[petsc-users] Performance of PETSc TS solver
Fri Aug 16 18:38:15 CDT 2013
  What percentage of the matrix entries are non-zero? If it more than, say 20 -30 percent nonzero then you should just use a dense matrix format.  But then I see you are using a DMDA which implies it comes from some kind of mesh? Is there coupling more than nearest neighbor in the matrix. Are there 4 by 4 blocks in the matrix? You could use BAIJ matrices with a block size of 4.
   Barry
On Aug 16, 2013, at 5:14 PM, "Jin, Shuangshuang" <Shuangshuang.Jin at pnnl.gov> wrote:
> Hello, Barry and Shri, thanks for your helps.
> To answer your question, n is 288. Usually there're greater than 1/8 nonzeros in the matrix, so it's pretty dense.
> We didn't preallocate the J[4*n][4*n] matrix, it was created in each IJacobian() call. I would like to create it in the main function, and pass it to the IJacobian() function to reuse it for each time step. I guess in that way it can save much time and memory usage?
> I have this piece of code in the main function:
>  ierr = MatCreate(PETSC_COMM_WORLD, &J); CHKERRQ(ierr); // J: Jacobian matrix
>  ierr = MatSetSizes(J, PETSC_DECIDE, PETSC_DECIDE, 4*n, 4*n); CHKERRQ(ierr);
>  ierr = MatSetFromOptions(J); CHKERRQ(ierr);
>  ierr = MatSetUp(J); CHKERRQ(ierr);
>  ierr = TSSetIJacobian(ts, J, J, (TSIJacobian) IJacobian, &user); CHKERRQ(ierr);
> Shall I add the constants values for the J matrix here somewhere to use what you mentioned " MatStoreValues() and MatRetrieveValues()"?
> Sorry I cannot post the Jacobian matrix equations here for nondisclosure policy. But I can paste the framework of our IJacobian function with the equations skipped for trouble shooting:
> PetscErrorCode Simulation::IJacobian(TS ts, PetscReal t, Vec X, Vec Xdot, PetscReal a, Mat *A, Mat *B, MatStructure *flag, Userctx *ctx)
>  PetscLogStage stage = ctx->stage;
>  PetscLogStagePush(stage);
>  PetscErrorCode ierr;
>  PetscInt n = ctx->n;
>  PetscScalar *x;
>  PetscScalar J[4*n][4*n];
>  PetscInt rowcol[4*n];
>  PetscScalar val[n];
>  PetscInt i, j;
>  DM da;
>  PetscInt xstart, xlen;
>  int me;
>  double t0, t1;
>  PetscFunctionBeginUser;
>  ierr = TSGetDM(ts, &da); CHKERRQ(ierr);
>  // Get pointers to vector data
>  MPI_Comm_rank(PETSC_COMM_WORLD, &me);
>  scatterMyVec(X, &x); CHKERRQ(ierr);
>  // Get local grid boundaries
>  ierr = DMDAGetCorners(da, &xstart, NULL, NULL, &xlen, NULL, NULL); CHKERRQ(ierr);
>  // This proves to be the most time-consuming block in the computation:
>  // Assign values to J matrix for the first 2*n rows (constant values)
>  ... (skipped)
>  // Assign values to J matrix for the following 2*n rows (depends on X values)
>  for (i = 0; i < n; i++) {
>    for (j = 0; j < n; j++) {
>       ...(skipped)
>  for (i = 0; i < 4*n; i++) {
>    rowcol[i] = i;
>  // Compute function over the locally owned part of the grid
>  for (i = xstart; i < xstart+xlen; i++) {
>    ierr = MatSetValues(*B, 1, &i, 4*n, rowcol, &J[i][0], INSERT_VALUES); CHKERRQ(ierr);
>  ierr = DMDAVecRestoreArray(da, X, &x); CHKERRQ(ierr);
>  ierr = MatAssemblyBegin(*A, MAT_FINAL_ASSEMBLY); CHKERRQ(ierr);
>  ierr = MatAssemblyEnd(*A, MAT_FINAL_ASSEMBLY); CHKERRQ(ierr);
>  if (*A != *B) {
>    ierr = MatAssemblyBegin(*B, MAT_FINAL_ASSEMBLY); CHKERRQ(ierr);
>    ierr = MatAssemblyEnd(*B, MAT_FINAL_ASSEMBLY); CHKERRQ(ierr);
>  *flag = SAME_NONZERO_PATTERN;
>  PetscLogStagePop();
>  PetscFunctionReturn(0);
> Hope this code can show you a better picture of our problem here.
> Thanks,
> Shuangshuang
> -----Original Message-----
> From: Barry Smith [mailto:bsmith at mcs.anl.gov]
> Sent: Friday, August 16, 2013 2:08 PM
> To: Jin, Shuangshuang
> Cc: Jed Brown; petsc-users at mcs.anl.gov
> Subject: Re: [petsc-users] Performance of PETSc TS solver
> On Aug 16, 2013, at 4:01 PM, "Jin, Shuangshuang" <Shuangshuang.Jin at pnnl.gov> wrote:
>> Hello, Jed, in my IJacobian subroutine, I defined a PetscScalar J[4*n][4*n], and filled in the values for this J matrix by MatSetValues().
>  What is n?
>   It should not be taking anywhere this much time. How sparse is the matrix? Do you preallocate the nonzero structure? Do you reuse the same matrix for each time step?
>> 245 seconds out of the total 351 seconds in the DAE TS solving part are due to this J matrix computation.
>> For that J matrix, half of them are constants values which doesn't change in each iteration. However, since my J is created inside each IJacobian() call, I couldn't reuse it. If that part of work belongs to redundant computation, I would like to know if there's a way to set up the Jacobian matrix outside of the IJacobian() subroutine, so that I can keep the constant part of values in J for all the iterations but only updates the changing values which depends on X?
> MatStoreValues() and MatRetrieveValues() but you can only call this after you have assembled the matrix with the correct nonzero structure. So you need to put the constants values in, put zeros in all the locations with non constant values (that are not permeant zeros), call MatAssemblyBegin/End() then call MatStoreValues() then for each computation of the Jacobian you first call MatRetrieveValues() and then put in the non constant values. Then call MatAssemblyBegin/End()
>   Barry
>> Thanks,
>> Shuangshuang
>> From: Jed Brown [mailto:five9a2 at gmail.com] On Behalf Of Jed Brown
>> Sent: Thursday, August 15, 2013 7:27 PM
>> Cc: petsc-users at mcs.anl.gov
>> Subject: RE: [petsc-users] Performance of PETSc TS solver
>> "Jin, Shuangshuang" <Shuangshuang.Jin at pnnl.gov> writes:
>>> Hi, Jed,
>>> I followed your suggestion and profiled the IJacobian stage, please see the related profile below:
>> Cool, all of these are pretty inexpensive, so your time is probably in compu
