[petsc-users] discontinuous viscosity stokes equation 3D staggered grid
Fri Aug 23 07:33:49 CDT 2013
On Fri, Aug 23, 2013 at 7:25 AM, Bishesh Khanal <bisheshkh at gmail.com> wrote:
> On Fri, Aug 23, 2013 at 2:09 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Fri, Aug 23, 2013 at 4:31 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>> Thanks Matt and Mark for comments in using near null space [question I
>>> asked in the thread with subject: *problem (Segmentation voilation)
>>> using -pc_type hypre -pc_hypre_type -pilut with multiple nodes in a cluster
>>> So I understood that I have to set a nearNullSpace to A00 block where
>>> the null space correspond to the rigid body motion. I tried it but still
>>> the gamg just keeps on iterating and convergence is very very slow. I am
>>> not sure what the problem is, right now gamg does not even work for the
>>> constant viscosity case.
>>> I have set up the following in my code:
>>> 1. null space for the whole system A 2. null space for the Schur
>>> complement S 3. Near null space for A00 4. a user preconditioner matrix of
>>> inverse viscosity in the diagonal for S.
>> If you want to debug solvers, you HAVE to send -ksp_view.
> When I use gamg, the -fieldsplit_0_ksp was iterating on and on so didn't
> get to the end to get -ksp_view results.
> Instead here I have put the -ksp_view output when running the program with
> following options: (In this case I get the results)
> -pc_type fieldsplit -pc_fieldsplit_type schur -pc_fieldsplit_dm_splits 0
> -pc_fieldsplit_0_fields 0,1,2 -pc_fieldsplit_1_fields 3
> -ksp_converged_reason -ksp_view
Okay, that looks fine. Does
  -fieldsplit_0_pc_type lu
  - fieldsplit_1_ksp_rtol 1.0e-10
converge in one Iterate?
What matrix did you attach as the preconditioner matrix for fieldsplit_1_?
     Matt
> Linear solve converged due to CONVERGED_RTOL iterations 2
> KSP Object: 1 MPI processes
>   type: gmres
>     GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
>     GMRES: happy breakdown tolerance 1e-30
>   maximum iterations=10000, initial guess is zero
>   tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>   left preconditioning
>   has attached null space
>   using PRECONDITIONED norm type for convergence test
> PC Object: 1 MPI processes
>   type: fieldsplit
>     FieldSplit with Schur preconditioner, blocksize = 4, factorization FULL
>     Preconditioner for the Schur complement formed from user provided
> matrix
>     Split info:
>     Split number 0 Fields  0, 1, 2
>     Split number 1 Fields  3
>     KSP solver for A00 block
>       KSP Object:      (fieldsplit_0_)       1 MPI processes
>         type: gmres
>       PC Object:      (fieldsplit_0_)       1 MPI processes
>         type: ilu
>           ILU: out-of-place factorization
>           0 levels of fill
>           tolerance for zero pivot 2.22045e-14
>           using diagonal shift on blocks to prevent zero pivot
>           matrix ordering: natural
>           factor fill ratio given 1, needed 1
>             Factored matrix follows:
>               Matrix Object:               1 MPI processes
>                 type: seqaij
>                 rows=8232, cols=8232
>                 package used to perform factorization: petsc
>                 total: nonzeros=576000, allocated nonzeros=576000
>                 total number of mallocs used during MatSetValues calls =0
>                   using I-node routines: found 2744 nodes, limit used is 5
>         linear system matrix = precond matrix:
