[petsc-users] When pull the petsc-dev for update:Connection timed out
Sun Nov 25 18:03:01 CST 2012
On Mon, Nov 26, 2012 at 12:59 AM, Zhenglun (Alan) Wei <
zhenglun.wei at gmail.com> wrote:
> Dear Sean,
>      Thank you so much for your help. Here I have another question.
>      After updating the PETSc, I tried to 'make ex45' in
> /src/ksp/ksp/example/tutorial/**. It says that 'petscksp.h' can not be
> found; therefore, I commented this library in ex45.c to see what will
> happen. It, then, shows that the 'petscdmmg.h' can not be found. Any idea
> on this? :)
Since DMMG is gone, baby gone, this means your environment (PETSC_DIR) is
still pointing to an old version of PETSc.
> thanks,
> Alan
>  On Sun, Nov 25, 2012 at 4:16 PM, Zhenglun (Alan) Wei
>> <zhenglun.wei at gmail.com> wrote:
>>> Thank you Sean,
>>>     I changed the
>>> $ cd config/buildsystem
>>> $ hg showconfig paths.default
>>>     to
>>> https://bitbucket.org/petsc/**buildsystem<https://bitbucket.org/petsc/buildsystem>
>>>    It gives me 2 extra changes.
>> Great! Glad to know it's working.
>>       Although, it always giev me the warning of 'certificate not
>>> verified',
>>> it updated lots of files. Should I just ignore this warning?
>> You could ignore those warnings, yes, but it would probably be better
>> to upgrade your mercurial and see if the host fingerprint option
>> works. Or you could try to use the ssh protocol, assuming your
>> university proxy allows ssh out.
>>     BTW, the reason I used 'https' instead of 'http' is that 'https' is
>>> shown
>>> in the website you gave to me. :) It may needs to be changed.
>> Well, as I said previously, bitbucket redirects all http traffic to
>> https, so I don't think changing it to just http would really work.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121126/a39f610e/attachment.html>
