complement A11 - A10 inv(A00) A01
>>>             A11
>>>                 type: seqaij
>>>                 rows=729, cols=729
>>>             A10
>>>                 type: seqaij
>>>                 rows=729, cols=2187
>>>                 total: nonzeros=46875, allocated nonzeros=46875
>>>             KSP of A00
>>> MPI processes
>>>                 type: gmres
>>> Gram-Schmidt Orthogonalization with no iterative refinement
>>> divergence=10000
>>> MPI processes
>>>                 type: ilu
>>>                   0 levels of fill
>>> processes
>>>                         type: seqaij
>>> calls =0
>>> used is 5
>>>                   type: seqaij
>>> =0
>>> is 5
>>>             A01
>>>                 type: seqaij
>>>                 rows=2187, cols=729
>>>           type: seqaij
>>>           rows=729, cols=729
>>>     type: seqaij
>>>     rows=2916, cols=2916, bs=4
>>>     total: nonzeros=250000, allocated nonzeros=250000
>>>> or
>>>>   PCFieldSplitSetDMSplits(pc, PETSC_FALSE)
>>>>   Thanks,
>>>>      Matt
>>>>> The errors I get when running with options: -pc_type fieldsplit
>>>>> [0]PETSC ERROR: --------------------- Error Message
>>>>> [0]PETSC ERROR: No support for this operation for this object type!
>>>>> [0]PETSC ERROR: Support only implemented for 2d!
>>>>> [0]PETSC ERROR:
>>>>> [0]PETSC ERROR: Petsc Release Version 3.4.2, Jul, 02, 2013
>>>>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>>>>> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>>>> [0]PETSC ERROR: See docs/index.html for manual pages.
>>>>> [0]PETSC ERROR:
>>>>> [0]PETSC ERROR: src/AdLemMain on a arch-linux2-cxx-debug named edwards
>>>>> by bkhanal Tue Aug  6 17:35:30 2013
>>>>> [0]PETSC ERROR: Libraries linked from
>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/arch-linux2-cxx-debug/lib
>>>>> [0]PETSC ERROR: Configure run at Fri Jul 19 14:25:01 2013
>>>>> [0]PETSC ERROR: Configure options --with-cc=gcc --with-fc=g77
>>>>> --with-cxx=g++ --download-f-blas-lapack=1 --download-mpich=1
>>>>> -with-clanguage=cxx --download-hypre=1
>>>>> [0]PETSC ERROR:
>>>>> [0]PETSC ERROR: DMCreateSubDM_DA() line 188 in
>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/dm/impls/da/dacreate.c
>>>>> [0]PETSC ERROR: DMCreateSubDM() line 1267 in
>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/dm/interface/dm.c
>>>>> [0]PETSC ERROR: PCFieldSplitSetDefaults() line 337 in
>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/ksp/pc/impls/fieldsplit/fieldsplit.c
>>>>> [0]PETSC ERROR: PCSetUp_FieldSplit() line 458 in
>>>>> [0]PETSC ERROR: PCSetUp() line 890 in
>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/ksp/pc/interface/precon.c
>>>>> [0]PETSC ERROR: KSPSetUp() line 278 in
>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/ksp/ksp/interface/itfunc.c
>>>>> [0]PETSC ERROR: solveModel() line 181 in
>>>>> "unknowndirectory/"/user/bkhanal/home/works/AdLemModel/src/PetscAdLemTaras3D.cxx
>>>>> WARNING! There are options you set that were not used!
>>>>> WARNING! could be spelling mistake, etc!
>>>>> Option left: name:-pc_fieldsplit_1_fields value: 3
>>>>>>    Matt
>>>>>>>>    Matt
>>>>>>>>>>    Matt
>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130823/7f8e9bf8/attachment-0001.html>