>           type: seqaij
>     KSP solver for S = A11 - A10 inv(A00) A01
>       KSP Object:      (fieldsplit_1_)       1 MPI processes
>         type: gmres
>       PC Object:      (fieldsplit_1_)       1 MPI processes
>         type: ilu
>           0 levels of fill
>                 type: seqaij
>                 rows=2744, cols=2744
>                 total: nonzeros=64000, allocated nonzeros=64000
>                   not using I-node routines
>         linear system matrix followed by preconditioner matrix:
>           type: schurcomplement
>             Schur complement A11 - A10 inv(A00) A01
>             A11
>                 type: seqaij
>             A10
>                 type: seqaij
>                 rows=2744, cols=8232
>                 total: nonzeros=192000, allocated nonzeros=192000
>             KSP of A00
> processes
>                 type: gmres
> Gram-Schmidt Orthogonalization with no iterative refinement
> divergence=10000
> processes
>                 type: ilu
>                   0 levels of fill
>                         type: seqaij
> calls =0
> used is 5
>                   type: seqaij
> 5
>             A01
>                 type: seqaij
>                 rows=8232, cols=2744
>           type: seqaij
>     type: seqaij
>     rows=10976, cols=10976, bs=4
>     total: nonzeros=1024000, allocated nonzeros=1024000
>>    Matt
>>> I am testing a small problem with CONSTANT viscosity for grid size of
>>> 14^3 with the run time option:
>>> -ksp_type gcr -pc_type fieldsplit -pc_fieldsplit_type schur
>>> -pc_fieldsplit_dm_splits 0 -pc_fieldsplit_0_fields 0,1,2
>>> -pc_fieldsplit_1_fields 3 -ksp_converged_reason -ksp_view
>>> -fieldsplit_0_ksp_type gcr -fieldsplit_0_pc_type gamg
>>> -fieldsplit_0_ksp_monitor_true_residual -fieldsplit_0_ksp_converged_reason
>>> -fieldsplit_1_ksp_monitor_true_residual
>>> Here is my relevant code of the solve function:
>>> PetscErrorCode ierr;
>>>     PetscFunctionBeginUser;
>>>     ierr = DMKSPSetComputeRHS(mDa,computeRHSTaras3D,this);CHKERRQ(ierr);
>>>     ierr =
>>> DMKSPSetComputeOperators(mDa,computeMatrixTaras3D,this);CHKERRQ(ierr);
>>>     ierr = KSPSetDM(mKsp,mDa);CHKERRQ(ierr);              //mDa with dof
>>> = 4, vx,vy,vz and p.
>>>     ierr = KSPSetNullSpace(mKsp,mNullSpace);CHKERRQ(ierr);//nullSpace
>>> for the main system
>>>     ierr = KSPSetFromOptions(mKsp);CHKERRQ(ierr);
>>>     ierr = KSPSetUp(mKsp);CHKERRQ(ierr);                  //register the
>>> fieldsplits obtained from options.
>>>     //Setting up user PC for Schur Complement
>>>     ierr = KSPGetPC(mKsp,&mPc);CHKERRQ(ierr);
>>>     ierr =
>>> PCFieldSplitSchurPrecondition(mPc,PC_FIELDSPLIT_SCHUR_PRE_USER,mPcForSc);CHKERRQ(ierr);
>>>     KSP *subKsp;
>>>     PetscInt subKspPos = 0;
>>>     //Set up nearNullspace for A00 block.
>>>     ierr = PCFieldSplitGetSubKSP(mPc,&subKspPos,&subKsp);CHKERRQ(ierr);
>>>     MatNullSpace rigidBodyModes;
>>>     Vec coords;
>>>     ierr = DMGetCoordinates(mDa,&coords);CHKERRQ(ierr);
>>>     ierr =
>>> MatNullSpaceCreateRigidBody(coords,&rigidBodyModes);CHKERRQ(ierr);
>>>     Mat matA00;
>>>     ierr = KSPGetOperators(subKsp[0],&matA00,NULL,NULL);CHKERRQ(ierr);
>>>     ierr = MatSetNearNullSpace(matA00,rigidBodyModes);CHKERRQ(ierr);
>>>     ierr = MatNullSpaceDestroy(&rigidBodyModes);CHKERRQ(ierr);
>>>     //Position 1 => Ksp corresponding to Schur complement S on pressure
>>> space
>>>     subKspPos = 1;
>>>     //Set up the null space of constant pressure.
