[petsc-users] relocation truncated to fit: R_X86_64_PC32 error
Jose E. Roman jroman at dsic.upv.es
Mon Sep 17 06:09:46 CDT 2012
El 17/09/2012, a las 13:03, Miguel Méndez escribió:
> Hi everybody,
> I'm getting the infamous "relocation truncated to fit: R_X86_64_PC32" error when compiling a fortran program. I've tried many things, the last one of them being to recompile Petsc and Slepc libraries. This has solved all of the compile errors related to this relocation except for one:
> /usr/local/software/slepc-3.0.0-p7-fpic/complex/build/lib/libslepc.a(cross.o): In function `ShellMatGetDiagonal_CROSS':
> cross.c:(.text+0x3ca): relocation truncated to fit: R_X86_64_PC32 against symbol `MPIU_COMPLEX' defined in COMMON section in /usr/local/software/petsc-3.0.0-p12-fpic/complex/build/lib/libpetsc.a(init.o)
> I don't even think I know where the error is, in Petsc or in Slepc? I've been trough Intel forums and done as they recommend: recompile the libraries with "--mcmodel=medium" and "shared-intel". I've tried too combinations with "-fpic", but I always end having the same error.
> I've searched the logs for messages about "libpetsc.a" building, but there's nothing about it. Who and when builds this exact library? Why it seems that compile options I set are not applying in the building of this file?
> Thanks,
> Miguel
slepc-3.0.0 is more than 3 years old. I would suggest you to upgrade to the latest version (3.3) and see if the problem persists.
Jose
