[petsc-users] Performance of PETSc TS solver
Fri Aug 16 19:00:23 CDT 2013
"Jin, Shuangshuang" <Shuangshuang.Jin at pnnl.gov> writes:
>   // This proves to be the most time-consuming block in the computation:
>   // Assign values to J matrix for the first 2*n rows (constant values)
>   ... (skipped)
>   // Assign values to J matrix for the following 2*n rows (depends on X values)
>   for (i = 0; i < n; i++) {
>     for (j = 0; j < n; j++) {
>        ...(skipped)
This is a dense iteration.  Are the entries really mostly nonzero?  Why
is your i loop over all rows instead of only over xstart to xstart+xlen?
>   for (i = 0; i < 4*n; i++) {
>     rowcol[i] = i;
>   // Compute function over the locally owned part of the grid
>   for (i = xstart; i < xstart+xlen; i++) {
>     ierr = MatSetValues(*B, 1, &i, 4*n, rowcol, &J[i][0], INSERT_VALUES); CHKERRQ(ierr);
This is seems to be creating a distributed dense matrix from a dense
matrix J of the global dimension.  Is that correct?  You need to
_distribute_ the work of computing the matrix entries if you want to see
a speedup.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130816/6409da06/attachment.pgp>