>>>     ierr = KSPSetNullSpace(subKsp[1],mNullSpaceP);CHKERRQ(ierr);
>>>     PetscBool isNull;
>>>     Mat matSc;
>>>     ierr = KSPGetOperators(subKsp[1],&matSc,NULL,NULL);CHKERRQ(ierr);
>>>     ierr = MatNullSpaceTest(mNullSpaceP,matSc,&isNull);
>>>     if(!isNull)
>>>         SETERRQ(PETSC_COMM_WORLD,PETSC_ERR_PLIB,"not a valid pressure
>>> null space \n");
>>>     ierr = KSPGetOperators(mKsp,&mA,NULL,NULL);CHKERRQ(ierr);
>>>     ierr = MatNullSpaceTest(mNullSpace,mA,&isNull);CHKERRQ(ierr);
>>>     if(!isNull)
>>>         SETERRQ(PETSC_COMM_WORLD,PETSC_ERR_PLIB,"not a valid system null
>>> space \n");
>>>     ierr = PetscFree(subKsp);CHKERRQ(ierr);
>>>     ierr = KSPSolve(mKsp,NULL,NULL);CHKERRQ(ierr);
>>>     ierr = KSPGetSolution(mKsp,&mX);CHKERRQ(ierr);
>>>     ierr = KSPGetRhs(mKsp,&mB);CHKERRQ(ierr);
>>>     PetscFunctionReturn(0);
>>> On Wed, Aug 7, 2013 at 2:15 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>> On Wed, Aug 7, 2013 at 7:07 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>>>> On Tue, Aug 6, 2013 at 11:34 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>> On Tue, Aug 6, 2013 at 10:59 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>>>>>> On Tue, Aug 6, 2013 at 4:40 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>>>> On Tue, Aug 6, 2013 at 8:06 AM, Bishesh Khanal <bisheshkh at gmail.com
>>>>>>>> > wrote:
>>>>>>>>> On Mon, Aug 5, 2013 at 4:14 PM, Matthew Knepley <knepley at gmail.com
>>>>>>>>> > wrote:
>>>>>>>>>> On Mon, Aug 5, 2013 at 8:48 AM, Bishesh Khanal <
>>>>>>>>>>> On Mon, Aug 5, 2013 at 3:17 PM, Matthew Knepley <
>>>>>>>>>>> knepley at gmail.com> wrote:
>>>>>>>>>>>> On Mon, Aug 5, 2013 at 7:54 AM, Bishesh Khanal <
>>>>>>>>>>>>> On Wed, Jul 17, 2013 at 9:48 PM, Jed Brown <
>>>>>>>>>>>>> jedbrown at mcs.anl.gov> wrote:
>>>>>>>>>>>>>> Bishesh Khanal <bisheshkh at gmail.com> writes:
>>>>>>>>>>>>>> > Now, I implemented two different approaches, each for both
>>>>>>>>>>>>>> 2D and 3D, in
>>>>>>>>>>>>>> > MATLAB. It works for the smaller sizes but I have problems
>>>>>>>>>>>>>> solving it for
>>>>>>>>>>>>>> > the problem size I need (250^3 grid size).
