[petsc-users] configure error with netcdf
fdkong fd.kong at siat.ac.cn
Mon Sep 10 23:00:41 CDT 2012
>On Sep 9, 2012, at 12:02 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>> On Sun, 9 Sep 2012, Barry Smith wrote:
>> >On Sep 9, 2012, at 7:55 AM, Matthew Knepley <knepley at gmail.com> wrote:
>>> >On Sun, Sep 9, 2012 at 12:31 AM, Satish Balay <balay at mcs.anl.gov> wrote:
>>>>> ncgentab.c:(.text+0x1e2): undefined reference to `yyunput'
>>  > Satish,
>> >  Weird undefined symbols like yyunput are always a result of flex issues.
>>   > Could you please make the same changes to netcdf.py that you made to the other package that used flex (which resolved the problem there).
> >In this case netcdf has its own configure - and does its own search for flex etc.
> >checking for flex... flex
> >checking lex output file root... lex.yy
> >checking lex library... -lfl
>> So the tools appear to be found. And I don't see them being used
> >further down [in configure.log].
  > Agreed. It seems some of the processing is lost; perhaps netcdf build tools do not properly display everything >they are doing
  > Note the use of .l files and the symbol yyunput which is very specific to flex.
> > So its not clear if 'missing flex'
> >is the cause of this error.
 >  Yes, it may not be a "missing" flex that is causing the problem but the problem is related flex, bison and all that >crap. Unfortunately if we cannot reproduce on a machine we have access to there is no way we can debug it.
I am not sure if  the error is the result of the "missing" flex, but when I used netcdf-4.1.3, instead of netcdf-4.1.1, the petsc worked well. Thus, Maybe there is a bug in the netcdf itself.
 >   Barry
> >And after my patch [with netcdf upgrade] - I have a successful build
> >of netcdf on rhel5 - even without flex/bison.
> >However flex is needed for ptscotch anyway [so one would get an error
> >from ptscotch if flex is missing]
> >Satish
Fande Kong
ShenZhen Institutes of Advanced Technology
Chinese Academy of Sciences
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120911/8217215b/attachment.html>
