[petsc-users] When pull the petsc-dev for update:Connection timed out
Zhenglun (Alan) Wei zhenglun.wei at gmail.com
Sun Nov 25 17:59:49 CST 2012
Dear Sean,
      Thank you so much for your help. Here I have another question.
      After updating the PETSc, I tried to 'make ex45' in
/src/ksp/ksp/example/tutorial/. It says that 'petscksp.h' can not be
found; therefore, I commented this library in ex45.c to see what will
happen. It, then, shows that the 'petscdmmg.h' can not be found. Any
idea on this? :)
thanks,
Alan
> On Sun, Nov 25, 2012 at 4:16 PM, Zhenglun (Alan) Wei
> <zhenglun.wei at gmail.com> wrote:
>> Thank you Sean,
>>     I changed the
>> $ cd config/buildsystem
>> $ hg showconfig paths.default
>>     to
>> https://bitbucket.org/petsc/buildsystem
>>    It gives me 2 extra changes.
> Great! Glad to know it's working.
>>      Although, it always giev me the warning of 'certificate not verified',
>> it updated lots of files. Should I just ignore this warning?
> You could ignore those warnings, yes, but it would probably be better
> to upgrade your mercurial and see if the host fingerprint option
> works. Or you could try to use the ssh protocol, assuming your
> university proxy allows ssh out.
>>    BTW, the reason I used 'https' instead of 'http' is that 'https' is shown
>> in the website you gave to me. :) It may needs to be changed.
> Well, as I said previously, bitbucket redirects all http traffic to
> https, so I don't think changing it to just http would really work.