>>>>>>>>>>>>>> > I use staggered grid with p on cell centers, and components
>>>>>>>>>>>>>> of v on cell
>>>>>>>>>>>>>> > faces. Similar split up of K to cell center and faces to
>>>>>>>>>>>>>> account for the
>>>>>>>>>>>>>> > variable viscosity case)
>>>>>>>>>>>>>> Okay, you're using a staggered-grid finite difference
>>>>>>>>>>>>>> discretization of
>>>>>>>>>>>>>> variable-viscosity Stokes.  This is a common problem and I
>>>>>>>>>>>>>> recommend
>>>>>>>>>>>>>> starting with PCFieldSplit with Schur complement reduction
>>>>>>>>>>>>>> (make that
>>>>>>>>>>>>>> work first, then switch to block preconditioner).  You can
>>>>>>>>>>>>>> use PCLSC or
>>>>>>>>>>>>>> (probably better for you), assemble a preconditioning matrix
>>>>>>>>>>>>>> containing
>>>>>>>>>>>>>> the inverse viscosity in the pressure-pressure block.  This
>>>>>>>>>>>>>> diagonal
>>>>>>>>>>>>>> matrix is a spectrally equivalent (or nearly so, depending on
>>>>>>>>>>>>>> discretization) approximation of the Schur complement.  The
>>>>>>>>>>>>>> velocity
>>>>>>>>>>>>>> block can be solved with algebraic multigrid.  Read the
>>>>>>>>>>>>>> PCFieldSplit
>>>>>>>>>>>>>> docs (follow papers as appropriate) and let us know if you
>>>>>>>>>>>>>> get stuck.
>>>>>>>>>>>>> I was trying to assemble the inverse viscosity diagonal matrix
>>>>>>>>>>>>> to use as the preconditioner for the Schur complement solve step as you
>>>>>>>>>>>>> suggested. I've few questions about the ways to implement this in Petsc:
>>>>>>>>>>>>> A naive approach that I can think of would be to create a
>>>>>>>>>>>>> vector with its components as reciprocal viscosities of the cell centers
>>>>>>>>>>>>> corresponding to the pressure variables, and then create a diagonal matrix
>>>>>>>>>>>>> from this vector. However I'm not sure about:
>>>>>>>>>>>>> How can I make this matrix, (say S_p) compatible to the Petsc
>>>>>>>>>>>>> distribution of the different rows of the main system matrix over different
>>>>>>>>>>>>> processors ? The main matrix was created using the DMDA structure with 4
>>>>>>>>>>>>> dof as explained before.
>>>>>>>>>>>>> The main matrix correspond to the DMDA with 4 dofs but for the
>>>>>>>>>>>>> S_p matrix would correspond to only pressure space. Should the distribution
>>>>>>>>>>>>> of the rows of S_p among different processor not correspond to the
>>>>>>>>>>>>> distribution of the rhs vector, say h' if it is solving for p with Sp = h'
>>>>>>>>>>>>> where S = A11 inv(A00) A01 ?
>>>>>>>>>>>> PETSc distributed vertices, not dofs, so it never breaks
>>>>>>>>>>>> blocks. The P distribution is the same as the entire problem divided by 4.
>>>>>>>>>>> Thanks Matt. So if I create a new DMDA with same grid size but
>>>>>>>>>>> with dof=1 instead of 4, the vertices for this new DMDA will be identically
>>>>>>>>>>> distributed as for the original DMDA ? Or should I inform PETSc by calling
>>>>>>>>>>> a particular function to make these two DMDA have identical distribution of
>>>>>>>>>>> the vertices ?
>>>>>>>>>> Yes.
>>>>>>>>>>>  Even then I think there might be a problem due to the presence
>>>>>>>>>>> of "fictitious pressure vertices". The system matrix (A) contains an
>>>>>>>>>>> identity corresponding to these fictitious pressure nodes, thus when using
>>>>>>>>>>> a -pc_fieldsplit_detect_saddle_point, will detect a A11 zero block of size
>>>>>>>>>>> that correspond to only non-fictitious P-nodes. So the preconditioner S_p
>>>>>>>>>>> for the Schur complement outer solve with Sp = h' will also need to
>>>>>>>>>>> correspond to only the non-fictitious P-nodes. This means its size does not
>>>>>>>>>>> directly correspond to the DMDA grid defined for the original problem.
>>>>>>>>>>> Could you please suggest an efficient way of assembling this S_p matrix ?
>>>>>>>>>> Don't use detect_saddle, but split it by fields
>>>>>>>>>> -pc_fieldsplit_0_fields 0,1,2 -pc_fieldsplit_1_fields 4
>>>>>>>>> How can I set this split in the code itself without giving it as a
>>>>>>>>> command line option when the system matrix is assembled from the DMDA for
>>>>>>>>> the whole system with 4 dofs. (i.e. *without* using the
>>>>>>>>> DMComposite or *without* using the nested block matrices to
>>>>>>>>> assemble different blocks separately and then combine them together).
