[petsc-users] Performance of PETSc TS solver
Jin, Shuangshuang Shuangshuang.Jin at pnnl.gov
Fri Aug 16 17:14:09 CDT 2013
Hello, Barry and Shri, thanks for your helps.
To answer your question, n is 288. Usually there're greater than 1/8 nonzeros in the matrix, so it's pretty dense.
We didn't preallocate the J[4*n][4*n] matrix, it was created in each IJacobian() call. I would like to create it in the main function, and pass it to the IJacobian() function to reuse it for each time step. I guess in that way it can save much time and memory usage?
I have this piece of code in the main function:
  ierr = MatCreate(PETSC_COMM_WORLD, &J); CHKERRQ(ierr); // J: Jacobian matrix
  ierr = MatSetSizes(J, PETSC_DECIDE, PETSC_DECIDE, 4*n, 4*n); CHKERRQ(ierr);
  ierr = MatSetFromOptions(J); CHKERRQ(ierr);
  ierr = MatSetUp(J); CHKERRQ(ierr);
  ierr = TSSetIJacobian(ts, J, J, (TSIJacobian) IJacobian, &user); CHKERRQ(ierr);
Shall I add the constants values for the J matrix here somewhere to use what you mentioned " MatStoreValues() and MatRetrieveValues()"?
Sorry I cannot post the Jacobian matrix equations here for nondisclosure policy. But I can paste the framework of our IJacobian function with the equations skipped for trouble shooting:
PetscErrorCode Simulation::IJacobian(TS ts, PetscReal t, Vec X, Vec Xdot, PetscReal a, Mat *A, Mat *B, MatStructure *flag, Userctx *ctx)
  PetscLogStage stage = ctx->stage;
  PetscLogStagePush(stage);
  PetscErrorCode ierr;
  PetscInt n = ctx->n;
  PetscScalar *x;
  PetscScalar J[4*n][4*n];
  PetscInt rowcol[4*n];
  PetscScalar val[n];
  PetscInt i, j;
  DM da;
  PetscInt xstart, xlen;
  int me;
  double t0, t1;
  PetscFunctionBeginUser;
  ierr = TSGetDM(ts, &da); CHKERRQ(ierr);
  // Get pointers to vector data
  MPI_Comm_rank(PETSC_COMM_WORLD, &me);
  scatterMyVec(X, &x); CHKERRQ(ierr);
  // Get local grid boundaries
  ierr = DMDAGetCorners(da, &xstart, NULL, NULL, &xlen, NULL, NULL); CHKERRQ(ierr);
  // This proves to be the most time-consuming block in the computation:
  // Assign values to J matrix for the first 2*n rows (constant values)
  ... (skipped)
  // Assign values to J matrix for the following 2*n rows (depends on X values)
  for (i = 0; i < n; i++) {
    for (j = 0; j < n; j++) {
       ...(skipped)
  for (i = 0; i < 4*n; i++) {
    rowcol[i] = i;
  // Compute function over the locally owned part of the grid
  for (i = xstart; i < xstart+xlen; i++) {
    ierr = MatSetValues(*B, 1, &i, 4*n, rowcol, &J[i][0], INSERT_VALUES); CHKERRQ(ierr);
  ierr = DMDAVecRestoreArray(da, X, &x); CHKERRQ(ierr);
  ierr = MatAssemblyBegin(*A, MAT_FINAL_ASSEMBLY); CHKERRQ(ierr);
  ierr = MatAssemblyEnd(*A, MAT_FINAL_ASSEMBLY); CHKERRQ(ierr);
  if (*A != *B) {
    ierr = MatAssemblyBegin(*B, MAT_FINAL_ASSEMBLY); CHKERRQ(ierr);
    ierr = MatAssemblyEnd(*B, MAT_FINAL_ASSEMBLY); CHKERRQ(ierr);
  *flag = SAME_NONZERO_PATTERN;
  PetscLogStagePop();
  PetscFunctionReturn(0);
Hope this code can show you a better picture of our problem here.
Shuangshuang
-----Original Message-----
Sent: Friday, August 16, 2013 2:08 PM
To: Jin, Shuangshuang
Cc: Jed Brown; petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] Performance of PETSc TS solver
On Aug 16, 2013, at 4:01 PM, "Jin, Shuangshuang" <Shuangshuang.Jin at pnnl.gov> wrote:
> Hello, Jed, in my IJacobian subroutine, I defined a PetscScalar J[4*n][4*n], and filled in the values for this J matrix by MatSetValues().
  What is n?
   It should not be taking anywhere this much time. How sparse is the matrix? Do you preallocate the nonzero structure? Do you reuse the same matrix for each time step?
> 245 seconds out of the total 351 seconds in the DAE TS solving part are due to this J matrix computation.
> For that J matrix, half of them are constants values which doesn't change in each iteration. However, since my J is created inside each IJacobian() call, I couldn't reuse it. If that part of work belongs to redundant computation, I would like to know if there's a way to set up the Jacobian matrix outside of the IJacobian() subroutine, so that I can keep the constant part of values in J for all the iterations but only updates the changing values which depends on X?
MatStoreValues() and MatRetrieveValues() but you can only call this after you have assembled the matrix with the correct nonzero structure. So you need to put the constants values in, put zeros in all the locations with non constant values (that are not permeant zeros), call MatAssemblyBegin/End() then call MatStoreValues() then for each computation of the Jacobian you first call MatRetrieveValues() and then put in the non constant values. Then call MatAssemblyBegin/End()
   Barry
> Thanks,
> Shuangshuang
> From: Jed Brown [mailto:five9a2 at gmail.com] On Behalf Of Jed Brown
> Sent: Thursday, August 15, 2013 7:27 PM
> Cc: petsc-users at mcs.anl.gov
> Subject: RE: [petsc-users] Performance of PETSc TS solver
> "Jin, Shuangshuang" <Shuangshuang.Jin at pnnl.gov> writes:
>> Hi, Jed,
>> I followed your suggestion and profiled the IJacobian stage, please see the related profile below:
> Cool, all of these are pretty inexpensive, so your time is probably in compu
