[petsc-users] question on PETSc option '-snes_mf_operator'
Thu Sep 27 13:09:14 CDT 2012
On Thu, Sep 27, 2012 at 2:01 PM, Zou (Non-US), Ling <ling.zou at inl.gov>wrote:
> Dear all,
> I have a question on the PETSc option '-snes_mf_operator'.
> I am reading the    <PETSc Users Manual Revision 3.3>. On page 100, 2nd
> paragraph, it says:
> "However, it allows us to check the analytic Jacobian we construct in
> FormJacobian() by passing the -snes_mf_operator flag. This causes PETSc to
> approximate the Jacobian using finite differencing of the function
> evaluation (discussed in section 5.6), and the analytic Jacobian becomes
> merely the preconditioner."
> I wonder, if the '-snes_mf_operator' option is used, the Jacobian will
> always be calculated from the finite difference method while
> ignore whatever has been provided from user.
Yes, yhe action will be FD, but it will take the user provided operator to
form a preconditioner from.
   Matt
> One more question, if I pass '-snes' to PETSc, since it is direct Newton's
> method, I assume it will explicitly construct a Jacobian. Does this
> Jacobian come from user provided Jacobian or from the finite difference
> Jacobian?
> Thanks,
> Ling
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120927/37e89116/attachment.html>