>>>>>>>>> I need the split to get access to the fieldsplit_1_ksp in my code,
>>>>>>>>> because not using detect_saddle_point means I cannot use
>>>>>>>>> -fieldsplit_1_ksp_constant_null_space due to the presence of identity for
>>>>>>>>> the fictitious pressure nodes present in the fieldsplit_1_ block. I need to
>>>>>>>>> use PCFieldSplitGetSubKsp() so that I can set proper null-space basis.
>>>>>>>> This is currently a real problem with the DMDA. In the unstructured
>>>>>>>> case, where we always need specialized spaces, you can
>>>>>>>> use something like
>>>>>>>>     PetscObject  pressure;
>>>>>>>>     MatNullSpace nullSpacePres;
>>>>>>>>     ierr = DMGetField(dm, 1, &pressure);CHKERRQ(ierr);
>>>>>>>>     ierr = MatNullSpaceCreate(PetscObjectComm(pressure),
>>>>>>>> PETSC_TRUE, 0, NULL, &nullSpacePres);CHKERRQ(ierr);
>>>>>>>>     ierr = PetscObjectCompose(pressure, "nullspace", (PetscObject)
>>>>>>>>     ierr = MatNullSpaceDestroy(&nullSpacePres);CHKERRQ(ierr);
>>>>>>>> and then DMGetSubDM() uses this information to attach the null
>>>>>>>> space to the IS that is created using the information in the PetscSection.
>>>>>>>> If you use a PetscSection to set the data layout over the DMDA, I
>>>>>>>> think this works correctly, but this has not been tested at all and is very
>>>>>>>> new code. Eventually, I think we want all DMs to use this
>>>>>>>> mechanism, but we are still working it out.
>>>>>>> Currently I do not use PetscSection. If this makes a cleaner
>>>>>>> approach, I'd try it too but may a bit later (right now I'd like test my
>>>>>>> model with a quickfix even if it means a little dirty code!)
>>>>>>>> Bottom line: For custom null spaces using the default layout in
>>>>>>>> DMDA, you need to take apart the PCFIELDSPLIT after it has been setup,
>>>>>>>> which is somewhat subtle. You need to call KSPSetUp() and then
>>>>>>>> reach in and get the PC, and the subKSPs. I don't like this at all, but we
>>>>>>>> have not reorganized that code (which could be very simple and
>>>>>>>> inflexible since its very structured).
>>>>>>> So I tried to get this approach working but I could not succeed and
>>>>>>> encountered some errors. Here is a code snippet:
>>>>>>> //mDa is the DMDA that describes the whole grid with all 4 dofs (3
>>>>>>> velocity components and 1 pressure comp.)
>>>>>>>     ierr =
>>>>>>>     ierr = KSPSetNullSpace(mKsp,mNullSpaceSystem);CHKERRQ(ierr);
>>>>>>> //I've the mNullSpaceSystem based on mDa, that contains a null space basis
>>>>>>> for the complete system.
>>>>>>>     ierr =
>>>>>>> //This I expect would register these options I give:-pc_type fieldsplit
>>>>>>> -pc_fieldsplit_type schur -pc_fieldsplit_0_fields 0,1,2
>>>>>>> //-pc_fieldsplit_1_fields 3
>>>>>>>     ierr = KSPGetPC(mKsp,&mPcOuter);     //Now get the PC that was
>>>>>>> obtained from the options (fieldsplit)
>>>>>>>     ierr =
>>>>>>> PCFieldSplitSchurPrecondition(mPcOuter,PC_FIELDSPLIT_SCHUR_PRE_USER,mPcForSc);CHKERRQ(ierr);
>>>>>>> //I have created the matrix mPcForSc using a DMDA with identical //size to
>>>>>>> mDa but with dof=1 corresponding to the pressure nodes (say mDaPressure).
>>>>>>>   ierr = PCSetUp(mPcOuter);CHKERRQ(ierr);
>>>>>>>     KSP *kspSchur;
>>>>>>>     PetscInt kspSchurPos = 1;
>>>>>>>     ierr =
>>>>>>> PCFieldSplitGetSubKSP(mPcOuter,&kspSchurPos,&kspSchur);CHKERRQ(ierr);
>>>>>>>     ierr =
>>>>>>> KSPSetNullSpace(kspSchur[1],mNullSpacePressure);CHKERRQ(ierr);
>>>>>>> //The null space is the one that correspond to only pressure nodes, created
>>>>>>> using the mDaPressure.
>>>>>>>     ierr = PetscFree(kspSchur);CHKERRQ(ierr);
>>>>>> Sorry, you need to return to the old DMDA behavior, so you want
>>>>> Thanks, with this it seems I can attach the null space properly, but I
>>>>> have a question regarding whether the Schur complement ksp solver is
>>>>> actually using the preconditioner matrix I provide.
>>>>> When using -ksp_view, the outer level pc object of type fieldsplit
>>>>> does report that: "Preconditioner for the Schur complement formed from user
>>>>> provided matrix", but in the KSP solver for Schur complement S, the pc
>>>>> object (fieldsplit_1_) is of type ilu and doesn't say that it is using the
>>>>> matrix I provide. Am I missing something here ?
>>>>> Below are the relevant commented code snippet and the output of the
>>>>> -ksp_view
>>>>> (The options I used: -pc_type fieldsplit -pc_fieldsplit_type schur
>>>>> -pc_fieldsplit_1_fields 3 -ksp_converged_reason -ksp_view )
>>>> If ILU does not error, it means it is using your matrix, because the
>>>> Schur complement matrix cannot be factored, and FS says it is using your
>>>> matrix.
>>>>    Matt
>>>>> Code snippet:
>>>>> ierr = KSPSetNullSpace(mKsp,mNullSpaceSystem);CHKERRQ(ierr);   //The
>>>>> nullspace for the whole system
>>>>>     ierr = KSPSetUp(mKsp);CHKERRQ(ierr);                   //Set up
>>>>> mKsp with the options provided with fieldsplit and the fields associated
>>>>> with the two splits.
>>>>>     ierr = KSPGetPC(mKsp,&mPcOuter);CHKERRQ(ierr);
>>>>> //Get the fieldsplit pc set up from the options
>>>>>     ierr =
>>>>> //Use mPcForSc as the preconditioner for Schur Complement
>>>>>     KSP *kspSchur;
>>>>>     ierr =
>>>>>     ierr =
>>>>> //Attach the null-space for the Schur complement ksp solver.
>>>>> the output of the -ksp_view
>>>>>   type: gmres
>>>>>   type: fieldsplit
>>>>> FULL
>>>>> matrix
>>>>>     Split info:
>>>>>         type: gmres
>>>>>         type: ilu
>>>>>           0 levels of fill
>>>>>                 type: seqaij
>>>>>                 rows=2187, cols=2187
>>>>>                 total: nonzeros=140625, allocated nonzeros=140625
>>>>> =0
>>>>>                   using I-node routines: found 729 nodes, limit used
>>>>> is 5
>>>>>           type: seqaij
>>>>>             using I-node routines: found 729 nodes, limit used is 5
>>>>>         type: gmres
>>>>>         type: ilu
>>>>>           0 levels of fill
>>>>>                 type: seqaij
>>>>>                 rows=729, cols=729
>>>>>                 total: nonzeros=15625, allocated nonzeros=15625
>>>>> =0
>>>>>           rows=729, cols=729
>>>>>             A11
>>>>>                 type: seqaij
>>>>>                 rows=729, cols=729
>>>>> =0
>>>>>             A10
>>>>>                 type: seqaij
>>>>>                 rows=729, cols=2187
>>>>>                 total: nonzeros=46875, allocated nonzeros=46875
>>>>> =0
>>>>>             KSP of A00
>>>>> MPI processes
>>>>>                 type: gmres
>>>>> divergence=10000
>>>>> MPI processes
>>>>>                 type: ilu
>>>>>                   0 levels of fill
>>>>> processes
>>>>>                         type: seqaij
>>>>> nonzeros=140625
>>>>> limit used is 5
>>>>>                   type: seqaij
>>>>> calls =0
>>>>> is 5
>>>>>             A01
>>>>>                 type: seqaij
>>>>>                 rows=2187, cols=729
>>>>> =0
>>>>> is 5
>>>>>           type: seqaij
>>>>>           rows=729, cols=729
>>>>>     type: seqaij
>>>>>     rows=2916, cols=2916, bs=4
>>>>>     total: nonzeros=250000, allocated nonzeros=250000
>>>>>> or
>>>>>>   PCFieldSplitSetDMSplits(pc, PETSC_FALSE)
>>>>>>   Thanks,
>>>>>>      Matt
>>>>>>> The errors I get when running with options: -pc_type fieldsplit
>>>>>>> [0]PETSC ERROR: --------------------- Error Message
>>>>>>> [0]PETSC ERROR: No support for this operation for this object type!
>>>>>>> [0]PETSC ERROR: Support only implemented for 2d!
>>>>>>> [0]PETSC ERROR:
>>>>>>> [0]PETSC ERROR: Petsc Release Version 3.4.2, Jul, 02, 2013
>>>>>>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>>>>>>> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>>>>>> [0]PETSC ERROR: See docs/index.html for manual pages.
>>>>>>> [0]PETSC ERROR:
>>>>>>> [0]PETSC ERROR: src/AdLemMain on a arch-linux2-cxx-debug named
>>>>>>> edwards by bkhanal Tue Aug  6 17:35:30 2013
>>>>>>> [0]PETSC ERROR: Libraries linked from
>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/arch-linux2-cxx-debug/lib
>>>>>>> [0]PETSC ERROR: Configure run at Fri Jul 19 14:25:01 2013
>>>>>>> [0]PETSC ERROR: Configure options --with-cc=gcc --with-fc=g77
>>>>>>> --with-cxx=g++ --download-f-blas-lapack=1 --download-mpich=1
>>>>>>> -with-clanguage=cxx --download-hypre=1
>>>>>>> [0]PETSC ERROR:
>>>>>>> [0]PETSC ERROR: DMCreateSubDM_DA() line 188 in
>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/dm/impls/da/dacreate.c
>>>>>>> [0]PETSC ERROR: DMCreateSubDM() line 1267 in
>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/dm/interface/dm.c
>>>>>>> [0]PETSC ERROR: PCFieldSplitSetDefaults() line 337 in
>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/ksp/pc/impls/fieldsplit/fieldsplit.c
>>>>>>> [0]PETSC ERROR: PCSetUp_FieldSplit() line 458 in
>>>>>>> [0]PETSC ERROR: PCSetUp() line 890 in
>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/ksp/pc/interface/precon.c
>>>>>>> [0]PETSC ERROR: KSPSetUp() line 278 in
>>>>>>> /home/bkhanal/Documents/softwares/petsc-3.4.2/src/ksp/ksp/interface/itfunc.c
>>>>>>> [0]PETSC ERROR: solveModel() line 181 in
>>>>>>> "unknowndirectory/"/user/bkhanal/home/works/AdLemModel/src/PetscAdLemTaras3D.cxx
>>>>>>> WARNING! There are options you set that were not used!
>>>>>>> WARNING! could be spelling mistake, etc!
>>>>>>> Option left: name:-pc_fieldsplit_1_fields value: 3
>>>>>>>>    Matt
>>>>>>>>>>    Matt
>>>>>>>>>>>>    Matt
>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>> their experiments lead.
>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130823/45543441/attachment-0001.html>
